Enigma2 ParserDetails.ini Warning
Begonnen von mod25, 26 März 2018, 08:23:02
mod25
habe leider nichts gefunden eventuell habt ihr eine Lösung. Fehler bzw. ich bekomme ständig ein Warning
2018.03.26 08:19:49 1: PERL WARNING: could not find ParserDetails.ini in /usr/local/share/perl/5.24.1/XML/SAX
2018.03.26 08:19:49 1: stacktrace:
2018.03.26 08:19:49 1:     main::__ANON__                      called by /usr/local/share/perl/5.24.1/XML/SAX.pm (212)
2018.03.26 08:19:49 1:     XML::SAX::do_warn                   called by /usr/local/share/perl/5.24.1/XML/SAX.pm (62)
2018.03.26 08:19:49 1:     XML::SAX::load_parsers              called by /usr/local/share/perl/5.24.1/XML/SAX.pm (114)
2018.03.26 08:19:49 1:     XML::SAX::parsers                   called by /usr/local/share/perl/5.24.1/XML/SAX/ParserFactory.pm (18)
2018.03.26 08:19:49 1:     XML::SAX::ParserFactory::new        called by /usr/local/share/perl/5.24.1/XML/SAX/ParserFactory.pm (26)
2018.03.26 08:19:49 1:     XML::SAX::ParserFactory::parser     called by /usr/share/perl5/XML/Simple.pm (385)
2018.03.26 08:19:49 1:     XML::Simple::build_tree             called by /usr/share/perl5/XML/Simple.pm (333)
2018.03.26 08:19:49 1:     (eval)                              called by /usr/share/perl5/XML/Simple.pm (332)
2018.03.26 08:19:49 1:     XML::Simple::build_simple_tree      called by /usr/share/perl5/XML/Simple.pm (294)
2018.03.26 08:19:49 1:     XML::Simple::parse_string           called by /usr/share/perl5/XML/Simple.pm (215)
2018.03.26 08:19:49 1:     XML::Simple::XMLin                  called by (eval 156) (1)
2018.03.26 08:19:49 1:     (eval)                              called by ./FHEM/70_ENIGMA2.pm (998)
2018.03.26 08:19:49 1:     main::ENIGMA2_ReceiveCommand        called by FHEM/HttpUtils.pm (583)
2018.03.26 08:19:49 1:     main::__ANON__                      called by fhem.pl (705)
Simple ist installiert.
Danke für eure Hilf
mod25
