TCM TCM310_0 wrong data checksum
Begonnen von bruen985, 02 Oktober 2018, 09:56:03
bruen985
seit einigen Wochen habe ich das Problem (nachdem Jahrelang alles problemlos lief), dass mein EnceanPi immer mal wieder folgende Fehlermeldung im Log anzeigt:
2018.10.01 20:09:47 3: EnOcean set EnO_019E64B4_Stehlampe_TF100L B0
2018.10.01 20:24:01 3: EnOcean set EnO_050FD939_TVSchrank_TF100L B0
2018.10.01 20:28:53 2: TCM TCM310_0 wrong data checksum: got A5, computed D3
2018.10.01 20:29:12 2: TCM TCM310_0 wrong data checksum: got A5, computed E7
2018.10.01 20:38:40 2: TCM TCM310_0 wrong data checksum: got A5, computed 96
2018.10.01 20:52:07 2: TCM TCM310_0 wrong data checksum: got A5, computed D3
2018.10.01 21:00:00 3: EnOcean set EnO_DG_Rollladen_FSB61NP not_reached
2018.10.01 21:03:36 2: TCM TCM310_0 wrong data checksum: got A5, computed E7
2018.10.01 21:04:54 2: TCM TCM310_0 wrong data checksum: got A5, computed FB
2018.10.01 21:16:59 2: TCM TCM310_0 wrong data checksum: got A5, computed 66
2018.10.01 21:22:25 2: TCM TCM310_0 wrong data checksum: got 01, computed 82
2018.10.01 21:30:33 3: EnOcean set EnO_019E64B4_Stehlampe_TF100L BI
2018.10.01 21:30:33 3: EnOcean set EnO_050FD939_TVSchrank_TF100L BI
2018.10.01 21:57:09 2: TCM TCM310_0 wrong data checksum: got A5, computed 66
2018.10.01 21:58:05 2: TCM TCM310_0 wrong header checksum: got 01, computed 7E
2018.10.01 22:03:29 2: TCM TCM310_0 wrong data checksum: got A5, computed 66
2018.10.01 22:43:39 2: TCM TCM310_0 wrong data checksum: got A5, computed 61
2018.10.01 23:00:27 2: TCM TCM310_0 wrong data checksum: got A5, computed FE
2018.10.01 23:07:27 2: TCM TCM310_0 wrong data checksum: got A5, computed 63
2018.10.01 23:25:21 2: TCM TCM310_0 wrong data checksum: got A5, computed D1
2018.10.01 23:27:53 2: TCM TCM310_0 wrong data checksum: got A5, computed 4C
2018.10.02 00:05:52 2: TCM TCM310_0 wrong data checksum: got A5, computed D1
2018.10.02 00:22:58 2: TCM TCM310_0 wrong data checksum: got A5, computed BC
2018.10.02 01:28:27 2: TCM TCM310_0 wrong data checksum: got A5, computed B8
2018.10.02 01:30:36 2: TCM TCM310_0 wrong data checksum: got A5, computed 90
2018.10.02 01:38:19 2: TCM TCM310_0 wrong data checksum: got A5, computed B8
Einge EnoCean-Geräte funktionieren dann noch, andere, wie z.B. die Wetterstation die alle 1 Minuten ein Update liefert "kommt nicht mehr durch". Hier hilft dann nur noch ein Shutdown & Neustart von FHEM.....allerdings nur für wenige Stunden.........dann kommen die Meldungen wieder und die Updates diverser Enocean-Geräte werden wieder ignoriert.
Den EnoceanPi habe ich schon getauscht, doch der Neue zeigt das gleiche Fehlerbild - also liegt es vermutlich nicht an dem EnoceanPi.
Ich nutze den EnoceanPi auf einem Raspi 3B
-> cat /sys/firmware/devicetree/base/model
Raspberry Pi 3 Model B Rev 1.2
-> cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
Neueste FHEM-Version ist installiert:
Latest Revision: 17417
File                Rev   Last Change
fhem.pl             17329 2018-09-12 07:03:11Z rudolfkoenig
39_alexa.pm         16299 2018-03-01 08:06:55Z justme1968
96_allowed.pm       17179 2018-08-20 15:49:33Z rudolfkoenig
98_autocreate.pm    15620 2017-12-16 18:10:36Z rudolfkoenig
14_CUL_TCM97001.pm  16274 2018-02-25 20:42:39Z bjoernh
95_Dashboard.pm     16920 2018-06-29 12:01:56Z DS_Starter
98_DOIF.pm          17411 2018-09-27 16:49:11Z Damian
98_DOIFtools.pm     17298 2018-09-08 13:03:22Z Ellert
98_dummy.pm         16965 2018-07-09 07:59:58Z rudolfkoenig
10_EnOcean.pm       17353 2018-09-15 18:02:31Z klaus.schauer
91_eventTypes.pm    14888 2017-08-13 12:07:12Z rudolfkoenig
98_fheminfo.pm      16909 2018-06-25 15:29:01Z betateilchen
01_FHEMWEB.pm       17398 2018-09-24 19:13:24Z rudolfkoenig
92_FileLog.pm       17181 2018-08-20 17:23:26Z rudolfkoenig
95_FLOORPLAN.pm     13735 2017-03-19 12:43:53Z UliM
95_holiday.pm       16502 2018-03-27 20:59:14Z rudolfkoenig
02_HTTPSRV.pm       16874 2018-06-15 17:18:55Z neubert
98_JsonList2.pm     17230 2018-08-30 13:03:48Z rudolfkoenig
98_logProxy.pm      16299 2018-03-01 08:06:55Z justme1968
No Id found for 99_myUtils.pm
73_PRESENCE.pm      16177 2018-02-14 08:58:43Z markusbloch
59_PROPLANTA.pm     17079 2018-08-02 17:47:03Z tupol
33_readingsGroup.pm 16299 2018-03-01 08:06:55Z justme1968
33_readingsProxy.pm 16299 2018-03-01 08:06:55Z justme1968
00_SIGNALduino.pm   16624 2018-04-15 18:58:49Z rudolfkoenig
98_structure.pm     16865 2018-06-14 07:21:25Z rudolfkoenig
99_SUNRISE_EL.pm    16632 2018-04-17 19:00:21Z rudolfkoenig
42_SYSMON.pm        17227 2018-08-29 19:58:18Z hexenmeister
00_TCM.pm           17333 2018-09-12 17:54:15Z klaus.schauer
98_telnet.pm        17116 2018-08-10 11:52:49Z rudolfkoenig
59_Twilight.pm      16005 2018-01-27 06:05:51Z igami
99_Utils.pm         15713 2017-12-28 11:01:02Z rudolfkoenig
98_version.pm       15140 2017-09-26 09:20:09Z markusbloch
91_watchdog.pm      16963 2018-07-09 07:40:22Z rudolfkoenig
98_weblink.pm       16293 2018-02-28 21:33:57Z rudolfkoenig
98_WOL.pm           10595 2016-01-22 17:05:38Z dietmar63
72_XiaomiDevice.pm  17305 2018-09-09 11:33:58Z moises
Blocking.pm         16985 2018-07-15 14:08:15Z rudolfkoenig
Color.pm            11159 2016-03-30 16:08:06Z justme1968
DevIo.pm            16623 2018-04-15 18:44:05Z rudolfkoenig
HttpUtils.pm        17034 2018-07-27 05:47:13Z rudolfkoenig
RTypes.pm           10476 2016-01-12 21:03:33Z borisneubert
SetExtensions.pm    17100 2018-08-07 07:40:20Z rudolfkoenig
TcpServerUtils.pm   17124 2018-08-11 06:54:58Z rudolfkoenig
doif.js                    15546 2017-12-03 09:57:42Z Ellert
fhemweb.js                 17371 2018-09-19 09:28:18Z rudolfkoenig
fhemweb_readingsGroup.js   15189 2017-10-03 17:53:27Z justme1968
svg.js                     17037 2018-07-27 13:42:42Z rudolfkoenig
Hat jemand eine Idee an was das liegen könnte??
bruen985
- FHEM v6 | Rasberry PI 4
- ESP3 Enocean USB-Stick
- V 3.3.2.1-rc9 SIGNALduino cc1101, v3.4.4
- MQTT2_FHEM_Server
SouzA
Hatte das gleiche Thema.
https://forum.fhem.de/index.php/topic,68771.0.html
Hab die Schnittstelle getauscht. (letzter Beitrag) Danach war Ruhe.
Woran das liegt weiß ich nicht. Gehe davon aus, dass irgendwas mit Raspian nicht passt. Oder irgendeine Konfiguration murks ist. Aber für sowas habe ich keinen Nerv... Deswegen zum USB-Dongel gewechselt und funzt.
Bis denn
SouzA
Raspi 4, EnOcean TCM310 USB, HM-MOD-UART-USB, Jeelink, hue, AMAD, fully, FRITZBOX, Signalbot, VIERA, Presence BT/Mac, TPLink, Gassistant, Shelly, fhempy, ZigBee
bruen985
hm, ok.
Ich habe eher das Gefühl, dass es irgendwie an FHEM liegt, denn nach einem Neustart von FHEM (shutdown restart) funktioniert es wieder eine gewisse Zeit.....
Danke & Gruß
bruen985
- MQTT2_FHEM_Server
SouzA
Zitat von: bruen985 am 06 Oktober 2018, 12:42:21
hm, ok.
Danke & Gruß
bruen985
Wobei ich nicht weiß, ob es dann rein zufällig wieder funktioniert.
Hatte es oft genug, dass nur ein Neustart des Raspi  wieder zu einer zufriedenstellenden Funktion geführt hat. (Temporär)
Bis denn
SouzA
bruen985
Hallo SouzA,
da es ein sehr störender Fehler ist, der gewisse (automatisierte) Abläufe stört/verhindert, habe ich mir jetzt auch einen USB-Dongel gekauft.
Damit klappt alles problemlos - schade für den EnoceanPi.
Danke für Deine Infos.
bruen985
- MQTT2_FHEM_Server
SouzA
freut mich. Ich bin seit dem Tausch auch absolut glücklich.
Falls noch jemand einen EnOcenPi braucht.... ;)
Bis denn
SouzA
