NODON SmartPlug ASP-2-1-11 kein Verbrauch
Begonnen von BerndDA, 06 März 2018, 13:01:27
BerndDA
habe den genannten Smartplug angelernt.
EEP D2-01-0B
wird in Attributes angezeigt.
Leider finden sich keine Readings zum aktuellen Verbrauch
Grüße!
Bernd
BerndDA
Ausgabe list <device>:
   CFGFN
   DEF        05017E43
   IODev      TCM_ESP3_0
   LASTInputDev TCM_ESP3_0
   MSGCNT     4
   NAME       EnO_05017E43
   NR         270
   NTFY_ORDER 50-EnO_05017E43
   STATE      off
   TCM_ESP3_0_DestinationID FFFFFFFF
   TCM_ESP3_0_MSGCNT 4
   TCM_ESP3_0_PacketType 1
   TCM_ESP3_0_RSSI -74
   TCM_ESP3_0_ReceivingQuality excellent
   TCM_ESP3_0_RepeatingCounter 0
   TCM_ESP3_0_SubTelNum 6
   TCM_ESP3_0_TIME 2018-03-06 13:07:26
   TYPE       EnOcean
     2018-03-06 13:07:26   channel0        off
     2018-03-06 13:07:26   dim             0
     2018-03-06 13:07:26   dim0            0
     2018-03-06 13:07:26   error0          not_supported
     2018-03-06 13:07:26   localControl0   enabled
     2018-03-06 13:07:26   overCurrentOff0 ready
     2018-03-06 13:07:26   powerFailure0   disabled
     2018-03-06 13:07:26   powerFailureDetection0 not_detected
     2018-03-06 13:07:26   state           off
     2018-03-06 12:52:32   teach           UTE teach-in accepted EEP D2-01-0B Manufacturer: ID-RF
   helper:
   IODev      TCM_ESP3_0
   comMode    biDir
   defaultChannel 0
   devChannel 1
   eep        D2-01-0B
   manufID    046
   room       EnOcean
   subDef     FFA01D89
   subType    actuator.01
   teachMethod UTE
Auszug aus dem Log
2018.03.07 17:39:57 3: EnOcean set EnO_05017E43 on
2018.03.07 17:39:57 4: EnOcean EnO_05017E43 sent PacketType: 1 RORG: D2 DATA: 010064 SenderID: FFA01D89 STATUS: 00 ODATA: 0305017E43FF00
2018.03.07 17:39:57 5: TCM TCM_ESP3_0 sent ESP: 550009070156D2010064FFA01D89000305017E43FF0045
2018.03.07 17:39:57 5: SW: 550009070156D2010064FFA01D89000305017E43FF0045
2018.03.07 17:39:57 5: TCM TCM_ESP3_0 received ESP: 5500010002650000
2018.03.07 17:39:57 5: TCM TCM_ESP3_0 RESPONSE: OK
2018.03.07 17:39:57 5: TCM TCM_ESP3_0 received ESP: 550009070156D201
2018.03.07 17:39:57 5: TCM TCM_ESP3_0 received ESP: 550009070156D2010064FFA01D898103
2018.03.07 17:39:57 5: TCM TCM_ESP3_0 received ESP: 550009070156D2010064FFA01D89810305017E434A00E755
2018.03.07 17:39:57 4: TCM TCM_ESP3_0 own telegram from FFA01D89 blocked.
2018.03.07 17:39:57 5: TCM TCM_ESP3_0 received ESP: 550009070156D20460
2018.03.07 17:39:57 5: TCM TCM_ESP3_0 received ESP: 550009070156D20460E405017E430004FF
2018.03.07 17:39:57 5: TCM TCM_ESP3_0 received ESP: 550009070156D20460E405017E430004FFFFFFFF4A0061
2018.03.07 17:39:57 5: TCM_ESP3_0: dispatch EnOcean:1:D2:0460E4:05017E43:00:04FFFFFFFF4A00
2018.03.07 17:39:57 4: EnOcean received via TCM_ESP3_0: EnOcean:1:D2:0460E4:05017E43:00:04FFFFFFFF4A00
2018.03.07 17:39:57 4: EnOcean EnO_05017E43 received PacketType: 1 RORG: D2 DATA: 0460E4 SenderID: 05017E43 STATUS: 00
2018.03.07 17:44:06 3: EnOcean set EnO_05017E43 off
2018.03.07 17:44:06 4: EnOcean EnO_05017E43 sent PacketType: 1 RORG: D2 DATA: 010000 SenderID: FFA01D89 STATUS: 00 ODATA: 0305017E43FF00
2018.03.07 17:44:06 5: TCM TCM_ESP3_0 sent ESP: 550009070156D2010000FFA01D89000305017E43FF001E
2018.03.07 17:44:06 5: SW: 550009070156D2010000FFA01D89000305017E43FF001E
2018.03.07 17:44:06 5: TCM TCM_ESP3_0 received ESP: 5500010002650000
2018.03.07 17:44:06 5: TCM TCM_ESP3_0 RESPONSE: OK
2018.03.07 17:44:06 5: TCM TCM_ESP3_0 received ESP: 550009070156D201
2018.03.07 17:44:06 5: TCM TCM_ESP3_0 received ESP: 550009070156D2010000FFA01D898103
2018.03.07 17:44:06 5: TCM TCM_ESP3_0 received ESP: 550009070156D2010000FFA01D89810305017E434F00FD
2018.03.07 17:44:06 4: TCM TCM_ESP3_0 own telegram from FFA01D89 blocked.
2018.03.07 17:44:06 5: TCM TCM_ESP3_0 received ESP: 550009070156D204
2018.03.07 17:44:06 5: TCM TCM_ESP3_0 received ESP: 550009070156D204608005017E430006
2018.03.07 17:44:06 5: TCM TCM_ESP3_0 received ESP: 550009070156D204608005017E430006FFFFFFFF4C00FD
2018.03.07 17:44:06 5: TCM_ESP3_0: dispatch EnOcean:1:D2:046080:05017E43:00:06FFFFFFFF4C00
2018.03.07 17:44:06 4: EnOcean received via TCM_ESP3_0: EnOcean:1:D2:046080:05017E43:00:06FFFFFFFF4C00
2018.03.07 17:44:06 4: EnOcean EnO_05017E43 received PacketType: 1 RORG: D2 DATA: 046080 SenderID: 05017E43 STATUS: 00
Gerät ist dieses hier:
https://nodon.fr/en/nodon/enocean-metering-smart-plug/
Bernd
Sammy51
#3
Habe mit einem baugleichen Metering Aktor das gleiche / ähnliche Problem. Daneben zeigt er State irgendwarum nicht brauchbar an.
Korrektur: ON/Off in FHEM-Web erzeugt nur fleißig Log-Einträge. Am Aktor passiert nichts. Drücke ich den Button am Gerät - erkennt FHEM den Status aber korrekt.
Das per autocreate erzeugte Plot zeigt nichts
SIGNALQUALITÄT
Im Erdgeschoss (wo es jetzt nur Testweise eingesteckt ist - ist die Signalqualität "good". In der ersten Etage Luftlinie 6-8m vom USB300 Stick ist diese "BAD". Bzgl. der beschriebenen Effekte macht es aber keinen Unterschied.
REPEATER
Nodon Sin 2-2-01 ... gemäß angeblichem Befehl special repeaterLevel 1|2 .. als Repeater aktiviert. Das funktioniert aber offenbar nicht und erzeugt ebenfalls nur einen passenden LOG-Eintrag.
Habe ein paar Dinge aus der CommandRef getestet und die Metering Parameter verändert (von Arbeit auf Leistung, Einheit von Ws auf W, MeasurementReport auf auto usw. siehe list infos nachfolgend). Das ändert bei mir nichts. Vielleicht werden auch bloß nicht alle Infos ins LogFile geschrieben?!
ZitatInternals:
   DEF        0***91
   IODev      TCM_ESP3_0
   MSGCNT     2
   NAME       BD.Power.Waschmaschiene
   NR         97
   NTFY_ORDER 50-BD.Power.Waschmaschiene
   STATE      on
   TCM_ESP3_0_MSGCNT 2
   TCM_ESP3_0_RSSI -83
   TCM_ESP3_0_ReceivingQuality good
   TCM_ESP3_0_SubTelNum 3
   TCM_ESP3_0_TIME 2018-04-16 21:29:51
   TYPE       EnOcean
     2018-04-16 21:35:13   channel0        off
     2018-04-16 21:29:51   dim             100
     2018-04-16 21:35:13   dim0            0
     2018-04-16 21:29:51   error0          not_supported
     2018-04-16 21:29:51   localControl0   enabled
     2018-04-15 09:54:39   measurementDelta 30
     2018-04-15 09:54:39   measurementMode power
     2018-04-15 09:54:39   measurementReport auto
     2018-04-15 09:54:39   measurementReset not_active
     2018-04-15 09:54:39   measurementUnit W
     2018-04-16 21:29:51   overCurrentOff0 ready
     2018-04-16 21:29:51   powerFailure0   disabled
     2018-04-16 21:29:51   powerFailureDetection0 not_detected
     2018-04-15 09:54:39   responseTimeMax 10
     2018-04-15 09:54:39   responseTimeMin 1
     2018-04-16 21:29:51   state           on
     2018-04-15 09:09:16   teach           UTE teach-in accepted EEP D2-01-0B Manufacturer: ID-RF
   helper:
   IODev      TCM_ESP3_0
   comMode    biDir
   defaultChannel 0
   devChannel 1
   eep        D2-01-0B
   group      Power
   icon       measure_power
   manufID    046
   room       DG
   subDef    ***81
   subType    actuator.01
   teachMethod UTE
Die per Autocreate angelegte Definitionen sehen so aus (wieso "current" - wenn "power" bzw. "energy" gemessen werden kann):
define BD.Power.Waschmaschiene EnOcean 0***1
attr BD.Power.Waschmaschiene IODev TCM_ESP3_0
attr BD.Power.Waschmaschiene comMode biDir
attr BD.Power.Waschmaschiene defaultChannel 0
attr BD.Power.Waschmaschiene devChannel 1
attr BD.Power.Waschmaschiene eep D2-01-0B
attr BD.Power.Waschmaschiene group Power
attr BD.Power.Waschmaschiene icon measure_power
attr BD.Power.Waschmaschiene manufID 046
attr BD.Power.Waschmaschiene room DG
attr BD.Power.Waschmaschiene subDef FF9F1881
attr BD.Power.Waschmaschiene subType actuator.01
attr BD.Power.Waschmaschiene teachMethod UTE
define FileLog_BD.Power.Waschmaschiene FileLog ./log/BD.Power.Waschmaschiene-%Y.log BD.Power.Waschmaschiene
attr FileLog_BD.Power.Waschmaschiene logtype EnO_power4energy4:Power/Energie,text
attr FileLog_BD.Power.Waschmaschiene room LOGS
define SVG_BD.Power.Waschmaschiene SVG FileLog_BD.Power.Waschmaschiene:SVG_BD.Power.Waschmaschiene:CURRENT
attr SVG_BD.Power.Waschmaschiene label 1
attr SVG_BD.Power.Waschmaschiene room Plots
attr SVG_BD.Power.Waschmaschiene title "BD.Power.Waschmaschiene Min $data{min1}, Max $data{max1}, Last $data{currval1}"
Hier ein Beispiel wie das Log so oder so ähnlich aussehen müsste (anderes Enocean Modul mit gleichem Funkprotokoll) - d.h. beim Nodon (Hardware/Firmware oder Autocreate) passt irgendetwas nicht?!
https://wiki.fhem.de/wiki/EnOcean-PSC234-Zwischenstecker
Vielen Dank für Eure Hilfe!
Sammy
PS: Versuche jetzt mal ein Delete ... Device-Reset und Neues AutoCreate ........... sonst neige ich zum zurücksenden bevor das zeitlich zu spät ist. Dann wird es eben doch Homematic oder so :(
PI3b FHEM@Buster | Homematic via HMLAN | Phillips HUE/Zigbee | EnoCean via USB300 | Z-Wave via USB | Sonos | AlexaConnector
In Schublade (Anwendungstipps?): Raspy 1 | HM-Raspi-Modul | USB-Serial Adapter
Sammy51
#4
Nachtrag: Nach Delete, reset und erneutem Anlernen folgender Effekt
Was ist die Destination ID? Muss die Vielleicht auf die ID des USB 300 angepasst werden? FFFFFF scheint eher komisch?!
Neue List Ausgabe:
   CFGFN
   DEF        05017E91
   IODev      TCM_ESP3_0
   MSGCNT     4
   NAME       E****E91
   NR         143
   NTFY_ORDER 50-EnO_05017E91
   STATE      on
   TCM_ESP3_0_MSGCNT 4
   TCM_ESP3_0_RSSI -88
   TCM_ESP3_0_ReceivingQuality bad
   TCM_ESP3_0_TIME 2018-04-16 21:49:23
   TYPE       EnOcean
     2018-04-16 21:49:23   channel0        on
     2018-04-16 21:49:23   dim             100
     2018-04-16 21:49:23   dim0            100
     2018-04-16 21:49:23   error0          not_supported
     2018-04-16 21:49:23   localControl0   enabled
     2018-04-16 21:49:23   overCurrentOff0 ready
     2018-04-16 21:49:23   powerFailure0   disabled
     2018-04-16 21:49:23   powerFailureDetection0 not_detected
     2018-04-16 21:49:23   state           on
     2018-04-16 21:48:23   teach           UTE teach-in accepted EEP D2-01-0B Manufacturer: ID-RF
   helper:
   IODev      TCM_ESP3_0
   comMode    biDir
   defaultChannel 0
   devChannel 1
   eep        D2-01-0B
   manufID    046
   room       EnOcean
   subDef     FF***1
   subType    actuator.01
   teachMethod UTE
- Schalten geht derzeit (im Wohnzimmer, anders als vorhin aber auch dort jetzt laut Listing "Receiving Quality Bad ... gleiche Etage und 2 Wände und ca. 5-6m Abstand zum USB 300 Stick
- Messwerte gibt es weiterhin weder in TEXT Log noch im Plot sichtbar (die ganzen Metering Konfigurationen sind anders als oben zunächst wieder Standard.
- Diese Metering/Measurement Konfigurationen sind mir aber auch etwas "unheimlich". Wieso muss man wählen? Kann der nicht gleichzeitig Leistung und Arbeit erfassen/übermitteln?!
- In ähnlichem Sinne "beunruhigend" ist: "Metering" ist auf der Verpackung offenbar nachträglich per Aufkleber angebracht?!
Wenn Niemand einen guten Rat hat - vielleicht machen Bernd und ich ja nur etwas falsch oder fehlt ein ProTipp weil FHEM die Dinger nicht ganz richtig anlegt - dann schick ich es zurück und teste Permundo (leider teuer) oder doch Homematic Metering Steckdose.
@Bernd: Was hast Du inzwischen diesbezüglich unternommen? Oder hast Du Dein Problem ggf. gelöst?
BerndDA
Hallo Sammy,
sorry für die späte Rückmeldung.
Das Einzige was ich geschafft habe, ist den aktuellen Verbrauch per Kommando abzufragen wenn MeasurementReport auf manuell gesetzt ist.
Eine Mail an Nodon in Frankreich dazu blieb leider auch unbeantwortet.
Da ich das nur dazu verwende um festzustellen, wann die Waschmaschine im Keller fertig ist, habe ich auf Revolt Messsteckdosen umgestellt. Die gibt es für 18€.
Bernd
Sammy51
#6
Habe den Nodon inzwischen auch zurück geschickt. Deren Wall-In Module sind recht cool - das erste ging bei mir wohl kaputt aber der Support hat in dem Fall reagiert auch wenn es mit 2-3 mal eMail hin und her, immer ein paar Tagen Abstand und teilweise eMails von denen im Spam-Ordner etwas gedauert hat. Kommunikation in Englisch ging (französisch kann ich nicht)
Zuletzt haben die mir auch eine Anleitung gesendet zur Aktivierung der Repeater Funktion (per Dolphin View).
Revolt müsste ich mal anschauen - welches Produkt exakt meinst Du? Finde von Revolt auf Anhieb nichts ... für den Preis gibt es wohl verschiedene Wlan Steckdosen unterschiedlicher Anbieter. Wlan dürfte wohl vom Standby verbrauch eher hoch sein - oder?
Schwanke ansonsten zwischen Homematic (eher nicht die neue homematic-ip variante) und permundo psc234 (enocean version). Preise mit etwas Recherche relativ ähnlich.
Enocean bei Bedarf als Repeater nutzbar und kleiner. Schaltleistung vergleichbar und laut commandref müsste auch der permundo problemlos eingebunden werden.
Gibt es aus Deiner/Eurer Sicht harte Gründe für das eine oder andere? - Tendiere eher zur Erweiterung mit Enocean. Andererseits hab ich ein paar Homematic Komponenten und werde die auch nicht aktiv "rausschmeißen". Auch gibt es ggf. manche Teile von denen die einfach gut sind - so dass vielleicht doch nochmal etwas dazu kommt.
Beste Grüße,
Sammy
Eisix
Einbindung des psc234 klappt Problemlos. Ich habe bei mir nur immer wieder Probleme mit der Dauerstabilität und habe auch schon welche bei mir aussortiert. Als lv1/lv2 Repeater funktionieren sie tadellos.
Eisix
Sammy51
Was meinst Du mit
Je nach "Härte" klingt das nach Argumenten dagegen (und damit für Homematic)?
Zuverlässig schalten, Zustand anzeigen und Messwerte übertragen wäre (neben "vielleicht als Repeater") für mich wichtige Basics. Will es z.B. für Waschmaschine und Trockner mit Auto-Info über "fertig" nutzen, für TV aus sobald Standby erkannt wird und derartiges.
Beste Grüße,
Sammy
Eisix
Nach dem Einrichten funktioniert immer alles perfekt, aber nach 2-3 Wochen habe ich immer wieder festgestellt das nicht geschaltet wurde. Ob das dann am Zwischenstecker lag oder vielleicht was mit der Übertragung nicht stimmt konnte ich nicht wirklich herausfinden.
Ich hatte sie auch an Trockner und Waschmaschine dazwischen gesteckt aber habe sie dann wieder rausgenommen da sie manchmal aus waren obwohl sie nur zum Messen dazwischen waren. Zur Zeit habe ich nur noch einen wirklich permanent zum Schalten aktiv an einem Subwoofer. Wird dann über fhem und Harmony geschaltet aber auch da Stelle ich alle 2-3 Wochen fest daß der Subwoofer im falschen Status ist. Die Anzeige in fhem passt aber es wurde nicht geschaltet. Einer war komplett defekt und ließ sich auch mit reset nicht wiederbeleben.  Ich setze sie eigentlich nur noch als Repeater oder für temporäre Sachen wie Weihnachtsbeleuchtung oder Filter des Planschbeckens ein.
Das ist nur meine subjektive Erfahrung, vielleicht habe ich auch öfters Montagsgeräte erwischt oder es stimmt was anderes nicht. Mit anderen Aktoren habe ich persönlich definitiv bessere Erfahrungen gemacht. Hier gibt es aber sicher andere die den Aktor auch im Einsatz haben und ihre Erfahrungen teilen können.
Du kannst ja auch Mal einen Kaufen und an der Waschmaschine testen.
Eisix
Sammy51
Hmm ... hast Du auch USB300? Da ist auch auf wenige Meter teilweise der Empfang/Sendequaltität sehr schlecht. Möglihc das es damit zusammenhängt. Auch haben di ePermundo durch das kleine Gehäuse ggf. auch ähnlich schlechte/kleine Antenne.
Gibt es denn Enocean Alternative mit denen Du bessere Erfahrungen hast?
Sonst würde ich doch mal zum Homematic greifen ... zumindest solange der HMLAN es noch tut dürte Empfang/Sendequalität damit besser sein. Auch fragt Homematic immer mal wieder zwischendurch ode rbeim ServerNeustart den STatus ab. Bei Enocean scheint so etwas nicht vorgesehen zu sein.
BerndDA
ich meine den Adapter von Revolt mit der bezeihnung SF-436.m. Gibt es bei Amazon.
Mit den PSC234 hab ich leider nicht so gute Erfahrungen gemacht. Innerhalb von 2 Jahren sind mir bereits 2 Stück kaputt gegangen. Reagieren dann einfach nicht mehr auf Schaltbefehle und bleiben aus.
Bernd
Eisix
Habe den usb300. Als Zwischenstecker nutze ich jetzt immer den Fibaro Wall Plug ist aber Zwave.
Sammy51
Der Revolt scheint echt die günstigsten Lösung, wenn man mehrere braucht und/oder schon ein passenden CUL hat (habe ich nicht).
Wenn ihr beide vom PSC234 abratet - dann scheint was dran zu sein. Also kein Permundo und kein Nodon Enocoean metering plug :o
Wenn ich nicht vor Jahren mit der ersten HM Komponente gestartet wäre hätte ich jetzt sicherlich nur Zwave und Enocean + Hue .... nun überlege ich ggf. dennoch Zwave zu ergänzen. Für Steckdosen und diverses ist Zwave auch günstiger als Enocean - Enocean bleibt aber mittel der wahl für einige Sensoren denke ich.
Was wäre denn eine sinnvolle "CUL" Lösung für Z-Wave? Preis/Leistung/Signalqualität ...?
Beste Grüße,
SAmmy
claudio
#14
Hello
I've the same problem with my nodon ASP-2-1-01, I could switch it on and off but I don't get the metering data from the smart plug. Is this a problem with fhem or a a configuration issue ?
When I click "get EnO_xxxxxxxx measurement" in the fhem device page, I get a dialog saying : "measurement   wrong, choose 0...30|all|input energy|power"
ps: I managed to get it running.
in fhem I write :
set <your device def> measurement report query auto
set <your device def> measurement mode power
set <your device def> measurement unit W
then, I got new readings, one energy0 and one power0. If I activate the energy mode like in the given commands, I get updated reading with realtime Watts consumption of the device connected to the plug as well as live power in the event log.
the plug send updated data only when value changes.
