Sysmon mit CCU3
Begonnen von uwirt, 20 November 2024, 17:15:33
uwirt
Kann mir jemand helfen um Sysmon für das Auslesen einer CCU3 einzurichten.
Das mit dem passwortfreien ssh-Zugang bekomme ich nicht hin.
define CCU3_pi SYSMON ssh:root@192.168.1.153 1 0 1 10
attr CCU3_pi filesystems fs_root:/:Root,fs_usb1:/media/usb1:USB-Stick
attr CCU3_pi icon hm_ccu
attr CCU3_pi network-interfaces wlan0:eth0:lo
attr CCU3_pi nonblocking 1
attr CCU3_pi room System
attr CCU3_pi ssh-params -q
attr CCU3_pi stateFormat stat_cpu_text
#   DEF        ssh:root@192.168.1.153 1 0 1 10
#   FUUID      673de8b4-f33f-c144-b9f1-ff6c5d817c9898b0
#   HOST       192.168.1.153
#   INTERVAL_BASE 60
#   INTERVAL_MULTIPLIERS 1 0 1 10
#   MODE       ssh
#   NAME       CCU3_pi
#   NOTIFYDEV  global,TYPE=SYSMON
#   NR         154
#   NTFY_ORDER 50-CCU3_pi
#   PORT       22
#   STATE      stat_cpu_text
#   TYPE       SYSMON
#   USER       root
#   eventCount 41
#   READINGS:
#     2024-11-20 17:14:29   cpu_core_count  1
#     2024-11-20 14:50:15   eth0            not available
#     2024-11-20 14:50:15   eth0_diff       not available
#     2024-11-20 17:10:29   fs_root         Total: 0 MB, Used: 0 MB, 0 %, Available: 0 MB at / (not available)
#     2024-11-20 17:10:29   fs_usb1         Total: 0 MB, Used: 0 MB, 0 %, Available: 0 MB at /media/usb1 (not available)
#     2024-11-20 14:56:38   lo              not available
#     2024-11-20 14:56:38   lo_diff         not available
#     2024-11-20 17:14:29   wlan0           not available
#     2024-11-20 17:14:29   wlan0_diff      not available
#   helper:
#     sys_cpu0_freq 0
#     sys_cpu0_temp 0
#     sys_cpu1_freq 0
#     sys_cpu1_temp 0
#     sys_cpu2_freq 0
#     sys_cpu2_temp 0
#     sys_cpu3_freq 0
#     sys_cpu3_temp 0
#     sys_cpu4_freq 0
#     sys_cpu4_temp 0
#     sys_cpu5_freq 0
#     sys_cpu5_temp 0
#     sys_cpu6_freq 0
#     sys_cpu6_temp 0
#     sys_cpu7_freq 0
#     sys_cpu7_temp 0
#     sys_cpu_freq_rpi_bbb 0
#     sys_cpu_temp_bbb 0
#     sys_cpu_temp_rpi 0
#     sys_fb     0
#     sys_power_ac 0
#     sys_power_bat 0
#     sys_power_usb 0
#     u_first_mark 1
#     cur_readings_map:
#       cpu0_idle_stat CPU0 min/max/avg (idle)
#       cpu1_idle_stat CPU1 min/max/avg (idle)
#       cpu2_idle_stat CPU2 min/max/avg (idle)
#       cpu3_idle_stat CPU3 min/max/avg (idle)
#       cpu4_idle_stat CPU4 min/max/avg (idle)
#       cpu5_idle_stat CPU5 min/max/avg (idle)
#       cpu6_idle_stat CPU6 min/max/avg (idle)
#       cpu7_idle_stat CPU7 min/max/avg (idle)
#       cpu_bogomips BogoMIPS
#       cpu_core_count Number of CPU cores
#       cpu_idle_stat CPU min/max/avg (idle)
#       cpu_model_name CPU model name
#       date       Date
#       fhemstarttime Fhem start time
#       fhemstarttime_text Fhem start time
#       fhemuptime System up time
#       fhemuptime_text FHEM up time
#       fs_root    Root
#       fs_root_free Root (free)
#       fs_root_used Root (used)
#       fs_root_used_percent Root (used %)
#       fs_usb1    USB-Stick
#       fs_usb1_free USB-Stick (free)
#       fs_usb1_used USB-Stick (used)
#       fs_usb1_used_percent USB-Stick (used %)
#       idletime   Idle time
#       idletime_text Idle time
#       io_sda     TEST
#       io_sda_diff TEST
#       io_sda_raw TEST
#       loadavg    Load average
#       loadavg_1  Load average 1
#       loadavg_15 Load average 15
#       loadavg_5  Load average 5
#       ram        RAM
#       ram_free   RAM free
#       ram_free_percent RAM free %
#       ram_total  RAM total
#       ram_used   RAM used
#       ram_used_stat RAM used stat
#       starttime  System start time
#       starttime_text System start time
#       stat_cpu   CPU statistics
#       stat_cpu0  CPU0 statistics
#       stat_cpu0_diff CPU0 statistics (diff)
#       stat_cpu0_percent CPU0 statistics (diff, percent)
#       stat_cpu0_text CPU0 statistics (text)
#       stat_cpu1  CPU1 statistics
#       stat_cpu1_diff CPU1 statistics (diff)
#       stat_cpu1_percent CPU1 statistics (diff, percent)
#       stat_cpu1_text CPU1 statistics (text)
#       stat_cpu2  CPU2 statistics
#       stat_cpu2_diff CPU2 statistics (diff)
#       stat_cpu2_percent CPU2 statistics (diff, percent)
#       stat_cpu2_text CPU2 statistics (text)
#       stat_cpu3  CPU3 statistics
#       stat_cpu3_diff CPU3 statistics (diff)
#       stat_cpu3_percent CPU3 statistics (diff, percent)
#       stat_cpu3_text CPU3 statistics (text)
#       stat_cpu4  CPU4 statistics
#       stat_cpu4_diff CPU4 statistics (diff)
#       stat_cpu4_percent CPU4 statistics (diff, percent)
#       stat_cpu4_text CPU4 statistics (text)
#       stat_cpu5  CPU5 statistics
#       stat_cpu5_diff CPU5 statistics (diff)
#       stat_cpu5_percent CPU5 statistics (diff, percent)
#       stat_cpu5_text CPU5 statistics (text)
#       stat_cpu6  CPU6 statistics
#       stat_cpu6_diff CPU6 statistics (diff)
#       stat_cpu6_percent CPU6 statistics (diff, percent)
#       stat_cpu6_text CPU6 statistics (text)
#       stat_cpu7  CPU7 statistics
#       stat_cpu7_diff CPU7 statistics (diff)
#       stat_cpu7_percent CPU7 statistics (diff, percent)
#       stat_cpu7_text CPU7 statistics (text)
#       stat_cpu_diff CPU statistics (diff)
#       stat_cpu_idle_percent CPU statistics idle %
#       stat_cpu_io_percent CPU statistics io %
#       stat_cpu_irq_percent CPU statistics irq %
#       stat_cpu_nice_percent CPU statistics nice %
#       stat_cpu_percent CPU statistics (diff, percent)
#       stat_cpu_sirq_percent CPU statistics sirq %
#       stat_cpu_sys_percent CPU statistics sys %
#       stat_cpu_text CPU statistics (text)
#       stat_cpu_user_percent CPU statistics user %
#       swap       swap
#       swap_free  swap free
#       swap_total swap total
#       swap_used  swap used
#       swap_used_percent swap used %
#       swap_used_stat swap used stat
#       uptime     System up time
#       uptime_text System up time
#       wlan0      lo
#       wlan0_diff lo (diff)
#       wlan0_ip   lo (IP)
#       wlan0_ip6  lo (IP6)
#       wlan0_rx   lo (RX)
#       wlan0_speed lo (speed)
#       wlan0_tx   lo (TX)
setstate CCU3_pi stat_cpu_text
setstate CCU3_pi 2024-11-20 17:14:29 cpu_core_count 1
setstate CCU3_pi 2024-11-20 14:50:15 eth0 not available
setstate CCU3_pi 2024-11-20 14:50:15 eth0_diff not available
setstate CCU3_pi 2024-11-20 17:10:29 fs_root Total: 0 MB, Used: 0 MB, 0 %, Available: 0 MB at / (not available)
setstate CCU3_pi 2024-11-20 17:10:29 fs_usb1 Total: 0 MB, Used: 0 MB, 0 %, Available: 0 MB at /media/usb1 (not available)
setstate CCU3_pi 2024-11-20 14:56:38 lo not available
setstate CCU3_pi 2024-11-20 14:56:38 lo_diff not available
setstate CCU3_pi 2024-11-20 17:14:29 wlan0 not available
setstate CCU3_pi 2024-11-20 17:14:29 wlan0_diff not available
FHEM / Ubuntu / fitlet2
HomeMatic: CCU3|HmIP-STHD|HmIP-PCBS|HmIP-PCBS2|HmIP-PCBS-BAT|HM-WDC7000|HM-WDS100-C6-O|HM-WDS40|HM-LC-Sw1-FM|HM-LC-RGBW-WM|HM-ES-PMSw1-Pl|HM-ES-TX-WM
NAS: DS218+|DS209j|DS216+II|DS412+
Devices: Panasonic Webcams|Withings|Gardena Smart|Tuya
passibe
Hast du den öffentlichen Schlüssel, den FHEM verwendet, auf der CCU in /root/.ssh/authorized_keys abgelegt?
Bin mir gerade nicht sicher, ob man zusätzlich noch irgendwelche Einstellungen über das CCU-Webinterface machen muss, ich glaube aber nicht.
uwirt
#2
Ich habe versucht mit dem von @Otto123 vorgeschlagenen Vorgehen den Passwort-freien Zugang zur CCU3 zu ermöglichen:
sudo cp /etc/passwd /etc/passwd.sav
sudo  sed -i -e 's/fhem:.*/fhem:x:999:20::\/opt\/fhem:\/bin\/bash/' /etc/passwd
sudo passwd fhem             # Passwort vergeben und bestätigen
su fhem                      # Als fhem einloggen, es startet eine neue session!
ssh-keygen -t rsa            # Speichert automatisch in /opt/fhem/
ssh-copy-id -i ~/.ssh/id_rsa <user>@<remote-system> # gleich den angebotenen Test machen
ssh <user>@<remote-system>   # es startet eine neue session!
exit                         # aus der ssh Test session vom Remotehost!
exit                         # aus der Anmeldung von fhem!
sudo cp /etc/passwd.sav /etc/passwd
Leider gibt es bei der Herstellung des Zertifikats den folgenden Fehler:
systemd-coredump@IoT-Chalet:/home/uw$ ssh-keygen -t rsa
Generating public/private rsa key pair.
Enter file in which to save the key (//.ssh/id_rsa):
Enter passphrase (empty for no passphrase):
Enter same passphrase again:
Saving key "//.ssh/id_rsa" failed: No such file or directory
Offenbar ist mit dem Befehl su fhem etwas nicht in Ordnung weil dann sollte es heissen fhem@IoT-Chalet und nicht systemd-coredump@IoT-Chalet!
Wenn ich bei FHEM in der Befehlszeile { qx(cat /etc/passwd) } eingebe dann erscheint für fhem:
fhem:x:998:20::/opt/fhem:/bin/falseAlso 998 und nicht 999.
Woran mag das denn liegen?
Das war's, 999 > 998 und jetzt funktioniert es!
ich habe jetzt hier keine CCU3 sondern nur eine RaspberryMatic.
hast Du denn in der Weboberfläche überhaupt ssh Zugang aktiviert?
Was sagt dort ein ls-lha nach dem einloggen? Bei mir ist .ssh verlinkt nach /usr/local/etc/ssh da wird ssh-copy-id eventuell nicht funktionieren.
Hat der User fhem denn schon einen public key? Ich hatte das hier mal noch etwas "fortschrittlicher" beschrieben.
{qx(ls -lha .ssh/id_*.pub || Echo 'Datei nicht gefunden')}
Wenn ja, dann melde Dich per ssh an der CCU3 an, schau wo das Verzeichnis .ssh liegt, kopiere wie beschrieben deinen Public Key vom user fhem als Text und schreib den einfach "per hand" in die .ssh/authorized_keys oder wo immer das auf der CCU3 ist!
echo 'Dein Public Key' >> .ssh/authorized_keys
uwirt
Danke Otto der Wechsel von 999 auf 998 brachte den Erfolg.
uwirt
Da es nun jetzt funktioniert bekomme ich einiges herein:
define CCU3_pi SYSMON ssh:root@192.168.1.153 1 1 1 10
#   DEF        ssh:root@192.168.1.153 1 1 1 10
#   INTERVAL_BASE 60
#   INTERVAL_MULTIPLIERS 1 1 1 10
#   MODE       ssh
#   NAME       CCU3_pi
#   NR         154
#   PORT       22
#   STATE      user: 1.04 %, nice: 0.00 %, sys: 0.34 %, idle: 98.58 %, io: 0.00 %, irq: 0.00 %, sirq: 0.04 %
#   TYPE       SYSMON
#   USER       root
#   eventCount 127
#   READINGS:
#     2024-11-21 16:20:48   cpu0_idle_stat  96.62 99.25 98.57
#     2024-11-21 16:20:48   cpu1_idle_stat  96.44 99.23 98.43
#     2024-11-21 16:20:48   cpu2_idle_stat  95.80 99.37 98.66
#     2024-11-21 16:20:48   cpu3_idle_stat  96.91 99.55 98.46
#     2024-11-21 16:20:48   cpu_core_count  4
#     2024-11-21 16:20:48   cpu_idle_stat   96.93 98.77 98.53
#     2024-11-21 16:20:48   fs_root         Total: 976 MB, Used: 478 MB, 53 %, Available: 431 MB at /
#     2024-11-21 16:20:48   fs_usb1         Total: 0 MB, Used: 0 MB, 0 %, Available: 0 MB at /media/usb1 (not available)
#     2024-11-21 16:20:48   idletime        22517 98.56 %
#     2024-11-21 16:20:48   idletime_text   0 days, 06 hours, 15 minutes (98.56 %)
#     2024-11-21 16:20:48   loadavg         0.16 0.07 0.02
#     2024-11-21 16:20:48   ram             Total: 970.83 MB, Used: 181.46 MB, 18.69 %, Free: 789.38 MB
#     2024-11-21 16:20:48   ram_used_stat   180.78 182.09 181.50
#     2024-11-21 16:20:48   starttime       1732179598
#     2024-11-21 16:20:48   starttime_text  21.11.2024 09:59:58
#     2024-11-21 16:20:48   stat_cpu        60497 0 24769 9007304 424 0 2208
#     2024-11-21 16:20:48   stat_cpu0       13595 0 8337 2218107 124 0 2125
#     2024-11-21 16:20:48   stat_cpu0_diff  29 0 25 5822 0 0 10
#     2024-11-21 16:20:48   stat_cpu0_percent 0.49 0.00 0.42 98.91 0.00 0.00 0.17
#     2024-11-21 16:20:48   stat_cpu0_text  user: 0.49 %, nice: 0.00 %, sys: 0.42 %, idle: 98.91 %, io: 0.00 %, irq: 0.00 %, sirq: 0.17 %
#     2024-11-21 16:20:48   stat_cpu1       16395 0 5730 2261876 120 0 23
#     2024-11-21 16:20:48   stat_cpu1_diff  94 0 22 5870 0 0 0
#     2024-11-21 16:20:48   stat_cpu1_percent 1.57 0.00 0.37 98.06 0.00 0.00 0.00
#     2024-11-21 16:20:48   stat_cpu1_text  user: 1.57 %, nice: 0.00 %, sys: 0.37 %, idle: 98.06 %, io: 0.00 %, irq: 0.00 %, sirq: 0.00 %
#     2024-11-21 16:20:48   stat_cpu2       14618 0 5354 2263696 37 0 30
#     2024-11-21 16:20:48   stat_cpu2_diff  54 0 20 5923 0 0 0
#     2024-11-21 16:20:48   stat_cpu2_percent 0.90 0.00 0.33 98.77 0.00 0.00 0.00
#     2024-11-21 16:20:48   stat_cpu2_text  user: 0.90 %, nice: 0.00 %, sys: 0.33 %, idle: 98.77 %, io: 0.00 %, irq: 0.00 %, sirq: 0.00 %
#     2024-11-21 16:20:48   stat_cpu3       15889 0 5348 2263623 142 0 30
#     2024-11-21 16:20:48   stat_cpu3_diff  70 0 15 5902 0 0 0
#     2024-11-21 16:20:48   stat_cpu3_percent 1.17 0.00 0.25 98.58 0.00 0.00 0.00
#     2024-11-21 16:20:48   stat_cpu3_text  user: 1.17 %, nice: 0.00 %, sys: 0.25 %, idle: 98.58 %, io: 0.00 %, irq: 0.00 %, sirq: 0.00 %
#     2024-11-21 16:20:48   stat_cpu_diff   247 0 82 23517 0 0 10
#     2024-11-21 16:20:48   stat_cpu_percent 1.04 0.00 0.34 98.58 0.00 0.00 0.04
#     2024-11-21 16:20:48   stat_cpu_text   user: 1.04 %, nice: 0.00 %, sys: 0.34 %, idle: 98.58 %, io: 0.00 %, irq: 0.00 %, sirq: 0.04 %
#     2024-11-21 16:20:48   swap            n/a
#     2024-11-21 16:20:48   swap_used_stat  0.00 0.00 0.00
#     2024-11-21 16:20:48   uptime          22847
#     2024-11-21 16:20:48   uptime_text     0 days, 06 hours, 20 minutes
#     2024-11-21 16:20:48   wlan0           RX: 0.00 MB, TX: 0.00 MB, Total: 0 MB
#     2024-11-21 16:20:48   wlan0_diff      RX: 0.00 MB, TX: 0.00 MB, Total: 0.00 MB
#     2024-11-21 16:20:48   wlan0_ip        192.168.1.153
#     2024-11-21 16:20:48   wlan0_rx        0
#     2024-11-21 16:20:48   wlan0_tx        0
#   helper:
#     net_wlan0_stat_class 1
#     proc_fs    1
#     sys_cpu0_freq 0
#     sys_cpu0_temp 0
#     sys_cpu1_freq 0
#     sys_cpu1_temp 0
#     sys_cpu2_freq 0
#     sys_cpu2_temp 0
#     sys_cpu3_freq 0
#     sys_cpu3_temp 0
#     sys_cpu4_freq 0
#     sys_cpu4_temp 0
#     sys_cpu5_freq 0
#     sys_cpu5_temp 0
#     sys_cpu6_freq 0
#     sys_cpu6_temp 0
#     sys_cpu7_freq 0
#     sys_cpu7_temp 0
#     sys_cpu_core_num 4
#     sys_cpu_num 1
#     sys_fb     0
#     sys_power_ac 0
#     sys_power_bat 0
#     sys_power_usb 0
#     u_first_mark 1
#     cur_readings_map:
#       date       Date
#       fs_root    Root
#       fs_usb1    USB-Stick
#       io_sda     TEST
#       io_sda_diff TEST
#       io_sda_raw TEST
#       ram        RAM
#       ram_free   RAM free
#       ram_used   RAM used
#       swap       swap
#       wlan0      lo
#       wlan0_ip   lo (IP)
#       wlan0_rx   lo (RX)
#       wlan0_tx   lo (TX)
#     excludes:
#     shadow_map:
#       cpu0_idle_stat 97.28 99.25 98.28
#       cpu1_idle_stat 96.66 99.23 97.77
#       cpu2_idle_stat 96.24 99.18 97.61
#       cpu3_idle_stat 96.91 99.55 99.14
#       cpu_core_count 4
#       cpu_idle_stat 97.41 98.77 98.20
#       fs_root    Total: 976 MB, Used: 478 MB, 53 %, Available: 431 MB at /
#       fs_usb1    Total: 0 MB, Used: 0 MB, 0 %, Available: 0 MB at /media/usb1 (not available)
#       idletime   21632 98.58 %
#       idletime_text 0 days, 06 hours, 00 minutes (98.58 %)
#       loadavg    0.12 0.06 0.01
#       ram        Total: 970.83 MB, Used: 181.68 MB, 18.71 %, Free: 789.15 MB
#       ram_used_stat 180.78 181.98 181.58
#       starttime  1732179598
#       starttime_text 21.11.2024 09:59:58
#       stat_cpu   56316 0 23560 8653257 424 0 2069
#       stat_cpu0  12593 0 7955 2130954 124 0 1991
#       stat_cpu0_diff 120 0 24 5700 0 0 5
#       stat_cpu0_percent 2.05 0.00 0.41 97.45 0.00 0.00 0.09
#       stat_cpu0_text user: 2.05 %, nice: 0.00 %, sys: 0.41 %, idle: 97.45 %, io: 0.00 %, irq: 0.00 %, sirq: 0.09 %
#       stat_cpu1  15356 0 5444 2172943 120 0 22
#       stat_cpu1_diff 125 0 32 5811 0 0 0
#       stat_cpu1_percent 2.09 0.00 0.54 97.37 0.00 0.00 0.00
#       stat_cpu1_text user: 2.09 %, nice: 0.00 %, sys: 0.54 %, idle: 97.37 %, io: 0.00 %, irq: 0.00 %, sirq: 0.00 %
#       stat_cpu2  13737 0 5093 2174464 37 0 27
#       stat_cpu2_diff 161 0 35 5778 0 0 0
#       stat_cpu2_percent 2.70 0.00 0.59 96.72 0.00 0.00 0.00
#       stat_cpu2_text user: 2.70 %, nice: 0.00 %, sys: 0.59 %, idle: 96.72 %, io: 0.00 %, irq: 0.00 %, sirq: 0.00 %
#       stat_cpu3  14630 0 5068 2174894 142 0 29
#       stat_cpu3_diff 38 0 9 5907 0 0 0
#       stat_cpu3_percent 0.64 0.00 0.15 99.21 0.00 0.00 0.00
#       stat_cpu3_text user: 0.64 %, nice: 0.00 %, sys: 0.15 %, idle: 99.21 %, io: 0.00 %, irq: 0.00 %, sirq: 0.00 %
#       stat_cpu_diff 444 0 100 23197 0 0 5
#       stat_cpu_percent 1.87 0.00 0.42 97.69 0.00 0.00 0.02
#       stat_cpu_text user: 1.87 %, nice: 0.00 %, sys: 0.42 %, idle: 97.69 %, io: 0.00 %, irq: 0.00 %, sirq: 0.02 %
#       swap       n/a
#       swap_used_stat 0.00 0.00 0.00
#       uptime     21943
#       uptime_text 0 days, 06 hours, 05 minutes
#       wlan0      RX: 0.00 MB, TX: 0.00 MB, Total: 0 MB
#       wlan0_diff RX: 0.00 MB, TX: 0.00 MB, Total: 0.00 MB
#       wlan0_ip   192.168.1.153
#       wlan0_rx   0
#       wlan0_tx   0
setstate CCU3_pi user: 1.04 %, nice: 0.00 %, sys: 0.34 %, idle: 98.58 %, io: 0.00 %, irq: 0.00 %, sirq: 0.04 %
setstate CCU3_pi 2024-11-21 16:20:48 cpu0_idle_stat 96.62 99.25 98.57
setstate CCU3_pi 2024-11-21 16:20:48 cpu1_idle_stat 96.44 99.23 98.43
setstate CCU3_pi 2024-11-21 16:20:48 cpu2_idle_stat 95.80 99.37 98.66
setstate CCU3_pi 2024-11-21 16:20:48 cpu3_idle_stat 96.91 99.55 98.46
setstate CCU3_pi 2024-11-21 16:20:48 cpu_core_count 4
setstate CCU3_pi 2024-11-21 16:20:48 cpu_idle_stat 96.93 98.77 98.53
setstate CCU3_pi 2024-11-21 16:20:48 fs_root Total: 976 MB, Used: 478 MB, 53 %, Available: 431 MB at /
setstate CCU3_pi 2024-11-21 16:20:48 fs_usb1 Total: 0 MB, Used: 0 MB, 0 %, Available: 0 MB at /media/usb1 (not available)
setstate CCU3_pi 2024-11-21 16:20:48 idletime 22517 98.56 %
setstate CCU3_pi 2024-11-21 16:20:48 idletime_text 0 days, 06 hours, 15 minutes (98.56 %)
setstate CCU3_pi 2024-11-21 16:20:48 loadavg 0.16 0.07 0.02
setstate CCU3_pi 2024-11-21 16:20:48 ram Total: 970.83 MB, Used: 181.46 MB, 18.69 %, Free: 789.38 MB
setstate CCU3_pi 2024-11-21 16:20:48 ram_used_stat 180.78 182.09 181.50
setstate CCU3_pi 2024-11-21 16:20:48 starttime 1732179598
setstate CCU3_pi 2024-11-21 16:20:48 starttime_text 21.11.2024 09:59:58
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu 60497 0 24769 9007304 424 0 2208
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu0 13595 0 8337 2218107 124 0 2125
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu0_diff 29 0 25 5822 0 0 10
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu0_percent 0.49 0.00 0.42 98.91 0.00 0.00 0.17
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu0_text user: 0.49 %, nice: 0.00 %, sys: 0.42 %, idle: 98.91 %, io: 0.00 %, irq: 0.00 %, sirq: 0.17 %
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu1 16395 0 5730 2261876 120 0 23
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu1_diff 94 0 22 5870 0 0 0
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu1_percent 1.57 0.00 0.37 98.06 0.00 0.00 0.00
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu1_text user: 1.57 %, nice: 0.00 %, sys: 0.37 %, idle: 98.06 %, io: 0.00 %, irq: 0.00 %, sirq: 0.00 %
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu2 14618 0 5354 2263696 37 0 30
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu2_diff 54 0 20 5923 0 0 0
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu2_percent 0.90 0.00 0.33 98.77 0.00 0.00 0.00
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu2_text user: 0.90 %, nice: 0.00 %, sys: 0.33 %, idle: 98.77 %, io: 0.00 %, irq: 0.00 %, sirq: 0.00 %
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu3 15889 0 5348 2263623 142 0 30
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu3_diff 70 0 15 5902 0 0 0
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu3_percent 1.17 0.00 0.25 98.58 0.00 0.00 0.00
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu3_text user: 1.17 %, nice: 0.00 %, sys: 0.25 %, idle: 98.58 %, io: 0.00 %, irq: 0.00 %, sirq: 0.00 %
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu_diff 247 0 82 23517 0 0 10
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu_percent 1.04 0.00 0.34 98.58 0.00 0.00 0.04
setstate CCU3_pi 2024-11-21 16:20:48 stat_cpu_text user: 1.04 %, nice: 0.00 %, sys: 0.34 %, idle: 98.58 %, io: 0.00 %, irq: 0.00 %, sirq: 0.04 %
setstate CCU3_pi 2024-11-21 16:20:48 swap n/a
setstate CCU3_pi 2024-11-21 16:20:48 swap_used_stat 0.00 0.00 0.00
setstate CCU3_pi 2024-11-21 16:20:48 uptime 22847
setstate CCU3_pi 2024-11-21 16:20:48 uptime_text 0 days, 06 hours, 20 minutes
setstate CCU3_pi 2024-11-21 16:20:48 wlan0 RX: 0.00 MB, TX: 0.00 MB, Total: 0 MB
setstate CCU3_pi 2024-11-21 16:20:48 wlan0_diff RX: 0.00 MB, TX: 0.00 MB, Total: 0.00 MB
setstate CCU3_pi 2024-11-21 16:20:48 wlan0_ip 192.168.1.153
setstate CCU3_pi 2024-11-21 16:20:48 wlan0_rx 0
setstate CCU3_pi 2024-11-21 16:20:48 wlan0_tx 0
Was allerdings fehlt ist die Temperatur, dies obwohl ich sie per cli lesen kann:
w@IoT-Chalet:~$ ssh root@192.168.1.153 vcgencmd measure_temp
root@192.168.1.153's password:
temp=50.5'C
Und ausserdem sind die WLAN-Werte alle 0. Muss ich da etwas aktivieren?
