[gelöst] FHEM update schlägt fehl
Begonnen von WhyTea, 02 Mai 2018, 10:01:54
WhyTea
Moin
Ich habe eben mehrfach versucht FHEM von dieser Version
Latest Revision: 15402
File                 Rev   Last Change
fhem.pl              15377 2017-11-01 16:59:23Z rudolfkoenig
60_allergy.pm        13588 2017-03-03 15:45:05Z moises
96_allowed.pm        14888 2017-08-13 12:07:12Z rudolfkoenig
73_AMADCommBridge.pm 15234 2017-10-11 20:13:09Z CoolTux
74_AMADDevice.pm     15234 2017-10-11 20:13:09Z CoolTux
90_at.pm             14995 2017-09-03 14:23:14Z rudolfkoenig
98_autocreate.pm     15377 2017-11-01 16:59:23Z rudolfkoenig
57_Calendar.pm       14832 2017-08-01 18:36:03Z neubert
10_CUL_HM.pm         15399 2017-11-05 17:42:40Z martinp876
93_DbLog.pm          15297 2017-10-20 20:59:52Z DS_Starter
98_DOIF.pm           14790 2017-07-26 10:27:41Z Damian
98_dummy.pm          12700 2016-12-02 16:49:42Z rudolfkoenig
91_eventTypes.pm     14888 2017-08-13 12:07:12Z rudolfkoenig
01_FHEMWEB.pm        15328 2017-10-27 10:51:17Z rudolfkoenig
92_FileLog.pm        14888 2017-08-13 12:07:12Z rudolfkoenig
98_GEOFANCY.pm       14110 2017-04-26 06:54:58Z loredo
98_HMinfo.pm         14608 2017-07-01 04:53:04Z martinp876
00_HMUARTLGW.pm      15383 2017-11-03 08:11:29Z mgernoth
98_HTTPMOD.pm        15035 2017-09-09 12:02:21Z StefanStrobel
02_HTTPSRV.pm        13976 2017-04-12 13:35:44Z neubert
36_JeeLink.pm        14707 2017-07-13 18:08:33Z justme1968
98_JsonList2.pm      13757 2017-03-20 19:17:02Z rudolfkoenig
36_LaCrosse.pm       15365 2017-10-31 16:59:42Z HCS
82_LGTV_WebOS.pm     15307 2017-10-23 14:51:59Z CoolTux
91_notify.pm         14888 2017-08-13 12:07:12Z rudolfkoenig
No Id found for 99_perfmon.pm
73_PRESENCE.pm       15302 2017-10-22 11:32:19Z markusbloch
59_PROPLANTA.pm      15358 2017-10-30 20:04:27Z tupol
70_Pushover.pm       15162 2017-10-01 11:25:11Z loredo
33_readingsGroup.pm  15100 2017-09-19 21:21:27Z justme1968
91_sequence.pm       14996 2017-09-03 15:20:42Z rudolfkoenig
98_structure.pm      15129 2017-09-24 08:58:57Z rudolfkoenig
99_SUNRISE_EL.pm     14888 2017-08-13 12:07:12Z rudolfkoenig
98_SVG.pm            14888 2017-08-13 12:07:12Z rudolfkoenig
42_SYSMON.pm         15378 2017-11-01 20:36:57Z hexenmeister
98_telnet.pm         15006 2017-09-05 09:37:33Z rudolfkoenig
59_Twilight.pm       14039 2017-04-19 19:59:56Z orti-otto
99_Utils.pm          13259 2017-01-28 17:39:39Z rudolfkoenig
77_UWZ.pm            15215 2017-10-09 09:01:41Z CoolTux
98_version.pm        15140 2017-09-26 09:20:09Z markusbloch
91_watchdog.pm       14888 2017-08-13 12:07:12Z rudolfkoenig
71_YAMAHA_AVR.pm     15364 2017-10-31 16:16:35Z markusbloch
Blocking.pm          15200 2017-10-05 08:27:30Z rudolfkoenig
Color.pm             11159 2016-03-30 16:08:06Z justme1968
DevIo.pm             14933 2017-08-20 14:21:58Z rudolfkoenig
HMConfig.pm          15337 2017-10-29 06:43:02Z martinp876
HttpUtils.pm         15284 2017-10-18 19:46:13Z rudolfkoenig
myUtilsTemplate.pm    7570 2015-01-14 18:31:44Z rudolfkoenig
RTypes.pm            10476 2016-01-12 21:03:33Z borisneubert
SetExtensions.pm     12935 2017-01-02 19:51:46Z rudolfkoenig
TcpServerUtils.pm    14862 2017-08-07 15:16:03Z rudolfkoenig
fhemweb.js                 15228 2017-10-10 17:34:56Z rudolfkoenig
fhemweb_readingsGroup.js   15189 2017-10-03 17:53:27Z justme1968
auf die aktuelle Version upzudaten.
Das Update läuft auch scheinbar sauber durch aber FHEM startet danach nicht mehr.
Hinweise im LOG:
2018.05.02 09:49:17 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at /var/fhem/FHEM/74_AMADDevice.pm line 376.
2018.05.02 09:49:17 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at /var/fhem/FHEM/73_AMADCommBridge.pm line 290.
2018.05.02 09:49:17 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at /var/fhem/FHEM/73_AMADCommBridge.pm line 291.
2018.05.02 09:49:17 1: PERL WARNING: Use of uninitialized value in pattern match (m//) at /var/fhem/FHEM/HttpUtils.pm line 116.
2018.05.02 09:49:17 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at /var/fhem/FHEM/HttpUtils.pm line 304.
2018.05.02 09:49:17 1: PERL WARNING: Use of uninitialized value in pattern match (m//) at /var/fhem/FHEM/HttpUtils.pm line 306.
2018.05.02 09:49:17 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at /var/fhem/FHEM/HttpUtils.pm line 313.
Can't use an undefined value as a subroutine reference at /var/fhem/FHEM/HttpUtils.pm line 869.
Natürlich habe ich ein Backup vorher gemacht sodass nach der Rücksicherung wieder alles läuft aber ich hoffe trotzdem auf Hilfe! ;-)
Daniel
Hallo Daniel,
kann der User fhem denn wirklich alles updaten/Dateien ersetzen? Stimmen die Berechtigungen in /var/fhem/ bei allen Dateien?
Eventuell
sudo chown -R fhem: /var/fhem/
CoolTux
Das liegt an AMAD. Da hat jemand nicht die Zwischenschritte und Empfehlungen der letzten Monate befolgt und hängt nun in der Luft.
Einziger Ausweg, alle AMAD Definitionen löschen.
Das TuxNet Wiki:
https://www.cooltux.net
WhyTea
Danke für den Hinweis!
Dann sind wir hier wohl fertig
und reden hier https://forum.fhem.de/index.php/topic,87469.0.html weiter. ;-)
Dann mach den Thread mal besser dicht. Mit dem Betreff wird der in Jahren sonst wieder hochgeholt.  ::)
WhyTea
