Autor Thema: Neues Modul: vitoconnect  (Gelesen 138355 mal)
Offline jemu75
  • Sr. Member
    • FHEM App
Antw:Neues Modul: vitoconnect
« Antwort #735 am: 21 November 2021, 23:36:51 »
in meinem LogFile häufen sich Fehlermeldungen. Daten werden aber problemlos abgerufen. Was kann ich da machen?
2021.11.21 21:47:18 1: PERL WARNING: "my" variable $param masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1858, <$fh> line 2145.
2021.11.21 21:47:18 1: PERL WARNING: "my" variable $err masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1865, <$fh> line 2145.
2021.11.21 21:47:18 1: PERL WARNING: "my" variable $msg masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1865, <$fh> line 2145.
2021.11.21 21:47:18 1: PERL WARNING: "my" variable $decode_json masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1866, <$fh> line 2145.
2021.11.21 21:47:18 3: vitoconnect - Passwort war bereits gespeichert
2021.11.21 21:47:30 1: PERL WARNING: Argument "" isn't numeric in numeric eq (==) at ./FHEM/98_vitoconnect.pm line 1755.
2021.11.21 21:47:30 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/98_vitoconnect.pm line 1849.
2021.11.21 21:47:30 1: vitoconnect - Fehler während installation features:  :: {"viErrorId":"req-c2a0ffb569274e8a8458c969d818269d","statusCode":500,"errorType":"INTERNAL_ERROR","message":"Internal server error"}
2021.11.21 22:11:37 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/98_vitoconnect.pm line 1948.
2021.11.21 22:11:37 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/98_vitoconnect.pm line 1953.
2021.11.21 22:11:37 1: vitoconnect - unbekannter Fehler: Bitte den Entwickler informieren!
2021.11.21 22:11:37 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/98_vitoconnect.pm line 1996.
2021.11.21 22:11:37 1: vitoconnect - statusCode: 500 errorType: INTERNAL_ERROR message: Internal server error error:
2021.11.21 22:47:50 1: vitoconnect - Fehler während installation features:  :: {"viErrorId":"req-4001c8c03ff14dfaa37e7e8a95c79fd7","statusCode":500,"errorType":"INTERNAL_ERROR","message":"Internal server error"}
2021.11.21 22:53:52 1: vitoconnect - unbekannter Fehler: Bitte den Entwickler informieren!
2021.11.21 22:53:52 1: vitoconnect - statusCode: 500 errorType: INTERNAL_ERROR message: Internal server error error:
« Letzte Änderung: 21 November 2021, 23:38:48 von jemu75 »
Offline andreas13
« Antwort #736 am: 23 November 2021, 20:29:20 »
Du kannst Viessmann sagen, sie mögen den Fehler bei,ihrem Server reparieren.
[ quote author=jemu75 link=topic=93664.msg1188525#msg1188525 date=1637534211]
[/quote]
Maintainer des Vitoconnect Moduls
In Betrieb: FritzBox 7590, Homematic
piko Wechelrichter (HTTPMOD). Sonos ....
noch: IT
Offline marhof
  • Newbie
« Antwort #737 am: 23 November 2021, 21:47:37 »
Hi hier die Daten.
Danke im Voraus.
Du kannst mal das Attribut vitoconnect_actions_active auf 1 setzen und mir die dann erzeugten zusätzlichen Readings schicken. Dann kann ich schauen, ob die API einen solchen Befehl kenn und ihn ggf. implementieren.
Andreas
defmod vitoconnect vitoconnect xxxx
attr vitoconnect room Heizung
attr vitoconnect vitoconnect_actions_active 1
setstate vitoconnect last update: 2021-11-23 21:37:18
setstate vitoconnect 2021-11-23 21:37:18 Aktive_Heizkreise 0
setstate vitoconnect 2021-11-23 21:37:18 Aussen_Status connected
setstate vitoconnect 2021-11-23 21:37:18 Aussentemperatur 4.3
setstate vitoconnect 2021-11-23 21:37:18 Aussentemperatur/Einheit celsius
setstate vitoconnect 2021-11-23 21:37:18 Controller_Seriennummer xxxxxxxxxxxxxx
setstate vitoconnect 2021-11-23 21:37:18 Device_Time_Offset 59
setstate vitoconnect 2021-11-23 21:37:18 HK1-Betriebsart dhwAndHeatingCooling
setstate vitoconnect 2021-11-23 21:37:18 HK1-Fixed_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Frostschutz_Status off
setstate vitoconnect 2021-11-23 21:37:18 HK1-Heizkurve-Niveau 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Heizkurve-Steigung 0.3
setstate vitoconnect 2021-11-23 21:37:18 HK1-Name
setstate vitoconnect 2021-11-23 21:37:18 HK1-Normal_Standby_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Programmstatus normal
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_Anforderung unknown
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_comfort 20
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_comfort_Anforderung unknown
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_comfort_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_eco 20
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_eco_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_normal 20
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_reduziert 16
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_reduziert_Anforderung unknown
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_reduziert_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Standby_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Typ heatingCircuit
setstate vitoconnect 2021-11-23 21:37:18 HK1-Vorlauftemperatur 27.2
setstate vitoconnect 2021-11-23 21:37:18 HK1-Vorlauftemperatur/Einheit celsius
setstate vitoconnect 2021-11-23 21:37:18 HK1-Vorlauftemperatur_aktiv connected
setstate vitoconnect 2021-11-23 21:37:18 HK1-WW_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-WW_und_Heizen_Kuehlen_aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 HK1-Zeitsteuerung_Heizung {"fri":[{"mode":"normal","start":"00:00","end":"24:00","position":0}],"mon":[{"start":"00:00","mode":"normal","end":"24:00","position":0}],"wed":[{"start":"00:00","mode":"normal","end":"24:00","position":0}],"sat":[{"mode":"normal","start":"00:00","position":0,"end":"24:00"}],"thu":[{"mode":"normal","start":"00:00","position":0,"end":"24:00"}],"sun":[{"position":0,"end":"24:00","start":"00:00","mode":"normal"}],"tue":[{"end":"24:00","position":0,"mode":"normal","start":"00:00"}]}
setstate vitoconnect 2021-11-23 21:37:18 HK1-Zeitsteuerung_Heizung_aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 HK1-Zirkulationspumpe on
setstate vitoconnect 2021-11-23 21:37:18 HK1-aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 HK2-Heizkurve-Niveau 0
setstate vitoconnect 2021-11-23 21:37:18 HK2-Heizkurve-Steigung 0.6
setstate vitoconnect 2021-11-23 21:37:18 HK3-Heizkurve-Niveau 0
setstate vitoconnect 2021-11-23 21:37:18 HK3-Heizkurve-Steigung 0.6
setstate vitoconnect 2021-11-23 21:37:18 Kessel_Common_Supply notConnected
setstate vitoconnect 2021-11-23 21:37:18 Kessel_Common_Supply_Temperatur/Einheit celsius
setstate vitoconnect 2021-11-23 21:37:18 Kessel_Seriennummer xxxxxxxxxx
setstate vitoconnect 2021-11-23 21:37:18 Mehrfamilenhaus_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 Urlaub_Ende
setstate vitoconnect 2021-11-23 21:37:18 Urlaub_Start
setstate vitoconnect 2021-11-23 21:37:18 Urlaub_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 WW-Aufladung 0
setstate vitoconnect 2021-11-23 21:37:18 WW-Haupttemperatur 35
setstate vitoconnect 2021-11-23 21:37:18 WW-Hysterese 5
setstate vitoconnect 2021-11-23 21:37:18 WW-Isttemperatur 45.4
setstate vitoconnect 2021-11-23 21:37:18 WW-Isttemperatur/Einheit celsius
setstate vitoconnect 2021-11-23 21:37:18 WW-Sensoren_Auslauf_Status notConnected
setstate vitoconnect 2021-11-23 21:37:18 WW-Sensoren_Auslauf_Wert/Einheit celsius
setstate vitoconnect 2021-11-23 21:37:18 WW-Status on
setstate vitoconnect 2021-11-23 21:37:18 WW-Temperatur_2 48
setstate vitoconnect 2021-11-23 21:37:18 WW-Temperatur_aktiv connected
setstate vitoconnect 2021-11-23 21:37:18 WW-Zeitplan {"sun":[{"position":0,"end":"14:00","mode":"temp-2","start":"11:00"},{"position":1,"end":"24:00","mode":"normal","start":"14:00"},{"end":"05:30","position":2,"mode":"normal","start":"00:00"},{"start":"05:30","mode":"temp-2","position":3,"end":"07:00"},{"end":"11:00","position":4,"mode":"normal","start":"07:00"}],"tue":[{"mode":"temp-2","start":"11:00","position":0,"end":"14:00"},{"end":"24:00","position":1,"mode":"normal","start":"14:00"},{"mode":"normal","start":"00:00","end":"11:00","position":2}],"thu":[{"end":"14:00","position":0,"mode":"temp-2","start":"11:00"},{"start":"14:00","mode":"normal","position":1,"end":"24:00"},{"mode":"normal","start":"00:00","end":"11:00","position":2}],"sat":[{"start":"11:00","mode":"temp-2","position":0,"end":"14:00"},{"mode":"normal","start":"14:00","end":"24:00","position":1},{"position":2,"end":"05:30","mode":"normal","start":"00:00"},{"end":"07:00","position":3,"start":"05:30","mode":"temp-2"},{"start":"07:00","mode":"normal","position":4,"end":"11:00"}],"wed":[{"mode":"temp-2","start":"11:00","end":"14:00","position":0},{"mode":"normal","start":"14:00","position":1,"end":"24:00"},{"position":2,"end":"11:00","start":"00:00","mode":"normal"}],"mon":[{"mode":"temp-2","start":"11:00","end":"14:00","position":0},{"mode":"normal","start":"14:00","end":"24:00","position":1},{"end":"05:30","position":2,"mode":"normal","start":"00:00"},{"mode":"temp-2","start":"05:30","end":"07:00","position":3},{"start":"07:00","mode":"normal","end":"11:00","position":4}],"fri":[{"position":0,"end":"14:00","mode":"temp-2","start":"11:00"},{"end":"24:00","position":1,"mode":"normal","start":"14:00"},{"start":"00:00","mode":"normal","end":"05:30","position":2},{"mode":"temp-2","start":"05:30","position":3,"end":"07:00"},{"position":4,"end":"11:00","start":"07:00","mode":"normal"}]}
setstate vitoconnect 2021-11-23 21:37:18 WW-Zirkulationspumpe_Status off
setstate vitoconnect 2021-11-23 21:37:18 WW-Zirkulationspumpe_Zeitplan {"tue":[{"position":0,"end":"06:40","start":"06:30","mode":"5/10-cycles"},{"position":1,"end":"12:10","start":"12:00","mode":"5/10-cycles"},{"position":2,"end":"17:10","start":"17:00","mode":"5/10-cycles"},{"position":3,"end":"08:10","mode":"5/10-cycles","start":"08:00"}],"sun":[{"mode":"5/10-cycles","start":"06:30","end":"06:40","position":0},{"mode":"5/10-cycles","start":"12:00","end":"12:10","position":1},{"end":"17:10","position":2,"start":"17:00","mode":"5/10-cycles"},{"mode":"5/10-cycles","start":"08:00","end":"08:10","position":3}],"thu":[{"end":"06:40","position":0,"mode":"5/10-cycles","start":"06:30"},{"start":"12:00","mode":"5/10-cycles","end":"12:10","position":1},{"end":"17:10","position":2,"mode":"5/10-cycles","start":"17:00"},{"position":3,"end":"08:10","mode":"5/10-cycles","start":"08:00"}],"sat":[{"position":0,"end":"06:40","start":"06:30","mode":"5/10-cycles"},{"end":"12:10","position":1,"mode":"5/10-cycles","start":"12:00"},{"position":2,"end":"17:10","mode":"5/10-cycles","start":"17:00"},{"mode":"5/10-cycles","start":"08:00","position":3,"end":"08:10"}],"mon":[{"start":"06:30","mode":"5/10-cycles","position":0,"end":"06:40"},{"end":"12:10","position":1,"start":"12:00","mode":"5/10-cycles"},{"mode":"5/10-cycles","start":"17:00","position":2,"end":"17:10"},{"start":"08:00","mode":"5/10-cycles","end":"08:10","position":3}],"wed":[{"mode":"5/10-cycles","start":"06:30","end":"06:40","position":0},{"end":"12:10","position":1,"mode":"5/10-cycles","start":"12:00"},{"mode":"5/10-cycles","start":"17:00","end":"17:10","position":2},{"mode":"5/10-cycles","start":"08:00","end":"08:10","position":3}],"fri":[{"end":"06:40","position":0,"mode":"5/10-cycles","start":"06:30"},{"position":1,"end":"12:10","mode":"5/10-cycles","start":"12:00"},{"start":"17:00","mode":"5/10-cycles","end":"17:10","position":2},{"mode":"5/10-cycles","start":"08:00","end":"08:10","position":3}]}
setstate vitoconnect 2021-11-23 21:37:18 WW-Zirkulationspumpe_Zeitsteuerung_aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 WW-Zirkulationspumpe_primaer off
setstate vitoconnect 2021-11-23 21:37:18 WW-aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 WW-einmaliges_Aufladen 0
setstate vitoconnect 2021-11-23 21:37:18 WW-zeitgesteuert_aktiv 1
setstate vitoconnect 2021-11-23 21:35:15 device xxxxx
setstate vitoconnect 2021-11-23 21:35:15 gw {"data“:xxxxxx
setstate vitoconnect 2021-11-23 21:35:16 gw_features xxxxxx
setstate vitoconnect 2021-11-23 21:37:18 heating.buffer.sensors.temperature.main.status notConnected
setstate vitoconnect 2021-11-23 21:37:18 heating.buffer.sensors.temperature.main.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.buffer.sensors.temperature.top.status notConnected
setstate vitoconnect 2021-11-23 21:37:18 heating.buffer.sensors.temperature.top.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.heating.roomInfluenceFactor.value 10
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.operating.modes.cooling.active 0
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.temperature.levels.max 47
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.temperature.levels.maxUnit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.temperature.levels.min 15
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.temperature.levels.minUnit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.temperature.value 29.1
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.1.heating.roomInfluenceFactor.value 10
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.1.temperature.value 0
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.2.heating.roomInfluenceFactor.value 10
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.2.temperature.value 0
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.active 0
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.cooling.week.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.cooling.week.unit kilowattHour
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.cooling.week.value 0
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.dhw.week.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.dhw.week.unit kilowattHour
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.dhw.week.value 13.7
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.heating.week.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.heating.week.unit kilowattHour
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.heating.week.value 89.1
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.phase off
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hours 670.9
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hoursLoadClassFive 22
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hoursLoadClassFour 147
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hoursLoadClassOne 51
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hoursLoadClassThree 263
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hoursLoadClassTwo 140
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.starts 3432
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.enabled 0
setstate vitoconnect 2021-11-23 21:37:18 heating.configuration.secondaryHeatGenerator.modeOnError.mode reduced
setstate vitoconnect 2021-11-23 21:37:18 heating.dhw.sensors.temperature.hotWaterStorage.bottom.status notConnected
setstate vitoconnect 2021-11-23 21:37:18 heating.dhw.sensors.temperature.hotWaterStorage.bottom.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.dhw.sensors.temperature.hotWaterStorage.top.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.dhw.sensors.temperature.hotWaterStorage.top.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.dhw.sensors.temperature.hotWaterStorage.top.value 45.4
setstate vitoconnect 2021-11-23 21:37:18 heating.heatingRod.runtime.levelOne 949099
setstate vitoconnect 2021-11-23 21:37:18 heating.heatingRod.runtime.levelTwo 781188
setstate vitoconnect 2021-11-23 21:37:18 heating.heatingRod.runtime.unit seconds
setstate vitoconnect 2021-11-23 21:37:18 heating.primaryCircuit.sensors.temperature.return.status notConnected
setstate vitoconnect 2021-11-23 21:37:18 heating.primaryCircuit.sensors.temperature.return.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.primaryCircuit.sensors.temperature.supply.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.primaryCircuit.sensors.temperature.supply.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.primaryCircuit.sensors.temperature.supply.value 5.2
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.return.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.return.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.return.value 26.9
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.supply.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.supply.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.supply.value 27
setstate vitoconnect 2021-11-23 21:37:18 heating.sensors.temperature.return.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.sensors.temperature.return.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.sensors.temperature.return.value 26.9
setstate vitoconnect 2021-11-23 21:35:15 installation xxxxxxxxxx
setstate vitoconnect 2021-11-23 21:35:16 installation_features {"data":[]}
setstate vitoconnect 2021-11-23 21:37:18 state last update: 2021-11-23 21:37:18
setstate vitoconnect 2021-11-23 21:37:18 ventilation.active 1
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.modes.active.value ventilation
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.modes.standard.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.modes.standby.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.modes.ventilation.active 1
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.active.value levelTwo
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.comfort.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.eco.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.holiday.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.holiday.end
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.holiday.start
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelFour.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelFour.unit cubicMeter/hour
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelFour.volumeFlow 215
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelOne.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelOne.unit cubicMeter/hour
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelOne.volumeFlow 120
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelThree.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelThree.unit cubicMeter/hour
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelThree.volumeFlow 170
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelTwo.active 1
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelTwo.unit cubicMeter/hour
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelTwo.volumeFlow 120
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.standby.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.standby.unit cubicMeter/hour
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.standby.volumeFlow 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.schedule.active 1
setstate vitoconnect 2021-11-23 21:37:18 ventilation.schedule.entries {"sat":[{"end":"14:00","position":0,"mode":"levelThree","start":"06:00"},{"start":"00:00","mode":"levelTwo","position":1,"end":"06:00"},{"end":"24:00","position":2,"start":"20:00","mode":"levelTwo"},{"end":"20:00","position":3,"mode":"levelFour","start":"14:00"}],"tue":[{"end":"20:00","position":0,"mode":"levelThree","start":"06:00"},{"mode":"levelTwo","start":"00:00","position":1,"end":"06:00"},{"mode":"levelTwo","start":"20:00","position":2,"end":"24:00"}],"sun":[{"end":"20:00","position":0,"start":"06:00","mode":"levelThree"},{"end":"06:00","position":1,"start":"00:00","mode":"levelTwo"},{"position":2,"end":"24:00","mode":"levelTwo","start":"20:00"}],"thu":[{"end":"20:00","position":0,"mode":"levelThree","start":"06:00"},{"end":"06:00","position":1,"start":"00:00","mode":"levelTwo"},{"end":"24:00","position":2,"mode":"levelTwo","start":"20:00"}],"fri":[{"mode":"levelThree","start":"06:00","end":"20:00","position":0},{"mode":"levelTwo","start":"00:00","end":"06:00","position":1},{"mode":"levelTwo","start":"20:00","end":"24:00","position":2}],"mon":[{"mode":"levelThree","start":"06:00","position":0,"end":"20:00"},{"mode":"levelTwo","start":"00:00","position":1,"end":"06:00"},{"position":2,"end":"24:00","start":"20:00","mode":"levelTwo"}],"wed":[{"start":"06:00","mode":"levelThree","end":"20:00","position":0},{"mode":"levelTwo","start":"00:00","end":"06:00","position":1},{"position":2,"end":"24:00","start":"20:00","mode":"levelTwo"}]}
Offline andreas13
« Antwort #738 am: 29 November 2021, 09:28:58 »
Hallo marof,
ich seh gerade, dass ich das Feature nach der Umstellung noch nicht implementiert habe :-( Vielleicht schaffe ich es zwischen den Jahren. Ich melde mich dann nochmal.
Andreas
Hi hier die Daten.
Danke im Voraus.
noch: IT
Offline xls
  • New Member
« Antwort #739 am: 30 November 2021, 08:15:05 »
Seit heute Nacht startet meine Wärmepumpe immer wieder neu.
Ich habe erstmal die Verbindung Heizung <-> Vitoconnect getrennt. Jetzt geht es wieder.
Irgendwie scheint die Heizung immer wieder den Befehl zum Neustart zu bekommen.
Keine Ahnung ob der Befehl aus dem Modul, oder direkt von Viessmann kommt.
Offline andreas13
« Antwort #740 am: 30 November 2021, 21:56:02 »
Das Modul sendet garantiert keine Befehle an Deine Heizung. Ein Befehl zum Neustart gibt es in der API nicht. Das muss eine andere Ursache haben.
noch: IT
Offline jemu75
  • Sr. Member
    • FHEM App
« Antwort #741 am: 03 Dezember 2021, 21:34:48 »
ich bekomme direkt nach dem Neustart von FHEM folgende Fehlermeldungen.
2021.12.03 21:23:53 1: PERL WARNING: "my" variable $param masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1858, <$fh> line 2135.
2021.12.03 21:23:53 1: PERL WARNING: "my" variable $err masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1865, <$fh> line 2135.
2021.12.03 21:23:53 1: PERL WARNING: "my" variable $msg masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1865, <$fh> line 2135.
2021.12.03 21:23:53 1: PERL WARNING: "my" variable $decode_json masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1866, <$fh> line 2135.
2021.12.03 21:23:53 3: vitoconnect - Passwort war bereits gespeichert
2021.12.03 21:24:04 1: PERL WARNING: Argument "" isn't numeric in numeric eq (==) at ./FHEM/98_vitoconnect.pm line 1755.
2021.12.03 21:24:05 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/98_vitoconnect.pm line 1849.
2021.12.03 21:24:05 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/98_vitoconnect.pm line 1867.
Woran kann das liegen?
« Letzte Änderung: 03 Dezember 2021, 21:37:48 von jemu75 »
Offline andreas13
« Antwort #742 am: 12 Dezember 2021, 06:19:28 »
das liegt daran, dass ich ein lausiger Programmierer bin. Das sind aber keine Fehlermeldungen, sondern nur Warnungen. Das Modul sollte aber trotzdem funktionieren. Wenn sonst alles ok ist, kannst Du das einfach ignorieren.
Andreas
noch: IT
Offline matthewk
  • Newbie
« Antwort #743 am: 14 Dezember 2021, 20:23:34 »
Hallo! Ich hatte schon immer das Problem, dass das Reading "heating.controller.serial.value" Probleme machte. Es produzierte einen Absturz wegen "wide character" beim Speichern in die Datenbank per LogDB. Dies Problem konnte ich das Attribut "DbLogExclude" lösen. Aber seit einiger Zeit ist dieser Parameter mit einem sehr großen Wert gefüllt, der aus unzähligen Wiederholungen von "Ã" besteht. Der Wert ist so groß, dass das Aufrufen des Vitoconnect Devices im FHEM das Webinterface erstmal für die nächsten paar Minuten lahmlegt. Ich vermute mal, ursächlich kann nur Viessmann das Problem in Ordnung bringen, aber gibt es eventuell eine Möglichkeit, die Anzeige des Readings bereits im Webinterface zu verhindern, bzw. das Reading mit einem vordefinierten Wert zu ersetzen?
Danke!
Offline CQuadrat
  • Sr. Member
« Antwort #744 am: 17 Dezember 2021, 10:02:31 »
Hallo Zusammen,
hat außer mir auch jemand Probleme mit der Verbindung zum Kommunikationsmodul?
Seit heute morgen bekomme ich keine Verbindung mehr; auch nicht mit der Original Viessmann-App. Komischerweise trat der Fehler auf, nachdem meine FritzBox heute Nacht eine neue IP vom Provider zugewiesen bekommen hat. Neustart diverser Geräte hat nichts gebracht.
Auf der Viessmann-Seite kann ich leider auch nichts finden
Danke und Gruß
Christoph
FHEM auf Mini-ITX-Server mit Intel Quad-Core J1900:
+ HM: HM-LAN, HM-USB, HM-MOD-UART mit div. HM-Komponenten
+ RFXtrx: Funkwetterstation Bresser mit ext. Thermometer, Regenmesser und Windmesser
+ TUL (KNX-Anbindung), KM271 (per ser2net), SONOS (div. Gimmicks), OneWire, Hue
Offline plin
  • Sr. Member
    • FHEM-Landschaft von plin
« Antwort #745 am: 17 Dezember 2021, 11:11:28 »
Meine ViCare-App hat auch keine Verbindung. Das VitoConnect-Modul blinkt rot (auch nach einem Restart).
FHEM1 (Main) Raspi3b mit CUL, Homematic, SDUINO 433/OOK, zentrale Steuerung
FHEM2 (Keller) x86 mit CUL/hmland, IP-basierte Module
FHEM3 (Erdgeschoss) Raspi2 mit SDUINO 868/GFSK
FHEM4 (Hausanschlussraum), USV und OBIS-Modul
FHEM5 (Docker) mit FHEM2FHEM, InfluxDB
Offline CQuadrat
  • Sr. Member
« Antwort #746 am: 17 Dezember 2021, 11:21:13 »
Danke für den Hinweis. Dann vermute ich den Fehler mal bei Viessmann und warte mal noch ab.
Ich hasse Cloud-Lösungen :-\ Leider ging es bei der Heizung nicht ohne.  >:(
Offline uron
« Antwort #747 am: 17 Dezember 2021, 11:56:37 »
Kann ich auch bestätigen, bin Gott sei Dank nicht der Einzige und warte mal ab!
Raspberry Pi  fhem  FHEMobile  CUL  FS20-, HM-, Intertechno-, AVM- und Shelly-Aktoren, Vitoconnect 100, Vitodens 300-W, Typ WB3D, Optolink, FTUI auf iPad, FTUI auf iPhone, Stromzähler von Powerfox
Offline uron
« Antwort #748 am: 17 Dezember 2021, 17:31:29 »
Seit heute, 12:55 Uhr, läuft das Kommunikationsmodul bei mir wieder rund!  :)
Offline andreas13
« Antwort #749 am: 21 Dezember 2021, 07:53:57 »
in der Tat ist das ein Problem, dass nur Viessmann ursächlich lösen kann. Als workaround kannst du Dir mit "inform" und "setreading" etwas basteln, dass das Reading auf einen vordefinierter Wert setzt,
Andreas
Danke!
noch: IT
