Hank RGB Bulb HKZW-RGB01 in FHEM
Begonnen von db0b23b, 07 März 2018, 19:33:44
db0b23b
ich habe versucht, diese Lampe (Hank RGB Bulb HKZW-RGB01) in FHEM einzubinden.
modelId: 0208-0100-0004
FHEM findet keine XML-Config-Informationen für mein ZWave-Gerät.
Ich finde die folgende xml-Datei im Internet:
https://github.com/OpenZWave/open-zwave/blob/master/config/hank/hkzw-rgb01.xml
Ist es möglich, diese xml-Datei in die openzwave_deviceconfig.xml.gz aufzunehmen?
Vielen Dank
krikan
Werde ich in Kürze aufnehmen. Bitte noch ein paar Tage Geduld.
Gruß, Christian
krikan
Habe ein Komplettupdate der openzwave-config-Dateien eingecheckt.
Ab sofort im svn und morgen früh ab ca. 8 Uhr per update.
vamsi
Team,
Please let me know i have
1. Hank RGB Bulb
2. Sigma Designs UZB Z-Wave USB Stick (ZMEEUZB1)
I am able to connect Z-Wave USB Stick to FHEM Software this stick is blinking also.
But please let me know how to connect FHEM Software to Hank RGB Bulb
Its very urgent please help me.
Cheers,
Vamsi krishna
krikan
#4
http://manuals-backend.z-wave.info/make.php?lang=en&sku=HNKERGB01 :
ZitatInclusion
To include RGB BULB into a Z-Wave network as a non-security device:
(1) Make sure the power supply is disconnected and the RGB BULB is located within a direct Z-Wave network"s main controller communication range.
(2) Set the Z-Wave network main controller into learning mode (see Z-Wave network controller operating manual).
(3) Insert the RGB BULB into a lamp-socket and then power on.
(4) Auto-inclusion will be activated. If the inclusion is successful, the RGB BULB will blink fast in blue for less than 5 seconds and then keep on for 3 seconds. RGB BULB will keep the same color as befor the inclusion.
(2) to set main controller into learning mode in FHEM:
set <ZWDongle> addNode on
vamsi
#5
Hallo krikan,
First of all thanks for your reply.
for your reference i used below command:
1.) define ZWDongle_0 ZWDongle /dev/ttyACM0@115200
After that i did below process:
(2) Set the Z-Wave network main controller into learning mode (set ZWDongle_0 addNode on)
After adding set ZWDongle_0 addNode on USB Stick light is blinking but Hank RGB Bulb not getting on .
Please give me your number i can explain you or you can help me here.
Cheers,
Vamsi krishna
