Hi!
I've bought an Enocean enabled heating actuator valve to control my radiators through FHEM.
The valve is sold by Caleffi (http://www.caleffi.com/italy/it/catalogo/wicalr-comando-elettronico-ad-onde-radio) and, apparently, they're also manufacturing it, since I haven't found any similar product on the web.
The problem is that I can't make it work with FHEM! I keep getting the same error, whatever is the configuration I try: "teach-in No EEP profile identifier and no Manufacturer ID".
Here comes the log:
2015.02.17 19:51:00 5: TCM TCM_ESP3_0 RAW: 55000A0701EBA580083805018F50280001FFFFFFFF5F0018
2015.02.17 19:51:00 5: TCM_ESP3_0 dispatch EnOcean:1:A5:80083805:018F5028:00:01FFFFFFFF5F00
2015.02.17 19:51:02 2: EnOcean Cryptographic functions available.
2015.02.17 19:51:02 1: EnOcean Unknown device with SenderID 018F5028 and RORG A5, please define it.
2015.02.17 19:51:02 2: autocreate: define EnO_sensor_018F5028 EnOcean 018F5028 EnOcean:1:A5:80083805:018F5028:00:01FFFFFFFF5F00
2015.02.17 19:51:02 2: EnOcean EnO_sensor_018F5028 teach-in No EEP profile identifier and no Manufacturer ID
2015.02.17 19:51:02 2: autocreate: define FileLog_EnO_sensor_018F5028 FileLog ./log/EnO_sensor_018F5028-%Y.log EnO_sensor_018F5028
2015.02.17 19:51:11 5: TCM TCM_ESP3_0 RAW: 55000A0701EBA580
2015.02.17 19:51:11 5: TCM TCM_ESP3_0 RAW: 55000A0701EBA580083805018F50280003FFFFFFFF5E00B4
2015.02.17 19:51:11 5: TCM_ESP3_0 dispatch EnOcean:1:A5:80083805:018F5028:00:03FFFFFFFF5E00
2015.02.17 19:51:11 2: EnOcean EnO_sensor_018F5028 teach-in No EEP profile identifier and no Manufacturer ID
What am I doing wrong? Is there something I can do to make it work?
Thanks in advance!
It seems as if the teach-in telegram is wrong. The data message "80083805" contains the following information:
- DB0.7 = 0: telegram without EEP and Manufacturer ID
- EEP: A5-20-01
- Manufacturer: Gruppo Giordano Idea Spa
If DB0.7 = 0, there is no possible to teach-in the device in FHEM. Please contact the manufacturer of the device. Further information about the teach-in can be found in the EEP-document chapter 3.3) from EnOcean.
Thanks a billion Klaus for your prompt reply!
Which kind of informations should I ask to the manufacturer in order to make it work with FHEM?
And...is there no way to force EEP and Manuf ID even if it is not included in the telegram sent from the device?
The device is only taught in automatically, if the DB0.7 bit is set to 1. The data telegram of the actuator currently not in compliance to the EEP specifications.
