59_Weather, DarkSky und OpenWeatherMap API Bugfixes
Begonnen von CoolTux, 13 Januar 2019, 21:22:31
KernSani
Hab's mir von Github geholt... scheint zu funktionieren. Danke!
Nestor
With the new module I get reports from Freezemon in the log:
2019.01.14 16:04:17 1: [Freezemon] freezemon: possible freeze starting at 16:04:16, delay is 1.208 possibly caused by: tmr-Weather_GetUpdate(Weather_Ganshoren) tmr-ModbusLD_GetUpdate(N/A)
2019.01.14 19:24:44 1: [Freezemon] freezemon: possible freeze starting at 19:24:43, delay is 1.176 possibly caused by: tmr-Weather_GetUpdate(Weather_Ganshoren) tmr-ModbusLD_GetUpdate(N/A)
2019.01.14 20:04:49 1: [Freezemon] freezemon: possible freeze starting at 20:04:48, delay is 1.16 possibly caused by: tmr-Modbus_ProcessRequestQueue(N/A) tmr-Weather_GetUpdate(Weather_Ganshoren)
2019.01.14 23:05:10 1: [Freezemon] freezemon: possible freeze starting at 23:05:09, delay is 1.331 possibly caused by: tmr-Weather_GetUpdate(Weather_Ganshoren)
2019.01.15 01:05:25 1: [Freezemon] freezemon: possible freeze starting at 01:05:24, delay is 1.637 possibly caused by: tmr-Modbus_ProcessRequestQueue(N/A) tmr-Weather_GetUpdate(Weather_Ganshoren)
2019.01.15 12:04:05 1: [Freezemon] freezemon: possible freeze starting at 12:04:04, delay is 1.422 possibly caused by: tmr-Weather_GetUpdate(Weather_Ganshoren)
2019.01.15 18:04:46 1: [Freezemon] freezemon: possible freeze starting at 18:04:45, delay is 1.354 possibly caused by: tmr-Weather_GetUpdate(Weather_Ganshoren)
2019.01.15 19:04:53 1: [Freezemon] freezemon: possible freeze starting at 19:04:52, delay is 1.251 possibly caused by: tmr-Weather_GetUpdate(Weather_Ganshoren) tmr-ModbusLD_GetUpdate(N/A)
2019.01.15 19:14:55 1: [Freezemon] freezemon: possible freeze starting at 19:14:54, delay is 1.311 possibly caused by: tmr-Weather_GetUpdate(Weather_Ganshoren)
2019.01.16 01:05:37 1: [Freezemon] freezemon: possible freeze starting at 01:05:36, delay is 1.541 possibly caused by: tmr-Modbus_ProcessRequestQueue(N/A) tmr-Weather_GetUpdate(Weather_Ganshoren)
2019.01.16 02:05:44 1: [Freezemon] freezemon: possible freeze starting at 02:05:43, delay is 1.347 possibly caused by: tmr-ModbusLD_GetUpdate(N/A) tmr-Weather_GetUpdate(Weather_Ganshoren)
2019.01.16 04:05:59 1: [Freezemon] freezemon: possible freeze starting at 04:05:58, delay is 1.204 possibly caused by: tmr-Modbus_ProcessRequestQueue(N/A) tmr-Weather_GetUpdate(Weather_Ganshoren)
2019.01.16 05:06:06 1: [Freezemon] freezemon: possible freeze starting at 05:06:05, delay is 1.414 possibly caused by: tmr-Weather_GetUpdate(Weather_Ganshoren) tmr-Modbus_ProcessRequestQueue(N/A)
2019.01.16 07:06:21 1: [Freezemon] freezemon: possible freeze starting at 07:06:20, delay is 1.824 possibly caused by: tmr-Weather_GetUpdate(Weather_Ganshoren) tmr-Modbus_ProcessRequestQueue(N/A) tmr-Modbus_ResponseTimeout(N/A)
Weather definition:
defmod Weather_Ganshoren Weather apikey=xxx interval=600
attr Weather_Ganshoren event-on-change-reading .*
attr Weather_Ganshoren group Weather
attr Weather_Ganshoren icon weather_station
attr Weather_Ganshoren room HVAC,System->Fhem
attr Weather_Ganshoren timestamp-on-change-reading .*
I timed an API request with curl and it takes indeed around 1 second.
time curl -o /dev/null https://api.darksky.net/forecast/xxx/37.8267,-122.4233
real 0m0.889s
user 0m0.043s
sys 0m0.021s
Can I just ignore the Freezemon logging for Weather module since the HTTP requests should be non-blocking?
KernSani
We should discuss that in the Freezemon Thread - you can put "Weather_Ganshoren" on the whitelist (see freezemon documentation)
moonsorrox
Warum sind eigentlich manche Tage in Englisch und manche in Deutsch.
Hier mal ein abgekürztes list:
   API        DarkSkyAPI
   APIKEY     c40bb79eba3b2a8b04d4f37c2744a12d
   APIOPTIONS cachemaxage:600
   CFGFN      ./FHEM/Wetter.cfg
   DEF        API=DarkSkyAPI,cachemaxage:600 apikey=c40bb79eba3b2a8b------------------368,9.624981 interval=3600 lang=de
   INTERVAL   3600
   LANG       de
   LOCATION   52.500368,9.624981
   NAME       MeinWetter
   NOTIFYDEV  global
   NR         2017
   NTFY_ORDER 50-MeinWetter
   STATE      T: 5 °C F: 82 % W: 21 km/h P: 1000 hPa
   TYPE       Weather
     2019-01-17 11:33:16   apiMaintainer   Leon Gaultier (<a href=https://forum.fhem.de/index.php?action=profile;u=13684>CoolTux</a>)
     2019-01-17 11:33:16   apparentTemperature 1
     2019-01-17 11:33:16   cloudCover      45
     2019-01-17 11:33:16   code            30
     2019-01-17 11:33:16   condition       Leicht bewölkt
     2019-01-17 11:33:16   current_date_time Thu, 17 Jan 2019 11:33
     2019-01-17 11:33:16   dewPoint        2
     2019-01-17 11:33:16   fc1_apparentTempHigh 1
     2019-01-17 11:33:16   fc1_apparentTempHighTime Thu, 17 Jan 2019 10:00
     2019-01-17 11:33:16   fc1_apparentTempLow -5
     2019-01-17 11:33:16   fc1_apparentTempLowTime Fri, 18 Jan 2019 07:00
     2019-01-15 12:39:35   fc1_apparenttempMax 3
     2019-01-15 12:39:35   fc1_apparenttempMaxTime Di, 15 Jan 2019 21:00
     2019-01-15 12:39:35   fc1_apparenttempMin -2
     2019-01-15 12:39:35   fc1_apparenttempMinTime Di, 15 Jan 2019 03:00
     2019-01-17 11:33:16   fc1_cloudCover  72
     2019-01-17 11:33:16   fc1_code        11
     2019-01-17 11:33:16   fc1_condition   Regen von nachmittags bis abends.
     2019-01-17 11:33:16   fc1_day_of_week Thu
     2019-01-17 11:33:16   fc1_dewPoint    2
     2019-01-17 11:33:16   fc1_high_c      5
     2019-01-17 11:33:16   fc1_humidity    82
     2019-01-17 11:33:16   fc1_icon        chance_of_rain
     2019-01-17 11:33:16   fc1_iconAPI     rain
     2019-01-17 11:33:16   fc1_low_c       -1
     2019-01-17 11:33:16   fc1_moonPhase   0.36
     2019-01-17 11:33:16   fc1_ozone       343.26
     2019-01-17 11:33:16   fc1_precipIntensity 0.3251
     2019-01-17 11:33:16   fc1_precipIntensityMax 1.8237
     2019-01-17 11:33:16   fc1_precipIntensityMaxTime Thu, 17 Jan 2019 16:00
     2019-01-17 11:33:16   fc1_precipProbability 0.84
     2019-01-17 11:33:16   fc1_precipType  rain
     2019-01-17 11:33:16   fc1_pressure    1000
     2019-01-17 11:33:16   fc1_pubDate     Thu, 17 Jan 2019 00:00
     2019-01-17 11:33:16   fc1_sunriseTime Thu, 17 Jan 2019 08:24
     2019-01-17 11:33:16   fc1_sunsetTime  Thu, 17 Jan 2019 16:40
     2019-01-17 11:33:16   fc1_tempHigh    5
     2019-01-17 11:33:16   fc1_tempHighTime Thu, 17 Jan 2019 14:00
     2019-01-17 11:33:16   fc1_tempLow     -1
     2019-01-17 11:33:16   fc1_tempLowTime Fri, 18 Jan 2019 06:00
     2019-01-15 12:39:35   fc1_tempMax     7
     2019-01-15 12:39:35   fc1_tempMaxTime Di, 15 Jan 2019 21:00
     2019-01-15 12:39:35   fc1_tempMin     2
     2019-01-15 12:39:35   fc1_tempMinTime Di, 15 Jan 2019 03:00
     2019-01-17 11:33:16   fc1_uvIndex     0
     2019-01-17 11:33:16   fc1_uvIndexTime Thu, 17 Jan 2019 00:00
     2019-01-17 11:33:16   fc1_visibility  10
     2019-01-17 11:33:16   fc1_wind        21
     2019-01-17 11:33:16   fc1_windGust    54
     2019-01-17 11:33:16   fc1_windGustTime Thu, 17 Jan 2019 00:00
     2019-01-17 11:33:16   fc1_wind_condition Wind: WSW 21 km/h
     2019-01-17 11:33:16   fc1_wind_direction 253
     2019-01-17 11:33:16   fc1_wind_speed  21
     2019-01-17 11:33:16   fc2_apparentTempHigh 0
     2019-01-17 11:33:16   fc2_apparentTempHighTime Fri, 18 Jan 2019 16:00
     2019-01-17 11:33:16   fc2_apparentTempLow -3
     2019-01-17 11:33:16   fc2_apparentTempLowTime Sat, 19 Jan 2019 08:00
     2019-01-15 12:39:35   fc2_apparenttempMax 3
     2019-01-15 12:39:35   fc2_apparenttempMaxTime Mi, 16 Jan 2019 07:00
     2019-01-15 12:39:35   fc2_apparenttempMin 1
     2019-01-15 12:39:35   fc2_apparenttempMinTime Mi, 16 Jan 2019 23:00
     2019-01-17 11:33:16   fc2_cloudCover  20
     2019-01-17 11:33:16   fc2_code        29
     2019-01-17 11:33:16   fc2_condition   Abends leicht bewölkt.
     2019-01-17 11:33:16   fc2_day_of_week Fri
     2019-01-17 11:33:16   fc2_dewPoint    -1
     2019-01-17 11:33:16   fc2_high_c      3
     2019-01-17 11:33:16   fc2_humidity    81
     2019-01-17 11:33:16   fc2_icon        partly_cloudy_night
     2019-01-17 11:33:16   fc2_iconAPI     partly-cloudy-night
     2019-01-17 11:33:16   fc2_low_c       -1
     2019-01-17 11:33:16   fc2_moonPhase   0.4
     2019-01-17 11:33:16   fc2_ozone       351.32
     2019-01-17 11:33:16   fc2_precipIntensity 0.0457
     2019-01-17 11:33:16   fc2_precipIntensityMax 0.3632
     2019-01-17 11:33:16   fc2_precipIntensityMaxTime Fri, 18 Jan 2019 10:00
     2019-01-17 11:33:16   fc2_precipProbability 0.35
     2019-01-17 11:33:16   fc2_precipType  snow
     2019-01-17 11:33:16   fc2_pressure    1017
     2019-01-17 11:33:16   fc2_pubDate     Fri, 18 Jan 2019 00:00
     2019-01-17 11:33:16   fc2_sunriseTime Fri, 18 Jan 2019 08:23
     2019-01-17 11:33:16   fc2_sunsetTime  Fri, 18 Jan 2019 16:42
     2019-01-17 11:33:16   fc2_tempHigh    3
     2019-01-17 11:33:16   fc2_tempHighTime Fri, 18 Jan 2019 15:00
     2019-01-17 11:33:16   fc2_tempLow     -1
     2019-01-17 11:33:16   fc2_tempLowTime Sat, 19 Jan 2019 08:00
     2019-01-15 12:39:35   fc2_tempMax     7
     2019-01-15 12:39:35   fc2_tempMaxTime Mi, 16 Jan 2019 00:00
     2019-01-15 12:39:35   fc2_tempMin     5
     2019-01-15 12:39:35   fc2_tempMinTime Mi, 16 Jan 2019 23:00
     2019-01-17 11:33:16   fc2_uvIndex     1
     2019-01-17 11:33:16   fc2_uvIndexTime Fri, 18 Jan 2019 12:00
     2019-01-17 11:33:16   fc2_visibility  16
     2019-01-17 11:33:16   fc2_wind        10
     2019-01-17 11:33:16   fc2_windGust    35
     2019-01-17 11:33:16   fc2_windGustTime Fri, 18 Jan 2019 00:00
     2019-01-17 11:33:16   fc2_wind_condition Wind: W 10 km/h
     2019-01-17 11:33:16   fc2_wind_direction 277
     2019-01-17 11:33:16   fc2_wind_speed  10
     2019-01-17 11:33:16   fc3_apparentTempHigh 0
     2019-01-17 11:33:16   fc3_apparentTempHighTime Sat, 19 Jan 2019 15:00
     2019-01-17 11:33:16   fc3_apparentTempLow -7
     2019-01-17 11:33:16   fc3_apparentTempLowTime Sun, 20 Jan 2019 08:00
     2019-01-15 12:39:35   fc3_apparenttempMax 1
     2019-01-15 12:39:35   fc3_apparenttempMaxTime Do, 17 Jan 2019 04:00
     2019-01-15 12:39:35   fc3_apparenttempMin -2
     2019-01-15 12:39:35   fc3_apparenttempMinTime Do, 17 Jan 2019 19:00
     2019-01-17 11:33:16   fc3_cloudCover  45
     2019-01-17 11:33:16   fc3_code        30
     2019-01-17 11:33:16   fc3_condition   Leicht bewölkt bis Nachmittag.
     2019-01-17 11:33:16   fc3_day_of_week Sat
     2019-01-17 11:33:16   fc3_dewPoint    -4
     2019-01-17 11:33:16   fc3_high_c      2
     2019-01-17 11:33:16   fc3_humidity    73
     2019-01-17 11:33:16   fc3_icon        partly_cloudy
     2019-01-17 11:33:16   fc3_iconAPI     partly-cloudy-day
     2019-01-17 11:33:16   fc3_low_c       -2
     2019-01-17 11:33:16   fc3_moonPhase   0.43
     2019-01-17 11:33:16   fc3_ozone       371.55
     2019-01-17 11:33:16   fc3_precipIntensity 0.0025
     2019-01-17 11:33:16   fc3_precipIntensityMax 0.0051
     2019-01-17 11:33:16   fc3_precipIntensityMaxTime Sat, 19 Jan 2019 10:00
     2019-01-17 11:33:16   fc3_precipProbability 0.09
     2019-01-17 11:33:16   fc3_precipType  snow
     2019-01-17 11:33:16   fc3_pressure    1019
     2019-01-17 11:33:16   fc3_pubDate     Sat, 19 Jan 2019 00:00
     2019-01-17 11:33:16   fc3_sunriseTime Sat, 19 Jan 2019 08:22
     2019-01-17 11:33:16   fc3_sunsetTime  Sat, 19 Jan 2019 16:44
     2019-01-17 11:33:16   fc3_tempHigh    2
     2019-01-17 11:33:16   fc3_tempHighTime Sat, 19 Jan 2019 14:00
     2019-01-17 11:33:16   fc3_tempLow     -2
     2019-01-17 11:33:16   fc3_tempLowTime Sun, 20 Jan 2019 08:00
     2019-01-15 12:39:35   fc3_tempMax     5
     2019-01-15 12:39:35   fc3_tempMaxTime Do, 17 Jan 2019 04:00
     2019-01-15 12:39:35   fc3_tempMin     3
     2019-01-15 12:39:35   fc3_tempMinTime Do, 17 Jan 2019 23:00
     2019-01-17 11:33:16   fc3_uvIndex     0
     2019-01-17 11:33:16   fc3_uvIndexTime Sat, 19 Jan 2019 00:00
     2019-01-17 11:33:16   fc3_visibility  16
     2019-01-17 11:33:16   fc3_wind        6
     2019-01-17 11:33:16   fc3_windGust    18
     2019-01-17 11:33:16   fc3_windGustTime Sat, 19 Jan 2019 20:00
     2019-01-17 11:33:16   fc3_wind_condition Wind: SO 6 km/h
     2019-01-17 11:33:16   fc3_wind_direction 141
     2019-01-17 11:33:16   fc3_wind_speed  6
     2019-01-17 11:33:16   fc4_apparentTempHigh -1
     2019-01-17 11:33:16   fc4_apparentTempHighTime Sun, 20 Jan 2019 15:00
     2019-01-17 11:33:16   fc4_apparentTempLow -6
     2019-01-17 11:33:16   fc4_apparentTempLowTime Mon, 21 Jan 2019 08:00
     2019-01-15 12:39:35   fc4_apparenttempMax 1
     2019-01-15 12:39:35   fc4_apparenttempMaxTime Fr, 18 Jan 2019 15:00
     2019-01-15 12:39:35   fc4_apparenttempMin -4
     2019-01-15 12:39:35   fc4_apparenttempMinTime Fr, 18 Jan 2019 09:00
     2019-01-17 11:33:16   fc4_cloudCover  35
     2019-01-17 11:33:16   fc4_code        30
     2019-01-17 11:33:16   fc4_condition   Den ganzen Tag lang leicht bewölkt.
     2019-01-17 11:33:16   fc4_day_of_week Sun
     2019-01-17 11:33:16   fc4_dewPoint    -6
     2019-01-17 11:33:16   fc4_high_c      1
     2019-01-17 11:33:16   fc4_humidity    68
     2019-01-17 11:33:16   fc4_icon        partly_cloudy
     2019-01-17 11:33:16   fc4_iconAPI     partly-cloudy-day
     2019-01-17 11:33:16   fc4_low_c       -2
     2019-01-17 11:33:16   fc4_moonPhase   0.47
     2019-01-17 11:33:16   fc4_ozone       371.9
     2019-01-17 11:33:16   fc4_precipIntensity 0
     2019-01-17 11:33:16   fc4_precipIntensityMax 0.0051
     2019-01-17 11:33:16   fc4_precipIntensityMaxTime Sun, 20 Jan 2019 12:00
     2019-01-17 11:33:16   fc4_precipProbability 0
     2019-01-17 06:21:30   fc4_precipType  snow
     2019-01-17 11:33:16   fc4_pressure    1018
     2019-01-17 11:33:16   fc4_pubDate     Sun, 20 Jan 2019 00:00
     2019-01-17 11:33:16   fc4_sunriseTime Sun, 20 Jan 2019 08:21
     2019-01-17 11:33:16   fc4_sunsetTime  Sun, 20 Jan 2019 16:46
     2019-01-17 11:33:16   fc4_tempHigh    1
     2019-01-17 11:33:16   fc4_tempHighTime Sun, 20 Jan 2019 15:00
     2019-01-17 11:33:16   fc4_tempLow     -2
     2019-01-17 11:33:16   fc4_tempLowTime Mon, 21 Jan 2019 08:00
     2019-01-15 12:39:35   fc4_tempMax     3
     2019-01-15 12:39:35   fc4_tempMaxTime Fr, 18 Jan 2019 00:00
     2019-01-15 12:39:35   fc4_tempMin     0
     2019-01-15 12:39:35   fc4_tempMinTime Fr, 18 Jan 2019 09:00
     2019-01-17 11:33:16   fc4_uvIndex     1
     2019-01-17 11:33:16   fc4_uvIndexTime Sun, 20 Jan 2019 13:00
     2019-01-17 11:33:16   fc4_visibility  16
     2019-01-17 11:33:16   fc4_wind        9
     2019-01-17 11:33:16   fc4_windGust    18
     2019-01-17 11:33:16   fc4_windGustTime Sun, 20 Jan 2019 10:00
     2019-01-17 11:33:16   fc4_wind_condition Wind: OSO 9 km/h
     2019-01-17 11:33:16   fc4_wind_direction 106
     2019-01-17 11:33:16   fc4_wind_speed  9
     2019-01-17 11:33:16   fc5_apparentTempHigh -3
     2019-01-17 11:33:16   fc5_apparentTempHighTime Mon, 21 Jan 2019 16:00
     2019-01-17 11:33:16   fc5_apparentTempLow -5
     2019-01-17 11:33:16   fc5_apparentTempLowTime Tue, 22 Jan 2019 00:00
     2019-01-15 12:39:35   fc5_apparenttempMax 0
     2019-01-15 12:39:35   fc5_apparenttempMaxTime Sa, 19 Jan 2019 15:00
     2019-01-15 12:39:35   fc5_apparenttempMin -5
     2019-01-15 12:39:35   fc5_apparenttempMinTime Sa, 19 Jan 2019 23:00
     2019-01-17 11:33:16   fc5_cloudCover  68
     2019-01-17 11:33:16   fc5_code        30
     2019-01-17 11:33:16   fc5_condition   Überwiegend bewölkt bis abends.
     2019-01-17 11:33:16   fc5_day_of_week Mon
     2019-01-17 11:33:16   fc5_dewPoint    -5
     2019-01-17 11:33:16   fc5_high_c      0
     2019-01-17 11:33:16   fc5_humidity    72
     2019-01-17 11:33:16   fc5_icon        partly_cloudy
     2019-01-17 11:33:16   fc5_iconAPI     partly-cloudy-day
     2019-01-17 11:33:16   fc5_low_c       -3
     2019-01-17 11:33:16   fc5_moonPhase   0.51
     2019-01-17 11:33:16   fc5_ozone       379.09
     2019-01-17 11:33:16   fc5_precipIntensity 0.0025
     2019-01-17 11:33:16   fc5_precipIntensityMax 0.0076
     2019-01-17 11:33:16   fc5_precipIntensityMaxTime Mon, 21 Jan 2019 07:00
     2019-01-17 11:33:16   fc5_precipProbability 0.02
     2019-01-17 11:33:16   fc5_precipType  snow
     2019-01-17 11:33:16   fc5_pressure    1018
     2019-01-17 11:33:16   fc5_pubDate     Mon, 21 Jan 2019 00:00
     2019-01-17 11:33:16   fc5_sunriseTime Mon, 21 Jan 2019 08:19
     2019-01-17 11:33:16   fc5_sunsetTime  Mon, 21 Jan 2019 16:47
     2019-01-17 11:33:16   fc5_tempHigh    0
     2019-01-17 11:33:16   fc5_tempHighTime Mon, 21 Jan 2019 16:00
     2019-01-17 11:33:16   fc5_tempLow     -3
     2019-01-17 11:33:16   fc5_tempLowTime Tue, 22 Jan 2019 01:00
     2019-01-15 12:39:35   fc5_tempMax     2
     2019-01-15 12:39:35   fc5_tempMaxTime Sa, 19 Jan 2019 15:00
     2019-01-15 12:39:35   fc5_tempMin     -1
     2019-01-15 12:39:35   fc5_tempMinTime Sa, 19 Jan 2019 08:00
     2019-01-17 11:33:16   fc5_uvIndex     0
     2019-01-17 11:33:16   fc5_uvIndexTime Mon, 21 Jan 2019 00:00
     2019-01-17 11:33:16   fc5_visibility  16
     2019-01-17 11:33:16   fc5_wind        10
     2019-01-17 11:33:16   fc5_windGust    20
     2019-01-17 11:33:16   fc5_windGustTime Mon, 21 Jan 2019 08:00
     2019-01-17 11:33:16   fc5_wind_condition Wind: OSO 10 km/h
CoolTux
Schau Dir mal Deine Timestamps zu den Readings an.
Am besten mal alle Readings löschen und neu abrufen.
Das TuxNet Wiki:
https://www.cooltux.net
moonsorrox
Ah, OK die sind ja zum Teil veraltet...
Mir ist das gestern schon mal aufgefallen als ein User hier etwas bereitgestellt hatte und dort waren die Readings alle in Deutsch, bei mir gestern waren sie immer noch alle in englisch  :-\
Ich werde mal alle löschen und neu abrufen...! mal schauen was dann da steht.
CoolTux
Das TuxNet Wiki:
moonsorrox
#97
ich habe das mit dem Update mal beobachtet (kurzer Zeitpunkt "interval=30" eingestellt) es gibt readings die er nicht aktualisiert wohl weil die z.B. vom 15.01. 2019 waren..?
Und es gibt readings von heute morgen 17.01. der auch nicht aktualisiert wird. Ansonsten sind die alle aktuell und alle wie du schon sagst in englisch so hatte ich das gestern auch schon beobachtet.
Es bedeutet für mich, dass immer die readings aktualisiert werden die nach der gerade abgerufenen Zeit aktuell sind, oder liege ich da falsch..?
Hier ist einer von heute morgen dabei der auch nicht aktualisiert wird:
fc4_precipIntensityMaxTime  Sun, 20 Jan 2019 12:00  2019-01-17 12:47:56
fc4_precipProbability 0 2019-01-17 12:47:56
fc4_precipType  snow  2019-01-17 06:21:30
CoolTux
Diese Readings sind Ausnahmen
precip*
Hier kann es sein das der neue Forecastdatensatz keine Daten zu diesen Werten enthält. Daher gab es auch bis gestern noch diese Fehlermeldung mit nicht initialisiert blabla.
Eventuell müsste ich da noch mal nachbessern. Zum Beispiel die Readings mit none überschrieben oder so.
Das TuxNet Wiki:
ChrisW
Jetzt erst gesehen das Yahoo nicht mehr geht. Gibt es wo eine anleitung wie ich auf Darksky wechsel ?
Raspberry PI3 mit allem möglichen.
KernSani
https://fhem.de/commandref.html#Weather
Frank_Huber
Nach heutigem Update hab ich beim Start auf der Startseite folgendes:
Messages collected while initializing FHEM:
configfile: Weather_DarkSky: unknown attribute model. Type 'attr Weather_DarkSky ?' for a detailed list.
Weather_OpenWeatherMap: unknown attribute model. Type 'attr Weather_OpenWeatherMap ?' for a detailed list.
Im Log das selbe.
moonsorrox
was mir heute aufgefallen ist das diese 4 Werte bei OpenWeather immer alle gleich sind. Ich habe alle readings durch geschaut.
hier mal eines davon welche ich meine. Habt ihr das auch..?
hfc10_tempHigh -5  2019-01-18 15:37:33
hfc10_tempLow -5  2019-01-18 15:37:33
hfc10_temp_c -5  2019-01-18 15:37:33
hfc10_temperature -5  2019-01-18 15:37:33
CoolTux
Schaue ich mir heute Abend an.
Das TuxNet Wiki:
CoolTux
Im Log das selbe.
Weiß ich Bescheid. Danke Dir.
Das TuxNet Wiki:
