Kurze Info.
System nackig,
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
perl libs alle drauf
libcrypt-ssleay-perl 0.73.06-1+b4
libflac8:armhf 1.3.3-2+deb11u1
libio-socket-ssl-perl 2.069-1
libnet-smtp-ssl-perl 1.04-1
libnet-ssleay-perl 1.88-3+b1
libssl-dev:armhf 1.1.1n-0+deb11u3
libssl1.1:armhf 1.1.1n-0+deb11u3
libzstd1:armhf 1.4.8+dfsg-2.1+rpi1
openssl 1.1.1n-0+deb11u3
perl-openssl-defaults:armhf 5
unpatched (HttpsUtils)
seit dem 3 reboots
2022.06.28 09:14:29 5: KLF200 (x_gw_io) GW_REBOOT_REQ
2022.06.28 09:14:29 5: KLF200 (x_gw_io) GW_REBOOT_CFM 0002
2022.06.28 09:14:29 1: KLF200 (x_gw_io) - reboot started, reconnect in 30 seconds
2022.06.28 09:27:36 5: KLF200 (x_gw_io) GW_REBOOT_REQ
2022.06.28 09:27:36 5: KLF200 (x_gw_io) GW_REBOOT_CFM 0002
2022.06.28 09:27:36 1: KLF200 (x_gw_io) - reboot started, reconnect in 30 seconds
2022.06.28 09:40:43 5: KLF200 (x_gw_io) GW_REBOOT_REQ
2022.06.28 09:40:43 5: KLF200 (x_gw_io) GW_REBOOT_CFM 0002
2022.06.28 09:40:43 1: KLF200 (x_gw_io) - reboot started, reconnect in 30 seconds
btw - 14 Geräte verbunden, sollte das eventuell noch "interessant" sein.
jetzt patch ich mal die lib und boote system neu.
[EDIT]
So patch gemacht.
2022.06.28 11:04:15 5: KLF200 (x_gw_io) GW_REBOOT_REQ
2022.06.28 11:04:15 5: KLF200 (x_gw_io) GW_REBOOT_CFM 0002
2022.06.28 11:04:15 1: KLF200 (x_gw_io) - reboot started, reconnect in 30 seconds
2022.06.28 11:17:23 5: KLF200 (x_gw_io) GW_REBOOT_REQ
2022.06.28 11:17:23 5: KLF200 (x_gw_io) GW_REBOOT_CFM 0002
2022.06.28 11:17:23 1: KLF200 (x_gw_io) - reboot started, reconnect in 30 seconds
2022.06.28 11:30:29 5: KLF200 (x_gw_io) GW_REBOOT_REQ
2022.06.28 11:30:30 5: KLF200 (x_gw_io) GW_REBOOT_CFM 0002
2022.06.28 11:30:30 1: KLF200 (x_gw_io) - reboot started, reconnect in 30 seconds
2022.06.28 11:43:37 5: KLF200 (x_gw_io) GW_REBOOT_REQ
2022.06.28 11:43:37 5: KLF200 (x_gw_io) GW_REBOOT_CFM 0002
2022.06.28 11:43:37 1: KLF200 (x_gw_io) - reboot started, reconnect in 30 seconds
reboot alle 13 min mit und ohne patch
gefahren wurden 0 Geräte in der Zeit.
Ideen ?
[/EDIT OFF]
