Qnap ( INTEL CPU )
Begonnen von Bloug, 25 Juni 2014, 07:16:24
Bloug
Hello, I have a Qnap Ts269-L core intel and not ARM.
I found the procedure to install on Qnap (ARM)
http://www.fhemwiki.de/wiki/Qnap_NAS#Installation_des_QPKG_Paketes_Optware_IPKG
What should I change my installation?
Thx for u help !
Bloug
P.A.Trick
I don't know, but u can install Debian on your QNAP and after that it is very easy to install fhem. You can download the *fhem*deb Package on
fhem.de and install it via apt-get install.
Another way is described on our wiki (sorry only in german)
Maybe u can use google translation to get the information.
immi
if not already done change
src tsx19 http://ipkg.nslu2-linux.org/feeds/optware/tsx19/cross/unstable
to your system
problably http://ipkg.nslu2-linux.org/feeds/optware/ts509/cross/unstable/
please look carefully at your system
if you need further drivers (like cdc_acm), I documented the compilation here.
http://forum.qnap.com/viewtopic.php?f=182&t=61052
immi
Bloug
ok Thank you for your help !
Step by step
1  -       I connect to putty
2  -       I  type the command: ipkg install libtool nano gcc make automake ncurses ncursesw wget perl autoconf
            .... Installation ....
3  -       I  type the command: cd /share/MD0_DATA/.qpkg/Optware/etc/ipkg/ts509.conf
4 -  I  type the command: vi ts509.conf
                it's already : src/gz ts509 http://ipkg.nslu2-linux.org/feeds/optware/ts509/cross/unstable
5 -  I  type the command: cd /share/MD0_DATA/.qpkg/Optware/etc
6 -  I  type the command: vi ipkg.conf
             I add below the line "dest root / " ==>  dest opt /opt    then I save
7 -  I  type the command: cd /share/MD0_DATA/.qpkg/Optware
8 -  I  type the command: mv Optware.sh Optware-ipkg.sh
9 -  I  type the command: vi Optware-ipkg.sh
             I change the line QPKG_NAME="Optware" ==>  QPKG_NAME="Optware-ipkg"    then I save
10 - I  type the command: /share/MD0_DATA/.qpkg/Optware/Optware-ipkg.sh restart
                     I have the following error message: Error: Optware-ipkg is disabled.
Plz  help me :)
immi
if the installation was correct (step 2), then step 3 and following are useless.
test the installed packages e.g. "perl -v"
depending on the fhem module you need, install  further perl packages:
e.g.
>> ipkg install perl-io-socket-ssl
in order to have a list of all installable perl  packages
>> ipkg list | grep perl
then install fhem in /opt/fhem/
start it and we look what happens.
immi
Bloug
>> "perl -v"
This is perl, v5.10.0 built for i686-unknown-linux-gnu
Copyright 1987-2007, Larry Wall
Perl may be copied only under the terms of either the Artistic License or the
GNU General Public License, which may be found in the Perl 5 source kit.
Complete documentation for Perl, including FAQ lists, should be found on
this system using "man perl" or "perldoc perl".  If you have access to the
Internet, point your browser at http://www.perl.org/, the Perl Home Page.
Installing perl-io-socket-ssl (0.999-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/ts509/cross/unstable/perl-io-socket-ssl_0.999-1_i686.ipk
Installing perl-net-ssleay (1.30-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/ts509/cross/unstable/perl-net-ssleay_1.30-1_i686.ipk
Installing openssl (0.9.8v-2) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/ts509/cross/unstable/openssl_0.9.8v-2_i686.ipk
Configuring openssl
Configuring perl-io-socket-ssl
Configuring perl-net-ssleay
Successfully terminated.
cups-pdf - 2.5.1-1 - CUPS-PDF provides a PDF Writer backend to CUPS. This can be used as a virtual printer in a paperless network.
microperl - 5.10.0-1 - Microperl.
perl - 5.10.0-6 - Practical Extraction and Report Language.
perl-algorithm-diff - 1.1901-2 - Algorithm-Diff - Compute *intelligent* differences between two files / lists.
perl-appconfig - 1.56-3 - Perl5 module for reading configuration files and parsing command line arguments.
perl-archive-tar - 1.38-1 - Archive-Tar - The Perl Database Interface by Tim Bunce.
perl-archive-zip - 1.16-3 - Archive-Zip - Provide an interface to ZIP archive files.
perl-assp - 1.2.6-1 - Anti-Spam SMTP Proxy Server
perl-b-keywords - 1.08-1 - Lists of reserved barewords and symbol names.
perl-berkeleydb - 0.32-1 - BerkeleyDB - Perl extension for Berkeley DB version 2, 3 or 4
perl-bit-vector - 6.4-1 - This package implements bit vectors of arbitrary size and provides efficient methods for handling them.
perl-bsd-resource - 1.28-1 - BSD process resource limit and priority functions.
perl-business-isbn - 1.84-1 - Business-ISBN - work with International Standard Book Numbers
perl-business-isbn-data - 1.17-1 - Business-ISBN-Data - <module_description>
perl-carp-clan - 5.3-1 - This module reports errors from the perspective of the caller of a clan of modules, similar to Carp.pm itself.
perl-cgi - 3.42-1 - Perl module for CGI.
perl-cgi-application - 3.31-2 - Framework for building reusable web-applications
perl-class-accessor - 0.30-2 - Class::Accessor - Automated accessor generation
perl-class-data-inheritable - 0.04-2 - Class-Data-Inheritable - Inheritable, overridable class data
perl-class-dbi - v3.0.15-1 - Class-DBI - Simple Database Abstraction.
perl-class-trigger - 0.10-2 - Class-Trigger - Mixin to add / call inheritable triggers.
perl-clone - 0.29-1 - Clone - recursively copy Perl datatypes.
perl-compress-zlib - 1.42-3 - Compress-Zlib - Interface to zlib compression library.
perl-convert-binhex - 1.119-1 - Convert-BinHex - extract data from Macintosh BinHex files
perl-convert-tnef - 0.17-2 - Convert-TNEF - Perl module to read TNEF files
perl-convert-uulib - 1.08-1 - Convert-UUlib - Perl interface to the uulib library (a.k.a. uudeview/uuenview).
perl-crypt-openssl-random - 0.03-1 - Crypt-OpenSSL-Random - Routines for accessing the OpenSSL pseudo-random number generator
perl-crypt-openssl-rsa - 0.24-1 - Crypt-OpenSSL-RSA - RSA encoding and decoding, using the openSSL libraries
perl-crypt-ssleay - 0.55-1 - OpenSSL glue that provides LWP https support.
perl-danga-socket - 1.44-1 - Event loop and event-driven async socket base class.
perl-date-calc - 5.4-2 - Gregorian calendar date calculations.
perl-date-manip - 5.48-1 - date manipulation routines
perl-db-file - 1.814-2 - A module which allows Perl programs to make use of the facilities provided by Berkeley DB version 1.
perl-dbd-mysql - 4.006-1 - DBD-mysql - The Perl Database Driver for MySQL.
perl-dbd-sqlite - 1.35-1 - The Perl Database Driver for SQLITE.
perl-dbi - 1.620-1 - DBI - The Perl Database Interface by Tim Bunce.
perl-dbix-contextualfetch - 1.03-2 - DBIx-ContextualFetch - Add contextual fetches to DBI.
perl-devel-caller - 0.11-1 - meatier versions of caller.
perl-devel-lexalias - 0.04-1 - alias lexical variables.
perl-device-serialport - 1.04-1 - Device::SerialPort for serial port users.
perl-digest-hmac - 1.01-4 - The module allows you to use the NIST SHA-1 message digest algorithm.
perl-digest-perl-md5 - 1.8-1 - Digest-Perl-MD5 - Perl implementation of Ron Rivests MD5 Algorithm
perl-digest-sha - 5.47-1 - Digest-SHA - Perl extension for SHA-1/224/256/384/512.
perl-digest-sha1 - 2.11-3 - The module allows you to use the NIST SHA-1 message digest algorithm.
perl-doc - 5.10.0-6 - Documentation for perl
perl-email-address - 1.889-1 - RFC 2822 Address Parsing and Creation.
perl-email-messageid - 1.401-1 - Generate world unique message-ids.
perl-email-mime - 1.863-3 - Easy MIME message parsing.
perl-email-mime-contenttype - 1.015-1 - Parse a MIME Content-Type Header.
perl-email-mime-encodings - 1.312-1 - A unified interface to MIME encodings and decoding.
perl-email-mime-modifier - 1.443-2 - Modify Email::MIME Objects Easily
perl-email-send - 2.194-2 - Simply Sending Email.
perl-email-simple - 2.005-1 - simple parsing of RFC2822 message format and headers.
perl-encode-detect - 1.00-1 - Detects the encoding of data.
perl-extutils-cbuilder - 0.18-2 - ExtUtils-CBuilder - Compile and link C code for Perl modules.
perl-extutils-parsexs - 2.19-1 - ExtUtils-ParseXS - converts Perl XS code into C code.
perl-file-next - 1.02-1 - File::Next is a lightweight, taint-safe file-finding module. It is lightweight and has no non-core prerequisites.
perl-file-rename - 0.05-1 - renames multiple files.
perl-gd - 2.35-2 - GD - Interface to Gd Graphics Library
perl-gd-barcode - 1.15-2 - GD-Barcode - Create barcode image with GD
perl-hottproxy - 0.24.0.0-1 - HTTP proxy targeted specifically toward serving the needs of wireless Internet devices (cell phones, PDAs, etc.).
perl-html-parser - 3.60-1 - A collection of modules that parse and extract information from HTML documents.
perl-html-tagset - 3.04-4 - This module contains data tables useful in dealing with HTML.
perl-html-template - 2.8-2 - Perl module to use HTML Templates from CGI scripts
perl-http-response-encoding - 0.05-1 - Adds encoding() to HTTP::Response.
perl-ima-dbi - 0.34-2 - Ima-DBI - Database connection caching and organization.
perl-io-multiplex - 1.09-1 - IO-Multiplex - Manage IO on many file handles
perl-io-socket-ssl - 0.999-1 - IO-Socket-SSL - Nearly transparent SSL encapsulation for IO::Socket::INET
perl-io-string - 1.08-2 - IO-String - Emulate file interface for in-core strings.
perl-io-stringy - 2.110-2 - IO-stringy - I/O on in-core objects like strings and arrays
perl-io-zlib - 1.09-1 - IO-Zlib - IO:: style interface to Compress::Zlib.
perl-ip-country - 2.21-1 - IP-Country - fast lookup of country codes by IP address
perl-json-xs - 1.5-1 - JSON serialising/deserialising, done correctly and fast.
perl-lexical-persistence - 0.97-1 - Persistent lexical variable values for arbitrary calls.
perl-libnet - 1.22-1 - A collection of Perl modules providing simple and consistent programming API to the client side of various internet protocols.
perl-libwww - 5.825-1 - libwww-perl - The World-Wide Web library for Perl
perl-libxml - 0.08-1 - Collection of Perl modules for working with XML
perl-mail-spf-query - 1.999.1-1 - Mail-SPF-Query - query Sender Policy Framework for an IP,email,helo
perl-mailtools - 1.77-1 - MailTools - Base class for manipulation of mail header fields
perl-mime-tools - 5.420-1 - MIME-tools - modules for parsing (and creating!) MIME entities
perl-module-build - 0.2808-1 - Module-Build - Build and install Perl modules.
perl-module-pluggable - 3.8-1 - Automatically give your module the ability to have plugins.
perl-module-refresh - 0.13-1 - Refresh %INC files when updated on disk.
perl-module-signature - 0.54-2 - Module-Signature - Module signature file manipulation.
perl-net-cidr-lite - 0.20-1 - Net-CIDR-Lite - Perl extension for merging IPv4 or IPv6 CIDR addresses
perl-net-dns - 0.48-4 - Perl DNS Resolver Module.
perl-net-ident - 1.20-4 - Net::Ident
perl-net-server - 0.97-1 - Net-Server - Extensible, general Perl server engine
perl-net-ssleay - 1.30-1 - Net_SSLeay - Perl extension for using OpenSSL
perl-padwalker - 1.5-1 - play with other people''s lexical variables
perl-par-dist - 0.21-2 - PAR-Dist - Create and manipulate PAR distributions.
perl-pod-readme - 0.081-2 - Pod-Readme - Convert POD to README file.
perl-poe-xs-queue-array - 0.005-1 - an XS implementation of POE::Queue::Array.
perl-return-value - 1.302-1 - Polymorphic Return Values
perl-scgi - 0.6-1 - The Perl SCGI server library.
perl-storable - 2.18-1 - The Storable extension brings persistency to your data.
perl-sys-hostname-long - 1.4-1 - Sys-Hostname-Long - Try every conceivable way to get full hostname
perl-sys-syscall - 0.22-1 - Access system calls that Perl does not normally provide access to.
perl-template-toolkit - 2.19-1 - The Template Toolkit is a fast, powerful and extensible template processing system. (www.template-toolkit.org)
perl-term-readkey - 2.30-2 - A perl module for simple terminal control
perl-term-readline-gnu - 1.16-1 - Perl extension for the GNU Readline/History Library.
perl-text-diff - 0.35-2 - Text-Diff - Perform diffs on files and record sets.
perl-timedate - 1.16-1 - A date and time module for perl.
perl-unicode-map - 0.112-3 - Unicode-Map - maps charsets from and to utf16 unicode
perl-unicode-string - 2.09-1 - Unicode-String - String of Unicode characters (UTF-16BE)
perl-universal-moniker - 0.08-2 - UNIVERSAL-moniker - This module will add a moniker (and plural_moniker) method to UNIVERSAL, and so to every class or module.
perl-unix-syslog - 0.100-1 - Unix-Syslog - Perl interface to the UNIX syslog(3) calls
perl-uri - 1.35-3 - URI - <module_description>
perl-version - 0.74-1 - version - Perl extension for Version Objects.
perl-wakeonlan - 0.41-1 - A Perl script that sends 'magic packets' to wake-on-LAN enabled ethernet adapters and motherboards, in order to switch on remot
perl-www-mechanize - 1.54-2 - Handy web browsing in a Perl object.
perl-xml-dom - 1.44-1 - A perl module for building DOM Level 1 compliant document structures
perl-xml-parser - 2.34-1 - A perl module for parsing XML documents.
perl-xml-regexp - 0.03-1 - Regular expressions for XML tokens
perl-yaml-syck - 1.05-1 - Fast, lightweight YAML loader and dumper.
perlbal - 1.78-1 - Reverse-proxy load balancer and webserver.
perlconsole - 0.4-2 - Perl Console is a small program that implements a Read-eval-print loop: it lets you evaluate Perl code interactively.
perltgd - 1.1.0-5 - Automated EPG updating for the Topfield range of PVRs
svn-pl - 1.7.7-1 - perl SWIG binding for subversion
[~] # This is perl, v5.10.0 built for i686-unknown-linux-gnu
-sh: This: command not found
I downloaded that I uncompressed FHEM-5.5.tar.gz. then moved to /share/MD0_DATA/.qpkg/Optware/opt/FHEM/fhem-5.5
>>  vi Makefile
VERS=5.5
DATE=2013-09-29
RELATIVE_PATH=YES
BINDIR=/opt/fhem
MODDIR=$(BINDIR)
VARDIR=$(BINDIR)/log
MANDIR=$(BINDIR)/docs
ETCDIR=$(BINDIR)
DEMODIR=$(BINDIR)
# Used for .deb package creation
RBINDIR=$(ROOT)$(BINDIR)
RMODDIR=$(ROOT)$(MODDIR)
RVARDIR=$(ROOT)$(VARDIR)
RMANDIR=$(ROOT)$(MANDIR)
RETCDIR=$(ROOT)$(ETCDIR)
RDEMODIR=$(ROOT)$(DEMODIR)
Does it's  ??????? :
# vi Makefile
BINDIR=/opt/bin
MODDIR=/opt/lib
VARDIR=/opt/var/log/fhem
Bientot :) :) :)
immi
in order to install, just untar
http://www.dhs-computertechnik.de/downloads/fhem-cvs.tgz
in /opt/fhem/
the stucture should look like
/opt/fhem/FHEM, /opt/fhem/log, /opt/fhem/contrib .....
now check the perl path with
>> which perl
my path is /opt/bin/perl
if different, edit the first line of /opt/fhem/fhem.pl accordingly
now start fhem
>> cd /opt/fhem
>> perl fhem.pl fhem.cfg
immi
Bloug
ok, I have copied into the correct folder opt / FHEM
after starting with :
  Use of uninitialized value in concatenation (.) Or string at fhem.pl line 448.
if I edit the file fhem.pl
>> vi fhem.pl
line 448
Log 0, "Server started with ".int(keys %defs).
        " defined entities (version $attr{global}{version}, $osuser, pid $$)";
immi
There are at least 20 post with the same error, if you search.
I told you in /opt/fhem
just to be sure
>>pwd
/opt/fhem
>>ls -l
-rwxrwx---    1 simone   everyone     65310 Mar 15 04:11 CHANGED*
-rwxrwx---    1 simone   everyone     18092 Sep  8  2013 COPYING*
drwxrwxrwx    5 simone   everyone     12288 Jul  3 20:12 FHEM/
-rwxrwx---    1 simone   everyone     22580 Mar  9 04:11 HISTORY*
-rwxrwx---    1 simone   everyone     19983 Mar 10 04:11 MAINTAINER.txt*
-rwxrwx---    1 simone   everyone      4208 Sep 30  2013 Makefile*
-rwxrwx---    1 simone   everyone       849 Sep  8  2013 README.SVN*
-rwxrwx---    1 simone   everyone       761 Sep 23  2013 README_DEMO.txt*
-rwxrwx---    1 simone   everyone     19245 Mar 14 04:11 configDB.pm*
drwxrwxrwx   28 simone   everyone      4096 Jul  3 20:12 contrib/
drwxrwxrwx    3 simone   everyone      4096 Jul  3 20:12 demolog/
drwxrwxrwx    5 simone   everyone      4096 Jul  3 20:12 docs/
-rwxrwx---    1 simone   everyone      2941 Jul  3 20:23 fhem.cfg*
-rwxrwx---    1 simone   everyone     11760 Mar  3 04:11 fhem.cfg.demo*
-rwxrwx---    1 simone   everyone    100204 Mar 17 04:11 fhem.pl*
drwxrwxrwx    3 simone   everyone      4096 Jul  3 20:23 log/
drwxrwxrwx    7 simone   everyone      4096 Jul  3 20:12 webfrontend/
drwxrwxrwx    9 simone   everyone      4096 Jul  3 20:12 www/
please use the standard fhem.cfg and post your logfiles /opt/fhem/log/
Bloug
Thank   :-[
>> pwd
/opt/fhem
[/opt/fhem] # ls -l
-rwxr-x---    1 admin    administ     54761 Jul  3 19:12 CHANGED*
-rwxr-x---    1 admin    administ     22056 Jul  3 19:12 HISTORY*
-rwxr-x---    1 admin    administ      4208 Jul  3 19:12 Makefile*
-rwxr-x---    1 admin    administ       849 Jul  3 19:12 README.SVN*
-rwxr-x---    1 admin    administ       761 Jul  3 19:12 README_DEMO.txt*
drwxr-x---   26 admin    administ      4096 Jul  3 19:12 contrib/
drwxr-x---    2 admin    administ      4096 Jul  3 19:12 demolog/
drwxr-x---    4 admin    administ      4096 Jul  3 19:12 docs/
-rwxr-x---    1 admin    administ       744 Jul  3 19:12 fhem.cfg*
-rwxr-x---    1 admin    administ      5123 Jul  3 19:12 fhem.cfg.demo*
-rwxr-x---    1 admin    administ     93295 Jul  3 19:12 fhem.pl*
drwxr-x---    2 admin    administ      4096 Jul  3 19:19 log/
drwxr-x---    6 admin    administ      4096 Jul  3 19:12 webfrontend/
drwxr-x---    7 admin    administ      4096 Jul  3 19:12 www/
My fhem-2014-07.log
[/opt/fhem/log] # vi fhem-2014-07.log
Please define WEBphone first
Unknown module FHEMWEB, choose one of
Please define WEBtablet first
Unknown module FileLog, choose one of
Unknown module autocreate, choose one of
Please define autocreate first
Unknown module eventTypes, choose one of
Unknown module notify, choose one of
2014.07.03 19:19:22 2: SecurityCheck:  Running with root privileges. Restart fhem for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2014.07.03 19:19:22 0: Server started with 1 defined entities (version , os linux, user admin, pid 10957)
2014.07.03 19:34:15 1: Including fhem.cfg
2014.07.03 19:34:15 3: modpath must point to a directory where the FHEM subdir is
2014.07.03 19:34:15 3: Please define WEBphone first
2014.07.03 19:34:15 3: Please define WEBtablet first
2014.07.03 19:34:15 3: Please define autocreate first
2014.07.03 19:34:15 1: configfile: modpath must point to a directory where the FHEM subdir is
Unknown module telnet, choose one of
2014.07.03 19:34:15 2: SecurityCheck:  Running with root privileges. Restart fhem for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2014.07.03 19:34:15 0: Server started with 1 defined entities (version , os linux, user admin, pid 13485)
2014.07.03 19:34:42 1: Including fhem.cfg
2014.07.03 19:34:42 3: modpath must point to a directory where the FHEM subdir is
2014.07.03 19:34:42 3: Please define WEBphone first
2014.07.03 19:34:42 3: Please define WEBtablet first
2014.07.03 19:34:42 3: Please define autocreate first
2014.07.03 19:34:42 1: configfile: modpath must point to a directory where the FHEM subdir is
2014.07.03 19:34:42 2: SecurityCheck:  Running with root privileges. Restart fhem for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2014.07.03 19:34:42 0: Server started with 1 defined entities (version , os linux, user admin, pid 13583)
immi
it is too small;which version have you installed?
have you used the version I told you?
Bloug
I erase and I recommance Sry :(
Bloug
Ok I'm BAck !
with : http://www.dhs-computertechnik.de/downloads/fhem-cvs.tgz
uncompress in /opt/fhem
I restart the cmd:
[/opt/fhem] # perl fhem.pl fhem.cfg
[/opt/fhem] #
no error it's Okay ?  :-X
Bloug
[/opt/fhem/log] # ls
fhem-2014-07.log
2014.07.03 21:17:22 1: Including fhem.cfg
2014.07.03 21:17:22 3: telnetPort: port 7072 opened
2014.07.03 21:17:23 3: WEB: port 8083 opened
2014.07.03 21:17:23 3: WEBphone: port 8084 opened
2014.07.03 21:17:23 3: WEBtablet: port 8085 opened
2014.07.03 21:17:23 2: eventTypes: loaded 0 events from ./log/eventTypes.txt
2014.07.03 21:17:23 1: usb create starting
2014.07.03 21:17:23 1: usb create end
2014.07.03 21:17:23 2: SecurityCheck:  WEB,WEBphone,WEBtablet has no basicAuth attribute. telnetPort has no password/globalpassword attribute. Running with root privileges. Restart fhem for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2014.07.03 21:17:23 0: Server started with 9 defined entities (version $Id: fhem.pl 5238 2014-03-16 16:23:31Z rudolfkoenig $, os linux, user admin, pid 17336)
