Bug in cmdalias
Begonnen von phervier, 14 Dezember 2014, 23:19:23
phervier
Hello
I hope this is the good place to post that.
i detected a bug in the cmdalias. If you define a simple command like
define c5 cmdalias casto1on AS {fhem ("set Prise_casto_1 on")}
if works perfectly as it should do but if unfortunatly you make a mistake and typas a command like
casto1on anything
FHEM just crash without any notice. This problem could be avoided if you define the cmdalias as :
define c5 cmdalias casto1on  .* AS {fhem ("set Prise_casto_1 on")}
but id definitely needs a notice.
rudolfkoenig
Thanks for the bugreport, I fixed it.
