96_SIP --------- CallRegister: Failed with error 110
Begonnen von GreenFHEMfan, 17 Januar 2019, 00:44:52
GreenFHEMfan
ich versuche gerade eine Rufumleitung per SIP Kommando zu schicken!
bekomme beim CALL Aufruf den Fehler CallRegister: Failed with error 110
INTERNALS
AC:        /usr/bin/sox
LPID:      14472
NOTIFYDEV: myTTS
NR:        361
NTFY_ORDER:50-Fritz.SIP
STATE:     initialized
TYPE:      SIP
VERSION:   V1.91 / 31.07.18
READINGS
call:          done
call_attempt:  0
call_state:    invite
call_success:  0
call_time:     0
caller:        fetch
last_error:    CallRegister: Failed with error 110
listen_alive:  no
state:         initialized
Attribute
T2S_Device:
myTTS
audio_converter:
sox
history_file:
./log/50-Fritz.SIP
history_size:
0
sip_call_audio_delay:
1.25
sip_dtmf_loop:
once
sip_dtmf_send:
audio
sip_dtmf_size:
2
sip_elbc:
yes
sip_from:
sip:fhem-server@xxx.xxx.xxx.xxx
sip_ip:
xxx.xxx.xxx.xxx
sip_listen:
wfp
sip_port:
5060
sip_registrar:
xxx.xxx.xxx.xxx
sip_ringtime:
2
sip_user:
fhem-server
verbose:
5
... keine Ahnung wo der Fehler ist im Logfile
logfile
2019.01.17 00:36:29 4: Fritz.SIP, listen process 15831 must be killed befor we start a new call !
2019.01.17 00:36:29 1: Timeout for SIP_ListenStart reached, terminated process 15831
2019.01.17 00:36:29 5: Fritz.SIP, MD5: Hallo Hallo -> e582a54fb94d3a59d219657be5223f5a.mp3
2019.01.17 00:36:29 5: Fritz.SIP, mp3 File file not found in cache
2019.01.17 00:36:29 4: Fritz.SIP, wait_for_t2s file : cache/e582a54fb94d3a59d219657be5223f5a.mp3
2019.01.17 00:36:29 4: Fritz.SIP, new T2S file cache/e582a54fb94d3a59d219657be5223f5a.mp3
2019.01.17 00:36:29 5: Fritz.SIP, /usr/bin/sox cache/e582a54fb94d3a59d219657be5223f5a.mp3 -t raw -r 8000 -c 1 -e a-law cache/e582a54fb94d3a59d219657be5223f5a.alaw 2>&1
2019.01.17 00:36:29 4: Fritz.SIP, audio file cache/e582a54fb94d3a59d219657be5223f5a.alaw found
2019.01.17 00:36:29 4: Fritz.SIP, Fritz.SIP|**611|30|cache/e582a54fb94d3a59d219657be5223f5a.alaw|0
2019.01.17 00:36:29 4: Fritz.SIP, call -> Fritz.SIP|**611|30|cache/e582a54fb94d3a59d219657be5223f5a.alaw|0|0
2019.01.17 00:36:29 5: Fritz.SIP, call has pid 15884
2019.01.17 00:36:30 4: Fritz.SIP[15884], my parent is 12715
2019.01.17 00:36:30 4: Fritz.SIP[15884], trying to use port 5070
2019.01.17 00:37:34 4: Fritz.SIP, CALLDone -> Fritz.SIP|0|CallRegister: Failed with error 110|0
2019.01.17 00:37:34 5: Fritz.SIP, fifo is empty
2019.01.17 00:37:34 4: Fritz.SIP, try restarting listen process after call ends
2019.01.17 00:37:34 4: Fritz.SIP, Listen new PID : 15959
2019.01.17 00:37:34 4: Fritz.SIP[15959], my parent is 12715
2019.01.17 00:37:34 4: Fritz.SIP[15959], trying to use port 5060
2019.01.17 00:38:10 4: Fritz.SIP, listen process 15959 must be killed befor we start a new call !
2019.01.17 00:38:10 1: Timeout for SIP_ListenStart reached, terminated process 15959
2019.01.17 00:38:10 5: Fritz.SIP, MD5: Hallo hallo -> fc6d6baa2c6ea2640f8b7aa36618067e.mp3
2019.01.17 00:38:10 5: Fritz.SIP, mp3 File file not found in cache
2019.01.17 00:38:10 4: Fritz.SIP, wait_for_t2s file : cache/fc6d6baa2c6ea2640f8b7aa36618067e.mp3
2019.01.17 00:38:10 4: Fritz.SIP, new T2S file cache/fc6d6baa2c6ea2640f8b7aa36618067e.mp3
2019.01.17 00:38:10 5: Fritz.SIP, /usr/bin/sox cache/fc6d6baa2c6ea2640f8b7aa36618067e.mp3 -t raw -r 8000 -c 1 -e a-law cache/fc6d6baa2c6ea2640f8b7aa36618067e.alaw 2>&1
2019.01.17 00:38:10 4: Fritz.SIP, audio file cache/fc6d6baa2c6ea2640f8b7aa36618067e.alaw found
2019.01.17 00:38:10 4: Fritz.SIP, Fritz.SIP|<Handynummer>|30|cache/fc6d6baa2c6ea2640f8b7aa36618067e.alaw|0
2019.01.17 00:38:11 4: Fritz.SIP, call -> Fritz.SIP|01725648690|30|cache/fc6d6baa2c6ea2640f8b7aa36618067e.alaw|0|0
2019.01.17 00:38:11 5: Fritz.SIP, call has pid 15984
2019.01.17 00:38:11 4: Fritz.SIP[15984], my parent is 12715
2019.01.17 00:38:11 4: Fritz.SIP[15984], trying to use port 5070
2019.01.17 00:38:22 4: Fritz.SIP, CALL Kill PID : 15984
2019.01.17 00:38:22 1: Timeout for SIP_CALLStart reached, terminated process 15984
2019.01.17 00:38:22 4: Fritz.SIP, Reset Call done
2019.01.17 00:38:22 4: Fritz.SIP, Listen new PID : 15994
2019.01.17 00:38:22 4: Fritz.SIP[15994], my parent is 12715
2019.01.17 00:38:22 4: Fritz.SIP[15994], trying to use port 5060
2019.01.17 00:38:33 4: Fritz.SIP, listen process 15994 must be killed befor we start a new call !
2019.01.17 00:38:33 1: Timeout for SIP_ListenStart reached, terminated process 15994
2019.01.17 00:38:33 5: Fritz.SIP, MD5: Hallo hallo -> fc6d6baa2c6ea2640f8b7aa36618067e.mp3
2019.01.17 00:38:33 5: Fritz.SIP, set call new -> Fritz.SIP call <Handynummer> 30 cache/fc6d6baa2c6ea2640f8b7aa36618067e.mp3
2019.01.17 00:38:33 4: Fritz.SIP, audio file cache/fc6d6baa2c6ea2640f8b7aa36618067e.mp3 found
2019.01.17 00:38:33 5: Fritz.SIP, not converted - using cache/fc6d6baa2c6ea2640f8b7aa36618067e.alaw from cache
2019.01.17 00:38:33 4: Fritz.SIP, Fritz.SIP|01725648690|30|cache/fc6d6baa2c6ea2640f8b7aa36618067e.alaw|0
2019.01.17 00:38:33 4: Fritz.SIP, call -> Fritz.SIP|01725648690|30|cache/fc6d6baa2c6ea2640f8b7aa36618067e.alaw|0|0
2019.01.17 00:38:33 5: Fritz.SIP, call has pid 16011
2019.01.17 00:38:33 4: Fritz.SIP[16011], my parent is 12715
2019.01.17 00:38:33 4: Fritz.SIP[16011], trying to use port 5070
2019.01.17 00:39:37 4: Fritz.SIP, CALLDone -> Fritz.SIP|0|CallRegister: Failed with error 110|0
2019.01.17 00:39:37 5: Fritz.SIP, fifo is empty
2019.01.17 00:39:37 4: Fritz.SIP, try restarting listen process after call ends
2019.01.17 00:39:37 4: Fritz.SIP, Listen new PID : 16187
2019.01.17 00:39:37 4: Fritz.SIP[16187], my parent is 12715
2019.01.17 00:39:37 4: Fritz.SIP[16187], trying to use port 5060
Kann mir jemand helfen?
Rasp 3B+,4 / CUL /  Duofernstick / SIGNALduino (nanocul CC1101 optiboot) / mqtt
Bauhof33
sip_from       Sip:<Benutzername wie Telefoniegerät festgelegt>@fritz.box
sip_user        <myuser> statt Nebenstellennummer
Ich hoffe ich konnte helfen mit neuen Fritzbox OS
Wzut
a. falsches Forum , richtig wäre -> https://forum.fhem.de/index.php/topic,67443.0.html ( da findet sich auch mehrfach die Frage nach Fehler 110 )
b. die xxx sind für uns zur Fehlersuche wenig hilfreich, sensibel ist nur das Passwort aber das wird bei list eh nicht gezeigt.
c. Wiki gelesen ? ->  https://wiki.fhem.de/wiki/SIP-Client
