Nirwana 1Wire & FHEM
Begonnen von Deckoffizier, 02 März 2018, 13:38:48
Deckoffizier
heute Morgen ohne ersichtlichen Grund kein 1 Wire und FHEM zu bedienen.
Andere Dienste auf dem Server waren weiter am laufen.
Letztendlich den Rechner neu gestartet.
Was ist nun Ursache oder Wirkung von beiden oder noch andere Ursache ?
hier mal Auszüge aus dem Log
2018.03.02 08:18:58 1: /dev/ttyUSB0 disconnected, waiting to reappear (OWio1)
2018.03.02 08:18:58 1: OWX_SER::Query OWio1:  0 of 1 bytes in last attempt and state opened, this is an unrecoverable error
2018.03.02 08:18:58 1: OWX_Complex called while interface OWio1 disconnected
2018.03.02 08:19:06 1: OWX_Complex called while interface OWio1 disconnected
2018.03.02 08:19:07 1: OWX_Complex called while interface OWio1 disconnected
usw.
nach Neustart noch einige Ungereimtheiten.....
2018.03.02 10:08:10 1: OWX_Complex called while interface OWio1 disconnected
Can't locate object method "Reopen" via package "OWX_SER" at ./FHEM/00_OWX.pm line 1072.
2018.03.02 10:10:43 1: Including fhem.cfg
2018.03.02 10:10:44 1: PERL WARNING: Subroutine GetState_Initialize redefined at ./FHEM/99_getstate.pm line 42, <$fh> line 12.
2018.03.02 10:10:44 1: PERL WARNING: Subroutine CommandGetState redefined at ./FHEM/99_getstate.pm line 52, <$fh> line 12.
2018.03.02 10:10:44 1: PERL WARNING: Subroutine stringToNumber redefined at ./FHEM/99_getstate.pm line 100, <$fh> line 12.
2018.03.02 10:10:44 1: PERL WARNING: Subroutine stripNumber redefined at ./FHEM/99_getstate.pm line 111, <$fh> line 12.
2018.03.02 10:10:44 1: PERL WARNING: Subroutine isNumber redefined at ./FHEM/99_getstate.pm line 124, <$fh> line 12.
2018.03.02 10:10:44 1: PERL WARNING: Subroutine isInteger redefined at ./FHEM/99_getstate.pm line 130, <$fh> line 12.
2018.03.02 10:10:44 1: PERL WARNING: Subroutine isFloat redefined at ./FHEM/99_getstate.pm line 136, <$fh> line 12.
2018.03.02 10:11:39 1: PERL WARNING: given is experimental at ./FHEM/98_PID20.pm line 305, <$fh> line 238.
2018.03.02 10:11:39 1: PERL WARNING: when is experimental at ./FHEM/98_PID20.pm line 307, <$fh> line 238.
2018.03.02 10:11:39 1: PERL WARNING: given is experimental at ./FHEM/98_PID20.pm line 339, <$fh> line 238.
2018.03.02 10:11:39 1: PERL WARNING: when is experimental at ./FHEM/98_PID20.pm line 341, <$fh> line 238.
2018.03.02 10:11:39 1: PERL WARNING: when is experimental at ./FHEM/98_PID20.pm line 345, <$fh> line 238.
2018.03.02 10:11:39 1: PERL WARNING: when is experimental at ./FHEM/98_PID20.pm line 356, <$fh> line 238.
2018.03.02 10:11:39 1: PERL WARNING: when is experimental at ./FHEM/98_PID20.pm line 363, <$fh> line 238.
2018.03.02 10:11:39 1: PERL WARNING: when is experimental at ./FHEM/98_PID20.pm line 370, <$fh> line 238.
2018.03.02 10:11:39 1: PERL WARNING: when is experimental at ./FHEM/98_PID20.pm line 385, <$fh> line 238.
2018.03.02 10:11:39 2: eventTypes: loaded 3432 events from log/eventTypes.txt
2018.03.02 10:11:48 1: OWX_SER::Define warning: version 7.05 not identical to OWX version 7.08
2018.03.02 10:11:52 1: OWID:     Device ROM_ID defined.
2018.03.02 10:11:52 1: Including ./log/fhem.save
2018.03.02 10:11:56 2: FB_CALLMONITOR (Fritz_Box_Monitor) - read 68 contacts from remote phonebook "Telefonbuch"
2018.03.02 10:11:56 2: FB_CALLMONITOR (Fritz_Box_Monitor) - found FritzBox phonebook /opt/fhem/FritzExport.xml
2018.03.02 10:11:56 2: FB_CALLMONITOR (Fritz_Box_Monitor) - read 67 contacts from /opt/fhem/FritzExport.xml
2018.03.02 10:11:56 0: Featurelevel: 5.8
2018.03.02 10:11:56 0: Server started with 215 defined entities (fhem.pl:16228/2018-02-20 perl:5.018002 os:linux user:fhem pid:2169)
2018.03.02 10:12:26 1: PERL WARNING: Use of uninitialized value $value in numeric eq (==) at ./FHEM/21_OWID.pm line 406.
2018.03.02 10:12:26 1: PERL WARNING: Use of uninitialized value $value in concatenation (.) or string at ./FHEM/21_OWID.pm line 412.
2018.03.02 10:12:48 1: OWX_Init called for bus OWio1 with interface state opened, now going for detect
2018.03.02 10:31:45 1: PERL WARNING: Use of uninitialized value $channel in concatenation (.) or string at ./FHEM/14_CUL_TCM97001.pm line 903.
2018.03.02 12:33:59 1: PERL WARNING: Use of uninitialized value $\ in concatenation (.) or string at ./FHEM/99_myUtils_Astro.pm line 51.
Läuft jetzt zwar wieder, würde aber gerne trotzdem solchen Ausfällen   vorbeugen, hat jemand von Euch eine Idee ?
Danke und mit freundlichen Gruß
Hans-Jürgen
FHEM 5.8 auf "yakkaroo Emu A1FL.1" mit CUL 868MHz, SIGNALduino,2 1Wire USB Busmaster, diverse 1 Wire Sensoren,Landroid,Aeotec USB Dongle Z-Wave Plus
Prof. Dr. Peter Henning
Nö. Keine Änderung rund um OWX in den letzten Tagen. Da war ich unschuldigerweise auf dem Golfplatz unterwegs...
pah
