Zwei Cul nur einer sendet
Begonnen von mrbreil, 02 April 2019, 10:27:19
mrbreil
Hallo, da ich Probleme mit meinen Credits bekam, habe ich im Obergeschoß einen weiteren Cul per Ser2net angeschlossen.
Cul EG
   CMDS       ABbCeFGhiKkLlMmNRTtUuVWXxYZ
   CUL_MAX_MSGCNT 102
   CUL_MAX_TIME 2019-04-02 10:18:45
   Clients    :CUL_MAX:HMS:CUL_IR:STACKABLE_CC:TSSTACKED:STACKABLE:
   DEF        antenne.breilnet-suennen.de:2001 1234
   DeviceName antenne.breilnet-suennen.de:2001
   FD         10
   FHTID      1234
   FUUID      5c4a0987-f33f-76a9-add7-d73f8c3f9329aa33
   NAME       CUL_MAX
   NR         129
   NR_CMD_LAST_H 27
   PARTIAL
   RAWMSG     Z0C4504421365860000000022B410
   RSSI       -66
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.67 CUL868
   initString X21
Zr
Za123456
Zw111111
   Helper:
     DBLOG:
       credit10ms:
         DBLogging:
           TIME       1554193198.81245
           VALUE      900
   MatchList:
     1:CUL_MAX  ^Z........................
     8:HMS      ^810e04....(1|5|9).a001
     D:CUL_IR   ^I............
     H:STACKABLE_CC ^\*
     M:TSSTACKED ^\*
     N:STACKABLE ^\*
     2019-04-02 09:19:56   cmds             A B b C e F G h i K k L l M m N R T t U u V W X x Y Z
     2019-04-02 10:19:58   credit10ms      900
     2019-04-02 10:18:45   state           Initialized
   XMIT_TIME:
     1554189596.35146
     1554189596.65192
     1554189626.97844
     1554189628.47527
     1554189634.97613
     1554189819.2761
     1554189825.78461
     1554189832.28646
     1554189838.84649
     1554190532.88576
     1554190535.15931
     1554190541.67944
     1554190548.18181
     1554190717.84762
     1554190852.28729
     1554190858.8425
     1554190865.3559
     1554190866.85459
     1554190867.94398
     1554190874.40215
     1554190880.95184
     1554190987.475
     1554191096.9798
     1554191206.49202
     1554191315.99177
     1554191434.49937
     1554191546.0056
   DbLogInclude credit10ms
   group      Antenne
   rfmode     MAX
   room       Interfaces
Cul OG
   CMDS       BbCFiAZEkGMKUYRTVWXefmltux
   CUL_MAX_Oben_MSGCNT 124
   CUL_MAX_Oben_TIME 2019-04-02 10:21:37
   DEF        antenne-oben.breilnet-suennen.de:2000 4321
   DeviceName antenne-oben.breilnet-suennen.de:2000
   FD         19
   FHTID      4321
   FUUID      5c9c8772-f33f-76a9-d217-eb0dad745f346a9c
   NAME       CUL_MAX_Oben
   NR         329
   NR_CMD_LAST_H 14
   PARTIAL
   RAWMSG     Z0C4604421365860000000022B418
   RSSI       -62
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.63 CUL868
   initString X21
Zr
Za654321
Zw111111
   Helper:
     DBLOG:
       credit10ms:
         DBLogging:
           TIME       1554193258.79484
           VALUE      900
   MatchList:
     H:STACKABLE_CC ^\*
     M:TSSTACKED ^\*
     N:STACKABLE ^\*
     2019-04-02 09:19:58   cmds             B b C F i A Z E k G M K U Y R T V W X e f m l t u x
     2019-04-02 10:20:58   credit10ms      900
     2019-04-02 10:21:37   state           Initialized
   XMIT_TIME:
     1554189598.96061
     1554189599.26107
     1554189629.58071
     1554189636.08362
     1554189642.59514
     1554189649.09189
     1554189653.72393
     1554189703.22613
     1554189811.72449
     1554189920.2318
     1554190684.23152
     1554190690.31229
     1554190696.81592
     1554190703.32284
   group      Antenne
   rfmode     MAX
   room       Interfaces
Und die passenden Max Device's erstellt.
Max EG
   CUL_MAX_MSGCNT 86
   CUL_MAX_Oben_MSGCNT 74
   CUL_MAX_Oben_RAWMSG Z0C4604421365860000000022B4
   CUL_MAX_Oben_RSSI -62
   CUL_MAX_RAWMSG Z0C4604421365860000000022B4
   CUL_MAX_RSSI -66
   CUL_MAX_TIME 2019-04-02 10:21:37
   DEF        123456
   FUUID      5c4a0a5a-f33f-76a9-8f12-e6df249967c6332e
   IODev      CUL_MAX
   LASTInputDev CUL_MAX
   MSGCNT     86
   NAME       MAX
   NR         130
   STATE      Defined
   TYPE       CUL_MAX
   addr       123456
   cnt        0
   pairmode   0
   retryCount 0
     2019-04-02 10:20:52   packetsLost     1042
   sendQueue:
     HASH(0x5611b0e536e0)
   IODev      CUL_MAX
   group      Antenne
   room       Interfaces
Max OG
   CUL_MAX_MSGCNT 19
   CUL_MAX_Oben_MSGCNT 50
   CUL_MAX_Oben_RAWMSG Z0F26040312345614676A0013020A5431
   CUL_MAX_Oben_RSSI -89
   CUL_MAX_Oben_TIME 2019-04-02 10:20:50
   CUL_MAX_RAWMSG Z0C4304421365860000000022B4
   CUL_MAX_RSSI -66.5
   CUL_MAX_TIME 2019-04-02 10:12:50
   DEF        654321
   FUUID      5c9c888b-f33f-76a9-e376-6743732f0e881853
   IODev      CUL_MAX_Oben
   LASTInputDev CUL_MAX_Oben
   MSGCNT     50
   NAME       MAX_Oben
   NR         330
   STATE      Defined
   TYPE       CUL_MAX
   addr       654321
   cnt        0
   pairmode   0
   retryCount 0
     2019-04-02 09:38:26   packetsLost     108
   sendQueue:
   IODev      CUL_MAX_Oben
   group      Antenne
   room       Interfaces
Setze ich jetzt ein "set MAX_Oben pairmode 60" ab, verringern sich die Credit's vom Cul im EG nicht OG.
Habe ich einen Denkfehler? Verstehe dieses Verhalten nicht. Vielleicht weiß einer von euch Rat.
Gruß Christian
Maui
Ich meine mich zu erinnern, dass die IODev's nicht treu sind. Die wandern bei MAX immer um auf den zuletzt quatschenden. Müsste man hier im Forum auch was zu finden.
Das sauberste bei MAX scheint wohl wirklich 2 fhem Instanzen zu sein.
Wzut
die haben wir fast alle , aber man könnte auch aus der 900 im Quelltext eine 3600 machen und hätte nie mehr Probleme, es soll User geben die das gemacht haben .....
Maui
Man müsste aber dann streng genommen den 2. CUL wieder abschalten oder beide auf 1800.
und es kann ja auch ein credits Problem mit zu hoher Reichweite sein. Häufig gibt es ja nur dann ein credits Problem, wenn etwas anderes nicht passt und frei dreht.
PS: ich würde meinen dyndns nicht öffentlich hier rein schreiben
