Create button to change temperature
Begonnen von Martijn, 17 November 2015, 11:42:00
Martijn
Hi, maybe a silly question, but I cannot figure it out.
On the webpage I want to have a button to Set the Temperature to Day or Night (or fixed value) of my FHT.
And/or set the desired-temperature to one of the possible options.
Now I have to go to the properties of the FHT or do the set command by hand.
But there should be a way to do this by a single button or someting from the main page.
Who can help?
ph1959de
martijn, you should probably have a look at readingsGroup (see especially this wiki sample - from your point of view unfortunately in German only) - there is a variety of samples to combine readings and controls from single, list of, or selection of devices into an overview type of display.
Peter
Aktives Mitglied des FHEM e.V. | Moderator im Forenbereich "Wiki"
Icinger
I think, what you are looking for are the Attributes setList and webCmd like here:
KaffemaschineOverride
   STATE      Auto
   TYPE       dummy
   Readings:
     2015-10-09 08:00:00   state           Auto
   setList    state:Auto,04:00,04:30,05:00,05:30,06:00,06:30,07:00,07:30,08:00
   webCmd     state
Stefan
Verwende deine Zeit nicht mit Erklärungen. Die Menschen hören (lesen) nur, was sie hören (lesen) wollen. (c) Paulo Coelho
immi
Hi martijn
2 possibilities
1) DUMMY module
you can find examples at the end of
http://www.fhemwiki.de/wiki/Tecalor_THZ_Heatpump
search for FanSelector
the same can be done with slider or other inputs.
2) readingsProxy module
readingsProxy can do similar things in an easier way, if you do not need to save old status
define FanPassiveCooling readingsProxy Mythz:p75passiveCooling
attr FanPassiveCooling group THZ
attr FanPassiveCooling room pompa
attr FanPassiveCooling setFn {$CMD = "$READING $CMD"}
attr FanPassiveCooling setList 0 1 2
attr FanPassiveCooling webCmd 0:1:2
Martijn
Peter
Thank you Peter this is what I Needed.
