ich möchte gerne beim Bau des Containers zusätzliche Debian APT packages installieren.
Hierzu habe ich in der docker-compose.yml folgendes hinzugefügt:
APT_PKGS: "libunixsocket-java dbus libnet-dbus-perl shared-mime-info haveged default-jre"
Leider bekomme ich in der /pkgs.apt folgende Fehler angezeigt:
Err:1 https://deb.nodesource.com/node_10.x buster InRelease
Temporary failure resolving 'deb.nodesource.com'
Err:2 https://cdn-aws.deb.debian.org/debian buster InRelease
Temporary failure resolving 'cdn-aws.deb.debian.org'
Get:3 https://cdn-aws.deb.debian.org/debian-security buster/updates InRelease [65,4 kB]
Get:4 https://cdn-aws.deb.debian.org/debian buster-updates InRelease [51,9 kB]
Get:5 https://cdn-aws.deb.debian.org/debian-security buster/updates/non-free amd64 Packages [556 B]
Get:6 https://cdn-aws.deb.debian.org/debian-security buster/updates/main amd64 Packages [268 kB]
Get:7 https://cdn-aws.deb.debian.org/debian buster-updates/main amd64 Packages [7.860 B]
Get:8 https://cdn-aws.deb.debian.org/debian buster-updates/non-free amd64 Packages [604 B]
Fetched 394 kB in 29s (13,5 kB/s)
Reading package lists...
W: Failed to fetch https://cdn-aws.deb.debian.org/debian/dists/buster/InRelease Temporary failure resolving 'cdn-aws.deb.debian.org'
W: Failed to fetch https://deb.nodesource.com/node_10.x/dists/buster/InRelease Temporary failure resolving 'deb.nodesource.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
Reading state information...
Package default-jre is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package haveged is not available, but is referred to by another package.
E: Unable to locate package libunixsocket-java
E: Unable to locate package libnet-dbus-perl
E: Package 'haveged' has no installation candidate
E: Package 'default-jre' has no installation candidate
Kann mir jemand einen Tipp geben, was ich falsch mache?
Vorab vielen Dank
Marc
