Hallo Forum,
ich habe ein seltsames Phänomen...
AptToDate zeigt im Status "alles gut"/grün - Der Server zeigt anwendbare Aktualisierungen.
Auch ein manuelles set reposync & get DistributionInfo (die beiden einzigen Optionen derzeit) per Hand ändern nichts daran.
In der Vergangenheit, bevor ich im Linux die automatischen Aktualisierungen aktiviert habe, wurden regelmäßig die fehlenden Pakete gemeldet.
Definition AptToDate:
defmod SVL01_APT AptToDate localhost
attr SVL01_APT DbLogExclude .*
attr SVL01_APT devStateIcon system.updates.available:security@red system.is.up.to.date:security@green .*in.progress:system_fhem_reboot@orange errors:message_attention@red
attr SVL01_APT event-on-change-reading .*
attr SVL01_APT room .System
setstate SVL01_APT system is up to date
setstate SVL01_APT 2022-08-09 11:29:49 .updatedList {}
setstate SVL01_APT 2022-09-08 15:39:25 .upgradeList {}
setstate SVL01_APT 2021-10-24 10:07:46 os-release_BUG_REPORT_URL https://bugs.launchpad.net/ubuntu/
setstate SVL01_APT 2021-10-24 10:07:46 os-release_HOME_URL https://www.ubuntu.com/
setstate SVL01_APT 2021-10-24 10:07:46 os-release_ID ubuntu
setstate SVL01_APT 2021-10-24 10:07:46 os-release_ID_LIKE debian
setstate SVL01_APT 2021-10-24 10:07:46 os-release_NAME Ubuntu
setstate SVL01_APT 2022-11-08 11:17:36 os-release_PRETTY_NAME Ubuntu 20.04.5 LTS
setstate SVL01_APT 2021-10-24 10:07:46 os-release_PRIVACY_POLICY_URL https://www.ubuntu.com/legal/terms-and-policies/privacy-policy
setstate SVL01_APT 2021-10-24 10:07:46 os-release_SUPPORT_URL https://help.ubuntu.com/
setstate SVL01_APT 2021-10-24 10:07:46 os-release_UBUNTU_CODENAME focal
setstate SVL01_APT 2022-11-08 11:17:36 os-release_VERSION 20.04.5 LTS (Focal Fossa)
setstate SVL01_APT 2021-10-24 10:07:46 os-release_VERSION_CODENAME focal
setstate SVL01_APT 2021-10-24 10:07:46 os-release_VERSION_ID 20.04
setstate SVL01_APT 2021-10-24 10:07:46 os-release_language de
setstate SVL01_APT 2022-11-08 11:18:20 repoSync fetched done
setstate SVL01_APT 2022-11-08 11:18:24 state system is up to date
setstate SVL01_APT 2022-08-09 11:29:49 toUpgrade successful
setstate SVL01_APT 2022-08-09 11:29:50 updatesAvailable 0
Anzeige auf dem Server:
Willkommen zu Ubuntu 20.04.5 LTS (GNU/Linux 5.4.0-131-generic x86_64)
System information as of Di 8. Nov 11:17:51 CET 2022
System load: 0.08 Processes: 245
Usage of /: 80.1% of 14.17GB Users logged in: 0
Memory usage: 37% IPv4 address for ens160: xxx
Swap usage: 5%
2 updates can be applied immediately.
1 of these updates is a standard security update.
To see these additional updates run: apt list --upgradable
Hat jemand eine Erklärung für das Verhalten?
Tom
Was sagt denn ein
apt list --upgradeable
Dat...
$ apt list --upgradeable
Auflistung... Fertig
libpixman-1-0/focal-updates,focal-security 0.38.4-0ubuntu2.1 amd64 [aktualisierbar von: 0.38.4-0ubuntu1]
libtiff5/focal-updates,focal-security 4.1.0+git191117-2ubuntu0.20.04.6 amd64 [aktualisierbar von: 4.1.0+git191117-2ubuntu0.20.04.5]
nodejs/unbekannt 14.21.1-deb-1nodesource1 amd64 [aktualisierbar von: 14.20.1-deb-1nodesource1]
php7.4-cgi/focal-updates,focal-security 7.4.3-4ubuntu2.15 amd64 [aktualisierbar von: 7.4.3-4ubuntu2.13]
php7.4-cli/focal-updates,focal-security 7.4.3-4ubuntu2.15 amd64 [aktualisierbar von: 7.4.3-4ubuntu2.13]
php7.4-common/focal-updates,focal-security 7.4.3-4ubuntu2.15 amd64 [aktualisierbar von: 7.4.3-4ubuntu2.13]
php7.4-intl/focal-updates,focal-security 7.4.3-4ubuntu2.15 amd64 [aktualisierbar von: 7.4.3-4ubuntu2.13]
php7.4-json/focal-updates,focal-security 7.4.3-4ubuntu2.15 amd64 [aktualisierbar von: 7.4.3-4ubuntu2.13]
php7.4-opcache/focal-updates,focal-security 7.4.3-4ubuntu2.15 amd64 [aktualisierbar von: 7.4.3-4ubuntu2.13]
php7.4-readline/focal-updates,focal-security 7.4.3-4ubuntu2.15 amd64 [aktualisierbar von: 7.4.3-4ubuntu2.13]
php7.4-sqlite3/focal-updates,focal-security 7.4.3-4ubuntu2.15 amd64 [aktualisierbar von: 7.4.3-4ubuntu2.13]
php7.4-xml/focal-updates,focal-security 7.4.3-4ubuntu2.15 amd64 [aktualisierbar von: 7.4.3-4ubuntu2.13]
ok, und was sagt
apt-get -s -q -V upgrade
Das...
$ apt-get -s -q -V upgrade
HINWEIS: Dies ist nur eine Simulation!
apt-get benötigt root-Privilegien für die reale Ausführung.
Behalten Sie ebenfalls in Hinterkopf, dass die Sperren deaktiviert
sind, verlassen Sie sich also bezüglich des reellen aktuellen
Status der Sperre nicht darauf!
Paketlisten werden gelesen...
Abhängigkeitsbaum wird aufgebaut....
Statusinformationen werden eingelesen....
Paketaktualisierung (Upgrade) wird berechnet...
Die folgenden Pakete werden aktualisiert (Upgrade):
nodejs (14.20.1-deb-1nodesource1 => 14.21.1-deb-1nodesource1)
1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Inst nodejs [14.20.1-deb-1nodesource1] (14.21.1-deb-1nodesource1 Node Source:deb.nodesource.com [amd64])
Conf nodejs (14.21.1-deb-1nodesource1 Node Source:deb.nodesource.com [amd64])
Inzwischen hat sich die Anmeldebegrüßung auch auf das geändert (AutoUpdate wahrscheinlich):
1 update can be applied immediately.
Bin da ehrlich gesagt etwas ratlos. Eigentlich solltest Du Daten bekommen. Das stimmt alles soweit.
zeige mal bitte ein list vom Device. Also
list SVL01_APT
in der FHEM Kommandozeile eingeben
DEF localhost
FUUID 5de3d301-f33f-eff5-c49a-23eececabd2edd22
FVERSION 42_AptToDate.pm:v1.4.5-s19639/2019-06-18
HOST localhost
NAME SVL01_APT
NOTIFYDEV global,SVL01_APT
NR 410
NTFY_ORDER 50-SVL01_APT
STATE system is up to date
TYPE AptToDate
VERSION v1.4.5
eventCount 4
2022-11-09 00:47:58 repoSync fetched done
2022-11-09 00:47:58 state system is up to date
helper:
lastSync 2022-11-09
DbLogExclude .*
room .System
Aktueller Zustand
New release '22.04.1 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
Last login: Wed Nov 9 17:41:10 2022
Ähm... "gelöst"... so scheint es derzeit.
Ich habe das
herausgenommen und dann ging es wieder.
Hätte jetzt nicht gedacht, dass das eine solche Wirkung haben könnte :-\
Danke für die Unterstützung CoolTux.
