Unterschiedliche TX-25IT?
Begonnen von SVLoneStar, 23 September 2015, 17:10:12
SVLoneStar
ich habe mir bei eBay (http://www.ebay.de/itm/TECHNOLINE-TX25-AUsEN-SENSOR-MIT-MESSSONDE-TX-25-SENDER-POOL-TEICH-THERMOMETER-/331250723172?hash=item4d2014e964) drei TX-25IT gekauft und eingerichtet.
Zwei der drei verhalten sich gleich (=identische Readings):
   DEF        0B
   IODev      myJeeLink
   LASTInputDev myJeeLink
   LaCrosse_lastRcv 2015-09-23 17:07:30
   MSGCNT     664
   NAME       LaCrosse_0B
   NR         1559
   STATE      T1: 23.9°C T2: 25.7°C F:40%
   TYPE       LaCrosse
   addr       0B
   battery_new 0
   corr1      0
   corr2      0
   myJeeLink_MSGCNT 664
   myJeeLink_RAWMSG OK 9 11 1 4 215 106
   myJeeLink_TIME 2015-09-23 17:07:30
   previousH  106
   previousH2 125
   previousT  23.9
   previousT2 25.7
   sensorType 0=T(H)
   CHANGETIME:
   Helper:
     Dblog:
       T:
         Logdb:
           TIME       1443020850.0511
           VALUE      23.9
       Battery:
         Logdb:
           TIME       1443020327.09718
           VALUE      ok
       Temperature:
         Logdb:
           VALUE      23.9
       Temperature2:
         Logdb:
           TIME       1443020837.8007
           VALUE      25.7
   Readings:
     2015-09-23 17:07:30   battery         ok
     2015-08-10 19:50:41   battery13       ok
     2015-09-23 17:07:25   battery2        ok
     2015-08-12 00:12:32   humidity        40
     2015-09-23 17:07:30   state           T: 23.9
     2015-09-23 17:07:30   temperature     23.9
     2015-08-10 19:50:41   temperature13   28
     2015-09-23 17:07:25   temperature2    25.7
   IODev      myJeeLink
   alias      TX25 IT 0B
   event-min-interval state:600,battery:600,temperature:600,temperature2:600
   event-on-change-reading temperature,temperature2,battery,state
   group      Thermometer
   icon       sani_buffer_temp_all
   room       9 - zNew Temp,7 - Thermometer
   stateFormat T1: temperature°C T2: temperature2°C F:humidity%
Der dritte jedoch hat andere Readings:
   CHANGED
   DEF        13
   IODev      myJeeLink
   LaCrosse_lastRcv 2015-09-23 17:06:43
   MSGCNT     587
   NAME       LaCrosse_13
   NR         1593
   STATE      T1: 23°C T2: 23°C F:humidity%
   TYPE       LaCrosse
   addr       13
   battery_new 0
   corr1      0
   corr2      0
   myJeeLink_MSGCNT 587
   myJeeLink_RAWMSG OK 9 19 1 4 206 106
   myJeeLink_TIME 2015-09-23 17:06:43
   previousH  106
   previousH2 125
   previousT  23
   previousT2 23
   sensorType 0=T(H)
   CHANGETIME:
   Helper:
     Dblog:
       T:
         Logdb:
           TIME       1443020737.62833
           VALUE      23
       Battery:
         Logdb:
           TIME       1443020372.5963
           VALUE      ok
       Temperature:
         Logdb:
           VALUE      23
       Temperature2:
         Logdb:
           TIME       1443020484.67641
           VALUE      23
   Readings:
     2015-09-23 17:06:43   battery         ok
     2015-09-23 17:06:39   battery2        ok
     2015-09-20 03:12:47   rain            318
     2015-09-23 17:06:43   state           T: 23
     2015-09-23 17:06:43   temperature     23
     2015-09-23 17:06:39   temperature2    23
   IODev      myJeeLink
   alias      TX25 IT 13
   group      Thermometer
Siehe das zusätzliche Reading 'rain' sowie das fehlende Reading 'humidity'.
Hat jemand eine Idee, was da schief läuft? Kann ich dem LaCrosse-Modul evtl. irgendwie mitteilen, daß es sich bei dem Sensor um ein bestimmtes Model handelt?
Alle drei Sensoren werden über einen JeeLink Classic empfangen.
EDIT: Habe mir gerade mal die Readings aller meiner 10 LaCrosse-Sensoren angesehen....da findet man komische Sachen. Hier z.B. die Readings eines TX-29 IT (ein Temperatur-Kanal, keine Luftfeuchtigkeits-Messung):
   CHANGED
   DEF        06
   IODev      myJeeLink
   LaCrosse_lastRcv 2015-09-23 17:28:48
   MSGCNT     715
   NAME       LaCrosse_06
   NR         347
   STATE      T: 22.7
   TYPE       LaCrosse
   addr       06
   battery_new 0
   corr1      0
   corr2      0
   myJeeLink_MSGCNT 715
   myJeeLink_RAWMSG OK 9 6 1 4 203 106
   myJeeLink_TIME 2015-09-23 17:28:48
   previousH  106
   previousT  22.7
   sensorType 0=T(H)
   CHANGETIME:
   Helper:
     Dblog:
       T:
         Logdb:
           TIME       1443022071.8401
           VALUE      22.7
       Battery:
         Logdb:
           TIME       1443021529.59061
           VALUE      ok
       Temperature:
         Logdb:
           VALUE      22.7
   Readings:
     2015-09-23 17:28:48   battery         ok
     2015-07-25 01:33:35   battery6        ok
     2015-08-08 15:07:48   error           0
     2015-08-01 18:12:29   humidity        91
     2015-09-23 17:27:51   state           T: 22.7
     2015-09-23 17:28:48   temperature     22.7
     2015-07-25 01:33:35   temperature6    5619.4
     2015-07-04 06:10:58   windDirectionDegree 0
     2015-07-04 06:10:58   windDirectionText N
     2015-08-08 15:07:48   windGust        11.2
     2015-07-04 06:10:58   windSpeed       19.2
   IODev      myJeeLink
   alias      TX-29 IT Bad UG
   event-on-change-reading temperature,battery,state
   fp_4_UG    123,904,1,,
   group      Thermometer
   icon       temp_temperature
   room       4 - UG Bad,7 - Thermometer
Wie will das Teil wissen, aus welcher Richtung und mit welcher Geschwindigkeit der Wind in meinem Bad weht?! ;-)
Besten Dank,
Stefan
FHEM 21222 auf Gigabyte NUC, CubieTruck & RasPis (Test)
CUL 868MHz, nanoCUL 868MHz, nanoCUL 433MHz, JeeLink Clone, JeeLink Classic, HM-CFG-USB2, Rademacher
Devices: FHT, FS20, KS300, MAX, IT, HMS100, LaCrosse, PCA301, Revolt, HomeMatic, ESA2000, UNIRoll, Sonos, Duofern, Tasmota, MySensors
HCS
Zitat von: SVLoneStar am 23 September 2015, 17:10:12Wie will das Teil wissen, aus welcher Richtung und mit welcher Geschwindigkeit der Wind in meinem Bad weht?! ;-)
Das kann es wirklich nicht wissen  :o
Die readings sind teils vom 04.07.2015, also fast drei Monate alt. Keine Ahnung, was da mal schiefgelaufen ist.
Kannst sie einfach mal löschen
deletereading LaCrosse_06 windSpeed
usw...
Ich muss mal das LaCrosse-Modul studieren, in welchem Fall das auftreten kann.
Hast Du auch eine WS 1600 in Betrieb?
Welche Version hat die 36_LaCrosse.pm?
Auch readings wie "temperature6" und "battery13" sind echt seltsam.
SVLoneStar
Modul-Version ist
# $Id: 36_LaCrosse.pm 9068 2015-08-14 17:22:55Z hcs-sv
Hardware ist ein selbstgebaute JeeLink-Clone.
Es sind in Summe 10 TX-Thermometer im Einsatz, bisher konnte ich keine Probleme feststellen.
WS 1600 habe ich nicht im Einsatz.
Das Ganze wäre ja eher lustig als problematisch, wenn mit bei einem TX-25 nicht Readings, die ich loggen will, fehlen würden.  ;D
Danke für Deine Unterstützung,
Stefan
HCS
Habe erst jetzt gerade verstanden, was bei welchem Listing fehlen soll.
Der TX25IT sendet keine Feuchtigkeit. Nur zwei Temperaturen.
Meiner Meinung nach fehlen Dir keine Readings.
Die Readings, die es gar nicht gibt, scheinen durch seltsame Dinge, die der Sketch vom JeeLink schickt, zu entstehen.
Welche Version ist denn da drauf?
Das LaCrosse Modul kann es fast nicht sein, da bin ich mir sehr sicher.
Ich habe aber auch bei einem meiner Sensoren ein recht altes Reading gefunden, das da nicht hin gehört.
Das rauszufinden wird aber dauern, ich bleibe dran.
SVLoneStar
ok...also zunächst: sorry für die Verwirrung bezüglich des 'fehlenden' Readings.
Ich hatte zwar eigentlich auch gedacht, daß der TX-25 IT 'nur' zwei Temperatur-Kanäle hat - aber da mehrere meiner TX-25 IT auch ein Humidity-Reading angezeigt haben, habe ich mich auf die falsche Fährte locken lassen...my fault :-)
Was meine Hardware bzw. Sketch angeht:
Ich verwende den Sketch
[LaCrosseITPlusReader.10.1i (RFM69CW) @17241 kbps / 868300 kHz]
in Verbindung mit einem RFM69HW-Board von hier:
http://modtronicsaustralia.com/shop/rfm69hw-breakout-board-with-module/
Hatte ich mir mal gegönnt, um unproblematisch eine 'vernünftige' Antenne anschliessen zu können...löttechnisch wusste ich nicht so recht, wie ich einen SMA-Adapter an den RFM12B ranbekomme. Modtronics bietet auch ein Breakout-Board für den RFM12B an, aber da dieses damals ausverkauft war, der LaCrosse-Sketch auch den RFM69 unterstützt und der im Vergleich zum RFM12B wohl 'besser' ist, habe ich mich für den RFM69 entschieden.
Gekauft und in Betrieb genommen habe ich den RFM69 im Mai - somit sollten alle Readings, die danach kamen, mit diesem Modul empfangen worden sein. Zuvor hatte ich einen RFM12B mit dem Jeelink-Clone verbunden.
Ich hoffe, diese Infos helfen Dir weiter. Wenn ich was ausprobieren/ändern/... soll, laß' es mich wissen!
Anbei mal die kompletten Daten meiner 10 LaCrosse-Sensoren (5 x TX-25 IT, 3 x TX-29 DTH IT, 2 x TX-29 IT).
Besten Dank,
Stefan
Lucky2k12
#5
Ich habe mir auf einen Tipp aus dem Wassermelder Thread hin ein Kit mit einer Anzeigestation WS-8301-IT bestellt, das bei Amazon billiger war als der TX-25 alleine.
https://www.amazon.de/gp/product/B00185OGBA/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Das habe ich heute in Betrieb genommen und stelle fest:
Die Station zeigt aktuelle Temperatur und Feuchtigkeit an.
Fhem zeigt nur die Temperatur.
Kann es sein, dass da zwei Telegrammtypen nacheinander rauskommen?
Edit: In der Anleitung ist auch angegeben, dass das Teil Feuchtigkeit misst. Jetzt könnte es natürlich noch sein, dass der Hygrometer in der Basisstation sitzt :bummer:
Da ich das ganze in meiner Filamentbox einsetzen will, um Feuchtigkeiten zu messen, käme mir die Logging Funktion von FHEM hier sehr entgegen.
HP T610, HM, Jeelink, LGW, mapleCUL868+434
