Hallo odroegehorn,
für die Erweiterung des Moduls zum empfangen von IT-messages via CUL möchte ich folgenden Patch zur Verfügung stellen:
siehe Link (http://forum.fhem.de/index.php?topic=14348.0)
--- /tmp/10_IT-HEAD.pm
+++ /home/martin/src/fhemsvn/fhem/FHEM/10_IT.pm
@@ -29,7 +29,11 @@
itswitch => 'simple',
itdimmer => 'dimmer',
+my %bintotristate=(
+ "00" => "0",
+ "01" => "F",
+ "11" => "1"
sub
IT_Initialize($)
@@ -39,12 +43,12 @@
$it_c2b{$codes{$k}} = $k;
-# $hash->{Match} = "";
+ $hash->{Match} = "^i......\$";
$hash->{SetFn} = "IT_Set";
$hash->{StateFn} = "IT_SetState";
$hash->{DefFn} = "IT_Define";
$hash->{UndefFn} = "IT_Undef";
-# $hash->{ParseFn} = "IT_Parse";
+ $hash->{ParseFn} = "IT_Parse";
$hash->{AttrList} = "IODev ITfrequency ITrepetition switch_rfmode:1,0 do_not_notify:1,0 ignore:0,1 dummy:1,0 model:itremote,itswitch,itdimmer loglevel:0,1,2,3,4,5,6";
@@ -300,7 +304,60 @@
sub
IT_Parse($$)
+ my ($hash, $msg) = @_;
+ my $housecode;
+ my $cmdcode;
+ my $def;
+ my $newstate;
+ my @list;
+ if (length($msg) != 7) {
+ Log3 undef,3,"message \"$msg\" to short!";
+ return "message \"$msg\" to short!";
+ # convert hex -> binary
+ my $bin=sprintf("%024b",hex(substr($msg,1,length($msg)-1)));
+ #convert binary -> tristate
+ my $msgcode="";
+ while (length($bin)>=2) {
+ if (substr($bin,0,2) != "10") {
+ $msgcode=$msgcode.$bintotristate{substr($bin,0,2)};
+ } else {
+ Log3 undef,4,"unknown tristate in \"$bin\"";
+ return "unknown tristate in \"$bin\""
+ $bin=substr($bin,2,length($bin)-2);
+ $housecode=substr($msgcode,0,length($msgcode)-2);
+ $cmdcode=substr($msgcode,length($msgcode)-2,2);
+ #Log3 $hash,3,$msg."->".$msgcode."->".$housecode." ".$cmdcode;
+ if(!defined($modules{IT}{defptr}{lc($housecode)})) {
+ Log3 undef,3,"$housecode not defined!";
+ return "$housecode not defined!";
+ $def=$modules{IT}{defptr}{lc($housecode)};
+ foreach my $name (keys %{$def}) {
+ if ($def->{$name}->{$it_c2b{"on"}} eq lc($cmdcode)) {
+ # ON cmd
+ $newstate="on";
+ } elsif ($def->{$name}->{$it_c2b{"off"}} eq lc($cmdcode)) {
+ #OFF cmd
+ $newstate="off";
+ # dim cmds not yet supported
+ # elsif ($def->{$name}->{$it_c2b{"dimup"}} eq lc($cmdcode)) {
+ else {
+ Log3 $def->{$name}{NAME},3,"Code $cmdcode not supported by $def->{$name}{NAME}.";
+ next;
+ Log3 $def->{$name}{NAME},3,"$def->{$name}{NAME} ".$def->{$name}->{STATE}."->".$newstate;
+ push(@list,$def->{$name}{NAME});
+ readingsSingleUpdate($def->{$name},"state",$newstate,1);
+ return @list;
1;
@@ -312,8 +369,7 @@
<h3>IT - InterTechno</h3>
<ul>
The InterTechno 433MHZ protocol is used by a wide range of devices, which are either of
- the sender/sensor category or the receiver/actuator category. As we right now are only
- able to SEND InterTechno commands, but CAN'T receive them, this module at the moment
+ the sender/sensor category or the receiver/actuator category. This module at the moment
supports just devices like switches, dimmers, etc. through an <a href="#CUL">CUL</a> device, so this must be defined first.
<br><br>
Martin
