Autor Thema: FHEM und Carwings/ConnectEV/You+NISSAN-API (Modul 98_Carwings.pm)  (Gelesen 18734 mal)
Offline c2j2
  • Full Member
Antw:FHEM und Carwings/ConnectEV/You+NISSAN-API (Modul 98_Carwings.pm)
« Antwort #105 am: 19 August 2019, 20:10:44 »
@Oli_t: weil es das nicht gibt, siehe oben:
  'chargeStatus' => '0',
  'batteryCapacity' => '240',
  'timeRequiredToFull200' => {
                               'hours' => '5',
                               'minutes' => '30'
  'cruisingRangeAcOff' => '212000.0',
  'timeRequiredToFull200_6kW' => {
                                   'hours' => '3',
                                   'minutes' => '0'
  'status' => 200,
  'batteryDegradation' => '187',
  'charging' => 'NO',
  'timeRequiredToFull' => {
                            'minutes' => '30',
                            'hours' => '11'
  'chargeMode' => 'NOT_CHARGING',
  'operationResult' => 'START',
  'currentChargeLevel' => '0',
  'responseFlag' => '1',
  'cruisingRangeAcOn' => '207000.0',
  'timeStamp' => '2019-08-10 20:00:48',
  'pluginState' => 'CONNECTED'
Offline skynet
  • New Member
« Antwort #106 am: 19 August 2019, 21:20:17 »
Ausgetauscht - Modul Reload ... Hmmm
  'url' => 'https://gdcportalgw.its-mo.com/api_v190426_NE/gdc/UserLoginRequest.php',
  'callback' => sub { "DUMMY" },
  'timeout' => 30,
  'method' => 'POST'
2019.08.19 21:18:27 3: Carwings::Leaf: <<<JOB login result: {
  'resultKey' => '',
  'status' => '-2010',
  'message' => 'INVALID PARAMS'
2019.08.19 21:18:27 3: Carwings::Leaf: <<<JOB login failed: {"status":"-2010","message":"INVALID PARAMS","resultKey":""}
2019.08.19 21:18:27 3: Carwings::Leaf: ERR>>>'status -2010: INVALID PARAMS'
2019.08.19 21:18:27 3: Carwings::Leaf: status -2010: INVALID PARAMS
2019.08.19 21:18:27 3: Carwings::Leaf: ERR login 3 status -2010: INVALID PARAMS
2019.08.19 21:18:27 3: Carwings::Leaf: Carwings_ExecuteNextJob
Korrekt das dies im Header ist - Korrekte Datei ?
#  98_Carwings.pm
# 2019-01-02:
#    hidden internal variables not needed to be viewed
« Letzte Änderung: 19 August 2019, 21:23:01 von skynet »
Offline c2j2
  • Full Member
« Antwort #107 am: 20 August 2019, 06:32:39 »
Das ist einen korrekte Fehlermeldung des Nissan-Servers ;)
Der hat im Moment seit ein paar Tagen zunehmend Probleme (wieder mal), heute hat der Connect nur 3 mal geklappt bisher.
Offline skynet
  • New Member
« Antwort #108 am: 20 August 2019, 06:57:48 »
Ok, thx.
Gesendet von meinem ONEPLUS A5010 mit Tapatalk
Offline Herjemine
  • Jr. Member
« Antwort #109 am: 12 September 2019, 12:32:26 »
Hallo c2j2,
bei mir bekommt Fhem seit einiger Zeit nur noch neue Daten, wenn im Smartphone eine neue Abfrage gestartet wird.
Hast Du eine Idee an was das liegt?
Brauchst du ein Log vom battery query?
thx
Hermann
Offline skynet
  • New Member
« Antwort #110 am: 27 September 2019, 07:44:33 »
Guten Morgen,
seit 2 Tagen zickt scheinbar die API.
Ich versuche Battery abzufragen bekomme aber keine ordentlichen Werte.
Der Login sieht gut aus.
Kann das jemand bestätigen?
Offline Herjemine
  • Jr. Member
« Antwort #111 am: 27 September 2019, 09:26:52 »
Hallo skynet,
bekommst du neue Daten wenn Du vorher im Handy neu Daten abfrägst?
So ist es seit einiger zeit bei mir.
Gruß Hermann
Offline skynet
  • New Member
« Antwort #112 am: 27 September 2019, 11:53:52 »
Scheinbar hat die Nissan App auch Probleme.
Hab heute morgen das letzte Mal eine Aktualisierung geschafft.
Danach kriege ich trotzdem keine Werte in FHEM
Offline Herjemine
  • Jr. Member
« Antwort #113 am: 27 September 2019, 12:08:15 »
Nissan App funktioniert bei mir letzte akt. 8:45 und jetzt 12:06 konnten neue Daten abgerufen werden,
allerdings alter LEAF  ;)
Offline moes
  • Jr. Member
« Antwort #114 am: 27 September 2019, 16:18:25 »
Ich kann bestätigen das die Abfrage auch bei mir seit zwei oder drei Tagen streikt. Auch die iOS App zeigt keinerlei Funktionalität.
Offline michael27983
  • New Member
    • Haussteuerung und andere Projekte
« Antwort #115 am: 28 September 2019, 11:55:45 »
Mal wieder bei Nissan kaputt. Die können es einfach nicht.
Offline moes
  • Jr. Member
« Antwort #116 am: 28 September 2019, 21:10:24 »
Seit eben geht App und Api wieder bei mir.
Offline skynet
  • New Member
« Antwort #117 am: 28 September 2019, 22:31:57 »
Jep, kann ich bestätigen
Offline moes
  • Jr. Member
« Antwort #118 am: 02 Oktober 2019, 22:54:38 »
Ich habe gerade die Vermutung das ein Multilogin möglich ist seit dem letzten Ausfall. Ich rufen aller 30 Minuten via FHEM den Status meines Leafs ab und konnte gerade eben ohne neuerlichen Login in der iOS App den Status auslesen.
Kann jemand die Vermutung bestätigen?
Offline c2j2
  • Full Member
« Antwort #119 am: 15 Oktober 2019, 08:30:12 »
Siehe Anhang... in den letzten Wochen geht fast nix.
