[gelöst] Problem mit Anzeige von HM-Fenster Sensor
Begonnen von Helmi55, 14 Mai 2018, 19:45:09
Helmi55
Hallo und guten Abend,
habe meinen RPi neu aufgesetzt und das Zip für FTUI heruntergeladen = Version 2.5
<head>
     /* FHEM tablet ui */
     * UI builder framework for FHEM
     * Version: 2.5.*
     * URL: https://github.com/knowthelist/fhem-tablet-ui
     * Copyright (c) 2015-2017 Mario Stephan <mstephan@shared-files.de>
     * Under MIT License (http://www.opensource.org/licenses/mit-license.php)
     * - create a new folder named 'tablet' in /<fhem-path>/www
     * - copy all files incl. sub folders into /<fhem-path>/www/tablet
     * - add 'define TABLETUI HTTPSRV ftui ./www/tablet Tablet' in fhem.cfg
     * - Tadaaa! A new fhem ui in http://<fhem-url>:8083/fhem/tablet/
    <link rel="icon" href="favicon.ico" type="image/x-icon" />
    <!-- define your personal style here, it wont be overwritten  -->
    <!-- link rel="stylesheet" href="css/fhem-green-ui.css" / -->
    <!-- link rel="stylesheet" href="css/fhem-tablet-ui-user.css" / -->
    <script src="js/fhem-tablet-ui.js" defer></script>
    <!-- Remove this line to enable for usage with WebViewControl
    <script defer>var wvcDevices = {'12345': 'Tablet'}; var wvcUserCssFile="webviewcontrol.css"</script>
    <script src="../pgm2/cordova-2.3.0.js" defer></script>
    <script src="../pgm2/webviewcontrol.js" defer></script>
    <!-- End for WebViewControl -->
    <title>Poolsteuerung</title>
</head>
<body>
    <div class="gridster">
        <ul>
<li data-row="1" data-col="1" data-sizex="1" data-sizey="1">
        <header>Einfahrt</header>
        <div data-type="symbol" data-device="Einfahrt"
             data-get-on='["Offen","Zu"]'
             data-icons='["oa-fts_garage_door_10","oa-fts_garage_door_100"]'
             data-on-colors='["red","green"]'
             class="bigger" >
        </div>
        <div data-type="label" class="bold"></div>
</li>
<li data-row="2" data-col="1" data-sizex="1" data-sizey="1">
        <header>Garagentor</header>
        <div data-type="symbol" data-device="GaragenTor"
             class="bigger" >
        </div>
        <div data-type="label" data-device="Tuer"
</li>
Ich bekomme die Einfahrt und das Garagentor nicht angezeigt ist ausgegraut??
Hier das List der Einfahrt
   DEF        4D242F
   IODev      HMUSB
   NAME       Einfahrt
   NOTIFYDEV  global
   NR         79
   NTFY_ORDER 50-Einfahrt
   STATE      Zu
   TYPE       CUL_HM
     2018-05-14 19:34:19   Activity        alive
     2018-05-10 13:10:32   D-firmware      2.4
     2018-05-10 13:10:32   D-serialNr      NEQ0755120
     2018-05-11 06:49:27   PairedTo        0x220355
     2018-05-11 06:49:27   R-cyclicInfoMsg off
     2018-05-11 06:49:28   R-eventDlyTime  0 s
     2018-05-11 06:49:27   R-pairCentral   0x220355
     2018-05-11 06:49:27   R-sabotageMsg   on
     2018-05-11 06:49:28   R-sign          off
     2018-05-11 06:49:27   RegL_00.        02:01 09:00 0A:22 0B:03 0C:55 10:01 14:06 00:00
     2018-05-11 06:49:28   RegL_01.        08:00 20:60 21:00 22:64 30:06 00:00
     2018-05-14 19:31:01   battery         ok
     2018-05-14 19:31:01   contact         closed (to VCCU)
     2018-05-14 19:31:01   state           closed
     2018-05-14 19:31:01   trigger_cnt     107
   helper:
     HM_CMDNR   97
     mId        00B1
     regLst     ,0,1,4p
     rxType     28
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +4D242F,00,00,00
       prefIO
       rxt        2
       vccu
       p:
         4D242F
         00
         00
         00
     mRssi:
       mNo
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
     tmpl:
   IODev      HMUSB
   actCycle   028:00
   actStatus  alive
   autoReadReg 4_reqStatus
   devStateIcon Offen:fts_yard_gate_2w_open@red Zu:fts_yard_gate_2w@green
   eventMap   open:Offen closed:Zu
   expert     2_raw
   firmware   2.4
   model      HM-SEC-SC-2
   peerIDs    00000000,
   room       Einfahrt
   serialNr   NEQ0755120
   subType    threeStateSensor
   webCmd     :
Was übersehe ich hier bitte?
Gruß und Danke
Helmut
System1 fhem 6.1 auf RPi 4B mit 4GB, HMUSBConfig, DS9490R-1Wire, Busware USB 868, Pool-Solarsteuerung mit FHEM. System2 fhem 6.1 auf RPi 4B mit 4GB (Bullseye) mit Busware USB 868 und 433 und HMUARTLGW für Haussteuerung
https://www.flickr.com/photos/canonhelmi/
juemuc
meine Definition sieht so aus:
            <li data-row="1" data-col="4" data-sizex="4" data-sizey="3">
               <header class="">Balkontür</header>
                <table class="">
                 <tr>
                     <td>
                        <div class="">
                            <div class=""></div>
                            <div data-type="label" data-device="HM_50F361" data-get="alias" data-color="white" class="left-space big""></div>
                        </div>
                     </td>
                     <td>
                        <div class="">
                            <div data-type="symbol" data-device="HM_50F361" data-get="state" data-states='["open","tilted","closed"]' data-colors='["red","red","green"]'
                                 data-icons='["oa-fts_door_open","oa-fts_door_tilt","oa-fts_door"]' data-background-color="black" class="left-space bigger">
                            </div>
                        </div>
                     </td>
                     <td>
                        <div class="">
                            <div data-type="label" data-device="HM_50F361" data-get="LastOpen" data-color="white" class="big"></div>
                        </div>
                     </td>
                  </tr>
                </table>
            </li>
Das funktioniert bestens
VG
Jürgen
3x Sonos Play 1, 1x Sonos Arc + Sub, 1 Sonos-One, 1x Sonos Playbar
FB6690 + FB7490 mit 4x Dect 200 und 3 Dect-ULE-Thermostate,  raspberry3B+, HM Funkmodul HM-MOD-RPI-PCB, HM Klingelsensor HM-Sen-DB-PCB, HM (IP) Fensterkontakte und  Amazon Echo Dot,  piVCCU, pi OS (bookworm).
Ulm32b
D.h. die Farben werden nicht angezeigt? Dann liegt es wahrscheinlich an
Probiere mal
data-get-on='["Offen","Zu"]'   :o ???
data-states='["Offen","Zu"]'
data-colors='["red","green"]'
Hier gab es im Frühjahr eine Änderung. data-on-colors wird nicht mehr unterstützt.
Nützliche Infos wie immer siehe Wiki.
Helmi55
Herzlichen Dank genau das wars.
Sorry da war ich anscheinend zu schlampig beim Lesen.
Schönen Tag
