hallo.
heute im log gesehen das speedtest nicht mehr klappt. hatte vor 14 tagen fhem update gemacht, vorher klappte es aber.
AttributeError: SpeedtestHTTPSConnection instance has no attribute '_context'
2019.02.06 15:31:35 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at /opt/fhem/FHEM/32_speedtest.pm line 140.
File "/usr/local/bin//speedtest-cli", line 1843, in <module>
main()
File "/usr/local/bin//speedtest-cli", line 1832, in main
shell()
File "/usr/local/bin//speedtest-cli", line 1729, in shell
secure=args.secure
File "/usr/local/bin//speedtest-cli", line 1009, in __init__
self.get_config()
File "/usr/local/bin//speedtest-cli", line 1042, in get_config
uh, e = catch_request(request, opener=self._opener)
File "/usr/local/bin//speedtest-cli", line 650, in catch_request
uh = _open(request)
File "/usr/lib/python2.7/urllib2.py", line 407, in open
response = meth(req, response)
File "/usr/lib/python2.7/urllib2.py", line 520, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python2.7/urllib2.py", line 439, in error
result = self._call_chain(*args)
File "/usr/lib/python2.7/urllib2.py", line 379, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 626, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File "/usr/lib/python2.7/urllib2.py", line 401, in open
response = self._open(req, data)
File "/usr/lib/python2.7/urllib2.py", line 419, in _open
'_open', req)
File "/usr/local/bin//speedtest-cli", line 489, in https_open
req
File "/usr/lib/python2.7/urllib2.py", line 1178, in do_open
h.request(req.get_method(), req.get_selector(), req.data, headers)
File "/usr/lib/python2.7/httplib.py", line 962, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python2.7/httplib.py", line 996, in _send_request
self.endheaders(body)
File "/usr/lib/python2.7/httplib.py", line 958, in endheaders
self._send_output(message_body)
File "/usr/lib/python2.7/httplib.py", line 818, in _send_output
self.send(msg)
File "/usr/lib/python2.7/httplib.py", line 780, in send
self.connect()
File "/usr/local/bin//speedtest-cli", line 427, in connect
self.sock = self._context.wrap_socket(self.sock, **kwargs)
hat wer tipp?
