tempListTmpl =>"[verify|restore]" ->Server crash<-
Begonnen von skeleton, 11 November 2018, 09:40:29
skeleton
Guten morgen
seit längerer Zeit ( ich hatte die Installation nicht beaufsichtigt, da sie einigermassen stabil lief) bekomme ich bei der Ausführung von
define AllNightCleanUP at *01:00 {\
fhem("set BLZ_Fenster_Clima tempListTmpl restore FHEM/tempList.cfg:BLZ_FE");;\
fhem("set GZ_Fenster_Clima tempListTmpl restore FHEM/tempList.cfg:GZ_FE");;\
fhem("set BU_FE_Clima tempListTmpl restore FHEM/tempList.cfg:BU_FE");;\
fhem("set FLUR_Clima tempListTmpl restore FHEM/tempList.cfg:FLUR");;\
fhem("set KU_FE_Clima tempListTmpl restore FHEM/tempList.cfg:OBERGESCHOSS");;\
fhem("set WZ_FE_Clima tempListTmpl restore FHEM/tempList.cfg:OBERGESCHOSS");;\
fhem("set WZ_Wand_Clima tempListTmpl restore FHEM/tempList.cfg:OBERGESCHOSS");;\
fhem("set WZ_Zentral_Climate tempListTmpl restore FHEM/tempList.cfg:OBERGESCHOSS");;\
fhem("set Wohnzimmer_Heizung tempListTmpl restore FHEM/tempList.cfg:OBERGESCHOSS");;\
fhem("set BZ_FE_Clima tempListTmpl restore FHEM/tempList.cfg:BZ_FE");;\
fhem("set SZ_FE_Clima tempListTmpl restore FHEM/tempList.cfg:SCHLAFZIMMER");;\
fhem("set JL_FE_Clima tempListTmpl restore FHEM/tempList.cfg:JOANA");;\
fhem("set JO_FE_Clima tempListTmpl restore FHEM/tempList.cfg:JEANLUC");;\
fhem("set TA_FE_Clima tempListTmpl restore FHEM/tempList.cfg:TAMARA");;\
folgende Fehlermeldung
2018.11.01 01:00:00 3: AllNightCleanUP: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.
2018.11.02 01:00:00 3: AllNightCleanUP: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.
2018.11.03 01:00:00 3: AllNightCleanUP: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.
2018.11.04 01:00:00 3: AllNightCleanUP: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.
2018.11.05 01:00:00 3: AllNightCleanUP: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.
2018.11.06 01:00:00 3: AllNightCleanUP: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.
2018.11.07 01:00:00 3: AllNightCleanUP: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.
2018.11.08 01:00:00 3: AllNightCleanUP: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.
2018.11.09 01:00:00 3: AllNightCleanUP: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.
2018.11.10 01:00:00 3: AllNightCleanUP: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.
2018.11.11 01:00:00 3: AllNightCleanUP: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.
Habe ich was verpasst, hatte lange Zeit funktioniert ?
Cheers
(C)arlos
BananaPi mt 0.5TB SSD,Fhem, Homebridge,CUL V3, 9xHM-CC-RT-DN,1xHM-WDS30-T-O, 1xHM-ES-PMSw1-Pl, 2xHM-WDS10-TH-O, 1xHM-SwI-3-FM,1xHM-SEC-WDS-2, 3xHM-Sec-SC-2, 3xHM-LC-Sw1PBU-FM, 3x,HM-SEC-SD-2,
3xHM-ES-PMSw1-Pl,1xHM-SWI-3-FM
skeleton
Nabend,
niemend einen Hinweis fuer mich ?
Ich binde gerade neue Heizkörper ein und würde das Profil gerne wieder schreiben können
Cheers
(C)arlos
ph1959de
Thema in den HomeMatic Bereich verschieben?
Aktives Mitglied des FHEM e.V. | Moderator im Forenbereich "Wiki"
skeleton
#3
Ok evtl. liegst du da richtig. Aber ich kann das nicht ( kein Knopf dafür da )
Ok erledigt, Knopf gefunden :-)
skeleton
Nabend,
kann hier wirklich niemand helfen ?
Cheers
(C)
skeleton
#5
Naja scheint ja nicht viele zu interessieren.
nur so nebenbei, wenn ich den Befehl direkt in FHEM eingebe Crashed der Server, aber ich wette auch das interessiert niemanden  ;)
CoolTux
In den meisten Fällen liegt das Problem nicht am System selbst
Ich habe mich mal getraut. Mein Ergebnis im Log
2018.11.29 09:23:23 3: CUL_HM set HeizungsThermostatWohnzimmer_1_Clima tempListSat prep 07:00 17.0 22:00 19.0 24:00 17.0
2018.11.29 09:23:23 3: CUL_HM set HeizungsThermostatWohnzimmer_1_Clima tempListSun prep 07:00 17.0 21:00 19.0 24:00 17.0
2018.11.29 09:23:23 3: CUL_HM set HeizungsThermostatWohnzimmer_1_Clima tempListMon prep 06:00 17.0 08:00 19.0 15:00 17.0 21:00 19.0 24:00 17.0
2018.11.29 09:23:23 3: CUL_HM set HeizungsThermostatWohnzimmer_1_Clima tempListTue prep 06:00 17.0 08:00 19.0 15:00 17.0 21:00 19.0 24:00 17.0
2018.11.29 09:23:23 3: CUL_HM set HeizungsThermostatWohnzimmer_1_Clima tempListWed prep 06:00 17.0 08:00 19.0 15:00 17.0 21:00 19.0 24:00 17.0
2018.11.29 09:23:23 3: CUL_HM set HeizungsThermostatWohnzimmer_1_Clima tempListThu prep 06:00 17.0 08:00 19.0 15:00 17.0 21:00 19.0 24:00 17.0
2018.11.29 09:23:23 3: CUL_HM set HeizungsThermostatWohnzimmer_1_Clima tempListFri prep 06:00 17.0 08:00 19.0 15:00 17.0 22:00 19.0 24:00 17.0
2018.11.29 09:23:23 3: CUL_HM set HeizungsThermostatWohnzimmer_1_Clima tempListFri exec 06:00 17.0 08:00 19.0 15:00 17.0 22:00 19.0 24:00 17.0
Und natürlich kein Crash.
Das TuxNet Wiki:
https://www.cooltux.net
CoolTux
Bist Du aktuell mit FHEM. Im Code finde ich ganz andere Dinge an der angezeigten Zeilennummer.
Gib mal bitte ein list von einem Beispiel Climakanal.
Das TuxNet Wiki:
MadMax-FHEM
Interessieren kann man nicht sagen aber ein crash war bislang nicht zu sehen...
...also in den Logs sind Meldungen aber ein crash...
Andere Frage: wozu schreibst du oder willst jede Nacht die Templisten auf die Geräte!?
Dass das auf Dauer (evtl.) den Flash dort kaputt macht ist dir bewusst!?
(gut es ist glaube ich eine Logik eingebaut, dass nur tatsächlich geschrieben wird, wenn nötig, also auf dem Gerät anders)
Soll heißen: wer ändert bei dir die Templisten, dass du denkst sie jede Nacht überschreiben zu müssen?
(das war die erste Feage die mir in den Sinn kam beim ersten lesen vor einiger Zeit / da ich aber keine Lösung für das Problem hatte/habe, habe ich gewartet, ob sich einer dem Problem annimmt / ich selbst nutze Templisten nicht bzw. habe ich meine halt mal "programmiert" und da die sich ja nicht selbst ändern und sie noch passen bleiben sie halt wie sie auf den Geräten hinterlegt sind)
Ansonsten würde ich mal Schritt für Schritt vorgehen und mal manuell mit einer Templist untersuchen warum es nicht geht...
Dazu dann mal das list hier posten und auch von hminfo etc.
Evtl. auch mal in der commandref/Wiki schauen, ob sich etwas geändert hat...
Und dann die Masterfrage: was hast du inzwischen getan dass es nicht mehr geht? (system update, fhem update [Änderungsbeschreibung beachtet], neue Module hinzu, an eigenen myUtils "geschraubt", ...)
Glaube nicht, dass es "einfach so" nicht mehr geht.
Wenn du tatsächlich nichts getan hast (siehe "Masterfrage"), dann kann (falls es ein PI ist) auch die Speicherkarte hinüber sein, das hat oft "komische Effekte"...
Gruß, Joachim
FHEM PI3 Buster (Test)
skeleton
Hi danke fuer deine Antwort
das habe ich eben noch gefunden.
2018.11.01 01:00:00 1: ERROR evaluating {
}: Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285
definitiv wenn ich set BLZ_Fenster_Clima tempListTmpl restore FHEM/tempList.cfg:BLZ_FE
in die FHEM Zeile Eingebe Crash der Server !
root@bananapi:/opt/fhem/log# tail -f  fhem-2018-11.log
2018.11.29 10:18:00 3: HCS heatDemand Found 14 Device(s): 0 FHT, 14 HM-CC-TC, 0 MAX, 0 ZWave, demand: 0, idle: 1, ignored: 13, excluded: 0, unknown: 0, eco: no overdrive: no
2018.11.29 10:23:00 3: HCS heatDemand Found 14 Device(s): 0 FHT, 14 HM-CC-TC, 0 MAX, 0 ZWave, demand: 0, idle: 1, ignored: 13, excluded: 0, unknown: 0, eco: no overdrive: no
2018.11.29 10:28:00 3: HCS heatDemand Found 14 Device(s): 0 FHT, 14 HM-CC-TC, 0 MAX, 0 ZWave, demand: 0, idle: 1, ignored: 13, excluded: 0, unknown: 0, eco: no overdrive: no
2018.11.29 10:33:01 3: HCS heatDemand Found 14 Device(s): 0 FHT, 14 HM-CC-TC, 0 MAX, 0 ZWave, demand: 0, idle: 1, ignored: 13, excluded: 0, unknown: 0, eco: no overdrive: no
2018.11.29 10:38:01 3: HCS heatDemand Found 14 Device(s): 0 FHT, 14 HM-CC-TC, 0 MAX, 0 ZWave, demand: 0, idle: 1, ignored: 13, excluded: 0, unknown: 0, eco: no overdrive: no
2018.11.29 10:43:01 3: HCS heatDemand Found 14 Device(s): 0 FHT, 14 HM-CC-TC, 0 MAX, 0 ZWave, demand: 0, idle: 1, ignored: 13, excluded: 0, unknown: 0, eco: no overdrive: no
2018.11.29 10:48:01 3: HCS heatDemand Found 14 Device(s): 0 FHT, 14 HM-CC-TC, 0 MAX, 0 ZWave, demand: 0, idle: 1, ignored: 13, excluded: 0, unknown: 0, eco: no overdrive: no
2018.11.29 10:53:01 3: HCS heatDemand Found 14 Device(s): 0 FHT, 14 HM-CC-TC, 0 MAX, 0 ZWave, demand: 0, idle: 1, ignored: 13, excluded: 0, unknown: 0, eco: no overdrive: no
2018.11.29 10:58:01 3: HCS heatDemand Found 14 Device(s): 0 FHT, 14 HM-CC-TC, 0 MAX, 0 ZWave, demand: 0, idle: 1, ignored: 13, excluded: 0, unknown: 0, eco: no overdrive: no
2018.11.29 11:03:02 3: HCS heatDemand Found 14 Device(s): 0 FHT, 14 HM-CC-TC, 0 MAX, 0 ZWave, demand: 0, idle: 1, ignored: 13, excluded: 0, unknown: 0, eco: no overdrive: no
[b]Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4285.[/b]
Und nach der letzten Zeile ist der Server weg und ich muss ihn Manuel neu starten
Ich bin nicht "brandaktuell" mit der Version und folgende Module stehen im Update check
List of new / modified files since last update:
UPD ./CHANGED
UPD FHEM/00_MQTT2_CLIENT.pm
UPD FHEM/00_Neuron.pm
UPD FHEM/10_CUL_HM.pm
UPD FHEM/10_MQTT2_DEVICE.pm
UPD FHEM/10_MQTT_GENERIC_BRIDGE.pm
UPD FHEM/10_NeuronPin.pm
UPD FHEM/12_HProtocolGateway.pm
UPD FHEM/30_DUOFERN.pm
UPD FHEM/36_Shelly.pm
UPD FHEM/42_AptToDate.pm
UPD FHEM/49_SSCam.pm
UPD FHEM/50_HP1000.pm
UPD FHEM/52_I2C_BME280.pm
UPD FHEM/52_I2C_EEPROM.pm
UPD FHEM/52_I2C_LM75A.pm
UPD FHEM/52_I2C_MCP23008.pm
UPD FHEM/52_I2C_MCP23017.pm
UPD FHEM/52_I2C_MCP342x.pm
UPD FHEM/52_I2C_PCA9532.pm
UPD FHEM/52_I2C_PCA9685.pm
UPD FHEM/52_I2C_PCF8574.pm
UPD FHEM/52_I2C_SHT21.pm
UPD FHEM/70_BRAVIA.pm
UPD FHEM/70_ENIGMA2.pm
UPD FHEM/70_PHTV.pm
UPD FHEM/70_Pushover.pm
UPD FHEM/74_XiaomiBTLESens.pm
UPD FHEM/88_HMCCU.pm
UPD FHEM/88_HMCCUCHN.pm
UPD FHEM/88_HMCCURPCPROC.pm
UPD FHEM/93_DbRep.pm
UPD FHEM/98_BOSEST.pm
UPD FHEM/98_HMinfo.pm
UPD FHEM/98_HMtemplate.pm
UPD FHEM/HMCCUConf.pm
UPD FHEM/HttpUtils.pm
UPD FHEM/lib/AttrTemplate/mqtt2.template
UPD FHEM/msgSchema.pm
UPD www/pgm2/fhemweb.js
Aber das Problem besteht schon länger wie ich beschrieben habe......
Ich selber habe ausser das ich updates gefahren habe am Code selber NICHTS geändert in der Zwischenzeit.
Was kann ich noch zur besseren Analyse liefern ?
Danke fuer die Hilfe
Cheers
(C)arlos
CoolTux
Also selbst wenn ich da was falsches in den Set Befehl mit angebe, also ein nicht vorhandenes Templistfile stürzt nichts ab.
Zeig mal bitte Dein Templistfile FHEM/tempList.cfg:BLZ_FE
Das TuxNet Wiki:
CoolTux
Das TuxNet Wiki:
skeleton
Hi CoolTux,
here we go
entities:BZ_FE
tempListSat>08:30 19.0  22:00 20 24:00 19.0
tempListSun>08:30 19.0  22:00 20 24:00 19.0
tempListMon>06:00 19.0 08:00 22 22:00 20.0 24:00 19.0
tempListTue>06:00 19.0  08:00 22 22:00 20.0 24:00 19.0
tempListWed>06:00 19.0 08:00 22 22:00 20.0 24:00 19.0
tempListThu>06:00 19.0  08:00 22 22:00 20.0 24:00 19.0
tempListFri>06:00 19.0   08:00 22 22:00 20.0 24:00 19.0
Update mache ich gleich mal, aber der Fehler besteht schon so lange das ich kaum glaube das es dran liegt :-)
CoolTux
Mal davon ab das Du Nachts anscheinend heizen willst sehe ich da erstmal keine Probleme.
ab 0 Uhr stellen sich Deine Thermostate auf 20 bzw. 22 Grad.
Das TuxNet Wiki:
skeleton
Ja das weiss ich :-)
nach dem update gerade gleiches verhalten
nach der Eingabe der Set Zeile Server crash.....
2018.11.29 12:40:45 4: Connection closed for WEB_10.0.4.10_61154: EOF
2018.11.29 12:40:45 4: Connection accepted from WEB_10.0.4.10_61155
2018.11.29 12:40:45 4: WEB_10.0.4.10_61155 POST /fhem&fw_id=1190&fwcsrf=csrf_249574717921129&cmd=set+BLZ_Fenster_Clima+tempListTmpl+restore+FHEM%2FtempList.cfg%3ABLZ_FE; BUFLEN:0
2018.11.29 12:40:45 5: Cmd: >set BLZ_Fenster_Clima tempListTmpl restore FHEM/tempList.cfg:BLZ_FE<
Undefined subroutine &main::HMinfo_tempListDefFn called at ./FHEM/10_CUL_HM.pm line 4288.
