ständige Reconnects bei alexa-fhem und gassistant
Begonnen von PingPong, 20 März 2019, 10:58:41
PingPong
ich habe seit gestern ständige reconnects im Log bzgl. alexa und gassistant.
Hier mal ein Auszug aus dem alexa log:
*** FHEM: connected
[2019-3-20 09:13:02] [FHEM] got: 5 results
[2019-3-20 09:13:02] [FHEM] Gartenbeleuchtung is light
[2019-3-20 09:13:02] [FHEM] Gartenbeleuchtung has
[2019-3-20 09:13:02] [FHEM]   On [onoff;on,off]
[2019-3-20 09:13:02] [FHEM]   Brightness [bri]
[2019-3-20 09:13:02] [FHEM] Kugellampen is light
[2019-3-20 09:13:02] [FHEM] Kugellampen has
[2019-3-20 09:13:02] [FHEM] SchlafzimmerLampen is light
[2019-3-20 09:13:02] [FHEM] SchlafzimmerLampen has
[2019-3-20 09:13:02] [FHEM]   On [state;on,off]
  2019-03-20 09:13:02 caching: SchlafzimmerLampen-state: off
[2019-3-20 09:13:02] [FHEM] aussen_alle is light
[2019-3-20 09:13:02] [FHEM] aussen_alle has
[2019-3-20 09:13:02] [FHEM]   Hue [hue;hue;0-65535]
[2019-3-20 09:13:02] [FHEM]   Saturation [sat;sat;0-254]
[2019-3-20 09:13:02] [FHEM]   Custom Color Temperature [ct]
[2019-3-20 09:13:02] [FHEM] aussen_alle-ct not a number: undefined
[2019-3-20 09:13:02] [FHEM] ku.Staubsauger_dummy is switch
[2019-3-20 09:13:02] [FHEM] ku.Staubsauger_dummy has
  2019-03-20 09:13:02 caching: ku.Staubsauger_dummy-state: off
[2019-3-20 09:13:02] [FHEM] alexa device is alexa
[2019-3-20 09:13:02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.24%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] Server listening on: http://127.0.0.1:38505 for proxy connections
[2019-3-20 09:13:02] *** SSH: checking proxy configuration
[2019-3-20 09:13:02] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2019-3-20 09:13:02] Passed config: {"connections":[{"port":"8083","name":"FHEM","uid":999,"webname":"fhem","server":"127.0.0.1","filter":"room=30_Sprachassistent->01_Alexa"}],"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":38505}}
[2019-3-20 09:13:02] sshautoconf: SSH key seems to exist
[2019-3-20 09:13:02] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2019-3-20 09:13:02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] BearerToken '...89F02' read from alexa
[2019-3-20 09:13:02] [FHEM] got .eventToken
[2019-3-20 09:13:02] refreshing token
[2019-3-20 09:13:02] 39_alexa.pm is new version: true
[2019-3-20 09:13:02] sshautoconf: completed successfully
[2019-3-20 09:13:02] *** SSH: proxy configuration set up done
[2019-3-20 09:13:02] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2019-3-20 09:13:02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] Starting SSH with -R 1234:127.0.0.1:38505 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2019-3-20 09:13:02] failed to refresh token: invalid_grant: 'The request has an invalid grant parameter : refresh_token'
[2019-3-20 09:13:03] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2019-3-20 09:13:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:03] *** SSH: proxy connection established
[2019-3-20 09:13:03] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[2019-3-20 09:14:01] [FHEM] longpoll ended, reconnect in: 200msec
[2019-3-20 09:14:01] [FHEM] trying longpoll to listen for fhem events
[2019-3-20 09:14:01] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069641904
[2019-3-20 09:14:03] [FHEM] got csrfToken: csrf_927594780954401
[2019-3-20 09:14:03] [FHEM] Checking devices and attributes...
[2019-3-20 09:14:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20TYPE%3Dalexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM] waiting for events ...
[2019-3-20 09:14:03] [FHEM] Fetching FHEM devices...
[2019-3-20 09:14:03] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E01_Alexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM] alexa device is alexa
[2019-3-20 09:14:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.24%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] Server emitted error: {"errno":"EADDRINUSE","code":"EADDRINUSE","syscall":"listen","address":"127.0.0.1","port":38505}
[2019-3-20 09:14:03] Terminating - starting the listener not possible (another instance running?)
[2019-3-20 09:14:04] using config from ./alexa-fhem.cfg
*** CONFIG: parsed completely
[2019-3-20 09:14:04] os.homedir()=/opt/fhem
[2019-3-20 09:14:04] this is alexa-fhem 0.5.24
[2019-3-20 09:14:04] connecting to FHEM ...
[2019-3-20 09:14:05] [FHEM] trying longpoll to listen for fhem events
[2019-3-20 09:14:05] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069645215
[2019-3-20 09:14:05] [FHEM] got csrfToken: csrf_927594780954401
[2019-3-20 09:14:05] [FHEM] Checking devices and attributes...
[2019-3-20 09:14:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] [FHEM] waiting for events ...
[2019-3-20 09:14:05] [FHEM] Fetching FHEM devices...
[2019-3-20 09:14:05] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E01_Alexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] [FHEM] alexa device is alexa
[2019-3-20 09:14:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.24%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] Server listening on: http://127.0.0.1:35507 for proxy connections
[2019-3-20 09:14:05] *** SSH: checking proxy configuration
[2019-3-20 09:14:05] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2019-3-20 09:14:05] Passed config: {"connections":[{"port":"8083","name":"FHEM","uid":999,"webname":"fhem","server":"127.0.0.1","filter":"room=30_Sprachassistent->01_Alexa"}],"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":35507}}
[2019-3-20 09:14:05] sshautoconf: SSH key seems to exist
[2019-3-20 09:14:06] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2019-3-20 09:14:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
*** FHEM: connected
[2019-3-20 09:14:06] [FHEM] got: 5 results
[2019-3-20 09:14:06] [FHEM] Gartenbeleuchtung is light
[2019-3-20 09:14:06] [FHEM] Gartenbeleuchtung has
[2019-3-20 09:14:06] [FHEM]   On [onoff;on,off]
[2019-3-20 09:14:06] [FHEM]   Brightness [bri]
[2019-3-20 09:14:06] [FHEM] Kugellampen is light
[2019-3-20 09:14:06] [FHEM] Kugellampen has
[2019-3-20 09:14:06] [FHEM] SchlafzimmerLampen is light
[2019-3-20 09:14:06] [FHEM] SchlafzimmerLampen has
[2019-3-20 09:14:06] [FHEM]   On [state;on,off]
  2019-03-20 09:14:06 caching: SchlafzimmerLampen-state: off
[2019-3-20 09:14:06] [FHEM] aussen_alle is light
[2019-3-20 09:14:06] [FHEM] aussen_alle has
[2019-3-20 09:14:06] [FHEM]   Hue [hue;hue;0-65535]
[2019-3-20 09:14:06] [FHEM]   Saturation [sat;sat;0-254]
[2019-3-20 09:14:06] [FHEM]   Custom Color Temperature [ct]
[2019-3-20 09:14:06] [FHEM] aussen_alle-ct not a number: undefined
[2019-3-20 09:14:06] [FHEM] ku.Staubsauger_dummy is switch
[2019-3-20 09:14:06] [FHEM] ku.Staubsauger_dummy has
  2019-03-20 09:14:06 caching: ku.Staubsauger_dummy-state: off
[2019-3-20 09:14:06] [FHEM] got .eventToken
[2019-3-20 09:14:06] refreshing token
[2019-3-20 09:14:06] BearerToken '...89F02' read from alexa
[2019-3-20 09:14:06] 39_alexa.pm is new version: true
[2019-3-20 09:14:06] sshautoconf: completed successfully
[2019-3-20 09:14:06] *** SSH: proxy configuration set up done
[2019-3-20 09:14:06] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2019-3-20 09:14:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:06] Starting SSH with -R 1234:127.0.0.1:35507 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2019-3-20 09:14:06] failed to refresh token: invalid_grant: 'The request has an invalid grant parameter : refresh_token'
[2019-3-20 09:14:06] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2019-3-20 09:14:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:06] *** SSH: proxy connection established
[2019-3-20 09:14:06] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[2019-3-20 09:15:05] [FHEM] longpoll ended, reconnect in: 200msec
[2019-3-20 09:15:05] [FHEM] trying longpoll to listen for fhem events
[2019-3-20 09:15:05] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069705415
[2019-3-20 09:15:06] [FHEM] got csrfToken: csrf_927594780954401
[2019-3-20 09:15:06] [FHEM] Checking devices and attributes...
[2019-3-20 09:15:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20TYPE%3Dalexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:06] [FHEM] waiting for events ...
[2019-3-20 09:15:06] [FHEM] Fetching FHEM devices...
[2019-3-20 09:15:06] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E01_Alexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:07] [FHEM] alexa device is alexa
[2019-3-20 09:15:07] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.24%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:07] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:07] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:07] Server emitted error: {"errno":"EADDRINUSE","code":"EADDRINUSE","syscall":"listen","address":"127.0.0.1","port":35507}
[2019-3-20 09:15:07] Terminating - starting the listener not possible (another instance running?)
[2019-3-20 09:15:07] using config from ./alexa-fhem.cfg
[2019-3-20 09:15:07] os.homedir()=/opt/fhem
[2019-3-20 09:15:07] this is alexa-fhem 0.5.24
[2019-3-20 09:15:07] connecting to FHEM ...
[2019-3-20 09:15:08] [FHEM] trying longpoll to listen for fhem events
[2019-3-20 09:15:08] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069708574
[2019-3-20 09:15:08] [FHEM] got csrfToken: csrf_927594780954401
[2019-3-20 09:15:08] [FHEM] Checking devices and attributes...
[2019-3-20 09:15:08] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:08] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:08] [FHEM] waiting for events ...
[2019-3-20 09:15:08] [FHEM] Fetching FHEM devices...
[2019-3-20 09:15:08] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E01_Alexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:09] [FHEM] alexa device is alexa
[2019-3-20 09:15:09] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.24%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:09] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:09] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:09] Server listening on: http://127.0.0.1:41705 for proxy connections
[2019-3-20 09:15:09] *** SSH: checking proxy configuration
[2019-3-20 09:15:09] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2019-3-20 09:15:09] Passed config: {"connections":[{"port":"8083","name":"FHEM","uid":999,"webname":"fhem","server":"127.0.0.1","filter":"room=30_Sprachassistent->01_Alexa"}],"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":41705}}
[2019-3-20 09:15:09] sshautoconf: SSH key seems to exist
[2019-3-20 09:15:09] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2019-3-20 09:15:09] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
*** FHEM: connected
[2019-3-20 09:15:09] [FHEM] got: 5 results
[2019-3-20 09:15:09] [FHEM] Gartenbeleuchtung is light
[2019-3-20 09:15:09] [FHEM] Gartenbeleuchtung has
[2019-3-20 09:15:09] [FHEM]   On [onoff;on,off]
[2019-3-20 09:15:09] [FHEM]   Brightness [bri]
[2019-3-20 09:15:09] [FHEM] Kugellampen is light
[2019-3-20 09:15:09] [FHEM] Kugellampen has
[2019-3-20 09:15:09] [FHEM] SchlafzimmerLampen is light
[2019-3-20 09:15:09] [FHEM] SchlafzimmerLampen has
[2019-3-20 09:15:09] [FHEM]   On [state;on,off]
  2019-03-20 09:15:09 caching: SchlafzimmerLampen-state: off
[2019-3-20 09:15:09] [FHEM] aussen_alle is light
[2019-3-20 09:15:09] [FHEM] aussen_alle has
[2019-3-20 09:15:09] [FHEM]   Hue [hue;hue;0-65535]
[2019-3-20 09:15:09] [FHEM]   Saturation [sat;sat;0-254]
[2019-3-20 09:15:09] [FHEM]   Custom Color Temperature [ct]
[2019-3-20 09:15:09] [FHEM] aussen_alle-ct not a number: undefined
[2019-3-20 09:15:09] [FHEM] ku.Staubsauger_dummy is switch
[2019-3-20 09:15:09] [FHEM] ku.Staubsauger_dummy has
  2019-03-20 09:15:09 caching: ku.Staubsauger_dummy-state: off
[2019-3-20 09:15:09] BearerToken '...89F02' read from alexa
[2019-3-20 09:15:09] [FHEM] got .eventToken
[2019-3-20 09:15:09] refreshing token
[2019-3-20 09:15:09] 39_alexa.pm is new version: true
[2019-3-20 09:15:09] sshautoconf: completed successfully
[2019-3-20 09:15:09] *** SSH: proxy configuration set up done
[2019-3-20 09:15:09] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2019-3-20 09:15:09] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:09] Starting SSH with -R 1234:127.0.0.1:41705 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2019-3-20 09:15:10] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2019-3-20 09:15:10] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:10] *** SSH: proxy connection established
[2019-3-20 09:15:10] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[2019-3-20 09:15:10] failed to refresh token: invalid_grant: 'The request has an invalid grant parameter : refresh_token'
[2019-3-20 09:16:05] Got SIGTERM, shutting down alexa-fhem...
[2019-3-20 09:16:05] Reading alexaFHEM.ProxyConnection set to stopping;; alexa-fhem terminating
[2019-3-20 09:16:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopping%3B%3B%20alexa-fhem%20terminating%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:16:05] Stopping SSH ...
[2019-3-20 09:16:05] Reading alexaFHEM.ProxyConnection set to stopped
[2019-3-20 09:16:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopped%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:16:05] *** SSH: exited with 143
und ein Auszug aus dem gassitant log:
[2019-3-20 09:09:40] ---
[2019-3-20 09:09:40] Google Assistant FHEM Connect 1.3.0 started
[2019-3-20 09:09:40] Fetching FHEM connections...
[2019-3-20 09:09:40] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069380808
  executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dgassistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:01] [FHEM] FHEM Google Assistant device detected: gassistant
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-version%201.3.0&fwcsrf=csrf_927594780954401&XHR=1
  executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3Dg2Hy0t8LiEZW9xXERS8V0GZixyMMc2YS3D-xD-IvHgM%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:01] [FHEM] Get refresh token...
  executing: http://127.0.0.1:8083/fhem?cmd=get%20gassistant%20refreshToken&fwcsrf=csrf_927594780954401&XHR=1
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:03] [FHEM] Found refresh token in reading
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-versionAvailable%201.3.0&fwcsrf=csrf_927594780954401&XHR=1
Refresh tokens finished. Next refresh in 86400 seconds.
[2019-3-20 09:10:05] [FHEM] refreshAllTokens executed
[2019-3-20 09:10:05] [FHEM] Fetching FHEM devices...
[2019-3-20 09:10:05] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:06] [FHEM] start connection executed
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20none&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:06] [FHEM] Checking devices and attributes...
(node:9020) DeprecationWarning: grpc.load: Use the @grpc/proto-loader module with grpc.loadPackageDefinition instead
DynamicFunctions updated
[2019-3-20 09:10:07] [FHEM] got: 1 results
[2019-3-20 09:10:07] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
SERVER FeatureLevel:{"featurelevel":2,"changelog":"implement Google Report State"}
SYNC   FeatureLevel:{"featurelevel":0}
>>> VERSION UPGRADE STARTED
[2019-3-20 09:10:07] [FHEM] reloading http://127.0.0.1:8083/fhem
[2019-3-20 09:10:07] [FHEM] Fetching FHEM devices...
[2019-3-20 09:10:07] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=csrf_927594780954401&XHR=1
update reading: HUEDevice19:colormode = ct
update reading: HUEDevice19:ct = 250 (4000K)
update reading: HUEDevice19:hue = 0
update reading: HUEDevice19:onoff = 0
update reading: HUEDevice19:pct = 0
update reading: HUEDevice19:reachable = 1
update reading: HUEDevice19:rgb = ffe4ce
update reading: HUEDevice19:sat = 0
>>> VERSION UPGRADE FINISHED - SYNC INITIATED
reportstateall initiated
[2019-3-20 09:10:49] [FHEM] longpoll ended, reconnect in: 200msec
[2019-3-20 09:10:50] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069450008
[2019-3-20 09:10:52] [FHEM] FHEM Google Assistant device detected: gassistant
  executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3DrwHIgrtqwZ_rWPF8myC6-som9oiojJXgaij2WK4m6Ng%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:52] [FHEM] Get refresh token...
[2019-3-20 09:10:52] [FHEM] Found refresh token in reading
[2019-3-20 09:10:54] [FHEM] refreshAllTokens executed
[2019-3-20 09:10:54] [FHEM] Fetching FHEM devices...
[2019-3-20 09:10:54] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:54] [FHEM] start connection executed
[2019-3-20 09:10:54] [FHEM] Checking devices and attributes...
[2019-3-20 09:10:54] [FHEM] got: 1 results
[2019-3-20 09:10:54] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
[2019-3-20 09:10:55] [FHEM] reloading http://127.0.0.1:8083/fhem
[2019-3-20 09:10:55] [FHEM] Fetching FHEM devices...
[2019-3-20 09:10:55] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:55] [FHEM] got: 1 results
[2019-3-20 09:11:53] [FHEM] longpoll ended, reconnect in: 200msec
[2019-3-20 09:11:53] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069513939
[2019-3-20 09:11:55] [FHEM] FHEM Google Assistant device detected: gassistant
  executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3D1DbdpgUgkAMCttVZl27MSVhxvCcBR-FM-BlYYvQgr5E%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:11:55] [FHEM] Get refresh token...
[2019-3-20 09:11:56] [FHEM] Found refresh token in reading
[2019-3-20 09:11:58] [FHEM] refreshAllTokens executed
[2019-3-20 09:11:58] [FHEM] Fetching FHEM devices...
[2019-3-20 09:11:58] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:11:58] [FHEM] start connection executed
[2019-3-20 09:11:58] [FHEM] Checking devices and attributes...
[2019-3-20 09:11:58] [FHEM] got: 1 results
[2019-3-20 09:11:59] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
[2019-3-20 09:11:59] [FHEM] reloading http://127.0.0.1:8083/fhem
[2019-3-20 09:11:59] [FHEM] Fetching FHEM devices...
[2019-3-20 09:11:59] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:11:59] [FHEM] got: 1 results
[2019-3-20 09:12:57] [FHEM] longpoll ended, reconnect in: 200msec
[2019-3-20 09:12:57] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069577892
[2019-3-20 09:13:00] [FHEM] FHEM Google Assistant device detected: gassistant
  executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3Dv8GH1Wd5yJajSYgogsaSq7zYWt6m85IJo0KPFUTHkH4%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:00] [FHEM] Get refresh token...
[2019-3-20 09:13:00] [FHEM] Found refresh token in reading
[2019-3-20 09:13:02] [FHEM] refreshAllTokens executed
[2019-3-20 09:13:02] [FHEM] Fetching FHEM devices...
[2019-3-20 09:13:02] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] [FHEM] start connection executed
[2019-3-20 09:13:02] [FHEM] Checking devices and attributes...
[2019-3-20 09:13:02] [FHEM] got: 1 results
[2019-3-20 09:13:03] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
[2019-3-20 09:13:03] [FHEM] reloading http://127.0.0.1:8083/fhem
[2019-3-20 09:13:03] [FHEM] Fetching FHEM devices...
[2019-3-20 09:13:03] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:03] [FHEM] got: 1 results
[2019-3-20 09:14:01] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069641895
[2019-3-20 09:14:03] [FHEM] FHEM Google Assistant device detected: gassistant
  executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3DBb2EyP8rMVcgEH7X_Y7JFH9ShKy2We4J60MoLL-HtB8%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM] Get refresh token...
[2019-3-20 09:14:03] [FHEM] Found refresh token in reading
[2019-3-20 09:14:05] [FHEM] refreshAllTokens executed
[2019-3-20 09:14:06] [FHEM] Fetching FHEM devices...
[2019-3-20 09:14:06] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:06] [FHEM] start connection executed
[2019-3-20 09:14:06] [FHEM] Checking devices and attributes...
[2019-3-20 09:14:06] [FHEM] got: 1 results
[2019-3-20 09:14:07] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
[2019-3-20 09:14:07] [FHEM] reloading http://127.0.0.1:8083/fhem
[2019-3-20 09:14:07] [FHEM] Fetching FHEM devices...
[2019-3-20 09:14:07] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:07] [FHEM] got: 1 results
[2019-3-20 09:14:43] Got SIGTERM, shutting down...
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20disconnected&fwcsrf=csrf_927594780954401&XHR=1
Hat einer von Euch Idee, woran das liegen könnte?
VieleN Dank
Marc
PingPong
kann ich vielleicht noch zusätzliche Informationen beisteuern?
Bin ich wirklich der einzige, mit dem Problem?
SouzA
Ich nutze nur Google, habe aber keine reconnects.
Könnte es sein, dass deine Internetleitung nicht stabil ist?
Mal ins log des Routers geschaut?
Hast du eine Automatik laufen, die Module oä updaten soll?
Bis denn
SouzA
Raspi 4, EnOcean TCM310 USB, HM-MOD-UART-USB, Jeelink, hue, AMAD, fully, FRITZBOX, Signalbot, VIERA, Presence BT/Mac, TPLink, Gassistant, Shelly, fhempy, ZigBee
PingPong
Hi, danke für Deine Antwort.
Ja, ins Routerlog habe ich geschaut, da sind keine Auffälligkeiten - keine Anzeichen für ein Problem.
An was für eine Automatik denkst Du? Bewusst habe ich in der Art nichts laufen.
justme1968
was ist das für ein system?
setz mal verbose 4 für fhemweb. was sieht du dort im log wenn die verbindung beendet wird?
PingPong
was meinst Du mit "Was ist das für ein System?"
Hier das Log:
2019.03.23 21:31:41 4: Connection accepted from WEB_127.0.0.1_55200
2019.03.23 21:31:41 4: WEB_127.0.0.1_55200 GET /fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_166221922029187&XHR=1; BUFLEN:0
2019.03.23 21:31:41 4: WEB: /fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_166221922029187&XHR=1 / RL:274 / text/plain; charset=UTF-8 / Content-Encoding: gzip
/ Cache-Control: no-cache, no-store, must-revalidate
2019.03.23 21:31:41 4: Connection closed for WEB_127.0.0.1_55196: EOF
2019.03.23 21:31:41 4: Connection closed for WEB_127.0.0.1_55198: EOF
2019.03.23 21:31:41 4: Connection closed for WEB_127.0.0.1_55200: EOF
2019.03.23 21:31:41 4: Connection accepted from WEB_127.0.0.1_55218
2019.03.23 21:31:41 4: WEB_127.0.0.1_55218 GET /fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_166221922029187&XHR=1; BUFLEN:0
2019.03.23 21:31:41 4: WEB: /fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_166221922029187&XHR=1 / RL:1673 / application/json; charset=utf-8 / Content-Encoding: gzip
2019.03.23 21:31:41 4: Connection closed for WEB_127.0.0.1_55218: EOF
2019.03.23 21:31:41 4: Connection accepted from WEB_127.0.0.1_55224
2019.03.23 21:31:41 4: WEB_127.0.0.1_55224 GET /fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_166221922029187&XHR=1; BUFLEN:0
2019.03.23 21:31:41 4: WEB: /fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_166221922029187&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.23 21:31:41 4: Connection closed for WEB_127.0.0.1_55224: EOF
2019.03.23 21:31:42 4: Connection accepted from WEB_127.0.0.1_55264
2019.03.23 21:31:42 4: WEB_127.0.0.1_55264 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=csrf_166221922029187&XHR=1; BUFLEN:0
2019.03.23 21:31:42 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=csrf_166221922029187&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.23 21:31:42 4: Connection closed for WEB_127.0.0.1_55264: EOF
2019.03.23 21:31:42 4: Connection accepted from WEB_127.0.0.1_55272
2019.03.23 21:31:42 4: WEB_127.0.0.1_55272 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=csrf_166221922029187&XHR=1; BUFLEN:0
2019.03.23 21:31:42 4: Connection closed for WEB_127.0.0.1_55272: EOF
2019.03.23 21:31:43 4: WEB_192.168.178.35_52697 GET /fhem/FileLog_logWrapper&dev=gassistantFHEMlog&type=text&file=gassistant-2019-03-23.log; BUFLEN:0
2019.03.23 21:31:43 4: Connection closed for WEB_192.168.178.35_52723: EOF
2019.03.23 21:31:44 4: Connection accepted from WEB_192.168.178.35_52724
2019.03.23 21:31:50 4: Connection closed for WEB_192.168.178.35_52712: EOF
2019.03.23 21:31:50 4: Connection closed for WEB_192.168.178.35_52713: EOF
2019.03.23 21:31:50 4: Connection closed for WEB_192.168.178.35_52715: EOF
2019.03.23 21:31:50 4: Connection closed for WEB_192.168.178.35_52714: EOF
2019.03.23 21:32:09 4: WEB_192.168.178.35_52697 GET /fhem/FileLog_logWrapper&dev=gassistantFHEMlog&type=text&file=gassistant-2019-03-23.log; BUFLEN:0
2019.03.23 21:32:09 4: Connection closed for WEB_192.168.178.35_52724: EOF
2019.03.23 21:32:11 4: Connection accepted from WEB_192.168.178.35_52725
2019.03.23 21:32:20 4: Connection closed for WEB_192.168.178.35_52711: EOF
2019.03.23 21:32:20 4: WEB_192.168.178.35_52697 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
amenomade
Zitat[2019-3-20 09:15:07] Server emitted error: {"errno":"EADDRINUSE","code":"EADDRINUSE","syscall":"listen","address":"127.0.0.1","port":35507}
Das ist m.M.n. nicht normal. Was lauscht schon auf dem port 35507 ? Hast Du noch ne alte alexa-fhem Installation als Dienst?
PingPong
Nein, eigentlich nicht.
Habe FHEM komplett neu aufgesetzt. Da können eigentlich keine alten Reste sein.
dominik
Guter Punkt, im Log betrifft es nicht nur den Port 35507, sondern auch ein anderer Port 38505 wird ebenfalls als belegt gemeldet.
Kann es sein, dass du irgendwelche extra Sicherheitseinstellungen nutzt die die Ports blockieren?
fhempy -  https://github.com/fhempy/fhempy: GoogleCast, Tuya, UPnP, Ring, EQ3BT, Nespresso, Xiaomi, Spotify, Object Detection, ...
Kaffeespende: https://paypal.me/todominik
PingPong
Auch da nicht wissentlich.
Habe mMn keine besonderen Einstellungen vorgenommen.
Du meinst jetzt schon in fhem oder?
amenomade
Was sagt :
sudo netstat -lntp |grep 35507
sudo netstat -lntp |grep 38505
PingPong
beim dem Befehl kommt leider kein Ergebnis als Antwort. Der Cursor springt direkt wieder in die Eingabezeile.
Muss ich hier vorher etwas installieren? Oder wird das Ergebnis irgendwo weggeschrieben?
dominik
Nein, nicht FHEM, sondern die Linux Installation. Was nutzt du? Raspbian stretch?
PingPong
Habe mein System auf Basis über die Installation Homematic All-In-One Images von der io-broker Seite aufgesetzt.
Grundlage dürfte gem. Doku ein Raspbian light Stretch sein.
dominik
Mach mal ein komplett sauberes Raspbian stretch. Die Installation von NOOBS kann ich auch empfehlen, geht schneller und viele Sachen werden gleich bei der Installation abgefragt und richtig gesetzt.
