Watchdog not working properly
Begonnen von VVlasy, 14 April 2015, 11:14:56
VVlasy
define wd_closeGate watchdog gate:open 00:15:00 SAME set gate close;;trigger wd_closeGate .
even if the state is different then open eg. closed... It still triggers the event
You did not tell enough to verify your problem (the generated events are missing), but I assume that you have to exchange SAME with gate:closed (or similar).
VVlasy
#2
Well, I want the watchdog to trigger on gate opening, and check after 15 minutes if gate:open trigger the gate, else do nothing..
this is my code now:
define wd_Vrata_Brana watchdog Vrata_Brana:open 00:00:30 Vrata_Brana:open set Vrata Vrata;;trigger wd_Vrata_Brana .
here, you can see it, the gate is first opened then closed, but watchdog triggers it still afetr 30 secs even when its closed, making it open again, and after 30 secs closes
(the first 3. dummy Vrata Vrata is user generated, eg opening, stopping and closing)
(dummy Vrata Vrata is dummy device Vrata getting triggered by pressing button vrata which sets device on for timer so the gate opens/closes)
2015-04-14 23:10:00 watchdog wd_Vrata_Brana .
2015-04-14 23:10:00 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A CMDs_done
2015-04-14 23:10:00 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 deviceMsg: on (to COC)
2015-04-14 23:10:00 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 level: 100
2015-04-14 23:10:00 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 pct: 100
2015-04-14 23:10:00 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 on
2015-04-14 23:10:00 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 timedOn: running
2015-04-14 23:10:03 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 deviceMsg: off (to broadcast)
2015-04-14 23:10:03 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 level: 0
2015-04-14 23:10:03 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 pct: 0
2015-04-14 23:10:03 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 off
2015-04-14 23:10:03 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 timedOn: off
2015-04-14 23:10:04 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A CMDs_pending
2015-04-14 23:10:04 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 set_on-for-timer 0.1
2015-04-14 23:10:04 dummy Vrata Vrata
2015-04-14 23:10:04 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A CMDs_done
2015-04-14 23:10:04 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 deviceMsg: on (to COC)
2015-04-14 23:10:04 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 level: 100
2015-04-14 23:10:04 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 pct: 100
2015-04-14 23:10:04 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 on
2015-04-14 23:10:04 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 timedOn: running
2015-04-14 23:10:08 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 deviceMsg: off (to broadcast)
2015-04-14 23:10:08 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 level: 0
2015-04-14 23:10:08 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 pct: 0
2015-04-14 23:10:08 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 off
2015-04-14 23:10:08 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 timedOn: off
2015-04-14 23:10:08 CUL_HM HM_1DD5E5 battery: ok
2015-04-14 23:10:08 CUL_HM HM_1DD5E5 CMDs_done
2015-04-14 23:10:08 dummy Vrata otevřeno
2015-04-14 23:10:08 dummy Vrata_Brana open
2015-04-14 23:10:08 CUL_HM HM_1DD5E5_Sw_01 contact: open (to COC)
2015-04-14 23:10:08 CUL_HM HM_1DD5E5_Sw_01 open
2015-04-14 23:10:08 CUL_HM HM_1DD5E5_Sw_01 trigger_cnt: 75
2015-04-14 23:10:08 CUL_HM CUL_HM_HM_OU_LED16_1AC67F color: 000001AA
2015-04-14 23:10:08 CUL_HM CUL_HM_HM_OU_LED16_1AC67F 000001AA
2015-04-14 23:10:08 CUL_HM CUL_HM_HM_OU_LED16_1AC67F CMDs_done
2015-04-14 23:10:08 CUL_HM CUL_HM_HM_OU_LED16_1AC67F_Led_05 color: red
2015-04-14 23:10:08 CUL_HM CUL_HM_HM_OU_LED16_1AC67F_Led_05 red
2015-04-14 23:10:09 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A CMDs_pending
2015-04-14 23:10:09 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 set_on-for-timer 0.1
2015-04-14 23:10:09 dummy Vrata Vrata
2015-04-14 23:10:09 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A CMDs_done
2015-04-14 23:10:09 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 deviceMsg: on (to COC)
2015-04-14 23:10:09 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 level: 100
2015-04-14 23:10:09 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 pct: 100
2015-04-14 23:10:09 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 on
2015-04-14 23:10:09 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 timedOn: running
2015-04-14 23:10:10 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A CMDs_pending
2015-04-14 23:10:10 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 set_on-for-timer 0.1
2015-04-14 23:10:10 dummy Vrata Vrata
2015-04-14 23:10:11 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A CMDs_done
2015-04-14 23:10:11 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 deviceMsg: on (to COC)
2015-04-14 23:10:11 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 level: 100
2015-04-14 23:10:11 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 pct: 100
2015-04-14 23:10:11 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 on
2015-04-14 23:10:11 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 timedOn: running
2015-04-14 23:10:14 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 deviceMsg: off (to broadcast)
2015-04-14 23:10:14 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 level: 0
2015-04-14 23:10:14 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 pct: 0
2015-04-14 23:10:14 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 off
2015-04-14 23:10:14 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 timedOn: off
2015-04-14 23:10:16 CUL_HM HM_1DD5E5 battery: ok
2015-04-14 23:10:16 CUL_HM HM_1DD5E5 CMDs_done
2015-04-14 23:10:16 dummy Vrata zavřeno
2015-04-14 23:10:16 dummy Vrata_Brana closed
2015-04-14 23:10:16 CUL_HM HM_1DD5E5_Sw_01 contact: closed (to COC)
2015-04-14 23:10:16 CUL_HM HM_1DD5E5_Sw_01 closed
2015-04-14 23:10:16 CUL_HM HM_1DD5E5_Sw_01 trigger_cnt: 76
2015-04-14 23:10:38 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A CMDs_pending
2015-04-14 23:10:38 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 set_on-for-timer 0.1
2015-04-14 23:10:38 dummy Vrata Vrata
2015-04-14 23:10:38 watchdog wd_Vrata_Brana .
2015-04-14 23:10:38 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A CMDs_done
2015-04-14 23:10:38 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 deviceMsg: on (to COC)
2015-04-14 23:10:38 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 level: 100
2015-04-14 23:10:38 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 pct: 100
2015-04-14 23:10:38 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 on
2015-04-14 23:10:38 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 timedOn: running
2015-04-14 23:10:42 CUL_HM HM_1DD5E5 battery: ok
2015-04-14 23:10:42 CUL_HM HM_1DD5E5 CMDs_done
2015-04-14 23:10:42 dummy Vrata otevřeno
2015-04-14 23:10:42 dummy Vrata_Brana open
2015-04-14 23:10:42 CUL_HM HM_1DD5E5_Sw_01 contact: open (to COC)
2015-04-14 23:10:42 CUL_HM HM_1DD5E5_Sw_01 open
2015-04-14 23:10:42 CUL_HM HM_1DD5E5_Sw_01 trigger_cnt: 77
2015-04-14 23:10:42 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 deviceMsg: off (to broadcast)
2015-04-14 23:10:42 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 level: 0
2015-04-14 23:10:42 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 pct: 0
2015-04-14 23:10:42 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 off
2015-04-14 23:10:42 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 timedOn: off
2015-04-14 23:11:12 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A CMDs_pending
2015-04-14 23:11:12 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 set_on-for-timer 0.1
2015-04-14 23:11:12 dummy Vrata Vrata
2015-04-14 23:11:12 watchdog wd_Vrata_Brana .
2015-04-14 23:11:13 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A CMDs_done
2015-04-14 23:11:13 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 deviceMsg: on (to COC)
2015-04-14 23:11:13 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 level: 100
2015-04-14 23:11:13 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 pct: 100
2015-04-14 23:11:13 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 on
2015-04-14 23:11:13 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 timedOn: running
2015-04-14 23:11:14 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 deviceMsg: off (to broadcast)
2015-04-14 23:11:14 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 level: 0
2015-04-14 23:11:14 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 pct: 0
2015-04-14 23:11:14 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 off
2015-04-14 23:11:14 CUL_HM CUL_HM_HM_LC_SW4_PCB_1D897A_Sw_02 timedOn: off
2015-04-14 23:11:47 CUL_HM HM_1DD5E5 battery: ok
2015-04-14 23:11:47 CUL_HM HM_1DD5E5 CMDs_done
2015-04-14 23:11:47 dummy Vrata zavřeno
2015-04-14 23:11:47 dummy Vrata_Brana closed
2015-04-14 23:11:47 CUL_HM HM_1DD5E5_Sw_01 contact: closed (to COC)
2015-04-14 23:11:47 CUL_HM HM_1DD5E5_Sw_01 closed
2015-04-14 23:11:47 CUL_HM HM_1DD5E5_Sw_01 trigger_cnt: 78
if the gate is open after 15 minutes, it works ok, but if it is closed after 15 minutes, it still trgiggers, making the gate open, reinitiating, and closing it after 15 minutes again, If you understand me...
