Autor Thema: 39_gassistant.pm (Google Assistant, Google Home)  (Gelesen 144736 mal)
Offline JF Mennedy
  • New Member
Antw:39_gassistant.pm (Google Assistant, Google Home)
« Antwort #1680 am: 07 April 2020, 21:35:37 »
   FD         17
   FUUID      5e8c5740-f33f-7f5e-3c4b-9b242fdee6a25bed
   LAST_START 2020-04-07 20:38:20
   LAST_STOP  2020-04-07 20:38:20
   NAME       gassistant
   NOTIFYDEV  global,global:npmjs.*gassistant-fhem.*
   NR         2298
   NTFY_ORDER 50-gassistant
   PID        5214
   STARTS     3
   STATE      running /usr/local/bin/gassistant-fhem
   TYPE       gassistant
   currentlogfile ./log/gassistant-2020-04-07.log
   logfile    ./log/gassistant-%Y-%m-%d.log
   CoProcess:
     cmdFn      gassistant_getCMD
     name       gassistant-fhem
     state      running /usr/local/bin/gassistant-fhem
   Helper:
     DBLOG:
       gassistant-fhem:
         DBLogging:
           TIME       1586255681.27806
           VALUE      running /usr/local/bin/gassistant-fhem
       gassistantFHEM.loginURL:
         DBLogging:
           TIME       1586255681.1199
           VALUE      Waiting for login url from gassistant-fhem
       gassistantFHEM.refreshToken:
         DBLogging:
           TIME       1586255681.14026
           VALUE      crypt:355d0d5d2d632e1f0b0b5c5b57665f4c585c436601230b0b00494f2130486e0d57542a7555053504540c6e4631
     2020-04-07 20:38:20   gassistant-fhem running /usr/local/bin/gassistant-fhem
     2020-04-07 20:38:23   gassistant-fhem-connection connecting...
     2020-04-07 20:38:23   gassistant-fhem-lastServerError none
     2020-04-07 20:38:27   gassistant-fhem-lasterror none
     2020-04-07 20:38:26   gassistant-fhem-localHome inactive
     2020-04-07 20:38:23   gassistant-fhem-version 3.0.0
     2020-04-07 20:38:23   gassistant-fhem-versionAvailable 3.0.0
     2020-04-07 20:38:23   gassistantFHEM.loginURL <html><a href="https://fhemconnector.eu.auth0.com/authorize?audience=https://europe-west1-fhem-ga-connector.cloudfunctions.net/&scope=offline_access%20openid%20profile&response_type=code&client_id=EI0TI2Y0W1743Ico53Nvsg1FsmoZniCC&code_challenge=OeQ4og23WHcR-XgYFrtoy3BlwWIDl5Jq4kZu1Z1Xu2I&code_challenge_method=S256&redirect_uri=https://europe-west1-fhem-ga-connector.cloudfunctions.net/codelanding/start" target="_blank">Click here to login (new window/tab)</a><br></html>
     2020-04-07 12:35:46   gassistantFHEM.refreshToken crypt:355d0d5d2d632e1f0b0b5c5b57665f4c585c436601230b0b00494f2130486e0d57542a7555053504540c6e4631
   DbLogExclude .*
   alias      gassistant
   devStateIcon stopped:control_home@red:start stopping:control_on_off@orange running.*:control_on_off@green:stop
   gassistantFHEM-config ./gassistant-fhem.cfg
   gassistantFHEM-log ./log/gassistant-%Y-%m-%d.log
   nrarchive  10
   room       50_Server,55_System,GoogleAssistant
   stateFormat gassistant-fhem
« Letzte Änderung: 07 April 2020, 21:39:57 von JF Mennedy »
Offline dominik
« Antwort #1681 am: 07 April 2020, 21:46:48 »
Kann es sein, dass gassistant-fhem von einem anderen Startscript als dem gassistant Modul gestartet wurde? Das wuerde es fuer mich erklaeren.
Stoppe es mal aus dem gassistant Modul und pruefe dann mit ps -efa ob noch ein gassistant Prozess laeuft.
Autor: 10_EQ3BT (EQ-3 Bluetooth Thermostat), 98_BOSEST (BOSE SoundTouch), 98_DLNARenderer (DLNA Renderer), 98_GOOGLECAST (Google Cast), 39_gassistant (Google Assistant), 10_GFPROBT (G.F.Pro Watering)
Kaffeespende: https://paypal.me/todominik
Offline JF Mennedy
  • New Member
« Antwort #1682 am: 07 April 2020, 22:08:11 »
Es liefen nach dem Stoppen sogar noch 2 Instanzen... Wahrscheinlich die beiden, die ich aus der Konsole gestartet hatte... Habe sie gerade gestoppt und dann aus fhem neu gestartet... Das ändert aber leider nichts daran dass der Status auf connecting... stehen bleibt und bei Synchronisierung der Assistant leer bleibt...
Offline dominik
« Antwort #1683 am: 07 April 2020, 22:11:45 »
Ich vermute, da siehst du im Log noch eine Menge Fehlermeldungen oder? Wenn nein, poste bitte das gassistant Log.
Offline dominik
« Antwort #1684 am: 07 April 2020, 22:24:56 »
Passt, lass das noch laufen, die Nachrichten müssen noch verarbeitet werden.
Bitte lösche das Log dann hier wieder, da tw. sensitive Infos drin sind.
Offline JF Mennedy
  • New Member
« Antwort #1685 am: 07 April 2020, 22:29:22 »
ok, hab das wieder gelöscht... Warte dann mal bis Morgen ab... War das nicht mal in der Anfangszeit, dass man irgendwie bis zu 24 Stunden warten musste bis man das Device wieder anlegen konnte? Ich hab da irgendwie so was noch im Hinterkopf...
Offline dominik
« Antwort #1686 am: 07 April 2020, 22:35:45 »
Nein, hat damit nix zu tun, das sind nur alte Fehlermeldungen. Schick mir deine uid per PN, dann kann ich in der Datenbank die Meldungen löschen und du musst nicht warten.
Offline SouzA
  • Sr. Member
  • Nein! Doch!! Ohhh....
« Antwort #1687 am: 08 April 2020, 06:53:06 »
https://developers.googleblog.com/2020/04/local-home-sdk-ready-for-actions.html
Wann geht es denn bei uns los?  8) ;D
Bis denn
SouzA
Raspi 4, EnOcean TCM310 USB, HM-MOD-UART-USB, Jeelink, hue, AMAD, fully, FRITZBOX, TelegramBot, VIERA, Presence BT/Mac, TPLink, Gassistant, Shelly
Offline noname41
  • New Member
« Antwort #1688 am: 08 April 2020, 18:25:48 »
ich habe ein Problem mit dem gassistanten. Seit ein paar tagen steht der status immer auf connecting.
Es reagieren auch keine geräte.
Folgendes steht im log:
[2020-4-8 18:18:07] GOOGLE MSG RECEIVED: {"msg":"LOG_ERROR","log":"Error with device ZWave_ENTRY_CONTROL_38","ts":1585301085959}
[2020-4-8 18:18:07]   Received message is older than 10s, therefore it gets discarded. Please check your date/time settings if you think that the messages is not that old.
Wenn ich das gerät aus dem Raum nehme ändert sich nichts.
Wie kann ich da vorgehen?
Danke im voraus!
Offline dominik
« Antwort #1689 am: 08 April 2020, 18:39:17 »
Bis denn
SouzA
Hoffentlich noch heute :) Seit heute habe ich in der Google Actions Console ebenfalls die Option.
Ich melde mich sobald es News gibt.
@noname41, wenn du das Geraet aus den Raum genommen hast, mach dann einen kompletten gassistant-fhem Neustart, dann sollte der Fehler weg sein.
Offline JF Mennedy
  • New Member
« Antwort #1690 am: 08 April 2020, 18:55:18 »
Das ist doch selbe Fehler den wir gestern bei mir behoben haben...
Gesendet von meinem VOG-L29 mit Tapatalk
Offline noname41
  • New Member
« Antwort #1691 am: 08 April 2020, 20:30:21 »
Danke für den Tipp. Ich hab das nochmal versucht.
Der Fehler bleibt leider...
Ich hab auch fhem komplett neu aufgesetzt und die config eingespielt selbes Ergebnis....
Zweite Instanz läuft auch keine....
Noch ein Tipp? nach dem fhem update werden gar keine Geräte mehr eingespielt......
« Letzte Änderung: 08 April 2020, 21:12:01 von noname41 »
Offline dominik
« Antwort #1692 am: 08 April 2020, 21:18:34 »
Schick mir bitte per PN deine gassistant-fhem-uid. Ist nur eine dieser Fehlermeldungen in diesem Log oder hunderte?
Offline dominik
« Antwort #1693 am: 08 April 2020, 21:23:39 »
Ich habe gerade Google Local Home SDK eingerichtet und bei Google zum Update eingereicht. Ich hoffe das Review dort geht diesmal schnell.
Fuer alle die sich schon vorbereiten wollen:
 - gassistant-fhem Version 3.0 ist Vorraussetzung!
 - gassistant-fhem-localHome Reading sollte auf inactive stehen
Befehle die ueber die Home App ausgeloest werden, werden dann ebenfalls Lokal ausgefuehrt. Ob Sonos und andere Hersteller ebenfalls unterstuetzt werden, weiss ich leider nicht. Google Home und Mini gehen auf alle Faelle.
Offline Ma_Bo
« Antwort #1694 am: 09 April 2020, 10:58:34 »
Hallo Leute, ich habe mal eine Frage...
Ist es mit gassistant möglich, dass ich ein Reading angezeigt bekomme, indem mein gesprochner Text steht...?
Grüße Marcel
NUC mit FHEM, HM Heizungsthermostate, HM Wandthermostate, Intertechno Funksteckdosen, 10" Tablet als Wanddisplay, KeyMatic, Fensterkontakte, Fensterkontakte umgebaut als Wassermelder und Briefkastenmelder, Aussenthermostat, Anwesenheitssteuerung über Fritz Box, Google Home usw. usw.
decade-submarginal
