Seit einigen Tagen - ist mir heute zufällig aufgefallen - extremer Spam im Log von einem unbekannten Gerät, dass offenbar von meinem CUL433 empfangen wird:
2018.03.15 16:15:57 3: CUL_WZ: Unknown code ? (1 / 1 is unknown) Use one of B b C F i A Z N k G M K U Y R T V 1 / 1 is unknown) Use one of B b C F i A Z N k G M K U Y R T V is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x, help me!
2018.03.15 16:15:57 3: CUL_WZ: Unknown code ? (? (? (drfV 1.66 CUL433 is unknown) Use one of B b C F i A Z N k ? (?? (? is unknown) Use one of B b C F i A Z N k G M K U Y R T is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x, help me!
2018.03.15 16:15:57 3: CUL_WZ: Unknown code LOVF, help me!
2018.03.15 16:15:57 3: CUL_WZ: Unknown code ? (one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x k ? (?? (? is unknown) Use one of B b C F i A Z N k G M K U Y R T is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x, help me!
2018.03.15 16:15:57 3: CUL_WZ: Unknown code ? ( is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x k ? (?? (? is unknown) Use one of B b C F i A Z N is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x, help me!
2018.03.15 16:15:57 1: CUL_WS UNDEFINED unknown sensor detected, code 1
2018.03.15 16:15:57 3: CUL_WZ: Unknown code ? (? ( 01 / 1drfV 1.66 CUL433drfcrfcrfcrfR0000 = 01 / 1R0000 = 01? (? ( 01 / 1drfV 1.66 CUL433drfcrfcrfcrfR0000 = 01 / 1R0000 = is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x, help me!
2018.03.15 16:15:57 3: CUL_WZ: Unknown code ? ( 01 / 1drfV 1.66 CUL433drfcrfcrfcrfR0000 = 01 / 1R0000 = 01 / 1R0000 = 01 / 1R0000 = 01 / 1grfR0000 = 01 / 1? ( 01 / 1drf is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x, help me!
2018.03.15 16:15:57 3: CUL_WZ: Unknown code ? ( / 1R0000 = 01 / 1R0000 = 01 / 1grfR0000 = 01 / 1? ( 01 / 1? ( 01 / 1drfV 1.66 CUL433drfcrfcrfcrfR0000 = 01 / 1R0000 = 01 is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x, help me!
2018.03.15 16:15:57 3: CUL_WZ: Unknown code ? ( = 01 is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x 1? ( 01 / 1drfV 1.66 CUL433drfcrfcrfcrfR000 is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x, help me!
2018.03.15 16:15:57 3: CUL_WZ: Unknown code ? (000 = 01 / 1R0000 = 01 is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x 1? ( 01 / 1drfV 1.66 CUL4 is unknown) Use one of B b C F i A Z N k G M K U Y R T V W X e f m L l t u x, help me!
Kann man da irgendwas machen? Da kommen die Meldungen praktisch im Sekundentakt. Mein Log der letzten Tage läuft langsam schon an der Gigabyte Grenze... Klar, mit Verbose kriegt man die Meldungen aus dem Log raus, aber es belastet ja die Installation wahrscheinlich trotzdem, wenn man die nicht irgendwie ignorieren kann?
Das klingt nach echo auf der seriellen Schnittstelle.
Hatten wir vor 10-8 Jahren haeufiger, in der letzten Zeit kamen solche Meldungen kaum noch.
Die Übertragung vom CUL zu FHEM läuft über ser2net. Aber es gab damit die letzten Monate keine Probleme, erst seit ein paar Tagen...
Irgendeine Idee was man machen kann oder wo ich noch suchen kann?
ser2net.conf
2000:raw:0:/dev/serial/by-id/usb-busware.de_CUL433-if00:115200 8DATABITS NONE 1STOPBIT NOBREAK
Der CUL funktioniert so übrigens auch nicht mehr, Befehle werden nicht ordnungsgemäß ausgeführt, keine erkennbare Reaktion.
Ok, habe meine ser2net Konfiguration angepasst und damit scheint das Problem weg zu sein. Warum auch immer es vorher mit der alten Konfiguration ewig lange gelaufen ist...
2000:raw:0:/dev/serial/by-id/usb-busware.de_CUL433-if00:38400 8DATABITS NONE 1STOPBIT
