Neuigkeiten:
Am Sonntag den 8.12.2024 kann es ab ca. 8:00 Uhr zu kurzzeitigen Einschränkungen / Ausfällen bei den Diensten des FHEM Vereines kommen.
Die Server müssen mal gewartet und dabei neu gestartet werden ;)
Z-Wave transfer
Begonnen von Paul Guijt, 07 April 2024, 15:13:41
Paul Guijt
I have several clients through a Z-Wave USB stick on FHEM. I want to transfer these clients to a Razberry, also on FHEM.
Can I? How?
Regards,
Paul
RasPi 2B, CUL 433, Jens' FW, Berker, HomeMatic, KlikaanKlikuit, RFXtrx443, Squeezebox, Z-Wave, TradFri in die Niederlände
I would first backup the Razberry with the FHEM ZWDongle backup command.
Then backup the USB-Stick in the same way.
Then try to restore the USB-Stick backup on the Razberry.
These backups contain the inclusion/routing information on the chip, and might(!) be compatible for different ZWave transceiver.
