nach gestrigem Update: configCheck mit Fehlermeldungen
Begonnen von Omega, 14 August 2018, 09:04:31
Omega
Gestern (13.08..) habe ich ein Update durchgeführt. Heute - nach einem get configCheck - habe ich folgende Fehlermeldungen im Log (ich mache täglich einen configCheck, daher weiß ich, dass es erst nach dem Update zu dem Verhalten kam):
configCheck done:
boost or template differ in team
    Az.Wandthermostat_Climate team:Az.Thermostat_links_Clima  boost differ Value not captured:Az.Wandthermostat_Climate - boostPeriod / Value not captured:Az.Thermostat_links_Clima - boostPeriod
    Az.Wandthermostat_Climate team:Az.Thermostat_rechts_Clima  boost differ Value not captured:Az.Wandthermostat_Climate - boostPeriod / Value not captured:Az.Thermostat_rechts_Clima - boostPeriod
    Bad.Wandthermostat_Climate team:Bad.Thermostat_Clima  boost differ Value not captured:Bad.Wandthermostat_Climate - boostPeriod / Value not captured:Bad.Thermostat_Clima - boostPeriod
    KG.Gast.Wandthermostat_Climate team:KG.Gast.Thermostat_Clima  boost differ Value not captured:KG.Gast.Wandthermostat_Climate - boostPeriod / Value not captured:KG.Gast.Thermostat_Clima - boostPeriod
    KG.Hobby.Wandthermostat_Climate team:KG.Hobby.Thermostat_Clima  boost differ Value not captured:KG.Hobby.Wandthermostat_Climate - boostPeriod / Value not captured:KG.Hobby.Thermostat_Clima - boostPeriod
    OG.Bad.Wandthermostat_Climate team:OG.Bad.Thermostat_Clima  boost differ Value not captured:OG.Bad.Wandthermostat_Climate - boostPeriod / Value not captured:OG.Bad.Thermostat_Clima - boostPeriod
    OG.Jami.Wandthermostat_Climate team:OG.Jami.Thermostat_links_Clima  boost differ Value not captured:OG.Jami.Wandthermostat_Climate - boostPeriod / Value not captured:OG.Jami.Thermostat_links_Clima - boostPeriod
    OG.Jami.Wandthermostat_Climate team:OG.Jami.Thermostat_rechts_Clima  boost differ Value not captured:OG.Jami.Wandthermostat_Climate - boostPeriod / Value not captured:OG.Jami.Thermostat_rechts_Clima - boostPeriod
    OG.Kinder.Wandthermostat_Climate team:OG.Kinder.Thermostat_Clima  boost differ Value not captured:OG.Kinder.Wandthermostat_Climate - boostPeriod / Value not captured:OG.Kinder.Thermostat_Clima - boostPeriod
    OG.Naehen.Wandthermostat_Climate team:OG.Naehen.Thermostat_links_Clima  boost differ Value not captured:OG.Naehen.Wandthermostat_Climate - boostPeriod / Value not captured:OG.Naehen.Thermostat_links_Clima - boostPeriod
    OG.Naehen.Wandthermostat_Climate team:OG.Naehen.Thermostat_rechts_Clima  boost differ Value not captured:OG.Naehen.Wandthermostat_Climate - boostPeriod / Value not captured:OG.Naehen.Thermostat_rechts_Clima - boostPeriod
    Sz.Wandthermostat_Climate team:Sz.Thermostat_Clima  boost differ Value not captured:Sz.Wandthermostat_Climate - boostPeriod / Value not captured:Sz.Thermostat_Clima - boostPeriod
    Wz.Wandthermostat_Climate team:Kueche.Thermostat_Clima  boost differ Value not captured:Wz.Wandthermostat_Climate - boostPeriod / Value not captured:Kueche.Thermostat_Clima - boostPeriod
    Wz.Wandthermostat_Climate team:Wz.Thermostat_Essecke_Clima  boost differ Value not captured:Wz.Wandthermostat_Climate - boostPeriod / Value not captured:Wz.Thermostat_Essecke_Clima - boostPeriod
    Wz.Wandthermostat_Climate team:Wz.Thermostat_TV_Clima  boost differ Value not captured:Wz.Wandthermostat_Climate - boostPeriod / Value not captured:Wz.Thermostat_TV_Clima - boostPeriod
Auf Wandthermostat und dazugehörigen Thermostaten habe ich ein getConfig ausgelöst. Das behebt das Problem aber nicht.
Da alle Wandthermostate (mit ihren dazugehörigen Thermostaten) betroffen sind, halte ich es für ein generelles Problem.
Holger
NUC6i3SYH (FHEM 5.8 in VM)
Homematic: HMLAN, HMUSB, HM-Sec-SD, HM-CC-RT-DN, HM-TC-IT, ... + diverse weitere
LaCrosseGateway, ESPEasy
ZWave
martinp876
Omega
ZWave
martinp876
Omega
Ich habe mir aus dem SVN 98_HMinfo.pm und HMConfig.pm geholt, nach FHEM kopiert, Rechte angepasst und dann FHEM neu gestartet (HMConfig.pm ließ sich nicht per reload nachladen).
Die Fehlermeldungen sind leider geblieben.
ZWave
Omega
Heute habe ich noch einmal ein Update durchgeführt. Jetzt sind die Fehlermeldungen weg  :).
Danke!
ZWave
