Autor Thema: ( Erledigt ) Thermostat Logeintraege  (Gelesen 272 mal)
Offline Wolfgang Hochweller
  • Full Member
« am: 16 März 2019, 18:42:45 »
Ich verwende Z-Wave Thermostate fuer meine Fussbodenheizung :
   DEF        cfba8db6 73
   FUUID      5c80f2d1-f33f-775d-3d8c-721cd82ab5c7e1bb
   IODev      ZWAVE2
   LASTInputDev ZWAVE2
   MSGCNT     994
   NAME       HeizungWC
   NR         305
   STATE      Heat
   TYPE       ZWave
   ZWAVE2_MSGCNT 994
   ZWAVE2_RAWMSG 00040049063105012200cc
   ZWAVE2_TIME 2019-03-16 18:36:57
   ZWaveSubDevice no
   homeId     cfba8db6
   isWakeUp
   nodeIdHex  49
     2019-03-09 13:10:51   SEND_DATA       failed:00
     2019-03-16 12:26:54   UNPARSED        SWITCH_BINARY 052500040000
     2019-03-16 18:31:15   basicReport     0
     2019-03-09 13:10:22   configAHiAirMaxLimit 350
     2019-03-09 13:10:45   configALoAirMinLimit 50
     2019-03-09 13:10:58   configButtonBrightnessActiveState 60
     2019-03-09 13:10:58   configButtonBrightnessDimmedState 100
     2019-03-09 13:10:59   configCOModeSetpoint 180
     2019-03-09 13:10:59   configCOOLSetpoint 0
     2019-03-09 13:10:59   configDIFFL4    5
     2019-03-09 13:10:59   configDisplayBrightnessActiveState 60
     2019-03-09 13:10:59   configDisplayBrightnessDimmedState 10
     2019-03-09 13:11:00   configECOModeSetpoint 210
     2019-03-09 13:11:00   configExternalSensorCalibration 100
     2019-03-09 13:11:00   configFHiFloorMaxLimit 300
     2019-03-09 13:11:00   configFLoFloorMinLimit 50
     2019-03-09 13:11:00   configFloorSensorCalibration 10
     2019-03-09 13:11:00   configFloorSensorType 10kNtc
     2019-03-09 13:11:02   configOperationMode Heat
     2019-03-09 13:11:01   configPLoMinTemperatureInPowerRegMode 200
     2019-03-09 13:11:02   configPSetting  0
     2019-03-09 13:11:02   configRoomSensorCalibration 0
     2019-03-09 13:11:02   configTemperatureDisplay 10
     2019-03-09 13:11:02   configTemperatureReportInterval 10
     2019-03-09 13:11:02   configTemperatureSensor AFRoomModeWFloorLimitations
     2019-03-16 18:36:56   energy           36.4 kWh
     2019-03-07 11:31:25   mcCapability_01 ZWAVEPLUS_INFO ASSOCIATION ASSOCIATION_GRP_INFO MULTI_CHANNEL_ASSOCIATION SUPERVISION THERMOSTAT_SETPOINT THERMOSTAT_MODE
     2019-03-07 11:31:26   mcCapability_02 ZWAVEPLUS_INFO ASSOCIATION ASSOCIATION_GRP_INFO MULTI_CHANNEL_ASSOCIATION SUPERVISION SENSOR_MULTILEVEL
     2019-03-07 11:31:26   mcCapability_03 ZWAVEPLUS_INFO ASSOCIATION ASSOCIATION_GRP_INFO MULTI_CHANNEL_ASSOCIATION SUPERVISION SENSOR_MULTILEVEL
     2019-03-07 11:31:26   mcCapability_04 ZWAVEPLUS_INFO ASSOCIATION ASSOCIATION_GRP_INFO MULTI_CHANNEL_ASSOCIATION SUPERVISION SWITCH_BINARY METER
     2019-03-07 11:31:23   mcEndpoints     total 4, different
     2019-03-07 11:31:25   model           ThermoFloor AS Heatit Thermostat TF 033
     2019-03-07 11:31:25   modelConfig     thermofloor/heatit033.xml
     2019-03-07 11:31:25   modelId         019b-0003-0202
     2019-03-07 14:29:46   neighborList    LichtFlur Warmwasser
     2019-03-07 14:27:35   neighborUpdate  done
     2019-03-16 18:36:56   power            0.02 W
     2019-03-09 10:57:11   setpointTemp    20.0 C heating
     2019-03-09 13:11:28   state           tmHeating
     2019-03-16 18:36:57   temperature     20.4 C
     2019-03-09 12:05:35   thermostatMode  heating
     2019-03-09 13:11:28   timeToAck       0.094
     2019-03-09 13:11:28   transmit        OK
     2019-03-09 22:38:28   undef           0.07 undef
     2019-03-16 18:36:56   voltage          239 V
   IODev      ZWAVE2
   classes    ZWAVEPLUS_INFO ASSOCIATION ASSOCIATION_GRP_INFO MULTI_CHANNEL_ASSOCIATION MULTI_CHANNEL TRANSPORT_SERVICE VERSION MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY POWERLEVEL SECURITY SECURITY_S2 SUPERVISION CONFIGURATION FIRMWARE_UPDATE_MD THERMOSTAT_SETPOINT THERMOSTAT_MODE METER
   devStateIcon .*Off:vent_ventilation .*Heat:sani_heating
   eventMap   /tmOff:Off/tmHeating:Heat
   icon       sani_floor_heating
   room       Heizung,ZWave
   vclasses   ASSOCIATION:2 DEVICE_RESET_LOCALLY:1 FIRMWARE_UPDATE_MD:4 MANUFACTURER_SPECIFIC:2 METER:3 MULTI_CHANNEL:4 MULTI_CHANNEL_ASSOCIATION:3 POWERLEVEL:1 SECURITY:1 SECURITY_S2:1 SUPERVISION:1 THERMOSTAT_MODE:3 THERMOSTAT_SETPOINT:3 TRANSPORT_SERVICE:2 VERSION:3 ZWAVEPLUS_INFO:2
   webCmd     Off:Heat
Die Logeintraege sehen so aus :
2019-03-16_00:00:45 HeizungWC energy:  34.2 kWh
2019-03-16_00:00:45 HeizungWC power:  427.96 W
2019-03-16_00:00:45 HeizungWC voltage:  242.7 V
2019-03-16_00:00:45 HeizungWC temperature: 0.0 C
2019-03-16_00:00:46 HeizungWC temperature: 20.2 C
Die Temperaturwerte werden immer zweimal angezeigt. Warum ?
Das ist übrigens bei allen Thermostaten diese Typs so.
« Letzte Änderung: 16 März 2019, 22:18:35 von howi42 »
Offline rudolfkoenig
  • Administrator
Antw:Thermostat Logeintraege
« Antwort #1 am: 16 März 2019, 18:59:41 »
Eine der Moeglichkeiten ist, dass FHEM (vertreten durch den ZWave Controller) in mehreren Assoziazionsgruppen des Geraetes steckt, und das Geraet sendet die Daten blind an jede eingetragene Einheit.
