Eltako FL62-230V Anlernen
Begonnen von Damu, 29 März 2025, 14:59:01
Flachzange
Macht für die eigentliche Funktionsweise keinen Unterschied, aber sind es denn beides FL62-230V oder ist der neue Aktor vielleicht ein FL62NP-230V oder anderes Derivat?
Damu
Hallo
Ist ein FL62-230V
ZitatLatest Revision: 29839
File                      Rev  Last Change
fhem.pl                  29809 2025-03-30 09:15:04Z rudolfkoenig
96_allowed.pm            26004 2022-04-29 19:06:05Z rudolfkoenig
95_Astro.pm              29078 2024-08-17 17:47:08Z phenning
90_at.pm                  28711 2024-03-27 11:25:38Z rudolfkoenig
98_autocreate.pm          29378 2024-11-30 18:25:51Z rudolfkoenig
No Id found for 73_AutoShuttersControl.pm
98_BOSEST.pm              21773 2020-04-25 17:30:30Z dominik
57_Calendar.pm            29398 2024-12-04 19:04:10Z neubert
57_CALVIEW.pm            17605 2018-10-23 16:37:40Z chris1284
10_CUL_HM.pm              26934 2022-12-31 16:24:33Z martinp876
98_DOIF.pm                29460 2024-12-29 20:25:48Z Damian
98_DOIFtools.pm          27854 2023-08-18 08:28:36Z Ellert
98_dummy.pm              25606 2022-02-01 10:43:57Z rudolfkoenig
10_EnOcean.pm            29839 2025-04-10 18:53:57Z klaus.schauer
Ist immer noch das selbe.
define EnO_042CC990 EnOcean 042CC990
attr EnO_042CC990 IODev POE_EnOcean_OG
attr EnO_042CC990 creator autocreate
attr EnO_042CC990 manufID 00D
attr EnO_042CC990 room EnOcean
attr EnO_042CC990 subType MSC
#   CFGFN
#   DEF        042CC990
#   FUUID      67f94b97-f33f-d169-36f6-4c068dbf28698cc9
#   IODev      POE_EnOcean_OG
#   LASTInputDev POE_EnOcean_UG
#   MSGCNT     2
#   NAME       EnO_042CC990
#   NR         579
#   NTFY_ORDER 50-EnO_042CC990
#   POE_EnOcean_OG_DestinationID FFFFFFFF
#   POE_EnOcean_OG_MSGCNT 2
#   POE_EnOcean_OG_PacketType 1
#   POE_EnOcean_OG_RSSI -48
#   POE_EnOcean_OG_ReceivingQuality excellent
#   POE_EnOcean_OG_RepeatingCounter 1
#   POE_EnOcean_OG_SubTelNum 8
#   POE_EnOcean_OG_TIME 2025-04-11 19:06:22
#   POE_EnOcean_UG_DestinationID FFFFFFFF
#   POE_EnOcean_UG_MSGCNT 2
#   POE_EnOcean_UG_PacketType 1
#   POE_EnOcean_UG_RSSI -55
#   POE_EnOcean_UG_ReceivingQuality excellent
#   POE_EnOcean_UG_RepeatingCounter 1
#   POE_EnOcean_UG_SubTelNum 9
#   POE_EnOcean_UG_TIME 2025-04-11 19:06:22
#   STATE      ???
#   TYPE       EnOcean
#   eventCount 1
#   READINGS:
#     2025-04-11 19:04:23   IODev           POE_EnOcean_OG
#     2025-04-11 19:04:23   teach           MSC teach-in REF-ID 000004B8 not supported Manufacturer Eltako
#   helper:
setstate EnO_042CC990 2025-04-11 19:04:23 IODev POE_EnOcean_OG
setstate EnO_042CC990 2025-04-11 19:04:23 teach MSC teach-in REF-ID 000004B8 not supported Manufacturer Eltako
2025.04.11 20:22:03 3: TCM POE_EnOcean_OG set teach 60
2025.04.11 20:22:03 5: TCM POE_EnOcean_OG sent ESP: 5500100001A5D0114F06FFFFFFFFFFFFFF0425BA220015
2025.04.11 20:22:03 5: DevIo_SimpleWrite POE_EnOcean_OG: 5500100001A5D0114F06FFFFFFFFFFFFFF0425BA220015
2025.04.11 20:22:03 5: TCM POE_EnOcean_OG received ESP: 5500010002650000
2025.04.11 20:22:03 5: TCM POE_EnOcean_OG TCM_Parse 00
2025.04.11 20:22:03 5: TCM POE_EnOcean_OG RESPONSE: OK
2025.04.11 20:22:04 5: TCM POE_EnOcean_OG received ESP: 5500010004770838
2025.04.11 20:22:04 5: TCM POE_EnOcean_OG received ESP: 5500100701CED0114F06FFFFFFFFFFFFFF0425BA220104FFFFFFFF3500CB
2025.04.11 20:22:04 4: TCM POE_EnOcean_OG received own telegram from 0425BA22 blocked.
2025.04.11 20:22:11 5: TCM POE_EnOcean_OG received ESP: 55000D0701FDD100D0FF000004B8042CC9900107FFFFFFFF3500E2
2025.04.11 20:22:11 5: POE_EnOcean_OG: dispatch EnOcean:1:D1:00D0FF000004B8:042CC990:01:07FFFFFFFF3500
2025.04.11 20:22:11 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:D1:00D0FF000004B8:042CC990:01:07FFFFFFFF3500
2025.04.11 20:22:11 1: EnOcean Unknown device with SenderID 042CC990 and MSC telegram, please define it.
2025.04.11 20:22:11 2: autocreate: define EnO_042CC990 EnOcean 042CC990 EnOcean:1:D1:00D0FF000004B8:042CC990:01:07FFFFFFFF3500
2025.04.11 20:22:11 2: EnOcean define EnO_042CC990 EnOcean 042CC990 EnOcean:1:D1:00D0FF000004B8:042CC990:01:07FFFFFFFF3500
2025.04.11 20:22:11 2: EnOcean define FileLog_EnO_042CC990 FileLog ./log/EnO_042CC990-%Y.log EnO_042CC990
2025.04.11 20:22:11 2: EnOcean EnO_042CC990 MSC teach-in REF-ID 000004B8 not supported Manufacturer Eltako
2025.04.11 20:22:12 5: TCM POE_EnOcean_OG received ESP: 55000E070140D100D0FE0303010076042CC9900109FFFFFFFF3500DF
2025.04.11 20:22:12 5: POE_EnOcean_OG: dispatch EnOcean:1:D1:00D0FE0303010076:042CC990:01:09FFFFFFFF3500
2025.04.11 20:22:12 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:D1:00D0FE0303010076:042CC990:01:09FFFFFFFF3500
2025.04.11 20:22:12 2: EnOcean EnO_042CC990 MSC data: 00D0FE0303010076
2025.04.11 20:22:14 5: TCM POE_EnOcean_OG received ESP: 550009070156D20400000185CD750006FFFFFFFF3500B6
2025.04.11 20:22:14 5: POE_EnOcean_OG: dispatch EnOcean:1:D2:040000:0185CD75:00:06FFFFFFFF3500
2025.04.11 20:22:14 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:D2:040000:0185CD75:00:06FFFFFFFF3500
2025.04.11 20:22:17 5: TCM POE_EnOcean_OG received ESP: 55000A0701EBA51D00000F01A4EAA60106FFFFFFFF3500B1
2025.04.11 20:22:17 5: POE_EnOcean_OG: dispatch EnOcean:1:A5:1D00000F:01A4EAA6:01:06FFFFFFFF3500
2025.04.11 20:22:17 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:A5:1D00000F:01A4EAA6:01:06FFFFFFFF3500
2025.04.11 20:22:30 5: TCM POE_EnOcean_OG received ESP: 55000A0701EBA5D63E000F05261FC40109FFFFFFFF3500CF
2025.04.11 20:22:30 5: POE_EnOcean_OG: dispatch EnOcean:1:A5:D63E000F:05261FC4:01:09FFFFFFFF3500
2025.04.11 20:22:30 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:A5:D63E000F:05261FC4:01:09FFFFFFFF3500
2025.04.11 20:23:03 3: TCM POE_EnOcean_OG set teach 0
klaus.schauer
Hab leider einen Schreibfehler bei der Ref-ID eingebaut. Morgen kommt das berichtigte Update.
Damu
Passt eigentlich.
Das Model ist Richtig?
attr EnO_042CC990 comMode confirm
attr EnO_042CC990 eep A5-38-08
attr EnO_042CC990 gwCmd switching
attr EnO_042CC990 model Eltako_TF
attr EnO_042CC990 modelVersion 0106
attr EnO_042CC990 mscRefID 000004B8
attr EnO_042CC990 subDef FFFCB097
attr EnO_042CC990 subType gateway
attr EnO_042CC990 teachMethod confirm
attr EnO_042CC990 webCmd on:off
#   CFGFN
#   DEF        042CC990
#   FUUID      67fb6d88-f33f-d169-2aa4-e1521f264c54ba9d
#   LASTInputDev POE_EnOcean_OG
#   MSGCNT     9
#   NAME       EnO_042CC990
#   NR         579
#   POE_EnOcean_OG_MSGCNT 9
#   POE_EnOcean_OG_RSSI -53
#   POE_EnOcean_OG_SubTelNum 5
#   POE_EnOcean_OG_TIME 2025-04-13 09:55:47
#   POE_EnOcean_UG_MSGCNT 9
#   POE_EnOcean_UG_RSSI -59
#   POE_EnOcean_UG_SubTelNum 7
#   POE_EnOcean_UG_TIME 2025-04-13 09:55:47
#   STATE      off
#   TYPE       EnOcean
#   eventCount 15
#   READINGS:
#     2025-04-13 09:53:44   IODev           POE_EnOcean_OG
#     2025-04-13 09:54:22   block           unlock
#     2025-04-13 09:54:23   state           off
#     2025-04-13 09:53:46   teach           4BS teach-in accepted EEP: A5-38-08 Manufacturer: Eltako
#   helper:
setstate EnO_042CC990 off
setstate EnO_042CC990 2025-04-13 09:53:44 IODev POE_EnOcean_OG
setstate EnO_042CC990 2025-04-13 09:54:22 block unlock
setstate EnO_042CC990 2025-04-13 09:54:23 state off
setstate EnO_042CC990 2025-04-13 09:53:46 teach 4BS teach-in accepted EEP: A5-38-08 Manufacturer: Eltako
klaus.schauer
Das Reading model wird beim MSC teach-in auf Eltako_FL62 vorgegeben. Da das gemeinsame Profil N5-38-08 verwendet wird, wird dieser Wert wohl später im weiteren Programmablauf auf Eltako_TF geändert. Für die spätere Funktion ist das unerheblich. Beides ist gleichwertig.
