Enocean USB300, Connecting to Micropelt MVA 005
Begonnen von zia, 03 April 2019, 13:42:46
zia
Dear All,
I am currently designing a Home Automation System, I am using RPi3 for micro controller and using USB 300 to connect to MVA 005 Radiator valve.
I have followed the tutorials and mange to run FHEM on my browser. I want some references ideas how can I connect to the Valve using the Enocean USB?
Please share some solutions.
I am following the tutorials.
https://www.enocean.com/fileadmin/redaktion/pdf/white_paper/wp_Raspberry_talks_EnOcean.pdf
BR,
Zia
Tampere, FI.
krikan
#1
Hello!
Attention: The mentioned tutorial is a little bit outdated.
Try this, please:
If available, delete all previous FHEM-devices of the MVA005, save and restart FHEM.
Put FHEM in learning mode:
set <IODev> teach <time [s]>
If your IODev is  TCM310_0 then for example:
set  TCM310_0 teach 600
Then press button on MVA005 to teach-in according MVA005-manual
Now FHEM should create the device automatically.
That should be all.
Greetings, Christian
edit: FHEM must be up-to-date. Use the update command in FHEM to get the most recent version.
zia
Hello,
Thank you for your response.
Can you please elaborate your answer? How do FHEM knows that I am trying to connect to a certain device? any device ID etc. ?
Secondly, I am in FHEM > TCM ESP  Where do I put a certain command?
Please check the Picture for response.
BR,
Zia
krikan
In learning mode FHEM/TCM-Device is waiting for a teach-in telegram of any device.
You can put any FHEM command in the white command field; right next to FHEM-Logo. First of all you should use the FHEM command
update
and after that
shutdown restart
short english general introductions:
https://wiki.fhem.de/wiki/First_steps_in_FHEM and
https://wiki.fhem.de/wiki/Quick-Start/en
Details about Enocean in FHEM:
https://fhem.de/commandref.html#EnOcean
