Revision 17525: 98_DOIF.pm: DOIF_Readings: create readings directly; Perl-Mode: no ...
Begonnen von System, 14 Oktober 2018, 00:30:55
System
98_DOIF.pm: DOIF_Readings: create readings directly; Perl-Mode: no set/change/delete state, delete attributes: state, initialize, startup, delete set initialize
Source: Revision 17525: 98_DOIF.pm: DOIF_Readings: create readings directly; Perl-Mode: no ...
