fhempy: Tuya Cloud
Begonnen von dominik, 30 Juli 2021, 21:36:48
stefanru
Hi Dominik,
das Probiere ich.
Leider habe ich die nächsten 2 Tage keine Zeit aber ich schaue es mir an.
Werde auch nochmal alles neu Aufsetzen bekomme einen Raspberry PI 400.
Mal sehen ob das etwas ändert.
Heute wars im Log dann ab 12 Uhr ruhig.
Heute abend um 19:41, ich weiß da war ich nicht mal am System ein kleinen aussetzer.
Hier das Log dazu.
fhem.log
2023.02.01 19:40:03 1: BindingsIo (local_pybinding): ERROR: Timeout while waiting for function to finish (id: 95874632)
2023.02.01 19:40:03 1:   function =>  Set
2023.02.01 19:40:03 1:   NAME =>  Computer_Stefan_bf881b7977c814af88jmrc
2023.02.01 19:40:03 1:   FHEMPYTYPE =>  tuya_cloud
2023.02.01 19:40:03 1:   id =>  95874632
2023.02.01 19:40:03 1:   PYTHONTYPE =>  tuya_cloud
2023.02.01 19:40:03 1:   defargs =>  ARRAY(0x7522bf0)
2023.02.01 19:40:03 1:   msgtype =>  function
2023.02.01 19:40:03 1:   argsh =>  HASH(0x8ac01a8)
2023.02.01 19:40:03 1:   defargsh =>  HASH(0x75e31c8)
2023.02.01 19:40:03 1:   args =>  ARRAY(0x920d420)
2023.02.01 19:41:01 1: readingsUpdate(Sybille_Tablet_bf68d9b41c16be3713vcc1,cur_voltage,228.5) missed to call readingsBeginUpdate first.
2023.02.01 19:41:01 1: stacktrace:
2023.02.01 19:41:01 1:     main::readingsBulkUpdate            called by (eval 4948527) (1)
2023.02.01 19:41:01 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.01 19:41:01 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.01 19:41:01 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (430)
2023.02.01 19:41:01 1:     main::BindingsIo_Write              called by fhem.pl (1064)
2023.02.01 19:41:01 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (91)
2023.02.01 19:41:01 1:     main::fhempy_Set                    called by fhem.pl (3976)
2023.02.01 19:41:01 1:     main::CallFn                        called by fhem.pl (1954)
2023.02.01 19:41:01 1:     main::DoSet                         called by fhem.pl (1996)
2023.02.01 19:41:01 1:     main::CommandSet                    called by fhem.pl (2904)
2023.02.01 19:41:01 1:     main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3331)
2023.02.01 19:41:01 1:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (3223)
2023.02.01 19:41:01 1:     main::FW_Notify                     called by fhem.pl (3976)
2023.02.01 19:41:01 1:     main::CallFn                        called by fhem.pl (3888)
2023.02.01 19:41:01 1:     main::DoTrigger                     called by fhem.pl (4995)
2023.02.01 19:41:01 1:     main::readingsEndUpdate             called by (eval 4948526) (1)
2023.02.01 19:41:01 1:     main::readingsEndUpdate             called by (eval 4948525) (1)
2023.02.01 19:41:01 1:     main::readingsEndUpdate             called by (eval 4948523) (1)
fhempy.log
2023-02-01 19:41:00,936 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'tuya_local_bfb7810a3e397c5fa4u7ud'},'add_ele','0.004');;
2023-02-01 19:41:00,941 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'tuya_local_bf881b7977c814af88jmrc'},'online','1');;
2023-02-01 19:41:00,948 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'tuya_local_bf68d9b41c16be3713vcc1'},'cur_voltage','228.5');;
2023-02-01 19:41:01,770 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBeginUpdate($defs{'Sybille_Tablet_bf68d9b41c16be3713vcc1'});;
Im fhem py log hat es aber doch mit local zu tun und mit Cloud.
im fhem log sind 2 Cloud Devices genannt.
Das eine taucht auch im fhempy.log auf das andere aber nicht.
Gruß und vielen Dank,
Stefan
dominik
Danke dir für das Log! Das hat mir geholfen da nochmals auf genauere Fehlersuche zu gehen.
Ich habe eine Korrektur in der BindingsIo gemacht. Bitte daher ein FHEM update machen und prüfen ob die Fehler weiterhin auftreten.
fhempy -  https://github.com/fhempy/fhempy: GoogleCast, Tuya, UPnP, Ring, EQ3BT, Nespresso, Xiaomi, Spotify, Object Detection, ...
Kaffeespende: https://paypal.me/todominik
stefanru
Super, vielen Dank!
Mache ich sobald ich dazu komme, und melde mich.
Stefan
thburkhart
#783
Zitat von: dominik am 01 Februar 2023, 22:09:05
Das doppelt Anlegen liegt nicht an der Cloud oder Polling oder ähnlichen. Das liegt mit 99%iger Wahrscheinlichkeit an der fehlenden Rückmeldung von FHEM zur Abfrage ob ein Device mit der DEVICEID bereits existiert.
Bitte daher nach dem shutdown restart die beiden Logs posten.
Guten Mogen,
habe erst das FHEM-Update gefahren  und dann shutdown restart.
Log FHEM:
2023.02.02 09:30:29 1:
2023.02.02 09:30:29 1: Downloading https://fhem.de/fhemupdate/controls_fhem.txt
2023.02.02 09:30:29 2: Backup with command: tar czf ./backup/FHEM-20230202_093029.tar.gz "./db_create.sql" "./fhem.pl" "./fhem 2022-12-13-1.cfg" "./fhem 2022-12-14.cfg" "./db.conf" "./contrib" "./lib" "./README_DEMO.txt" "./www" "./GPL_V2.txt" "./fhem-demo.cfg" "./alexa-fhem.cfg" "./README" "./MAINTAINER.txt" "./fhem mit tuya 2023-01-20.cfg" "./restoreDir" "./fhem.cfg" "./demolog" "./configDB.db" "./fhem-2023-01-31.cfg" "./log" "./sqldump" "./configDB.conf" "./fhem tuya auskommentiert1 2023-01-20.cfg" "./configDB.pm" "./docs" "./CHANGED" "./fhem 2023-01-30.cfg" "./fhem 2023-01-21.cfg" "./fhem.cfg.demo" "./fhem 2023-01-24.cfg" "./FHEM"
2023.02.02 09:31:43 1: backup done: FHEM-20230202_093029.tar.gz (134610717 Bytes)
2023.02.02 09:31:43 1: fhem
2023.02.02 09:31:43 1: RMDIR: ./restoreDir/update/2023-01-28
2023.02.02 09:31:43 1: UPD ./CHANGED
2023.02.02 09:31:43 1: UPD FHEM/10_ZWave.pm
2023.02.02 09:31:43 1: UPD FHEM/72_FB_CALLMONITOR.pm
2023.02.02 09:31:43 1: UPD FHEM/74_AutomowerConnect.pm
2023.02.02 09:31:43 1: UPD FHEM/75_AutomowerConnectDevice.pm
2023.02.02 09:31:43 1: UPD FHEM/93_DbLog.pm
2023.02.02 09:31:43 1: UPD FHEM/93_DbRep.pm
2023.02.02 09:31:43 1: UPD FHEM/98_ComfoAir.pm
2023.02.02 09:31:44 1: UPD FHEM/98_Modbus.pm
2023.02.02 09:31:44 1: saving fhem.cfg
2023.02.02 09:31:44 1: saving ./log/fhem.save
2023.02.02 09:31:44 1: New entries in the CHANGED file:
2023.02.02 09:31:44 1:  - feature:  74_AutomowerConnect: rework detail view
2023.02.02 09:31:44 1:              getter for MowerData and StatisticsData
2023.02.02 09:31:44 1:  - feature:  75_AutomowerConnectDevice: same as AutomowerConnect
2023.02.02 09:31:44 1:  - feature: 93_DbLog: new Get menu for a selection of getters,
2023.02.02 09:31:44 1:                       send Log data back to parent process, Forum:#131790
2023.02.02 09:31:44 1:  - change:  93_DbRep: ignore non-numeric values in diffValue and output
2023.02.02 09:31:44 1:                       the erroneous record in the log
2023.02.02 09:31:44 1: Downloading https://raw.githubusercontent.com/dominikkarall/fhempy/master/controls_pythonbinding.txt
2023.02.02 09:31:44 1: pythonbinding
2023.02.02 09:31:44 1: UPD FHEM/10_BindingsIo.pm
2023.02.02 09:31:44 1: See https://github.com/fhempy/fhempy/releases for details
2023.02.02 09:31:44 1: Downloading https://raw.githubusercontent.com/PatricSperling/FHEM_SST/master/controls_SST.txt
2023.02.02 09:31:44 1: SST
2023.02.02 09:31:45 1: nothing to do...
2023.02.02 09:31:45 1: Calling /usr/bin/perl ./contrib/commandref_modular.pl, this may take a while
2023.02.02 09:31:45 1: update finished, "shutdown restart" is needed to activate the changes.
2023.02.02 09:32:09 3: Pythonbinding_15733: read: end of file reached while sysread
2023.02.02 09:32:09 3: Pythonbinding_15733: stopped
2023.02.02 09:32:09 3: Pythonbinding_15733: starting
2023.02.02 09:32:10 2: Deleting fhempy-2023-01-23.log
2023.02.02 09:32:10 3: Pythonbinding_15733: using logfile: ./log/fhempy-2023-02-02.log
2023.02.02 09:32:23 3: Please define 0 first
2023.02.02 09:32:23 3: attr 0 DbLogExclude .* ; attr 0 event-on-change-reading .* : Please define 0 first
2023.02.02 09:32:23 3: n_defined return value: Please define 0 first
2023.02.02 09:32:26 1: ERROR evaluating my $EVENT=   $evalSpecials->{'%EVENT'};my $EVTPART0=   $evalSpecials->{'%EVTPART0'};my $NAME=   $evalSpecials->{'%NAME'};my $SELF=   $evalSpecials->{'%SELF'};my $TYPE=   $evalSpecials->{'%TYPE'};{ fhem("attr $EVTPART1 DbLogExclude .* ; attr $EVTPART1 event-on-change-reading .*");}: Global symbol "$EVTPART1" requires explicit package name (did you forget to declare "my $EVTPART1"?) at (eval 766349) line 1.
2023.02.02 09:32:26 3: n_defined return value: Global symbol "$EVTPART1" requires explicit package name (did you forget to declare "my $EVTPART1"?) at (eval 766349) line 1.
2023.02.02 09:33:49 3: Please define 1 first
2023.02.02 09:33:49 3: attr 1 DbLogExclude .* ; attr 1 event-on-change-reading .* : Please define 1 first
2023.02.02 09:33:49 3: n_defined return value: Please define 1 first
2023.02.02 09:33:49 1: ERROR evaluating my $EVENT=   $evalSpecials->{'%EVENT'};my $EVTPART0=   $evalSpecials->{'%EVTPART0'};my $NAME=   $evalSpecials->{'%NAME'};my $SELF=   $evalSpecials->{'%SELF'};my $TYPE=   $evalSpecials->{'%TYPE'};{ fhem("attr $EVTPART1 DbLogExclude .* ; attr $EVTPART1 event-on-change-reading .*");}: Global symbol "$EVTPART1" requires explicit package name (did you forget to declare "my $EVTPART1"?) at (eval 769034) line 1.
2023.02.02 09:33:49 3: n_defined return value: Global symbol "$EVTPART1" requires explicit package name (did you forget to declare "my $EVTPART1"?) at (eval 769034) line 1.
2023.02.02 09:34:16 1: PERL WARNING: Argument "14\0" isn't numeric in sprintf at ./FHEM/36_LaCrosse.pm line 212.
2023.02.02 09:34:16 1: PERL WARNING: Argument "\04" isn't numeric in multiplication (*) at ./FHEM/36_LaCrosse.pm line 219.
2023.02.02 09:34:17 1: PERL WARNING: Argument "140\0" isn't numeric in addition (+) at ./FHEM/36_LaCrosse.pm line 219.
2023.02.02 10:07:25 2: DbLog dblog_THB - Wait for last database cycle due to shutdown ...
2023.02.02 10:07:25 1: Server shutdown delayed due to dblog_THB,alexa for max 10 sec
2023.02.02 10:07:26 2: DbLog dblog_THB - Last database write cycle done
2023.02.02 10:07:27 3: alexa: read: end of file reached while sysread
2023.02.02 10:07:27 3: alexa: stopped
2023.02.02 10:07:27 0: Server shutdown
2023.02.02 10:07:27 2: DbLog dblog_THB - stopping SubProcess PID >16605< ...
2023.02.02 10:07:27 2: DbLog dblog_THB - SubProcess PID >16605< stopped
2023.02.02 10:07:29 1: Including fhem.cfg
2023.02.02 10:07:30 2: DbLog dblog_THB - Subprocess >23532< initialized ... ready for non-blocking operation
2023.02.02 10:07:31 3: telnetPort: port 7072 opened
2023.02.02 10:07:31 3: WEB: port 8083 opened
2023.02.02 10:07:31 3: WEBphone: port 8084 opened
2023.02.02 10:07:31 3: WEBtablet: port 8085 opened
2023.02.02 10:07:31 3: TelegramBot_Define TelegramBotTHB: called
2023.02.02 10:07:31 3: MQTT2: port 1883 opened
2023.02.02 10:07:31 3: BindingsIo v1.0.1
2023.02.02 10:07:31 3: found IP 127.0.0.1
2023.02.02 10:07:31 3: fhempyServer v1.0.0
2023.02.02 10:07:31 3: fhempy v1.0.0 (tuya_cloud: TUYA)
2023.02.02 10:07:32 3: fhempy v1.0.0 (tuya: tuya_system)
2023.02.02 10:07:32 3: Opening CUL_0 device /dev/ttyACM0
2023.02.02 10:07:32 3: Setting CUL_0 serial parameters to 9600,8,N,1
2023.02.02 10:07:32 3: CUL_0: Possible commands: BbCFiAZNkGMKUYRTVWXefmLltux
2023.02.02 10:07:32 3: CUL_0 device opened
2023.02.02 10:07:32 2: Switched CUL_0 rfmode to MAX
2023.02.02 10:07:32 3: Opening JLLaCR device /dev/ttyUSB0
2023.02.02 10:07:32 3: Setting JLLaCR serial parameters to 57600,8,N,1
2023.02.02 10:07:33 3: JLLaCR device opened
2023.02.02 10:07:33 1: PERL WARNING: Use of uninitialized value in numeric ge (>=) at ./FHEM/12_OilFox.pm line 387, <$fh> line 524.
2023.02.02 10:07:33 2: LOGIN TOKEN MISSING OR EXPIRED
2023.02.02 10:07:33 3: myOilFox - email set to bkt@gmx.net
2023.02.02 10:07:33 3: myOilFox - set interval: 36000
2023.02.02 10:07:33 3: myOilFox - password set to thbbkt25
2023.02.02 10:07:33 3: powerfox: Defined with URL https://bkt%40gmx.net:thbbkt25@backend.powerfox.energy/api/2.0/my/246f283cfeac/current and interval 60 featurelevel 6.2
2023.02.02 10:07:49 2: eventTypes: loaded 15849 lines from ./log/eventTypes.txt
2023.02.02 10:07:49 3: TX29_00: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_01: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_02: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_03: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_04: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_05: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_06: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_07: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_08: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_09: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_10: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_11: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_12: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX25IT_13: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_14: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_15: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_16: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_17: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_18: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_19: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_20: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_21: I/O device is JLLaCR
2023.02.02 10:07:49 3: TX29DTH_22: I/O device is JLLaCR
2023.02.02 10:07:49 3: HUEDevice2: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice4: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice5: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice6: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice7: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice8: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice10: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice17: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice18: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice19: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice20: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice22: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice23: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice24: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice25: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice27: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice28: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice29: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice30: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice31: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice32: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice33: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice38: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice39: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice40: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice41: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup0: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup1: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup2: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup3: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup4: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup5: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup6: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup7: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup8: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup9: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup10: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup11: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup12: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup13: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup14: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup15: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup16: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup17: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup18: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup19: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup20: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup21: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup22: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup23: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup24: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup25: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup26: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup27: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup28: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup29: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup30: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice44: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEGroup31: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor6: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor8: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor10: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor13: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor24: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor27: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor34: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor37: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor45: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice45: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice46: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice47: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice48: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice49: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice50: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice51: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor91: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor110: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUESensor1: I/O device is hueBridge1
2023.02.02 10:07:49 3: HUEDevice52: I/O device is hueBridge1
2023.02.02 10:07:49 1: MaxTemp: WT
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_BULB1)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_BULB2)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_BULB3)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_DIY1)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_DIY3)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_DIY4)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_EMYLO1)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_EMYLO2)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_EMYLOD2)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_EMYLO3)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_EMYLO4)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL02)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL03)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL04)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL05)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL06)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL07)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL08)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL09)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL10Z)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL11Z)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL12Z)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL13)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL14)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL15)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL16)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL17)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL18)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL19)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL20)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL21)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL22)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL23)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL24)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL25)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL26)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL27)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL28)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL29)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL30)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL31)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL32)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL33)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL34)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL35)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_JL36)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_PS1)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_PS2)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_PS3)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_PS4)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_PS5)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_PS7)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SCHF1)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SCHF2)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SCHF3)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SCHF4)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP01)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP02)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP03)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP04)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP05)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP06)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP07)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP08)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP09)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP10)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP11)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP12)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP13)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP14)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP15)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_SP16)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_STF1)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_STF2)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_STF3)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya: TUYA_MMG)
2023.02.02 10:07:50 3: SST (SamsungSmartThingsConnector): define - CONNECTOR defined as SamsungSmartThingsConnector
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: TUYA_Temp03)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: TUYA_Temp04)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: TUYA_Temp05)
2023.02.02 10:07:50 1: PERL WARNING: Useless use of anonymous hash ({}) in void context at (eval 127) line 1, <$fh> line 6335.
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: TUYA_Temp07)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_60381718807d3a04bbb4)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_60381718500291bade80)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_180025363c6105dcdcaf)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bfbeab33da30f5635ffj0r)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bfd99c63a8b65928a56hdb)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bf9e9fea71f3692d15gzrq)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bfffc31d13d14bca5dayj6)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: TUYA_Temp01)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_50880180cc50e30cbe91)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_52470320e09806c9a53f)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_60381718807d3a01eb63)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_67242256f4cfa2ce1662)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_045074212cf432ca0721)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_00673231e09806cb6fa5)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_260064612cf432ca55d8)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_07847240bcddc29b03e9)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_07847240dc4f225fdda0)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_06515140cc50e3d62490)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_00673231e09806cb188e)
2023.02.02 10:07:50 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bf3761a5af5f8d6361rmhh)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_47104178dc4f2236e437)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bf6b1900c331a78a2fkecw)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bffb7d9839e65fcdeciaqn)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_453005615002911dfe06)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bf16f1788a2fd6edd6pr1d)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_34602852ecfabc47cbe1)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bfefd42e199ea92ee3jbwh)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_4530056170039f4a87e5)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_720570712462ab27e625)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_720570712462ab280270)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_887800042cf4325f15ef)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_853556472cf4326e60da)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_743066432cf43267661d)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_627425735002915f502b)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_50880180840d8e87664b)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_50880180cc50e30c4c90)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_21410806cc50e37bdb15)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_104380002462ab30258d)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_0120018760019453b4b1)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: TUYA_Temp06)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_17710212600194dba99d)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: TUYA_Temp02)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bfc0750fc8af85f5d5vei7)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bfabd3dbaa5113764dzgkn)
2023.02.02 10:07:51 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bfe1b5bb54592232acz7dg)
2023.02.02 10:07:51 1: Including ./log/fhem.save
2023.02.02 10:07:51 1: Messages collected while initializing FHEM:SecurityCheck:
  telnetPort is not password protected
  WEBphone is not password protected
  MQTT2 is not password protected
  WEBtablet is not password protected
  WEB is not password protected
Protect this FHEM installation by defining an allowed device with define allowed allowed
You can disable this message with attr global motd none
2023.02.02 10:07:51 3: Pythonbinding_15733: starting
2023.02.02 10:07:51 3: Pythonbinding_15733: using logfile: ./log/fhempy-2023-02-02.log
2023.02.02 10:07:52 2: alexa: starting alexa-fhem: /usr/local/bin/alexa-fhem -c ./alexa-fhem.cfg
2023.02.02 10:07:52 3: alexa: starting
2023.02.02 10:07:52 3: alexa: using logfile: ./log/alexa-2023-02-02.log
2023.02.02 10:07:52 2: hueBridge1: autocreate: created 0/0/0 devices (ignored 0/2/26)
2023.02.02 10:07:54 2: alexa: starting alexa-fhem: /usr/local/bin/alexa-fhem -c ./alexa-fhem.cfg
2023.02.02 10:07:54 0: Featurelevel: 6.2
2023.02.02 10:07:54 0: Server started with 532 defined entities (fhem.pl:27110/2023-01-23 perl:5.032001 os:linux user:fhem pid:23531)
2023.02.02 10:07:54 3: DbLog dblog_THB - DB connection parameters are initialized in the SubProcess
2023.02.02 10:07:54 1: PERL WARNING: devspec2array *: Unknown verb pattern '' in regex; marked by <-- HERE in m/^(*) <-- HERE $/ at fhem.pl line 1352.
2023.02.02 10:07:54 1: PERL WARNING: ^* matches null string many times in regex; marked by <-- HERE in m/^* <-- HERE :.*RSSI.*$/ at ./FHEM/93_DbLog.pm line 1310.
2023.02.02 10:07:55 3: DbLog dblog_THB - DB connection parameters are stored in SubProcess
2023.02.02 10:07:55 3: alexa: read: end of file reached while sysread
2023.02.02 10:07:55 3: alexa: stopped
2023.02.02 10:07:55 2: alexa: starting alexa-fhem: /usr/local/bin/alexa-fhem -c ./alexa-fhem.cfg
2023.02.02 10:07:55 3: alexa: starting
2023.02.02 10:07:55 3: alexa: using logfile: ./log/alexa-2023-02-02.log
2023.02.02 10:07:56 2: AttrTemplates: got 258 entries
2023.02.02 10:08:01 3: Please define server first
2023.02.02 10:08:01 3: attr server DbLogExclude .* ; attr server event-on-change-reading .* : Please define server first
2023.02.02 10:08:01 3: n_defined return value: Please define server first
2023.02.02 10:08:04 2: hueBridge1: http request failed:  SSL connect attempt failed
2023.02.02 10:08:04 2: Buderus : km200_ParseHttpResponseInit - ERROR                : /: No proper Communication with Gateway: read from http://192.168.9.114:80 timed out
2023.02.02 10:08:04 2: Buderus : km200_ParseHttpResponseInit - ERROR                : Timer restarted to try again in 10s
2023.02.02 10:08:05 2: hueBridge1: http request failed: https://192.168.9.179/eventstream/clip/v2: empty answer received
2023.02.02 10:08:05 2: hueBridge1: EventStream: terminated; retrying later
2023.02.02 10:08:06 3: Please define server first
2023.02.02 10:08:06 3: attr server DbLogExclude .* ; attr server event-on-change-reading .* : Please define server first
2023.02.02 10:08:06 3: n_defined return value: Please define server first
2023.02.02 10:08:08 1: PERL WARNING: Use of uninitialized value $value in string eq at ./FHEM/10_MAX.pm line 2057.
2023.02.02 10:08:08 1: PERL WARNING: Use of uninitialized value $value in string eq at ./FHEM/10_MAX.pm line 2058.
2023.02.02 10:08:10 3: Please define 0 first
2023.02.02 10:08:10 3: attr 0 DbLogExclude .* ; attr 0 event-on-change-reading .* : Please define 0 first
2023.02.02 10:08:10 3: n_defined return value: Please define 0 first
2023.02.02 10:08:15 1: ERROR evaluating my $EVENT=   $evalSpecials->{'%EVENT'};my $EVTPART0=   $evalSpecials->{'%EVTPART0'};my $NAME=   $evalSpecials->{'%NAME'};my $SELF=   $evalSpecials->{'%SELF'};my $TYPE=   $evalSpecials->{'%TYPE'};{ fhem("attr $EVTPART1 DbLogExclude .* ; attr $EVTPART1 event-on-change-reading .*");}: Global symbol "$EVTPART1" requires explicit package name (did you forget to declare "my $EVTPART1"?) at (eval 706) line 1.
2023.02.02 10:08:15 3: n_defined return value: Global symbol "$EVTPART1" requires explicit package name (did you forget to declare "my $EVTPART1"?) at (eval 706) line 1.
2023.02.02 10:08:38 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_63667231840d8e501cab)
2023.02.02 10:08:42 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_bff304caecd1bfb52dahwu)
2023.02.02 10:08:47 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_2053863070039f179683)
2023.02.02 10:09:50 1: readingsUpdate(TUYA_JL04,cur_current,240.0) missed to call readingsBeginUpdate first.
2023.02.02 10:09:50 1: stacktrace:
2023.02.02 10:09:50 1:     main::readingsBulkUpdate            called by fhem.pl (5012)
2023.02.02 10:09:50 1:     main::readingsBulkUpdateIfChanged   called by (eval 3576) (1)
2023.02.02 10:09:50 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 10:09:50 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 10:09:50 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (430)
2023.02.02 10:09:50 1:     main::BindingsIo_Write              called by fhem.pl (1064)
2023.02.02 10:09:50 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (103)
2023.02.02 10:09:50 1:     main::fhempy_Attr                   called by fhem.pl (3976)
2023.02.02 10:09:50 1:     main::CallFn                        called by fhem.pl (3198)
2023.02.02 10:09:50 1:     main::CommandAttr                   called by (eval 3567) (1)
2023.02.02 10:09:50 1:     main::CommandAttr                   called by (eval 3565) (1)
2023.02.02 10:09:50 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (91)
2023.02.02 10:09:50 1:     main::fhempy_Set                    called by fhem.pl (3976)
2023.02.02 10:09:50 1:     main::CallFn                        called by fhem.pl (1954)
2023.02.02 10:09:50 1:     main::DoSet                         called by fhem.pl (1996)
2023.02.02 10:09:50 1:     main::CommandSet                    called by fhem.pl (2904)
2023.02.02 10:09:50 1:     main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3331)
2023.02.02 10:09:50 1:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (3223)
2023.02.02 10:09:50 1:     main::FW_Notify                     called by fhem.pl (3976)
2023.02.02 10:09:50 1:     main::CallFn                        called by fhem.pl (3888)
2023.02.02 10:09:50 1:     main::DoTrigger                     called by fhem.pl (4995)
2023.02.02 10:09:50 1:     main::readingsEndUpdate             called by fhem.pl (5178)
2023.02.02 10:09:50 1:     main::readingsSingleUpdate          called by (eval 3543) (1)
2023.02.02 10:09:50 1:     main::CommandAttr                   called by (eval 3540) (1)
2023.02.02 10:09:51 1: readingsUpdate(TUYA_JL04,cur_power,34.1) missed to call readingsBeginUpdate first.
2023.02.02 10:09:51 1: stacktrace:
2023.02.02 10:09:51 1:     main::readingsBulkUpdate            called by fhem.pl (5012)
2023.02.02 10:09:51 1:     main::readingsBulkUpdateIfChanged   called by (eval 3669) (1)
2023.02.02 10:09:51 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 10:09:51 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 10:09:51 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (430)
2023.02.02 10:09:51 1:     main::BindingsIo_Write              called by fhem.pl (1064)
2023.02.02 10:09:51 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (91)
2023.02.02 10:09:51 1:     main::fhempy_Set                    called by fhem.pl (3976)
2023.02.02 10:09:51 1:     main::CallFn                        called by fhem.pl (1954)
2023.02.02 10:09:51 1:     main::DoSet                         called by fhem.pl (1996)
2023.02.02 10:09:51 1:     main::CommandSet                    called by fhem.pl (2904)
2023.02.02 10:09:51 1:     main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3331)
2023.02.02 10:09:51 1:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (3223)
2023.02.02 10:09:51 1:     main::FW_Notify                     called by fhem.pl (3976)
2023.02.02 10:09:51 1:     main::CallFn                        called by fhem.pl (3888)
2023.02.02 10:09:51 1:     main::DoTrigger                     called by fhem.pl (4995)
2023.02.02 10:09:51 1:     main::readingsEndUpdate             called by (eval 3664) (1)
2023.02.02 10:09:51 1:     main::readingsEndUpdate             called by (eval 3636) (1)
2023.02.02 10:09:51 1:     main::readingsEndUpdate             called by (eval 3635) (1)
2023.02.02 10:13:03 2: error while requesting https://api.oilfox.io/customer-api/v1/login - read from https://api.oilfox.io:443 timed out
2023.02.02 10:13:11 3: DbLog dblog_THB - SubProcess connected to fhem
2023.02.02 10:13:13 2: hueBridge1: http request failed: https://192.168.9.179/eventstream/clip/v2: empty answer received
2023.02.02 10:13:13 2: hueBridge1: EventStream: terminated; retrying later
2023.02.02 10:13:17 1: PERL WARNING: Argument "40\0" isn't numeric in sprintf at ./FHEM/36_LaCrosse.pm line 212.
2023.02.02 10:13:17 1: PERL WARNING: Argument "\01" isn't numeric in bitwise and (&) at ./FHEM/36_LaCrosse.pm line 213.
2023.02.02 10:13:17 1: PERL WARNING: Argument "\073" isn't numeric in addition (+) at ./FHEM/36_LaCrosse.pm line 219.
2023.02.02 10:13:18 1: RMDIR: ./restoreDir/save/2023-01-30
2023.02.02 10:13:19 2: hueBridge1: autocreate: created 0/0/0 devices (ignored 0/2/26)
2023.02.02 10:14:03 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_2053863070039f16cef8)
2023.02.02 10:14:05 3: fhempy v1.0.0 (tuya_cloud: tuya_cloud_3367036770039f60c576)
2023.02.02 10:14:07 1: readingsUpdate(tuya_cloud_52470320e09806c9a53f,state,on) missed to call readingsBeginUpdate first.
2023.02.02 10:14:07 1: stacktrace:
2023.02.02 10:14:07 1:     main::readingsBulkUpdate            called by (eval 4059) (1)
2023.02.02 10:14:07 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 10:14:07 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 10:14:07 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (301)
2023.02.02 10:14:07 1:     main::BindingsIo_Read               called by fhem.pl (3976)
2023.02.02 10:14:07 1:     main::CallFn                        called by fhem.pl (784)
2023.02.02 10:14:07 1: readingsUpdate(tuya_cloud_00673231e09806cb6fa5,state,on) missed to call readingsBeginUpdate first.
2023.02.02 10:14:07 1:     main::readingsBulkUpdate            called by (eval 4060) (1)
2023.02.02 10:14:09 1: readingsUpdate(tuya_cloud_00673231e09806cb6fa5,state,on) missed to call readingsBeginUpdate first.
2023.02.02 10:14:09 1: stacktrace:
2023.02.02 10:14:09 1:     main::readingsBulkUpdate            called by (eval 4130) (1)
2023.02.02 10:14:09 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 10:14:09 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 10:14:09 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (301)
2023.02.02 10:14:09 1:     main::BindingsIo_Read               called by fhem.pl (3976)
2023.02.02 10:14:09 1:     main::CallFn                        called by fhem.pl (784)
2023.02.02 10:14:09 1:     main::readingsBulkUpdate            called by (eval 4131) (1)
2023.02.02 10:14:09 1:     main::readingsBulkUpdate            called by (eval 4132) (1)
2023.02.02 10:14:09 1:     main::readingsBulkUpdate            called by (eval 4135) (1)
2023.02.02 10:14:09 1:     main::readingsBulkUpdate            called by (eval 4139) (1)
2023.02.02 10:14:09 1:     main::readingsBulkUpdate            called by (eval 4148) (1)
2023.02.02 10:14:09 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (430)
2023.02.02 10:14:09 1:     main::BindingsIo_Write              called by fhem.pl (1064)
2023.02.02 10:14:09 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (91)
2023.02.02 10:14:09 1:     main::fhempy_Set                    called by fhem.pl (3976)
2023.02.02 10:14:09 1:     main::CallFn                        called by fhem.pl (1954)
2023.02.02 10:14:09 1:     main::DoSet                         called by fhem.pl (1996)
2023.02.02 10:14:09 1:     main::CommandSet                    called by fhem.pl (2904)
2023.02.02 10:14:09 1:     main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3331)
2023.02.02 10:14:09 1:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (3223)
2023.02.02 10:14:09 1:     main::FW_Notify                     called by fhem.pl (3976)
2023.02.02 10:14:09 1:     main::CallFn                        called by fhem.pl (3888)
2023.02.02 10:14:09 1:     main::DoTrigger                     called by fhem.pl (4995)
2023.02.02 10:14:09 1:     main::readingsEndUpdate             called by fhem.pl (5178)
2023.02.02 10:14:09 1:     main::readingsSingleUpdate          called by (eval 4145) (1)
2023.02.02 10:14:09 1: readingsUpdate(tuya_cloud_52470320e09806c9a53f,countdown_1,0.0) missed to call readingsBeginUpdate first.
2023.02.02 10:14:09 1:     main::readingsBulkUpdate            called by (eval 4161) (1)
2023.02.02 10:14:09 1: readingsUpdate(tuya_cloud_00673231e09806cb6fa5,countdown_1,0.0) missed to call readingsBeginUpdate first.
2023.02.02 10:14:09 1:     main::readingsBulkUpdate            called by (eval 4162) (1)
1 RASPI4B, 1 RASPI3B, 2 CUL, 2 Jeelink, 60 Tuya-Devices (Schalter, Dimmer, Sensoren, Cameras), 30 HUE-Lampen, 5 MAX! WTs, 16 MAX! HTs, 12 MAX! FKs, 1 Bresser 5in1, 1 OilFox, 8 ALEXA Echos und Dots, FHEM, 5 Tasmota-Devices, SonOff -Bridge, PowerFox, Buderus KM200
stefanru
#784
habe das Update auch gemacht und nun neue Fehler beim Neustart und auch alt bekannt.
Insgesammt nochmal einiges mehr an Fehlern.
Der fhempyserver stürzt nun regelmäßig ab :-(
Leider komme ich gerade nicht an das fhempy.log.
fhem.log
2023.02.02 10:37:39 1: BindingsIo (local_pybinding): ERROR: Timeout while waiting for function to finish (id: 92513506)
2023.02.02 10:37:39 1:   function =>  Set
2023.02.02 10:37:39 1:   FHEMPYTYPE =>  tuya_cloud
2023.02.02 10:37:39 1:   defargs =>  ARRAY(0x68f8200)
2023.02.02 10:37:39 1:   defargsh =>  HASH(0x68f8140)
2023.02.02 10:37:39 1:   args =>  ARRAY(0x87d4998)
2023.02.02 10:37:39 1:   PYTHONTYPE =>  tuya_cloud
2023.02.02 10:37:39 1:   argsh =>  HASH(0x867c7e0)
2023.02.02 10:37:39 1:   id =>  92513506
2023.02.02 10:37:39 1:   NAME =>  Fernseher_bfb7810a3e397c5fa4u7ud
2023.02.02 10:37:39 1:   msgtype =>  function
2023.02.02 10:37:43 1: BindingsIo (local_pybinding): Use of uninitialized value in string eq at (eval 1519) line 1.
=> COMMAND: foreach my $fhem_dev (sort keys %main::defs) {  return 1 if(defined($main::defs{$fhem_dev}{FHEMPYTYPE}) && $main::defs{$fhem_dev}{FHEMPYTYPE} eq 'tuya_cloud' && $main::defs{$fhem_dev}{DEVICEID} eq 'bffa550a829a269630vhcn');;}return 0;;
2023.02.02 10:37:43 1: BindingsIo (local_pybinding): Use of uninitialized value in string eq at (eval 1550) line 1.
=> COMMAND: foreach my $fhem_dev (sort keys %main::defs) {  return 1 if(defined($main::defs{$fhem_dev}{FHEMPYTYPE}) && $main::defs{$fhem_dev}{FHEMPYTYPE} eq 'tuya_cloud' && $main::defs{$fhem_dev}{DEVICEID} eq 'bf881b7977c814af88jmrc');;}return 0;;
2023.02.02 10:37:43 1: BindingsIo (local_pybinding): Use of uninitialized value in string eq at (eval 1551) line 1.
=> COMMAND: foreach my $fhem_dev (sort keys %main::defs) {  return 1 if(defined($main::defs{$fhem_dev}{FHEMPYTYPE}) && $main::defs{$fhem_dev}{FHEMPYTYPE} eq 'tuya' && $main::defs{$fhem_dev}{DEVICEID} eq 'bf881b7977c814af88jmrc');;}return 0;;
2023.02.02 10:37:44 1: readingsUpdate(Stefan_Tablet_bf0572e0fb6ccbe356ykuh,active_time,1638460188) missed to call readingsBeginUpdate first.
2023.02.02 10:37:44 1: stacktrace:
2023.02.02 10:37:44 1:     main::readingsBulkUpdate            called by (eval 1559) (1)
2023.02.02 10:37:44 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 10:37:44 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 10:37:44 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (430)
2023.02.02 10:37:44 1:     main::BindingsIo_Write              called by fhem.pl (1064)
2023.02.02 10:37:44 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (65)
2023.02.02 10:37:44 1:     main::fhempy_Define                 called by fhem.pl (3976)
2023.02.02 10:37:44 1:     main::CallFn                        called by fhem.pl (2155)
2023.02.02 10:37:44 1:     main::CommandDefine                 called by (eval 1558) (1)
2023.02.02 10:37:44 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (301)
2023.02.02 10:37:44 1:     main::BindingsIo_Read               called by fhem.pl (3976)
2023.02.02 10:37:44 1:     main::CallFn                        called by fhem.pl (784)
2023.02.02 10:37:44 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,active_time,1674825254) missed to call readingsBeginUpdate first.
2023.02.02 10:37:44 1:     main::readingsBulkUpdate            called by (eval 1560) (1)
2023.02.02 10:37:44 1: readingsUpdate(Sybille_Tablet_bf68d9b41c16be3713vcc1,active_time,1638468323) missed to call readingsBeginUpdate first.
2023.02.02 10:37:44 1:     main::readingsBulkUpdate            called by (eval 1561) (1)
2023.02.02 10:37:44 1: BindingsIo (local_pybinding): ^* matches null string many times in regex; marked by <-- HERE in m/^* <-- HERE $/ at ./FHEM/33_readingsGroup.pm line 154.
=> COMMAND: CommandDefine(undef, "tuya_cloud_bf881b7977c814af88jmrc fhempy tuya_cloud tuya_cloud_connector bf881b7977c814af88jmrc")
2023.02.02 10:37:44 1: BindingsIo (local_pybinding): ^* matches null string many times in regex; marked by <-- HERE in m/^* <-- HERE $/ at ./FHEM/33_readingsGroup.pm line 160.
2023.02.02 10:37:45 1: readingsUpdate(Stefan_Tablet_bf0572e0fb6ccbe356ykuh,biz_type,0) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1: stacktrace:
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1591) (1)
2023.02.02 10:37:45 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 10:37:45 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 10:37:45 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (301)
2023.02.02 10:37:45 1:     main::BindingsIo_Read               called by fhem.pl (3976)
2023.02.02 10:37:45 1:     main::CallFn                        called by fhem.pl (784)
2023.02.02 10:37:45 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,biz_type,0) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1593) (1)
2023.02.02 10:37:45 1: readingsUpdate(Sybille_Tablet_bf68d9b41c16be3713vcc1,biz_type,0) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1594) (1)
2023.02.02 10:37:45 1: readingsUpdate(Stefan_Tablet_bf0572e0fb6ccbe356ykuh,category,cz) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1600) (1)
2023.02.02 10:37:45 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,category,wsdcg) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1602) (1)
2023.02.02 10:37:45 1: readingsUpdate(Sybille_Tablet_bf68d9b41c16be3713vcc1,category,cz) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1603) (1)
2023.02.02 10:37:45 1: readingsUpdate(Stefan_Tablet_bf0572e0fb6ccbe356ykuh,create_time,1638459915) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1607) (1)
2023.02.02 10:37:45 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (430)
2023.02.02 10:37:45 1:     main::BindingsIo_Write              called by fhem.pl (1064)
2023.02.02 10:37:45 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (103)
2023.02.02 10:37:45 1:     main::fhempy_Attr                   called by fhem.pl (3976)
2023.02.02 10:37:45 1:     main::CallFn                        called by fhem.pl (3198)
2023.02.02 10:37:45 1:     main::CommandAttr                   called by (eval 1604) (1)
2023.02.02 10:37:45 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,create_time,1674825254) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1608) (1)
2023.02.02 10:37:45 1: readingsUpdate(Sybille_Tablet_bf68d9b41c16be3713vcc1,create_time,1638468323) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1609) (1)
2023.02.02 10:37:45 1: readingsUpdate(Stefan_Tablet_bf0572e0fb6ccbe356ykuh,icon,https://images.tuyaeu.com/smart/icon/ay15422864509092y6k8/94efe8972e318399f1a1ee3887c704e8.png) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1616) (1)
2023.02.02 10:37:45 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (91)
2023.02.02 10:37:45 1:     main::fhempy_Set                    called by fhem.pl (3976)
2023.02.02 10:37:45 1:     main::CallFn                        called by fhem.pl (1954)
2023.02.02 10:37:45 1:     main::DoSet                         called by fhem.pl (1996)
2023.02.02 10:37:45 1:     main::CommandSet                    called by fhem.pl (2904)
2023.02.02 10:37:45 1:     main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3331)
2023.02.02 10:37:45 1:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (3223)
2023.02.02 10:37:45 1:     main::FW_Notify                     called by fhem.pl (3976)
2023.02.02 10:37:45 1:     main::CallFn                        called by fhem.pl (3888)
2023.02.02 10:37:45 1:     main::DoTrigger                     called by fhem.pl (4995)
2023.02.02 10:37:45 1:     main::readingsEndUpdate             called by (eval 1615) (1)
2023.02.02 10:37:45 1:     main::CommandAttr                   called by (eval 1614) (1)
2023.02.02 10:37:45 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,icon,https://images.tuyaeu.com/smart/icon/ay1525749833414yotNt/b3a94a9431b68373894805b4a19092e4.png) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1617) (1)
2023.02.02 10:37:45 1: readingsUpdate(Sybille_Tablet_bf68d9b41c16be3713vcc1,icon,https://images.tuyaeu.com/smart/icon/ay15148582002916nitB/c58a91c23c2e2b5309c7c5d776871390.png) missed to call readingsBeginUpdate first.
2023.02.02 10:37:45 1:     main::readingsBulkUpdate            called by (eval 1618) (1)
2023.02.02 10:37:46 1: readingsUpdate(Stefan_Tablet_bf0572e0fb6ccbe356ykuh,id,bf0572e0fb6ccbe356ykuh) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1: stacktrace:
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1624) (1)
2023.02.02 10:37:46 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 10:37:46 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 10:37:46 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (301)
2023.02.02 10:37:46 1:     main::BindingsIo_Read               called by fhem.pl (3976)
2023.02.02 10:37:46 1:     main::CallFn                        called by fhem.pl (784)
2023.02.02 10:37:46 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,id,bffa550a829a269630vhcn) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1625) (1)
2023.02.02 10:37:46 1: readingsUpdate(Sybille_Tablet_bf68d9b41c16be3713vcc1,id,bf68d9b41c16be3713vcc1) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1626) (1)
2023.02.02 10:37:46 1: readingsUpdate(Stefan_Tablet_bf0572e0fb6ccbe356ykuh,ip,87.158.205.193) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1629) (1)
2023.02.02 10:37:46 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (430)
2023.02.02 10:37:46 1:     main::BindingsIo_Write              called by fhem.pl (1064)
2023.02.02 10:37:46 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (103)
2023.02.02 10:37:46 1:     main::fhempy_Attr                   called by fhem.pl (3976)
2023.02.02 10:37:46 1:     main::CallFn                        called by fhem.pl (3198)
2023.02.02 10:37:46 1:     main::CommandAttr                   called by (eval 1627) (1)
2023.02.02 10:37:46 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,ip,84.188.243.243) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1630) (1)
2023.02.02 10:37:46 1: readingsUpdate(Sybille_Tablet_bf68d9b41c16be3713vcc1,ip,87.158.205.193) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1631) (1)
2023.02.02 10:37:46 1: readingsUpdate(Stefan_Tablet_bf0572e0fb6ccbe356ykuh,lat,49.6104) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1632) (1)
2023.02.02 10:37:46 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,lat,49.6104) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1633) (1)
2023.02.02 10:37:46 1: readingsUpdate(Sybille_Tablet_bf68d9b41c16be3713vcc1,lat,49.6104) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1665) (1)
2023.02.02 10:37:46 1: readingsUpdate(Stefan_Tablet_bf0572e0fb6ccbe356ykuh,local_key,b4ca4d3e6b518fd1) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1668) (1)
2023.02.02 10:37:46 1:     main::CommandAttr                   called by (eval 1666) (1)
2023.02.02 10:37:46 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,local_key,55db39dd00af9487) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1669) (1)
2023.02.02 10:37:46 1: readingsUpdate(Sybille_Tablet_bf68d9b41c16be3713vcc1,local_key,68c71bfc9491dabc) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1670) (1)
2023.02.02 10:37:46 1: readingsUpdate(Stefan_Tablet_bf0572e0fb6ccbe356ykuh,lon,8.7262) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1676) (1)
2023.02.02 10:37:46 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,lon,8.7263) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1677) (1)
2023.02.02 10:37:46 1: readingsUpdate(Sybille_Tablet_bf68d9b41c16be3713vcc1,lon,8.7261) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1678) (1)
2023.02.02 10:37:46 1: readingsUpdate(Stefan_Tablet_bf0572e0fb6ccbe356ykuh,model,0942 CB2S) missed to call readingsBeginUpdate first.
2023.02.02 10:37:46 1:     main::readingsBulkUpdate            called by (eval 1685) (1)
thburkhart
auch bei mir hat das log nicht in code gepasst
Letzte Zeile löschen und /code setzen.
PerformanceProbleme?
Der Start dauert eben 20 Minuten; seit 10:16 keine log einträge im fhemlog.
Der Raum fhempy ist immer noch nicht aufgebaut (nach 50 min) Darstellund ist nun Seitenbreit
stefanru
#786
Ok nach noch einem Neustart ist es jetzt ok.
Verstehe ncht warum ich 2 x starten musste ohne Änderung zwischen drin.
Diese Fehler sind nun verschwunden:
Es läuft performant, Daten kommen.
Leider gibt es beim Start immer noch seitenweise diese Fehlermeldungen.
Es gibt 3 Arten die beim Start kommen, insgesamt unheimlich viele!
Zuerst diese:
2023.02.02 10:57:56 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,active_time,1674825254) missed to call readingsBeginUpdate first.
2023.02.02 10:57:56 1: stacktrace:
2023.02.02 10:57:56 1:     main::readingsBulkUpdate            called by (eval 1463) (1)
2023.02.02 10:57:56 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 10:57:56 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 10:57:56 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (301)
2023.02.02 10:57:56 1:     main::BindingsIo_Read               called by fhem.pl (3976)
2023.02.02 10:57:56 1:     main::CallFn                        called by fhem.pl (784)
2023.02.02 10:57:56 1: readingsUpdate(tuya_cloud_bf4f644bc7dd2fc71d9q52,active_time,1638458218) missed to call readingsBeginUpdate first.
Danach diese:
2023.02.02 10:58:03 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,time_zone,+01:00) missed to call readingsBeginUpdate first.
2023.02.02 10:58:03 1: stacktrace:
2023.02.02 10:58:03 1:     main::readingsBulkUpdate            called by (eval 2097) (1)
2023.02.02 10:58:03 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 10:58:03 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 10:58:03 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (430)
2023.02.02 10:58:03 1:     main::BindingsIo_Write              called by fhem.pl (1064)
2023.02.02 10:58:03 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (91)
2023.02.02 10:58:03 1:     main::fhempy_Set                    called by fhem.pl (3976)
2023.02.02 10:58:03 1:     main::CallFn                        called by fhem.pl (1954)
2023.02.02 10:58:03 1:     main::DoSet                         called by fhem.pl (1996)
2023.02.02 10:58:03 1:     main::CommandSet                    called by fhem.pl (2904)
2023.02.02 10:58:03 1:     main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3331)
2023.02.02 10:58:03 1:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (3223)
2023.02.02 10:58:03 1:     main::FW_Notify                     called by fhem.pl (3976)
2023.02.02 10:58:03 1:     main::CallFn                        called by fhem.pl (3888)
2023.02.02 10:58:03 1:     main::DoTrigger                     called by fhem.pl (4995)
2023.02.02 10:58:03 1:     main::readingsEndUpdate             called by (eval 2082) (1)
2023.02.02 10:58:03 1:     main::readingsEndUpdate             called by (eval 2070) (1)
2023.02.02 10:58:03 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (301)
2023.02.02 10:58:03 1:     main::BindingsIo_Read               called by fhem.pl (3976)
2023.02.02 10:58:03 1:     main::CallFn                        called by fhem.pl (784)
Und dann noch mal ein Schwung von diesen:
2023.02.02 10:58:04 1: readingsUpdate(tuya_cloud_bffa550a829a269630vhcn,update_time_hr,27.01.2023, 14:14:17) missed to call readingsBeginUpdate first.
2023.02.02 10:58:04 1: stacktrace:
2023.02.02 10:58:04 1:     main::readingsBulkUpdate            called by fhem.pl (4980)
2023.02.02 10:58:04 1:     main::readingsEndUpdate             called by (eval 2176) (1)
2023.02.02 10:58:04 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 10:58:04 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 10:58:04 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (430)
2023.02.02 10:58:04 1:     main::BindingsIo_Write              called by fhem.pl (1064)
2023.02.02 10:58:04 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (91)
2023.02.02 10:58:04 1:     main::fhempy_Set                    called by fhem.pl (3976)
2023.02.02 10:58:04 1:     main::CallFn                        called by fhem.pl (1954)
2023.02.02 10:58:04 1:     main::DoSet                         called by fhem.pl (1996)
2023.02.02 10:58:04 1:     main::CommandSet                    called by fhem.pl (2904)
2023.02.02 10:58:04 1:     main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3331)
2023.02.02 10:58:04 1:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (3223)
2023.02.02 10:58:04 1:     main::FW_Notify                     called by fhem.pl (3976)
2023.02.02 10:58:04 1:     main::CallFn                        called by fhem.pl (3888)
2023.02.02 10:58:04 1:     main::DoTrigger                     called by fhem.pl (4995)
2023.02.02 10:58:04 1:     main::readingsEndUpdate             called by (eval 2173) (1)
2023.02.02 10:58:04 1:     main::readingsEndUpdate             called by (eval 2169) (1)
2023.02.02 10:58:04 1:     main::readingsEndUpdate             called by (eval 2167) (1)
Danke und Gruß,
Stefan
thburkhart
#787
nach zwei Stunden weitere Bewegungen in der FHEL-log:
2023.02.02 10:16:40 1:     main::CallFn                        called by fhem.pl (784)
2023.02.02 12:10:05 3: Watchdog WDT_BAD_F2 triggered
2023.02.02 12:17:09 3: Watchdog WDT_HWR_F2 triggered
2023.02.02 12:20:53 1: readingsUpdate(tuya_cloud_260064612cf432ca55d8,state,on) missed to call readingsBeginUpdate first.
2023.02.02 12:20:53 1: stacktrace:
2023.02.02 12:20:53 1:     main::readingsBulkUpdate            called by (eval 211684) (1)
2023.02.02 12:20:53 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 12:20:53 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 12:20:53 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (301)
2023.02.02 12:20:53 1:     main::BindingsIo_Read               called by fhem.pl (3976)
2023.02.02 12:20:53 1:     main::CallFn                        called by fhem.pl (784)
2023.02.02 12:20:54 1: readingsUpdate(tuya_cloud_260064612cf432ca55d8,countdown_1,0.0) missed to call readingsBeginUpdate first.
2023.02.02 12:20:54 1: stacktrace:
2023.02.02 12:20:54 1:     main::readingsBulkUpdate            called by (eval 211689) (1)
2023.02.02 12:20:54 1:     (eval)                              called by ./FHEM/10_BindingsIo.pm (576)
2023.02.02 12:20:54 1:     main::BindingsIo_processMessage     called by ./FHEM/10_BindingsIo.pm (688)
2023.02.02 12:20:54 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (430)
2023.02.02 12:20:54 1:     main::BindingsIo_Write              called by fhem.pl (1064)
2023.02.02 12:20:54 1:     main::IOWrite                       called by ./FHEM/10_fhempy.pm (91)
2023.02.02 12:20:54 1:     main::fhempy_Set                    called by fhem.pl (3976)
2023.02.02 12:20:54 1:     main::CallFn                        called by fhem.pl (1954)
2023.02.02 12:20:54 1:     main::DoSet                         called by fhem.pl (1996)
2023.02.02 12:20:54 1:     main::CommandSet                    called by fhem.pl (2904)
2023.02.02 12:20:54 1:     main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3331)
2023.02.02 12:20:54 1:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (3223)
2023.02.02 12:20:54 1:     main::FW_Notify                     called by fhem.pl (3976)
2023.02.02 12:20:54 1:     main::CallFn                        called by fhem.pl (3888)
2023.02.02 12:20:54 1:     main::DoTrigger                     called by fhem.pl (4995)
2023.02.02 12:20:54 1:     main::readingsEndUpdate             called by (eval 211687) (1)
2023.02.02 12:20:54 1:     main::BindingsIo_readWebsocketMessage called by ./FHEM/10_BindingsIo.pm (301)
2023.02.02 12:20:54 1:     main::BindingsIo_Read               called by fhem.pl (3976)
2023.02.02 12:20:54 1:     main::CallFn                        called by fhem.pl (784)
2023.02.02 12:20:54 1: readingsUpdate(tuya_cloud_260064612cf432ca55d8,add_ele,0.1) missed to call readingsBeginUpdate first.
2023.02.02 12:20:54 1:     main::readingsBulkUpdate            called by (eval 211693) (1)
2023.02.02 12:20:54 1: readingsUpdate(tuya_cloud_260064612cf432ca55d8,cur_current,4278.0) missed to call readingsBeginUpdate first.
2023.02.02 12:20:54 1:     main::readingsBulkUpdate            called by (eval 211697) (1)
2023.02.02 12:20:54 1:     main::readingsEndUpdate             called by (eval 211696) (1)
2023.02.02 12:20:54 1: readingsUpdate(tuya_cloud_260064612cf432ca55d8,cur_power,288.4) missed to call readingsBeginUpdate first.
2023.02.02 12:20:54 1:     main::readingsBulkUpdate            called by (eval 211701) (1)
2023.02.02 12:20:54 1:     main::readingsEndUpdate             called by (eval 211699) (1)
2023.02.02 12:20:54 1:     main::readingsEndUpdate             called by (eval 211698) (1)
2023.02.02 12:20:54 1: readingsUpdate(tuya_cloud_260064612cf432ca55d8,cur_voltage,229.8) missed to call readingsBeginUpdate first.
2023.02.02 12:20:54 1:     main::readingsBulkUpdate            called by (eval 211703) (1)
room FMEMPY brauch ca. 5 min zum Aufbau
in FHEMPY-Log hersch allerdings weitgehen Ruhe:
2023-02-02 10:15:32,296 - ERROR    - root: tuya_cloud_00673231e09806cb6fa5: readingsBulkUpdate without readingsBeginUpdate: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb6fa5'},'cur_voltage','230.3');;
2023-02-02 10:15:32,297 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb6fa5'},'add_ele','0.006');;
2023-02-02 10:15:32,297 - ERROR    - root: tuya_cloud_00673231e09806cb6fa5: readingsBulkUpdate without readingsBeginUpdate: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb6fa5'},'cur_current','116.0');;
2023-02-02 10:15:32,297 - ERROR    - root: tuya_cloud_00673231e09806cb6fa5: readingsBulkUpdate without readingsBeginUpdate: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb6fa5'},'cur_power','12.2');;
2023-02-02 10:15:32,298 - ERROR    - root: tuya_cloud_00673231e09806cb6fa5: readingsBulkUpdate without readingsBeginUpdate: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb6fa5'},'cur_voltage','230.3');;
2023-02-02 10:15:55,827 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_63667231dc4f22f329f1'},'sub','off');;
2023-02-02 10:16:09,601 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_2053863070039f16cebe'},'lat','48.5585');;
2023-02-02 10:16:09,601 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP11'},'dp_22','715');;
2023-02-02 10:16:09,601 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP15'},'dp_25','995');;
2023-02-02 10:16:09,602 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_50134218c4dd571b3390'},'countdown_3','0.0');;
2023-02-02 10:16:13,840 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_8877821724a160151069'},'model','欧è§,,,10A,带计ç"µé‡ï¼Œæ"¯æŒé...·å®¢RF产测');;
2023-02-02 10:16:13,953 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP10'},'dp_22','722');;
2023-02-02 10:16:13,954 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb188e'},'state','on');;
2023-02-02 10:16:20,831 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_8877821724a16014ef14'},'ip','149.172.226.177');;
2023-02-02 10:16:25,669 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_067327848cce4ec3fe13'},'create_time','1606310994');;
2023-02-02 10:16:25,669 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_04086463840d8e50124b'},'switch_3','on');;
2023-02-02 10:16:25,670 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_JL33'},'dp_07','0');;
2023-02-02 10:16:25,670 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_PS2'},'countdown_2','0.0');;
2023-02-02 10:16:25,671 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_JL27'},'dp_07','0');;
2023-02-02 10:16:25,672 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP05'},'cur_voltage','210.1');;
2023-02-02 10:16:25,675 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP02'},'cur_voltage','231.7');;
2023-02-02 10:16:25,676 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP03'},'cur_voltage','211.5');;
2023-02-02 10:16:25,678 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP07'},'cur_voltage','225.3');;
2023-02-02 10:16:25,682 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP09'},'cur_voltage','230.4');;
2023-02-02 10:16:38,865 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBeginUpdate($defs{'TUYA_JL26'});;
2023-02-02 10:16:38,865 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_JL29'},'cur_voltage','230.4');;
2023-02-02 10:16:38,865 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_JL24'},'switch_1','on');;
2023-02-02 10:16:38,866 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_bfe1b5bb54592232acz7dg'},'va_humidity','78.0');;
2023-02-02 10:16:38,866 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: AttrVal('TUYA_PS3', 'dp_104', '')
2023-02-02 10:16:38,866 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: AttrVal('TUYA_MMG', 'dp_34', '')
2023-02-02 10:16:38,866 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_bffb7d9839e65fcdeciaqn'},'state','normal');;
2023-02-02 10:16:38,984 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP01'},'switch_1','on');;
2023-02-02 10:16:38,985 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_453005615002911e00b4'},'state','on');;
2023-02-02 10:16:38,985 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb188e'},'add_ele','0.002');;
2023-02-02 10:16:38,985 - ERROR    - root: tuya_cloud_00673231e09806cb188e: readingsBulkUpdate without readingsBeginUpdate: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb188e'},'cur_current','38.0');;
2023-02-02 10:16:38,986 - ERROR    - root: tuya_cloud_00673231e09806cb188e: readingsBulkUpdate without readingsBeginUpdate: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb188e'},'cur_power','4.3');;
2023-02-02 10:16:38,986 - ERROR    - root: tuya_cloud_00673231e09806cb188e: readingsBulkUpdate without readingsBeginUpdate: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb188e'},'cur_voltage','229.3');;
2023-02-02 10:16:38,986 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_bfefd42e199ea92ee3jbwh'},'bright_value_v2','1000.0');;
2023-02-02 10:54:23,185 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_8877821724a160151069'},'state','on');;
2023-02-02 10:54:23,185 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_JL33'},'cur_current','320.0');;
2023-02-02 10:54:23,186 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP15'},'online','1');;
2023-02-02 11:32:08,990 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP16'},'online','1');;
2023-02-02 11:32:08,990 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_3367036770039f60ce2b'},'countdown_1','0.0');;
2023-02-02 12:20:53,768 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBeginUpdate($defs{'tuya_cloud_260064612cf432ca55d8'});;
2023-02-02 12:20:53,771 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_JL04'},'cur_current','236.0');;
2023-02-02 12:20:53,773 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb188e'},'add_ele','0.002');;
2023-02-02 13:24:27,927 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBeginUpdate($defs{'tuya_cloud_3367036770039f613620'});;
2023-02-02 13:24:27,927 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_JL26'},'cur_voltage','228.0');;
2023-02-02 13:38:50,146 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBeginUpdate($defs{'TUYA_JL08'});;
2023-02-02 13:38:50,147 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP15'},'online','1');;
2023-02-02 14:09:26,137 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdate($defs{'tuya_cloud_00673231e09806cb6fa5'},'cur_current','117.0');;
2023-02-02 14:09:26,137 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsEndUpdate($defs{'TUYA_STF2'},1);;
2023-02-02 14:09:26,138 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP14'},'dp_21','1');;
2023-02-02 14:09:26,139 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsEndUpdate($defs{'TUYA_STF1'},1);;
2023-02-02 14:09:26,139 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP16'},'cur_power','1.6');;
2023-02-02 14:09:26,263 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP15'},'cur_voltage','225.7');;
2023-02-02 14:09:26,263 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP12'},'cur_voltage','225.9');;
2023-02-02 14:09:26,264 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsBulkUpdateIfChanged($defs{'TUYA_SP13'},'dp_24','20333');;
2023-02-02 14:09:26,264 - ERROR    - fhempy.lib.fhem: NO RESPONSE since 60s: readingsEndUpdate($defs{'TUYA_JL20'},1);;
stefanru
Ok, hab mich auch zu früh gefreut.
Die Meldungen sind auch wieder da
2023.02.02 14:07:15 1: BindingsIo (local_pybinding): Use of uninitialized value $d in hash element at fhem.pl line 4766.
=> COMMAND: readingsEndUpdate($defs{'tuya_cloud_bf4f644bc7dd2fc71d9q52'},1);;
2023.02.02 14:07:15 1: BindingsIo (local_pybinding): Use of uninitialized value $dev in hash element at fhem.pl line 3839.
Außerdem die anderen auch die ganze Zeit.
Mein fhem.log file hat nach 2 Stunden über 50 MB!
Stefan
thburkhart
Nachtrag:
so nach ca.  6 Stunden nach dem Stutdown reset wird der room FHEMPY wieder quasi sofort angezeigt :-)
in fhempi log haben wir inzwischen 16000-mal
2023-02-02 16:35:38,461 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:35:43,473 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:35:45,872 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:35:48,485 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:35:53,497 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:35:55,883 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:35:57,802 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:35:58,511 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:36:03,522 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:36:05,896 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:36:08,534 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:36:13,546 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:36:15,908 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:36:18,558 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:36:23,570 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:36:25,920 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:36:28,582 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:36:33,594 - WARNING  - asyncio: socket.send() raised exception.
2023-02-02 16:36:35,932 - WARNING  - asyncio: socket.send() raised exception.
dominik
Damit haben sich nun die socket.send() Fehler erklärt. Sie treten auf, wenn FHEM blockiert ist.
Ich kann diese Verhalten bei mir einfach nicht reproduzieren obwohl ich ca. 20 Tuya Devices eingebunden hab. Sowohl cloud, als auch local.
@thburkhart, nachdem du so viele Devices drin hast. Könntest du mir deine Credentials (=tuya_cloud setup Definition) per PN zukommen lassen und ich richte die mal bei mir ein? Ich kann die Fehler sonst bei mir leider nicht reproduzieren.
fhempy -  https://github.com/fhempy/fhempy: GoogleCast, Tuya, UPnP, Ring, EQ3BT, Nespresso, Xiaomi, Spotify, Object Detection, ...
Kaffeespende: https://paypal.me/todominik
thburkhart
sehr gerne ....
funktioell ist es so, dass ich _local vs. _cloud viele devices  doppelt habe und diese nur über _cloud bedienen kann
dominik
Danke für die Zusendung der Credentials! Das Gute, ich kann den Fehler nun bei mir nachstellen und bekomme diesen auch...ich mach mich auf die Suche.
thburkhart
thburkhart
zum Thema shutdown restart
habe eben tuyaunabhängig in der fhem.cfg was geändert und gespeichert.
Folge: fhempy offline
dann  tuya restart
fempy server immer noch offline
traue mich nicht, fhem neu starten
was tun?
