39_gassistant.pm (Google Assistant, Google Home)
Begonnen von dominik, 29 Januar 2019, 21:59:53
Superposchi
Hallo, ich habe Probleme mit dem GAssistant.
Es werden keine Befehle ausgetauscht, bzw. Sprachanweisungen werden in Fhem nicht ausgeführt.
Hier das Log:
[code]Loading cli.js...
Loading version.js...
Loading server.js...
Loading user.js...
Loading logger.js...
Loading fhem.js...
Loading database.js...
Loading localhandleQUERY.js...
Loading utils.js...
Loading localserver.js...
Loading localhandleEXECUTE.js...
[19/10/2021, 08.21.46] using ./gassistant-fhem.cfg
[19/10/2021, 08.21.46] ---
[19/10/2021, 08.21.46] config:
{"connections":[{"filter":"room=GoogleAssistant","port":8083,"server":"127.0.0.1","webname":"fhem","name":"FHEM"}],"gassistant":{"description":"FHEM Connect"}}
[19/10/2021, 08.21.46] Google Assistant FHEM Connect 3.0.4 started
[19/10/2021, 08.21.46] Fetching FHEM connections...
[19/10/2021, 08.21.46] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1634624506376
(node:9116) Warning: Accessing non-existent property '_system' of module exports inside circular dependency
(Use `node --trace-warnings ...` to show where the warning was created)
[19/10/2021, 08.21.46] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dgassistant&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.21.46] [FHEM] FHEM Google Assistant device detected: gassistant
[19/10/2021, 08.21.46] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-version%203.0.4&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.21.46] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lastServerError%20none&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.21.46] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3DOiDFFk5_z8a_GAD76Qb4FJVUWkg6wfkRWJ4lM1tOMII%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.21.46] [FHEM] Get refresh token...
[19/10/2021, 08.21.46] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=get%20gassistant%20refreshToken&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.21.46] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20login%20required%3B%20set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3D04nB-HTkZvY7Fdf98W3P6ZIOvj7LkrPN2I78eEHxueE%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.21.46] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20none&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.23.27] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.23.27] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20refreshToken%20KLPms4vpwRvXFtRYik35YTtlLh0TrHczvEgyF_pEcEhVU&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.23.28] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-uid%20google-oauth2%7C100673568922433100803&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.23.28] Start Connection and listen for Firebase
[19/10/2021, 08.23.28] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-localHome%20inactive&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.23.28] [LOCAL] FHEM Connect Google local home server running on port 37000
[19/10/2021, 08.23.28] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20login%20failed%2C%20please%20retry&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.23.28] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20ReferenceError%3A%20exports%20is%20not%20defined&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.23.29] [LOCAL] Bonjour successfully published
[19/10/2021, 08.23.29] [LOCAL] Local Home ready
[19/10/2021, 08.23.29] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-localHome%20active&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.23.56] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.23.56] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20login%20failed%2C%20please%20retry&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.23.56] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20Error%3A%20No%20refresh%20token%20available%2C%20please%20login%20again&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.24.26] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.24.26] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20refreshToken%20AoU_tDMEjZN5XoNlJdfI1VdZ9YpXggGdjgnRQOybsAYtg&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.24.26] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-uid%20google-oauth2%7C100673568922433100803&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.24.27] Start Connection and listen for Firebase
[19/10/2021, 08.24.27] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-localHome%20inactive&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.24.27] [LOCAL] Error: listen EADDRINUSE: address already in use 0.0.0.0:37000
    at Server.setupListenHandle [as _listen2] (net.js:1331:16)
    at listenInCluster (net.js:1379:12)
    at doListen (net.js:1516:7)
    at processTicksAndRejections (internal/process/task_queues.js:83:21) {
  code: 'EADDRINUSE',
  errno: -98,
  syscall: 'listen',
  address: '0.0.0.0',
  port: 37000
[19/10/2021, 08.24.27] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20login%20failed%2C%20please%20retry&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.24.27] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20ReferenceError%3A%20exports%20is%20not%20defined&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.24.40] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20reloading...&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.24.40] [FHEM] Reload and SYNC to Google
[19/10/2021, 08.24.40] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lastServerError%20none&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.24.40] [FHEM] longpoll ended, reconnect in: 4700msec
[19/10/2021, 08.24.41] [FHEM] Fetching FHEM devices...
[19/10/2021, 08.24.41] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.24.41] [FHEM] got: 16 results
[19/10/2021, 08.24.42] [FHEM] update reading: GAssistant_DeckenlichtFl:state = off
[19/10/2021, 08.24.42] [FHEM] update reading: GAssistant_DeckenlichtKu:state = off
[19/10/2021, 08.24.42] [FHEM] update reading: GAssistant_DeckenlichtWZ:state = on
[19/10/2021, 08.24.42] [FHEM] update reading: GAssistant_Schlafzimmerrollo:state = on
[19/10/2021, 08.24.42] [FHEM] update reading: dummy_Eishockeyerinnerung:state = on
[19/10/2021, 08.24.42] [FHEM] update reading: dummy_Geburtstagserinnerung:state = on
[19/10/2021, 08.24.42] [FHEM] update reading: dummy_muellabfuhrerinnerung:state = on
[19/10/2021, 08.24.42] [FHEM] update reading: light_sz_computerlichtgruppe:colormode = ct
[19/10/2021, 08.24.42] [FHEM] update reading: light_sz_computerlichtgruppe:ct = 155
[19/10/2021, 08.24.42] [FHEM] update reading: light_sz_computerlichtgruppe:effect = none
[19/10/2021, 08.24.42] [FHEM] update reading: light_sz_computerlichtgruppe:hue = 41869
[19/10/2021, 08.24.42] [FHEM] update reading: light_sz_computerlichtgruppe:onoff = 0
[19/10/2021, 08.24.42] [FHEM] update reading: light_sz_computerlichtgruppe:pct = 0
[19/10/2021, 08.24.42] [FHEM] update reading: light_sz_computerlichtgruppe:reachable = 1
[19/10/2021, 08.24.42] [FHEM] update reading: light_sz_computerlichtgruppe:rgb = e7ebff
[19/10/2021, 08.24.42] [FHEM] update reading: light_sz_computerlichtgruppe:sat = 32
[19/10/2021, 08.24.42] [FHEM] update reading: plug_wz_audiosystem:state = on
[19/10/2021, 08.24.42] [FHEM] update reading: plug_wz_audiosystem:temperature = 24.0 C (measured)
[19/10/2021, 08.24.42] [FHEM] update reading: plug_wz_blumenlicht:state = off
[19/10/2021, 08.24.42] [FHEM] update reading: plug_wz_blumenlicht:temperature = 25.5 C (measured)
[19/10/2021, 08.24.42] [FHEM] update reading: plug_wz_sideboard:state = off
[19/10/2021, 08.24.42] [FHEM] update reading: plug_wz_sideboard:temperature = 24.5 C (measured)
[19/10/2021, 08.24.42] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:state = off
[19/10/2021, 08.24.42] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.75
[19/10/2021, 08.24.42] [FHEM] update reading: switch_wz_deckenlicht:state = off
[19/10/2021, 08.24.42] [FHEM] update reading: switch_wz_deckenlicht:temperature = 42.38
[19/10/2021, 08.24.42] [FHEM] update reading: unit_sz_dm7020hd:state = absent
[19/10/2021, 08.24.42] [FHEM] update reading: unit_sz_dm7020hd:volume = 60
[19/10/2021, 08.24.42] [FHEM] update reading: unit_wz_dm920uhd:state = on
[19/10/2021, 08.24.42] [FHEM] update reading: unit_wz_dm920uhd:volume = 40
[19/10/2021, 08.24.42] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.24.42] [FHEM]   error in longpoll connection: ReferenceError: exports is not defined
[19/10/2021, 08.24.45] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1634624685584
[19/10/2021, 08.24.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.24.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 42.60
[19/10/2021, 08.24.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.25.02] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.85
[19/10/2021, 08.25.02] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.25.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.25.20] [FHEM] update reading: switch_wz_deckenlicht:temperature = 42.38
[19/10/2021, 08.25.20] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.25.30] [LOCAL] LOCALHOME received: {"requestId":"7598277012188574986","inputs":[{"intent":"action.devices.EXECUTE","payload":{"commands":[{"devices":[{"customData":{"device":"switch_wz_deckenlicht"},"id":"switch_wz_deckenlicht"}],"execution":[{"command":"action.devices.commands.OnOff","params":{"on":true}}]}],"structureData":{}}}],"devices":[{"id":"plug_wz_audiosystem","customData":{"device":"plug_wz_audiosystem"}},{"id":"dummy_Geburtstagserinnerung","customData":{"device":"dummy_Geburtstagserinnerung"}},{"id":"GAssistant_DeckenlichtKu","customData":{"device":"GAssistant_DeckenlichtKu"}},{"id":"GAssistant_Schlafzimmerrollo","customData":{"device":"GAssistant_Schlafzimmerrollo"}},{"id":"light_sz_computerlichtgruppe","customData":{"device":"light_sz_computerlichtgruppe"}},{"id":"switch_wz_deckenlicht","customData":{"device":"switch_wz_deckenlicht"}},{"id":"unit_sz_dm7020hd","customData":{"device":"unit_sz_dm7020hd"}},{"id":"plug_wz_sideboard","customData":{"device":"plug_wz_sideboard"}},{"id":"plug_wz_blumenlicht","customData":{"device":"plug_wz_blumenlicht"}},{"id":"switch_sz_schlafzimmerbrunnen","customData":{"device":"switch_sz_schlafzimmerbrunnen"}},{"id":"GAssistant_DeckenlichtWZ","customData":{"device":"GAssistant_DeckenlichtWZ"}},{"id":"gassistant","customData":{"device":"gassistant"}},{"id":"fhemconnect-id","customData":{},"radioType":"WIFI","scanData":{"mdnsScanData":{"serviceName":"fhemconnect._http._tcp.local","texts":["httpPath=/fhemconnect/local","httpSSL=false","httpPort=37000","version=1.0"],"serviceInstance":"fhemconnect._http._tcp.local"}}},{"id":"unit_wz_dm920uhd","customData":{"device":"unit_wz_dm920uhd"}},{"id":"GAssistant_DeckenlichtFl","customData":{"device":"GAssistant_DeckenlichtFl"}},{"id":"dummy_Eishockeyerinnerung","customData":{"device":"dummy_Eishockeyerinnerung"}},{"id":"dummy_muellabfuhrerinnerung","customData":{"device":"dummy_muellabfuhrerinnerung"}}]}
[19/10/2021, 08.25.30] [LOCAL] Error in Local Home: TypeError: localEXECUTE.handleEXECUTE is not a function
[19/10/2021, 08.25.33] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.96
[19/10/2021, 08.25.33] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.25.40] [FHEM] update reading: switch_wz_deckenlicht:state = set_on
[19/10/2021, 08.25.40] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.25.40] [FHEM] update reading: switch_wz_deckenlicht:state = on
[19/10/2021, 08.25.42] [FHEM] update reading: switch_wz_deckenlicht:state = set_off
[19/10/2021, 08.25.42] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.25.42] [FHEM] update reading: switch_wz_deckenlicht:state = off
[19/10/2021, 08.25.47] [FHEM] update reading: switch_wz_deckenlicht:state = set_on
[19/10/2021, 08.25.47] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.25.47] [FHEM] update reading: switch_wz_deckenlicht:state = on
[19/10/2021, 08.25.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.25.49] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.26.02] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.75
[19/10/2021, 08.26.02] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.26.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.26.19] [FHEM] update reading: switch_wz_deckenlicht:temperature = 42.53
[19/10/2021, 08.26.19] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.26.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.26.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 42.82
[19/10/2021, 08.26.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.27.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.27.20] [FHEM] update reading: switch_wz_deckenlicht:temperature = 43.11
[19/10/2021, 08.27.20] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.27.33] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.85
[19/10/2021, 08.27.33] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.27.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.27.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 43.62
[19/10/2021, 08.27.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.28.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.28.20] [FHEM] update reading: switch_wz_deckenlicht:temperature = 44.34
[19/10/2021, 08.28.20] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.28.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.28.48] [FHEM] update reading: switch_wz_deckenlicht:temperature = 44.92
[19/10/2021, 08.28.49] [FHEM] update reading: plug_wz_blumenlicht:temperature = 25.0 C (measured)
[19/10/2021, 08.28.49] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.29.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.29.20] [FHEM] update reading: switch_wz_deckenlicht:temperature = 45.41
[19/10/2021, 08.29.20] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.29.38] [LOCAL] LOCALHOME received: {"requestId":"11278058516394071226","inputs":[{"intent":"action.devices.EXECUTE","payload":{"commands":[{"devices":[{"customData":{"device":"switch_wz_deckenlicht"},"id":"switch_wz_deckenlicht"}],"execution":[{"command":"action.devices.commands.OnOff","params":{"on":false}}]}],"structureData":{}}}],"devices":[{"id":"plug_wz_audiosystem","customData":{"device":"plug_wz_audiosystem"}},{"id":"dummy_Geburtstagserinnerung","customData":{"device":"dummy_Geburtstagserinnerung"}},{"id":"GAssistant_DeckenlichtKu","customData":{"device":"GAssistant_DeckenlichtKu"}},{"id":"GAssistant_Schlafzimmerrollo","customData":{"device":"GAssistant_Schlafzimmerrollo"}},{"id":"light_sz_computerlichtgruppe","customData":{"device":"light_sz_computerlichtgruppe"}},{"id":"switch_wz_deckenlicht","customData":{"device":"switch_wz_deckenlicht"}},{"id":"unit_sz_dm7020hd","customData":{"device":"unit_sz_dm7020hd"}},{"id":"plug_wz_sideboard","customData":{"device":"plug_wz_sideboard"}},{"id":"plug_wz_blumenlicht","customData":{"device":"plug_wz_blumenlicht"}},{"id":"switch_sz_schlafzimmerbrunnen","customData":{"device":"switch_sz_schlafzimmerbrunnen"}},{"id":"GAssistant_DeckenlichtWZ","customData":{"device":"GAssistant_DeckenlichtWZ"}},{"id":"gassistant","customData":{"device":"gassistant"}},{"id":"fhemconnect-id","customData":{},"radioType":"WIFI","scanData":{"mdnsScanData":{"serviceName":"fhemconnect._http._tcp.local","texts":["httpPath=/fhemconnect/local","httpSSL=false","httpPort=37000","version=1.0"],"serviceInstance":"fhemconnect._http._tcp.local"}}},{"id":"unit_wz_dm920uhd","customData":{"device":"unit_wz_dm920uhd"}},{"id":"GAssistant_DeckenlichtFl","customData":{"device":"GAssistant_DeckenlichtFl"}},{"id":"dummy_Eishockeyerinnerung","customData":{"device":"dummy_Eishockeyerinnerung"}},{"id":"dummy_muellabfuhrerinnerung","customData":{"device":"dummy_muellabfuhrerinnerung"}}]}
[19/10/2021, 08.29.38] [LOCAL] Error in Local Home: TypeError: localEXECUTE.handleEXECUTE is not a function
[19/10/2021, 08.29.41] [LOCAL] LOCALHOME received: {"requestId":"8954657286951156353","inputs":[{"intent":"action.devices.EXECUTE","payload":{"commands":[{"devices":[{"customData":{"device":"switch_wz_deckenlicht"},"id":"switch_wz_deckenlicht"}],"execution":[{"command":"action.devices.commands.OnOff","params":{"on":true}}]}],"structureData":{}}}],"devices":[{"id":"plug_wz_audiosystem","customData":{"device":"plug_wz_audiosystem"}},{"id":"dummy_Geburtstagserinnerung","customData":{"device":"dummy_Geburtstagserinnerung"}},{"id":"GAssistant_DeckenlichtKu","customData":{"device":"GAssistant_DeckenlichtKu"}},{"id":"GAssistant_Schlafzimmerrollo","customData":{"device":"GAssistant_Schlafzimmerrollo"}},{"id":"light_sz_computerlichtgruppe","customData":{"device":"light_sz_computerlichtgruppe"}},{"id":"switch_wz_deckenlicht","customData":{"device":"switch_wz_deckenlicht"}},{"id":"unit_sz_dm7020hd","customData":{"device":"unit_sz_dm7020hd"}},{"id":"plug_wz_sideboard","customData":{"device":"plug_wz_sideboard"}},{"id":"plug_wz_blumenlicht","customData":{"device":"plug_wz_blumenlicht"}},{"id":"switch_sz_schlafzimmerbrunnen","customData":{"device":"switch_sz_schlafzimmerbrunnen"}},{"id":"GAssistant_DeckenlichtWZ","customData":{"device":"GAssistant_DeckenlichtWZ"}},{"id":"gassistant","customData":{"device":"gassistant"}},{"id":"fhemconnect-id","customData":{},"radioType":"WIFI","scanData":{"mdnsScanData":{"serviceName":"fhemconnect._http._tcp.local","texts":["httpPath=/fhemconnect/local","httpSSL=false","httpPort=37000","version=1.0"],"serviceInstance":"fhemconnect._http._tcp.local"}}},{"id":"unit_wz_dm920uhd","customData":{"device":"unit_wz_dm920uhd"}},{"id":"GAssistant_DeckenlichtFl","customData":{"device":"GAssistant_DeckenlichtFl"}},{"id":"dummy_Eishockeyerinnerung","customData":{"device":"dummy_Eishockeyerinnerung"}},{"id":"dummy_muellabfuhrerinnerung","customData":{"device":"dummy_muellabfuhrerinnerung"}}]}
[19/10/2021, 08.29.41] [LOCAL] Error in Local Home: TypeError: localEXECUTE.handleEXECUTE is not a function
[19/10/2021, 08.29.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.29.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 46.36
[19/10/2021, 08.29.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.30.14] [FHEM] update reading: switch_wz_deckenlicht:temperature = 47.73
[19/10/2021, 08.30.14] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.30.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.30.20] [FHEM] update reading: switch_wz_deckenlicht:temperature = 47.52
[19/10/2021, 08.30.20] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.30.33] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.75
[19/10/2021, 08.30.33] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.30.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.30.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 48.26
[19/10/2021, 08.30.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.31.03] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.85
[19/10/2021, 08.31.03] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.31.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.31.19] [FHEM] update reading: switch_wz_deckenlicht:temperature = 49.30
[19/10/2021, 08.31.19] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.31.33] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.75
[19/10/2021, 08.31.33] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.31.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.31.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 50.02
[19/10/2021, 08.31.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.32.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.32.20] [FHEM] update reading: switch_wz_deckenlicht:temperature = 51.26
[19/10/2021, 08.32.20] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.32.33] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.85
[19/10/2021, 08.32.33] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.32.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.32.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 51.97
[19/10/2021, 08.32.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.33.03] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.75
[19/10/2021, 08.33.03] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.33.07] [FHEM] update reading: switch_wz_deckenlicht:temperature = 52.78
[19/10/2021, 08.33.07] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.33.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.33.18] [FHEM] update reading: switch_wz_deckenlicht:temperature = 52.88
[19/10/2021, 08.33.33] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.85
[19/10/2021, 08.33.33] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.33.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.33.48] [FHEM] update reading: switch_wz_deckenlicht:temperature = 53.79
[19/10/2021, 08.33.49] [FHEM] update reading: plug_wz_audiosystem:temperature = 24.5 C (measured)
[19/10/2021, 08.33.49] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.33.50] [FHEM] update reading: plug_wz_blumenlicht:temperature = 25.5 C (measured)
[19/10/2021, 08.33.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.34.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.34.20] [FHEM] update reading: switch_wz_deckenlicht:temperature = 54.39
[19/10/2021, 08.34.20] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.34.33] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.96
[19/10/2021, 08.34.33] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.34.43] [LOCAL] LOCALHOME received: {"requestId":"4480378347028399871","inputs":[{"intent":"action.devices.EXECUTE","payload":{"commands":[{"devices":[{"customData":{"device":"switch_wz_deckenlicht"},"id":"switch_wz_deckenlicht"}],"execution":[{"command":"action.devices.commands.OnOff","params":{"on":false}}]}],"structureData":{}}}],"devices":[{"id":"plug_wz_audiosystem","customData":{"device":"plug_wz_audiosystem"}},{"id":"dummy_Geburtstagserinnerung","customData":{"device":"dummy_Geburtstagserinnerung"}},{"id":"GAssistant_DeckenlichtKu","customData":{"device":"GAssistant_DeckenlichtKu"}},{"id":"GAssistant_Schlafzimmerrollo","customData":{"device":"GAssistant_Schlafzimmerrollo"}},{"id":"light_sz_computerlichtgruppe","customData":{"device":"light_sz_computerlichtgruppe"}},{"id":"switch_wz_deckenlicht","customData":{"device":"switch_wz_deckenlicht"}},{"id":"unit_sz_dm7020hd","customData":{"device":"unit_sz_dm7020hd"}},{"id":"plug_wz_sideboard","customData":{"device":"plug_wz_sideboard"}},{"id":"plug_wz_blumenlicht","customData":{"device":"plug_wz_blumenlicht"}},{"id":"switch_sz_schlafzimmerbrunnen","customData":{"device":"switch_sz_schlafzimmerbrunnen"}},{"id":"GAssistant_DeckenlichtWZ","customData":{"device":"GAssistant_DeckenlichtWZ"}},{"id":"gassistant","customData":{"device":"gassistant"}},{"id":"fhemconnect-id","customData":{},"radioType":"WIFI","scanData":{"mdnsScanData":{"serviceName":"fhemconnect._http._tcp.local","texts":["httpPath=/fhemconnect/local","httpSSL=false","httpPort=37000","version=1.0"],"serviceInstance":"fhemconnect._http._tcp.local"}}},{"id":"unit_wz_dm920uhd","customData":{"device":"unit_wz_dm920uhd"}},{"id":"GAssistant_DeckenlichtFl","customData":{"device":"GAssistant_DeckenlichtFl"}},{"id":"dummy_Eishockeyerinnerung","customData":{"device":"dummy_Eishockeyerinnerung"}},{"id":"dummy_muellabfuhrerinnerung","customData":{"device":"dummy_muellabfuhrerinnerung"}}]}
[19/10/2021, 08.34.43] [LOCAL] Error in Local Home: TypeError: localEXECUTE.handleEXECUTE is not a function
[19/10/2021, 08.34.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.34.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 55.39
[19/10/2021, 08.34.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.35.02] [LOCAL] LOCALHOME received: {"requestId":"3065365379020585957","inputs":[{"intent":"action.devices.EXECUTE","payload":{"commands":[{"devices":[{"customData":{"device":"switch_wz_deckenlicht"},"id":"switch_wz_deckenlicht"}],"execution":[{"command":"action.devices.commands.OnOff","params":{"on":false}}]}],"structureData":{}}}],"devices":[{"id":"plug_wz_audiosystem","customData":{"device":"plug_wz_audiosystem"}},{"id":"dummy_Geburtstagserinnerung","customData":{"device":"dummy_Geburtstagserinnerung"}},{"id":"GAssistant_DeckenlichtKu","customData":{"device":"GAssistant_DeckenlichtKu"}},{"id":"GAssistant_Schlafzimmerrollo","customData":{"device":"GAssistant_Schlafzimmerrollo"}},{"id":"light_sz_computerlichtgruppe","customData":{"device":"light_sz_computerlichtgruppe"}},{"id":"switch_wz_deckenlicht","customData":{"device":"switch_wz_deckenlicht"}},{"id":"unit_sz_dm7020hd","customData":{"device":"unit_sz_dm7020hd"}},{"id":"plug_wz_sideboard","customData":{"device":"plug_wz_sideboard"}},{"id":"plug_wz_blumenlicht","customData":{"device":"plug_wz_blumenlicht"}},{"id":"switch_sz_schlafzimmerbrunnen","customData":{"device":"switch_sz_schlafzimmerbrunnen"}},{"id":"GAssistant_DeckenlichtWZ","customData":{"device":"GAssistant_DeckenlichtWZ"}},{"id":"gassistant","customData":{"device":"gassistant"}},{"id":"fhemconnect-id","customData":{},"radioType":"WIFI","scanData":{"mdnsScanData":{"serviceName":"fhemconnect._http._tcp.local","texts":["httpPath=/fhemconnect/local","httpSSL=false","httpPort=37000","version=1.0"],"serviceInstance":"fhemconnect._http._tcp.local"}}},{"id":"unit_wz_dm920uhd","customData":{"device":"unit_wz_dm920uhd"}},{"id":"GAssistant_DeckenlichtFl","customData":{"device":"GAssistant_DeckenlichtFl"}},{"id":"dummy_Eishockeyerinnerung","customData":{"device":"dummy_Eishockeyerinnerung"}},{"id":"dummy_muellabfuhrerinnerung","customData":{"device":"dummy_muellabfuhrerinnerung"}}]}
[19/10/2021, 08.35.02] [LOCAL] Error in Local Home: TypeError: localEXECUTE.handleEXECUTE is not a function
[19/10/2021, 08.35.03] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.75
[19/10/2021, 08.35.03] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.35.05] [LOCAL] LOCALHOME received: {"requestId":"4411891813925447844","inputs":[{"intent":"action.devices.EXECUTE","payload":{"commands":[{"devices":[{"customData":{"device":"switch_wz_deckenlicht"},"id":"switch_wz_deckenlicht"}],"execution":[{"command":"action.devices.commands.OnOff","params":{"on":true}}]}],"structureData":{}}}],"devices":[{"id":"plug_wz_audiosystem","customData":{"device":"plug_wz_audiosystem"}},{"id":"dummy_Geburtstagserinnerung","customData":{"device":"dummy_Geburtstagserinnerung"}},{"id":"GAssistant_DeckenlichtKu","customData":{"device":"GAssistant_DeckenlichtKu"}},{"id":"GAssistant_Schlafzimmerrollo","customData":{"device":"GAssistant_Schlafzimmerrollo"}},{"id":"light_sz_computerlichtgruppe","customData":{"device":"light_sz_computerlichtgruppe"}},{"id":"switch_wz_deckenlicht","customData":{"device":"switch_wz_deckenlicht"}},{"id":"unit_sz_dm7020hd","customData":{"device":"unit_sz_dm7020hd"}},{"id":"plug_wz_sideboard","customData":{"device":"plug_wz_sideboard"}},{"id":"plug_wz_blumenlicht","customData":{"device":"plug_wz_blumenlicht"}},{"id":"switch_sz_schlafzimmerbrunnen","customData":{"device":"switch_sz_schlafzimmerbrunnen"}},{"id":"GAssistant_DeckenlichtWZ","customData":{"device":"GAssistant_DeckenlichtWZ"}},{"id":"gassistant","customData":{"device":"gassistant"}},{"id":"fhemconnect-id","customData":{},"radioType":"WIFI","scanData":{"mdnsScanData":{"serviceName":"fhemconnect._http._tcp.local","texts":["httpPath=/fhemconnect/local","httpSSL=false","httpPort=37000","version=1.0"],"serviceInstance":"fhemconnect._http._tcp.local"}}},{"id":"unit_wz_dm920uhd","customData":{"device":"unit_wz_dm920uhd"}},{"id":"GAssistant_DeckenlichtFl","customData":{"device":"GAssistant_DeckenlichtFl"}},{"id":"dummy_Eishockeyerinnerung","customData":{"device":"dummy_Eishockeyerinnerung"}},{"id":"dummy_muellabfuhrerinnerung","customData":{"device":"dummy_muellabfuhrerinnerung"}}]}
[19/10/2021, 08.35.05] [LOCAL] Error in Local Home: TypeError: localEXECUTE.handleEXECUTE is not a function
[19/10/2021, 08.35.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.35.20] [FHEM] update reading: switch_wz_deckenlicht:temperature = 56.28
[19/10/2021, 08.35.20] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.35.33] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.85
[19/10/2021, 08.35.33] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.35.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.35.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 57.07
[19/10/2021, 08.35.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.36.03] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.96
[19/10/2021, 08.36.03] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.36.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.36.20] [FHEM] update reading: switch_wz_deckenlicht:temperature = 57.55
[19/10/2021, 08.36.20] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.36.21] [FHEM] update reading: switch_wz_deckenlicht:temperature = 57.85
[19/10/2021, 08.36.21] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.36.33] [FHEM] update reading: switch_sz_schlafzimmerbrunnen:temperature = 55.85
[19/10/2021, 08.36.33] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.36.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.36.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 58.43
[19/10/2021, 08.36.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.36.59] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lastServerError%20none&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.36.59] [FHEM] longpoll ended, reconnect in: 4700msec
[19/10/2021, 08.37.00] [FHEM] Fetching FHEM devices...
[19/10/2021, 08.37.00] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.37.00] [FHEM] got: 14 results
[19/10/2021, 08.37.01] [FHEM] update reading: GAssistant_DeckenlichtFl:state = off
[19/10/2021, 08.37.01] [FHEM] update reading: GAssistant_DeckenlichtKu:state = off
[19/10/2021, 08.37.01] [FHEM] update reading: GAssistant_Schlafzimmerrollo:state = on
[19/10/2021, 08.37.01] [FHEM] update reading: dummy_Eishockeyerinnerung:state = on
[19/10/2021, 08.37.01] [FHEM] update reading: dummy_Geburtstagserinnerung:state = on
[19/10/2021, 08.37.01] [FHEM] update reading: dummy_muellabfuhrerinnerung:state = on
[19/10/2021, 08.37.01] [FHEM] update reading: light_sz_computerlichtgruppe:colormode = ct
[19/10/2021, 08.37.01] [FHEM] update reading: light_sz_computerlichtgruppe:ct = 155
[19/10/2021, 08.37.01] [FHEM] update reading: light_sz_computerlichtgruppe:effect = none
[19/10/2021, 08.37.01] [FHEM] update reading: light_sz_computerlichtgruppe:hue = 41869
[19/10/2021, 08.37.01] [FHEM] update reading: light_sz_computerlichtgruppe:onoff = 0
[19/10/2021, 08.37.01] [FHEM] update reading: light_sz_computerlichtgruppe:pct = 0
[19/10/2021, 08.37.01] [FHEM] update reading: light_sz_computerlichtgruppe:reachable = 1
[19/10/2021, 08.37.01] [FHEM] update reading: light_sz_computerlichtgruppe:rgb = e7ebff
[19/10/2021, 08.37.01] [FHEM] update reading: light_sz_computerlichtgruppe:sat = 32
[19/10/2021, 08.37.01] [FHEM] update reading: plug_wz_audiosystem:state = on
[19/10/2021, 08.37.01] [FHEM] update reading: plug_wz_audiosystem:temperature = 24.5 C (measured)
[19/10/2021, 08.37.01] [FHEM] update reading: plug_wz_blumenlicht:state = off
[19/10/2021, 08.37.01] [FHEM] update reading: plug_wz_blumenlicht:temperature = 25.5 C (measured)
[19/10/2021, 08.37.01] [FHEM] update reading: plug_wz_sideboard:state = off
[19/10/2021, 08.37.01] [FHEM] update reading: plug_wz_sideboard:temperature = 24.5 C (measured)
[19/10/2021, 08.37.01] [FHEM] update reading: switch_wz_deckenlicht:state = on
[19/10/2021, 08.37.01] [FHEM] update reading: switch_wz_deckenlicht:temperature = 58.43
[19/10/2021, 08.37.01] [FHEM] update reading: unit_sz_dm7020hd:state = absent
[19/10/2021, 08.37.01] [FHEM] update reading: unit_sz_dm7020hd:volume = 60
[19/10/2021, 08.37.01] [FHEM] update reading: unit_wz_dm920uhd:state = on
[19/10/2021, 08.37.01] [FHEM] update reading: unit_wz_dm920uhd:volume = 40
[19/10/2021, 08.37.01] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.37.01] [FHEM]   error in longpoll connection: ReferenceError: exports is not defined
[19/10/2021, 08.37.04] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1634625424654
[19/10/2021, 08.37.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.37.20] [FHEM] update reading: switch_wz_deckenlicht:temperature = 59.11
[19/10/2021, 08.37.20] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.37.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.37.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 59.59
[19/10/2021, 08.37.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.38.02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20refreshToken%20IHiFzDLqS3fT96bp0SDsmVw87dBbZe9q-cc2PvNPITRtU&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-uid%20google-oauth2%7C100673568922433100803&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.03] Start Connection and listen for Firebase
[19/10/2021, 08.38.03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-localHome%20inactive&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.03] [LOCAL] Error: listen EADDRINUSE: address already in use 0.0.0.0:37000
  code: 'EADDRINUSE',
  errno: -98,
  syscall: 'listen',
  address: '0.0.0.0',
  port: 37000
[19/10/2021, 08.38.03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20login%20failed%2C%20please%20retry&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20ReferenceError%3A%20exports%20is%20not%20defined&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.18] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.38.20] [FHEM] update reading: switch_wz_deckenlicht:temperature = 60.11
[19/10/2021, 08.38.20] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.38.45] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.45] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20refreshToken%20Xq8fk6TwrUM_5cavhhFs6vw1h3pesNLLZQL0Z3lB7VD0o&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.45] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-uid%20google-oauth2%7C100673568922433100803&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.46] Start Connection and listen for Firebase
[19/10/2021, 08.38.46] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-localHome%20inactive&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.46] [LOCAL] Error: listen EADDRINUSE: address already in use 0.0.0.0:37000
  code: 'EADDRINUSE',
  errno: -98,
  syscall: 'listen',
  address: '0.0.0.0',
  port: 37000
[19/10/2021, 08.38.46] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20login%20failed%2C%20please%20retry&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.46] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20ReferenceError%3A%20exports%20is%20not%20defined&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.38.48] [FHEM] update reading: switch_wz_deckenlicht:temperature = 60.62
[19/10/2021, 08.38.49] [FHEM] update reading: plug_wz_audiosystem:temperature = 24.0 C (measured)
[19/10/2021, 08.38.49] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.38.50] Got SIGTERM, shutting down...
[19/10/2021, 08.38.50] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20disconnected&fwcsrf=csrf_522648229077005&XHR=1
Loading cli.js...
Loading user.js...
Loading fhem.js...
Loading utils.js...
[19/10/2021, 08.38.51] using ./gassistant-fhem.cfg
[19/10/2021, 08.38.51] ---
[19/10/2021, 08.38.51] config:
[19/10/2021, 08.38.51] Google Assistant FHEM Connect 3.0.4 started
[19/10/2021, 08.38.51] Fetching FHEM connections...
[19/10/2021, 08.38.51] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1634625531921
(node:27764) Warning: Accessing non-existent property '_system' of module exports inside circular dependency
[19/10/2021, 08.38.52] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dgassistant&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.52] [FHEM] FHEM Google Assistant device detected: gassistant
[19/10/2021, 08.38.52] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-version%203.0.4&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.52] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lastServerError%20none&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.52] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3D3Ilz0KReb-Bkmn9s98--p4adjF5Zs7loQnS0yemIg5M%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.52] [FHEM] Get refresh token...
[19/10/2021, 08.38.52] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=get%20gassistant%20refreshToken&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.52] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.52] [FHEM] Found refresh token in reading
[19/10/2021, 08.38.52] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-versionAvailable%203.0.4&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.52] Refresh tokens finished. Next refresh in 86400 seconds.
[19/10/2021, 08.38.52] [FHEM] refreshAllTokens executed
[19/10/2021, 08.38.53] Start Connection and listen for Firebase
[19/10/2021, 08.38.53] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-localHome%20inactive&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.53] [LOCAL] FHEM Connect Google local home server running on port 37000
ReferenceError [Error]: exports is not defined
    at eval (eval at apply (/usr/lib/node_modules/gassistant-fhem/node_modules/vm2/lib/fixasync.js:21:10), <anonymous>:1:1)
    at eval (<anonymous>)
    at Object.apply (/usr/lib/node_modules/gassistant-fhem/node_modules/vm2/lib/fixasync.js:21:10)
    at Object.FHEM_getClientFunctions (/usr/lib/node_modules/gassistant-fhem/lib/remote-localhandleEXECUTE.js:18:5)
    at processTicksAndRejections (internal/process/task_queues.js:95:5)
[19/10/2021, 08.38.53] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20login%20failed%2C%20please%20retry&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.53] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20ReferenceError%3A%20exports%20is%20not%20defined&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.38.54] [LOCAL] Bonjour successfully published
[19/10/2021, 08.38.54] [LOCAL] Local Home ready
[19/10/2021, 08.39.22] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-localHome%20active&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.40.33] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.40.33] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20refreshToken%207Hto7m_EpHKtD_NAx_ME2qh7AU8wg0mj7cpPCGIpmZFUq&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.40.33] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-uid%20google-oauth2%7C100673568922433100803&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.40.34] Start Connection and listen for Firebase
[19/10/2021, 08.40.34] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-localHome%20inactive&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.40.34] [LOCAL] Error: listen EADDRINUSE: address already in use 0.0.0.0:37000
  code: 'EADDRINUSE',
  errno: -98,
  syscall: 'listen',
  address: '0.0.0.0',
  port: 37000
[19/10/2021, 08.40.34] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20login%20failed%2C%20please%20retry&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.40.34] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20ReferenceError%3A%20exports%20is%20not%20defined&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.41.43] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20reloading...&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.41.43] [FHEM] Reload and SYNC to Google
[19/10/2021, 08.41.43] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lastServerError%20none&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.41.43] [FHEM] longpoll ended, reconnect in: 4700msec
[19/10/2021, 08.41.43] [FHEM] Fetching FHEM devices...
[19/10/2021, 08.41.43] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.41.43] [FHEM] got: 14 results
[19/10/2021, 08.41.44] [FHEM] update reading: GAssistant_DeckenlichtFl:state = off
[19/10/2021, 08.41.44] [FHEM] update reading: GAssistant_DeckenlichtKu:state = off
[19/10/2021, 08.41.44] [FHEM] update reading: GAssistant_Schlafzimmerrollo:state = on
[19/10/2021, 08.41.44] [FHEM] update reading: dummy_Eishockeyerinnerung:state = on
[19/10/2021, 08.41.44] [FHEM] update reading: dummy_Geburtstagserinnerung:state = on
[19/10/2021, 08.41.44] [FHEM] update reading: dummy_muellabfuhrerinnerung:state = on
[19/10/2021, 08.41.44] [FHEM] update reading: light_sz_computerlichtgruppe:colormode = ct
[19/10/2021, 08.41.44] [FHEM] update reading: light_sz_computerlichtgruppe:ct = 155
[19/10/2021, 08.41.44] [FHEM] update reading: light_sz_computerlichtgruppe:effect = none
[19/10/2021, 08.41.44] [FHEM] update reading: light_sz_computerlichtgruppe:hue = 41869
[19/10/2021, 08.41.44] [FHEM] update reading: light_sz_computerlichtgruppe:onoff = 0
[19/10/2021, 08.41.44] [FHEM] update reading: light_sz_computerlichtgruppe:pct = 0
[19/10/2021, 08.41.44] [FHEM] update reading: light_sz_computerlichtgruppe:reachable = 1
[19/10/2021, 08.41.44] [FHEM] update reading: light_sz_computerlichtgruppe:rgb = e7ebff
[19/10/2021, 08.41.44] [FHEM] update reading: light_sz_computerlichtgruppe:sat = 32
[19/10/2021, 08.41.44] [FHEM] update reading: plug_wz_audiosystem:state = on
[19/10/2021, 08.41.44] [FHEM] update reading: plug_wz_audiosystem:temperature = 24.0 C (measured)
[19/10/2021, 08.41.44] [FHEM] update reading: plug_wz_blumenlicht:state = off
[19/10/2021, 08.41.44] [FHEM] update reading: plug_wz_blumenlicht:temperature = 25.5 C (measured)
[19/10/2021, 08.41.44] [FHEM] update reading: plug_wz_sideboard:state = off
[19/10/2021, 08.41.44] [FHEM] update reading: plug_wz_sideboard:temperature = 24.5 C (measured)
[19/10/2021, 08.41.44] [FHEM] update reading: switch_wz_deckenlicht:state = on
[19/10/2021, 08.41.44] [FHEM] update reading: switch_wz_deckenlicht:temperature = 62.13
[19/10/2021, 08.41.44] [FHEM] update reading: unit_sz_dm7020hd:state = absent
[19/10/2021, 08.41.44] [FHEM] update reading: unit_sz_dm7020hd:volume = 60
[19/10/2021, 08.41.44] [FHEM] update reading: unit_wz_dm920uhd:state = on
[19/10/2021, 08.41.44] [FHEM] update reading: unit_wz_dm920uhd:volume = 40
[19/10/2021, 08.41.44] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=csrf_522648229077005&XHR=1
[19/10/2021, 08.41.44] [FHEM]   error in longpoll connection: ReferenceError: exports is not defined
[19/10/2021, 08.41.47] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1634625707906
[19/10/2021, 08.41.48] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021, 08.41.50] [FHEM] update reading: switch_wz_deckenlicht:temperature = 62.38
[19/10/2021, 08.41.50] [FHEM]   error in longpoll connection: TypeError: localQUERY.processQUERY is not a function
[19/10/2021
kadettilac89
Ich vermute dein Post wurde abgeschnitten. Logs bitte in Code-Tags, das ist der Button mit der Raute (#) oben im Editor.
Information für die Helfenden ... du nutzt den default Docker-Container und hast im System-Bereich alle möglichen Dinge up-ge-dated. Evlt. sogar irgendwo Rote Fehler oder andere Probleme, richtig?
Da du einen Container hast, erstelle am besten den Container einmal neu und teste nochmal. Beim Update der NPM-Pakete oder node verkantet sich gassistant gerne mal. Erstellen des Containers sollte nicht viel Zeit kosten .. wenn es dann immer noch nicht geht --> nochmal melden mit dem neuen Log.
Ich glaub die Meldung "SetupListenHandle" hatte ich vor ein paar Tagen als ich mit Node rumgespielt hatte. Container neu erstellt und es lief auf Anhieb wieder. Kann nicht nachsehen, das ich das Log nur einen Tag halte.
Superposchi
Hallo, das Log steht in einem Code-Block, aus irgendeinem Grund wird es aber nicht korrekt angezeigt. Hatte ich vor einiger Zeit schon mal. Die Tags sind aber vorhanden.
Ja, ich nutze den default docker-container und dieser ist auf dem aktuellen Stand. Alles wurde geupdates und keine roten Fehler mehr vorhanden.
Der Container ist brandneu, aber werde es gerne mal probieren einen neuen zu erstellen.
Das Problem ist darin zu suchen, dass das Device offenbar auf einen anderen Account zugreift als fhem-connect auf dem Handy.
kadettilac89
wenn du dir das Updaten erstmal sparen willst kannst auch mal den dev-Tree von volschin testen, das Image ist relativ aktuell. Den habe ich seit August ohne Probleme im Einsatz. Der Originalcontainer von Loredo ist einiges älter.
docker pull ghcr.io/volschin/fhem-experimental:dev-bullseye
Docker für Fhem wird jetzt von CoolTux (mit) supportet. Da gibts dann sicher wieder regelmäßige Updates.
Superposchi
Mit dev-tree meinst du den Container oder was?
Der Container den ich nutze ist computerkoenig/fhem-Main. Dachte das der original von Rudolf König ist.
Es gibt ja diverses Container, weshalb der Begriff default zweideutig sein kann.
Das Verhalten ist komisch, das Device in Fhem ist Connecticut. Änderungen der Devices im Room GoogleAssistant werden auch in der Google Home App aktualisiert und können dort verbal angesprochen werden.
Lediglich werden die Geräte in der App nicht geschaltet  wenn sie verbal angesprochen werden bzw. eine manuelle Schaltung von Fhem zur App und umgekehrt nicht übergeben.
kadettilac89
#2705
den Container von dir kenn ich nciht. Der default ist https://hub.docker.com/r/fhem/fhem ... der ist auch im Docker Thread im ersten Beitrag verlinkt.
Der Container von dir ist minimalistisch, das Dockerfile (Bauanleitung) hat nur 100 Zeilen im Verlgeich zum Original mit 550. Da fehlen etliche Dinge. Das erklärt wahrscheinlich die - nicht nachstellbaren - Probleme aus deinen früheren Posts. Z. B. das SUDO Thema.
Ich nehme das zurück, der Container von dir baut auf den default auf, jedoch ist der schon älter. Empfehle trotzdem den default oder den von volschin zu verwenden.
Teste mal mit Original "docker pull fhem/fhem" oder den von volschin der basiert darauf, ist aber neuer.
rbm78bln
Hi zusammen,
auch ich kann mich der Fehlermeldung "exports is not defined" anschließen, habe aber im log noch das folgende gefunden:
2021.10.19 20:49:43.896 3: gassistant: [10/19/2021, 8:49:43 PM] Google Assistant FHEM Connect 3.0.4 started
2021.10.19 20:49:45.192 3: gassistant: (node:26980) Warning: Accessing non-existent property '_system' of module exports inside circular dependency  <==
2021.10.19 20:49:50.966 3: gassistant: ReferenceError [Error]: exports is not defined
    at eval (eval at apply (/opt/gassistant-fhem/node_modules/vm2/lib/fixasync.js:21:10), <anonymous>:1:1)
    at Object.apply (/opt/gassistant-fhem/node_modules/vm2/lib/fixasync.js:21:10)
    at Object.FHEM_getClientFunctions (/opt/gassistant-fhem/node_modules/gassistant-fhem/lib/remote-localhandleEXECUTE.js:18:5)
    at processTicksAndRejections (internal/process/task_queues.js:93:5)
Könnte das evtl. auf ein Dependency-Problem mit der aktuellen Version hindeuten?
kadettilac89
Zitat von: rbm78bln am 19 Oktober 2021, 21:10:49
Hi zusammen,
hast du fhem in docker, oder "normal" auf einem Linux? Welche npm / node-version und welche gassistant version hast du?
Superposchi
Werde den Container testen, kann aber 2-3 Dauern da ich morgen/übermorgen viele Termine habe.
Habe in der zwischen zeit auch mal ein wenig rumgetestet.
Zur Info, ich nutze zwei Nest-Minis und zwei Handys mit Google Home App.
Anzeige der Fhem-Devices ist wie gesagt auf allen Geräten deckend mit dem Fhem-Server.
Habe zum Testen ein Dummy-Device angelegt, das wurde nach kurzer Zeit auf allen Geräten korrekt erkannt. Aber ein manuelles Ausschalten auf einem der Handys wurde auf dem zweiten Handy nicht übernommen (reproduzierbar in beide Richtungen). Ein verbales Kommando wurde vom Nest-Mini bestätigt, in der Home-App aber auf beiden Handys und dem Fhem-Server nicht übernommen.
Irgendwie ist da alles nicht mehr miteinander verbunden.
Alle anderen Geräte werden interessanterweise synchronisiert. Das Chaos betrifft lediglich Geräte die per Fhem-Connect verknüpft sind.
kadettilac89
Es hört sich komisch an. In deinem Log sind connection errors, EADDRINUSE und so. Wenn der Container mit dem Image ohne irgend welche UPdates die selben Fehler bringt ist das zumindest mal ausgeschlossen. ... warten wir mal ab wie es dann aussieht.
rbm78bln
#2710
Nein, läuft nativ auf einer Ubuntu-Installation:
user@mqtt:~/gassistant-fhem-local$ node --version
v14.18.1
pi@mqtt:~/gassistant-fhem-local$ npm --version
8.1.0
pi@mqtt:~/gassistant-fhem-local$ cat package-lock.json
    "name": "gassistant-fhem-local",
    "version": "0.0.1",
    "lockfileVersion": 2,
    "requires": true,
    "packages": {
            "version": "0.0.1",
            "dependencies": {
                "gassistant-fhem": ">=0.0.0"
        "node_modules/gassistant-fhem": {
            "version": "3.0.4",
            "resolved": "https://registry.npmjs.org/gassistant-fhem/-/gassistant-fhem-3.0.4.tgz",
            "integrity": "sha512-hoogsr/tvLDZzQ4WOALqhWPnXgIytFYdTdXhFV9OKs7cS8m2uB8+MYl2DTyJxa1TqBS8gB773tNGbJdFwzXCvw==",
            "dependencies": {
            "bin": {
                "gassistant-fhem": "bin/gassistant-fhem"
Auf dem System sind keine zusätzlichen globalen packages installiert, sondern alle dependencies liegen im lokalen Verzeichnis in node_modules.
Superposchi
Also den von dir genannten Container von volchin finde ich nicht.
Es wird mir nur ein "volschin/fhem-collectord" angezeigt.
Ist das eventuell der gleiche?
den default habe ich schon mal gezogen und werde ihn versuchen gleich noch mal aufzusetzen.
kadettilac89
nein, das ist ein anderer. Ich denke volschin hat ihn vom docker hub / github auf private gesetzt da Cooltux einen neuen baut, vielleicht beteiligt sich da volschin auch.
Aber man kann ihn noch nutzen (mit docker pull) bzw. normal in deine Umgebung den Namen des containers eintragen. ... ghcr.io/volschin/fhem-experimental:dev-bullseye
.... gerade auch in Portainer geprüft, wird gefunden und verwendet.
Superposchi
Ich finde in der Grafischen Oberfläce des QNAP NAS in der Container-Station aktuell keine Möglichkeit einen bestimmten Container zu "ziehen". Das gabs mal, aber die haben wohl mit der neuen 5.0 Firmware optisch was geändert und ich finde es aktuell nicht.
Hab aber den default Container probiert und dort klappt es ohne Probleme.
Keine Ahnung was sich da so aufgehangen hat, aber war wohl schon was größeres.
kadettilac89
Ich hatte das auch schon mal, Container neu erstellen und es läuft wieder. Ich hatte mir nie die Zeit genommen da weiter zu analysieren da das Container erstellen in ein paar Minuten vorbei ist. Vielleicht werden beim neu erstellen irgend welche Sachen initialisiert ... keine Ahnung.
