Günstiger und unauffälliger Pflanzensensor: Xiaomi Flower Monitor
Begonnen von stoxx, 17 September 2016, 14:28:54
baukater
Zitat von: CoolTux am 12 November 2016, 13:22:28
Gib mal Log Ausgaben und ein list bitte
   BTMAC      C4:7C:8D:61:93:60
   DEF        C4:7C:8D:61:93:60
   INTERVAL   3600
   NAME       FM_Olivenbaum
   NR         106
   STATE      unreachable
   TYPE       XiaomiFlowerSens
   VERSION    0.1.45
   Readings:
     2016-11-12 12:46:31   battery         0
     2016-11-12 12:46:31   fertility       0
     2016-11-12 12:46:31   firmware        -30.-30.-30
     2016-11-12 12:46:31   lux             0
     2016-11-12 12:46:31   moisture        0
     2016-11-12 15:24:13   state           unreachable
     2016-11-12 12:46:31   temperature     0
   Helper:
   room       Garten,FlowerSens
   verbose    5
2016.11.12 15:23:57 5: Sub XiaomiFlowerSens (FM_Zitronenbaum) - Request Timer wird aufgerufen
2016.11.12 15:23:58 4: Sub XiaomiFlowerSens (FM_Zitronenbaum) - Starte Blocking Call
2016.11.12 15:23:58 4: Sub XiaomiFlowerSens_Run (FM_Zitronenbaum) - Running nonBlocking
2016.11.12 15:23:58 5: Sub XiaomiFlowerSens (FM_Olivenbaum) - Request Timer wird aufgerufen
2016.11.12 15:23:58 4: Sub XiaomiFlowerSens (FM_Olivenbaum) - Starte Blocking Call
2016.11.12 15:23:58 4: Sub XiaomiFlowerSens_Run (FM_Olivenbaum) - Running nonBlocking
2016.11.12 15:24:13 1: Timeout for XiaomiFlowerSens_Run reached, terminated process 12164
2016.11.12 15:24:13 3: (FM_Zitronenbaum) - The BlockingCall Process terminated unexpectedly. Timedout
2016.11.12 15:24:13 1: Timeout for XiaomiFlowerSens_Run reached, terminated process 12169
2016.11.12 15:24:13 3: (FM_Olivenbaum) - The BlockingCall Process terminated unexpectedly. Timedout
Host is down (112)
Host is down (112)
Und gleich mal über die Console geschaut, was die ausgibt.
pi@raspberrypi /dev $ sudo gatttool -b C4:7C:8D:61:93:60 --char-read -a 0x38 -n A01F
Characteristic value/descriptor: 64 10 32 2e 36 2e 32
FB7490,Raspi 2/3,HM-Lan,Jeelink Classic (868),Logilink BT0015 Bluetooth 4.0, 2x mySmartUSB light,RS485USB , entities:272 device:14 channel:27 virtual:1, 6 x HM-LC-BL1-FM,4 x HM-LC-SW4-WM, 1 x HM-LC-SW2-FM,1 x Fensterkontakt,1 1x Türkontakt, 1 1x Bewegungsmelder, DECT-200,DECT100,6xAuthentic Xiaom
Invers
Zitatdone als state gab es nur beim Script.
Sieht aus, als wäre eine alter chron-Job noch aktiv.
Das war doch nur als Beispiel, nicht die Realität.
mein Job läuft vom Modul völlig getrennt und Separat in einen eigenen Dummy, der dann eine readingsgroup befüllt.
Eine zweite RG wird vom Modul zu ganz anderen Zeiten gefüllt.
Guck doch mal:
Bei mir ändert sich halt nichts.
2016-11-12 14:42:35   state unreachable obwohl ja alle anderen Werte aufgefüllt wurden.
Wenn also die Werte korrekt abgerufen wurden, dann müsste halt nach meiner Auffassung auch "unreachable" durch "active" ersetzt werden.
mi.ke
Okay, ich gebe zu, ich verstehe kein Wort davon!?!?
FHEM 5.9 | RPi4 + 5 x RPi(Z) + FB7590 + FB 6890 LTE via LAN und WAN (VPN) verbunden.
2 x CUL868 + 3 x RFXTRX(e) + 6 x HMwLanGW + 4 x z2tGw + 5 x LGW + 2 x IRBlast + CO2 +++
FS20, FHT, FMS, Elro(mod), CM160, Revolt, LGTV, STV, AVR, withings, HM-sec-*, HM-CC-RT-DN, AMAD, PCA301, arlo, Aqara
CoolTux
-n gibt es bei einem char-read nicht. Das ist also falsch wie Du es geschrieben hast.
0x38 liest die Firmware und die Batterie aus. Du hast also Firmware 2.6.2 und Deine Batterie liegt bei 100%
Mach mal bitte ein 0x35
Was passiert wenn Du ein status Request machst?
Das TuxNet Wiki:
https://www.cooltux.net
CoolTux
Thema state. Den state legt erstmal der Entwickler fest, da kann auch drin stehen im Himmel ist Jahrmarkt.
Ich habe es so gemacht wie es mir plausibel erschien. Dazu gehört das nach einem define ein initial kommt. Wenn dann die Timerroutine gestartet wird weiß ich das das Modul activ ist also der Timer läuft. Als nächstes wird der eigentliche read aufgerufen um Daten zu holen. Daher call data.
Und nun kommt es drauf an. Wenn Blocking.pm ins Timeout läuft (15s) dann wird im state ein unreachable geschrieben und es muss INTERVAL Zeit gewartet werden bis wieder die Routine aufgerufen wird und active erscheint.
Wir können das gerne auch demokratisch ändern wenn ihr wollt. Mir ist das schnuppe.
Das TuxNet Wiki:
CoolTux
Ich habe eine neue Version. Es gibt nun ein Fehlerhandling. Wenn einmal Readings sauber geschieben wurden sollten diese bei einem Fehler nicht mit 0 oder so überschieben werden.
Das TuxNet Wiki:
Invers
Hab ich jetzt verstanden. Eine demokratische Änderung ist meinetwegen nicht nötig. Ich hielt es halt irrtümlich für einen Fehler, aber nun ist alles klar. Danke.
Laffer72
#217
erstmal danke für das Modul.
Anbei meine List-Ausgabe:
   BTMAC      C4:7C:8D:60:D9:B1
   CFGFN
   DEF        C4:7C:8D:60:D9:B1
   INTERVAL   3600
   NAME       Blume1
   NR         356
   STATE      active
   VERSION    0.1.48
   Readings:
     2016-11-12 20:54:30   battery         100
     2016-11-12 20:54:30   fertility       0
     2016-11-12 20:54:30   firmware        2.6.6
     2016-11-12 20:54:30   lux             0
     2016-11-12 20:54:30   moisture        0
     2016-11-12 20:54:30   state           active
     2016-11-12 20:54:30   temperature     0
   Helper:
   room       FlowerSens
> char-read-hnd 0x35
Characteristic value/descriptor: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> char-read-hnd 0x38
Characteristic value/descriptor: 64 13 32 2e 36 2e 36
2016.11.12 21:01:29 4: Sub XiaomiFlowerSens (Blume1) - Starte Blocking Call
2016.11.12 21:01:29 4: Sub XiaomiFlowerSens_Run (Blume1) - Running nonBlocking
2016.11.12 21:01:32 4: Sub XiaomiFlowerSens_Run (Blume1) - Rückgabe an Auswertungsprogramm beginnt
2016.11.12 21:01:32 4: Sub XiaomiFlowerSens_Done (Blume1) - Abschluss!
Leider zeigt er keine Daten an. Ich hatte aber stark mit der Bluetoothverbindung zu kämpfen und kämpfe manchmal immer noch damit :-). Kann mich aber erinnern, daß er bei einer der älteren Modulversionen mal die Temperatur angezeigt hat.
Allerdings hatte der Sensor da auch noch die Firmware 2.6.2 drauf.
Wenn ich noch was testen soll gerne.
Reinhard
Raspberry Pi Rev.B, FB7390 (FHEM2FHEM), Sonos, Smarter Coffee
Osram Lightify:2m LED-Streifen, 5m-LED-Streifen, Gartenspot, Surface 28W, Classic E14,E27, Classic RGBW E27, PAR16 GU10, Plug
CUL868:FS20-ST, FS20-DI, FS20-FMS, FS20-ES1
HMUSB:HM-Sec-RHS,HM-Sec-MDIR2
Jeelink868:TX-29-IT, TFA30.315
CoolTux
Das Problem ist das die Firmware 2.6.6 noch nicht unterstützt wird. Daher auch die Nullen. Es gibt zwar im Netz Hinweise wie man es machen könnte aber bei uns hat es noch nicht geklappt.
Das TuxNet Wiki:
baukater
Characteristic value/descriptor: d9 00 00 25 00 00 00 00 00 00 00 00 00 00 00 00
2016.11.13 07:09:51 5: Sub XiaomiFlowerSens (FM_Zitronenbaum) - Request Timer wird aufgerufen
2016.11.13 07:09:51 4: Sub XiaomiFlowerSens (FM_Zitronenbaum) - Starte Blocking Call
2016.11.13 07:09:52 4: Sub XiaomiFlowerSens_Run (FM_Zitronenbaum) - Running nonBlocking
2016.11.13 07:09:52 5: Sub XiaomiFlowerSens (FM_Olivenbaum) - Request Timer wird aufgerufen
2016.11.13 07:09:52 4: Sub XiaomiFlowerSens (FM_Olivenbaum) - Starte Blocking Call
2016.11.13 07:09:52 4: Sub XiaomiFlowerSens_Run (FM_Olivenbaum) - Running nonBlocking
Host is down (112)
2016.11.13 07:09:57 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/74_XiaomiFlowerSens.pm line 272.
2016.11.13 07:09:57 1: PERL WARNING: Use of uninitialized value $data[1] in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 274.
2016.11.13 07:09:57 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 274.
2016.11.13 07:09:57 1: PERL WARNING: Use of uninitialized value $data[4] in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 275.
2016.11.13 07:09:57 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 275.
2016.11.13 07:09:57 1: PERL WARNING: Use of uninitialized value $data[7] in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 276.
2016.11.13 07:09:57 1: PERL WARNING: Use of uninitialized value $data[9] in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 277.
2016.11.13 07:09:57 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 277.
2016.11.13 07:10:06 1: Timeout for XiaomiFlowerSens_Run reached, terminated process 19904
2016.11.13 07:10:07 3: (FM_Zitronenbaum) - The BlockingCall Process terminated unexpectedly. Timedout
2016.11.13 07:10:07 1: Timeout for XiaomiFlowerSens_Run reached, terminated process 19914
2016.11.13 07:10:07 3: (FM_Olivenbaum) - The BlockingCall Process terminated unexpectedly. Timedout
Host is down (112)
Device or resource busy (16)
2016.11.13 07:14:35 4: Sub XiaomiFlowerSens (FM_Olivenbaum) - Starte Blocking Call
2016.11.13 07:14:35 4: Sub XiaomiFlowerSens_Run (FM_Olivenbaum) - Running nonBlocking
Host is down (112)
2016.11.13 07:14:42 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/74_XiaomiFlowerSens.pm line 272.
2016.11.13 07:14:42 1: PERL WARNING: Use of uninitialized value $data[1] in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 274.
2016.11.13 07:14:42 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 274.
2016.11.13 07:14:42 1: PERL WARNING: Use of uninitialized value $data[4] in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 275.
2016.11.13 07:14:42 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 275.
2016.11.13 07:14:42 1: PERL WARNING: Use of uninitialized value $data[7] in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 276.
2016.11.13 07:14:42 1: PERL WARNING: Use of uninitialized value $data[9] in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 277.
2016.11.13 07:14:42 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/74_XiaomiFlowerSens.pm line 277.
2016.11.13 07:14:50 1: Timeout for XiaomiFlowerSens_Run reached, terminated process 20164
2016.11.13 07:14:50 3: (FM_Olivenbaum) - The BlockingCall Process terminated unexpectedly. Timedout
Host is down (112)
CoolTux
Das gatttool meldet das der Host Down ist. Das soll wohl bedeuten das der Sensor nicht im erkennbaren Modus ist.
@All
Wäre schön wenn ein zwei Leute die Zeit finden und im Netz mal schauen welche anderen Möglichkeiten es noch gibt um 2.6.6 aus zu lesen und das dann testet.
Das TuxNet Wiki:
Laffer72
Hallo CoollTux,
habe mit der 2.6.6 Erfolg gehabt.
Nach dem Connect mit gatttool muß zuerst
char-write-req 0x33 A01F
danach gleich
char-read-hnd 0x35
abgesetzt werden.
Hier das Ergebnis :
connect
Attempting to connect to C4:7C:8D:60:D9:B1
Connection successful
Notification handle = 0x0021 value: 00
[C4:7C:8D:60:D9:B1][LE]> char-write-req 0x33 A01F
Characteristic value was written successfully
[C4:7C:8D:60:D9:B1][LE]> char-read-hnd 0x35
Characteristic value/descriptor: 61 01 00 1a 00 00 00 00 00 00 02 3c 00 fb 34 9b
(gatttool:20758): GLib-WARNING **: Invalid file descriptor.
Hoffe das hilft Dir weiter.
Reinhard
CoolTux
Hallo Reinhard,
Dann wirst Du Der Testkandidat werden. Hihi. Eigentlich ist es genau das was wir gemacht haben, aber schauen wir mal. Ich baue da heute Nachmittag was mit genau Deinen gatttool Befehlen und Du bist so nett und testest.
Leon
Das TuxNet Wiki:
Hagenuck1
Klappt bei mir auch ;) keine Ahnung, was da am Freitag genau los war...
(http://uploads.tapatalk-cdn.com/20161113/6bb7fc414826c72ff7a92d80a37a3a72.png)
CoolTux
#224
So dann hier mal eine aktuelle Version.
Sofern Eure Firmware noch nicht erkannt wurde werden die korrekten Werte erst beim zweiten Durchlauf erscheinen. Ausschlaggebend ist also das die Firmware korrekt im Reading steht.
Ihr könnt ja set statusRequest machen.
Wegen Fehler entfernt!!!
Das TuxNet Wiki:
