Buderus KM200 Kommunikationsmodul
Begonnen von Sailor, 21 Juli 2014, 12:39:47
grossi33
Update hat geholfen - ich hatte zuvor nur das km200-Modul erneuert. ...
Meine derzeitigen Readings (mit Werten):  ;)
/dhwCircuits/dhw1/activeDhwTimeProgram
Program1
2015-03-27 16:19:42
/dhwCircuits/dhw1/actualTemp
43.900002
2015-03-27 16:19:42
/dhwCircuits/dhw1/currentSetpoint
41
2015-03-27 16:19:43
/dhwCircuits/dhw1/dhwSpLevels/off
0
2015-03-27 16:19:43
/dhwCircuits/dhw1/dhwSpLevels/on
1
2015-03-27 16:19:43
/dhwCircuits/dhw1/dhwTimePrograms/AlwaysHotWater/1-Mo
0000 on 2400 off
2015-03-27 16:19:44
/dhwCircuits/dhw1/dhwTimePrograms/AlwaysHotWater/2-Tu
0000 on 2400 off
2015-03-27 16:19:44
/dhwCircuits/dhw1/dhwTimePrograms/AlwaysHotWater/3-We
0000 on 2400 off
2015-03-27 16:19:44
/dhwCircuits/dhw1/dhwTimePrograms/AlwaysHotWater/4-Th
0000 on 2400 off
2015-03-27 16:19:44
/dhwCircuits/dhw1/dhwTimePrograms/AlwaysHotWater/5-Fr
0000 on 2400 off
2015-03-27 16:19:44
/dhwCircuits/dhw1/dhwTimePrograms/AlwaysHotWater/6-Sa
0000 on 2400 off
2015-03-27 16:19:44
/dhwCircuits/dhw1/dhwTimePrograms/AlwaysHotWater/7-Su
0000 on 2400 off
2015-03-27 16:19:44
/dhwCircuits/dhw1/dhwTimePrograms/Program1/1-Mo
1600 on 1700 off
2015-03-27 16:19:45
/dhwCircuits/dhw1/dhwTimePrograms/Program1/2-Tu
1600 on 1700 off
2015-03-27 16:19:45
/dhwCircuits/dhw1/dhwTimePrograms/Program1/3-We
1600 on 1700 off
2015-03-27 16:19:45
/dhwCircuits/dhw1/dhwTimePrograms/Program1/4-Th
1600 on 1700 off
2015-03-27 16:19:45
/dhwCircuits/dhw1/dhwTimePrograms/Program1/5-Fr
1600 on 1700 off
2015-03-27 16:19:45
/dhwCircuits/dhw1/dhwTimePrograms/Program1/6-Sa
1600 on 1700 off
2015-03-27 16:19:45
/dhwCircuits/dhw1/dhwTimePrograms/Program1/7-Su
1600 on 1700 off
2015-03-27 16:19:45
/dhwCircuits/dhw1/dhwTimePrograms/Program2/1-Mo
0000 on 2400 off
2015-03-27 16:19:46
/dhwCircuits/dhw1/dhwTimePrograms/Program2/2-Tu
0000 on 2400 off
2015-03-27 16:19:46
/dhwCircuits/dhw1/dhwTimePrograms/Program2/3-We
0000 on 2400 off
2015-03-27 16:19:46
/dhwCircuits/dhw1/dhwTimePrograms/Program2/4-Th
0000 on 2400 off
2015-03-27 16:19:46
/dhwCircuits/dhw1/dhwTimePrograms/Program2/5-Fr
0000 on 2400 off
2015-03-27 16:19:46
/dhwCircuits/dhw1/dhwTimePrograms/Program2/6-Sa
0000 on 2400 off
2015-03-27 16:19:46
/dhwCircuits/dhw1/dhwTimePrograms/Program2/7-Su
0000 on 2400 off
2015-03-27 16:19:46
/dhwCircuits/dhw1/extraDhw/activationStatus
OFF
2015-03-27 16:19:47
/dhwCircuits/dhw1/extraDhw/status
ON
2015-03-27 16:19:47
/dhwCircuits/dhw1/extraDhw/stopTemp
55
2015-03-27 16:19:47
/dhwCircuits/dhw1/extraDhw/time
0
2015-03-27 16:19:48
/dhwCircuits/dhw1/operationMode
Automatic
2015-03-27 16:19:48
/dhwCircuits/dhw1/setTemperature
41
2015-03-27 16:19:49
/gateway/DateTime
2015-03-27T16:19:39
2015-03-27 16:19:49
/gateway/language
de
2015-03-27 16:19:49
/gateway/userpassword
xxx
2015-03-27 16:18:05
/gateway/uuid
517xxxxxx
2015-03-27 15:46:04
/gateway/versionFirmware
01.05.01
2015-03-27 16:18:05
/gateway/versionHardware
iCom_low_CAN_v1
2015-03-27 15:46:04
/heatingCircuits/hc1/activeSwitchProgram
HP_OPTIMIZED
2015-03-27 16:18:06
/heatingCircuits/hc1/heatingCurveSetting/decrement
1
2015-03-27 16:18:06
/heatingCircuits/hc1/heatingCurveSetting/increment
1
2015-03-27 16:18:06
/heatingCircuits/hc1/heatingCurveSetting/percentage
29.375
2015-03-27 16:18:06
/heatingCircuits/hc1/holidayMode/activated
OFF
2015-03-27 16:18:07
/heatingCircuits/hc1/holidayMode/startStop
2015-02-16/2015-02-18
2015-03-27 16:18:08
/heatingCircuits/hc1/operationMode
automatic
2015-03-27 16:18:08
/heatingCircuits/hc1/status
ACTIVE
2015-03-27 16:18:08
/heatingCircuits/hc1/switchPrograms/Evening/1-Mo
0650 normal 2300 exception
2015-03-27 16:18:08
/heatingCircuits/hc1/switchPrograms/Evening/2-Tu
2015-03-27 16:18:08
/heatingCircuits/hc1/switchPrograms/Evening/3-We
2015-03-27 16:18:08
/heatingCircuits/hc1/switchPrograms/Evening/4-Th
2015-03-27 16:18:08
/heatingCircuits/hc1/switchPrograms/Evening/5-Fr
2015-03-27 16:18:08
/heatingCircuits/hc1/switchPrograms/Evening/6-Sa
0650 normal 2350 exception
2015-03-27 16:18:08
/heatingCircuits/hc1/switchPrograms/Evening/7-Su
0700 normal 2300 exception
2015-03-27 16:18:08
/heatingCircuits/hc1/switchPrograms/Family/1-Mo
0550 normal 2200 exception
2015-03-27 16:18:09
/heatingCircuits/hc1/switchPrograms/Family/2-Tu
2015-03-27 16:18:09
/heatingCircuits/hc1/switchPrograms/Family/3-We
2015-03-27 16:18:09
/heatingCircuits/hc1/switchPrograms/Family/4-Th
2015-03-27 16:18:09
/heatingCircuits/hc1/switchPrograms/Family/5-Fr
0550 normal 2300 exception
2015-03-27 16:18:09
/heatingCircuits/hc1/switchPrograms/Family/6-Sa
2015-03-27 16:18:09
/heatingCircuits/hc1/switchPrograms/Family/7-Su
0700 normal 2200 exception
2015-03-27 16:18:09
/heatingCircuits/hc1/switchPrograms/Morning/1-Mo
0450 normal 2200 exception
2015-03-27 16:18:09
/heatingCircuits/hc1/switchPrograms/Morning/2-Tu
2015-03-27 16:18:09
/heatingCircuits/hc1/switchPrograms/Morning/3-We
2015-03-27 16:18:09
/heatingCircuits/hc1/switchPrograms/Morning/4-Th
2015-03-27 16:18:10
/heatingCircuits/hc1/switchPrograms/Morning/5-Fr
0450 normal 2300 exception
2015-03-27 16:18:10
/heatingCircuits/hc1/switchPrograms/Morning/6-Sa
2015-03-27 16:18:10
/heatingCircuits/hc1/switchPrograms/Morning/7-Su
2015-03-27 16:18:10
/heatingCircuits/hc1/switchPrograms/Program1/1-Mo
2015-03-27 16:18:11
/heatingCircuits/hc1/switchPrograms/Program1/2-Tu
2015-03-27 16:18:11
/heatingCircuits/hc1/switchPrograms/Program1/3-We
2015-03-27 16:18:11
/heatingCircuits/hc1/switchPrograms/Program1/4-Th
2015-03-27 16:18:11
/heatingCircuits/hc1/switchPrograms/Program1/5-Fr
2015-03-27 16:18:11
/heatingCircuits/hc1/switchPrograms/Program1/6-Sa
2015-03-27 16:18:11
/heatingCircuits/hc1/switchPrograms/Program1/7-Su
2015-03-27 16:18:11
/heatingCircuits/hc1/switchPrograms/Program2/1-Mo
2015-03-27 16:18:12
/heatingCircuits/hc1/switchPrograms/Program2/2-Tu
2015-03-27 16:18:12
/heatingCircuits/hc1/switchPrograms/Program2/3-We
2015-03-27 16:18:12
/heatingCircuits/hc1/switchPrograms/Program2/4-Th
2015-03-27 16:18:13
/heatingCircuits/hc1/switchPrograms/Program2/5-Fr
2015-03-27 16:18:13
/heatingCircuits/hc1/switchPrograms/Program2/6-Sa
2015-03-27 16:18:13
/heatingCircuits/hc1/switchPrograms/Program2/7-Su
2015-03-27 16:18:13
/heatingCircuits/hc1/switchPrograms/Seniors/1-Mo
2015-03-27 16:18:13
/heatingCircuits/hc1/switchPrograms/Seniors/2-Tu
2015-03-27 16:18:13
/heatingCircuits/hc1/switchPrograms/Seniors/3-We
2015-03-27 16:18:13
/heatingCircuits/hc1/switchPrograms/Seniors/4-Th
2015-03-27 16:18:13
/heatingCircuits/hc1/switchPrograms/Seniors/5-Fr
2015-03-27 16:18:13
/heatingCircuits/hc1/switchPrograms/Seniors/6-Sa
2015-03-27 16:18:13
/heatingCircuits/hc1/switchPrograms/Seniors/7-Su
2015-03-27 16:18:13
/heatingCircuits/hc1/temperatureLevels/exception
16
2015-03-27 16:18:13
/heatingCircuits/hc1/temperatureLevels/normal
22.299999
2015-03-27 16:18:14
/heatingCircuits/hc2/activeSwitchProgram
HP_OPTIMIZED
2015-03-27 16:18:14
/heatingCircuits/hc2/heatingCurveSetting/decrement
1
2015-03-27 16:18:14
/heatingCircuits/hc2/heatingCurveSetting/increment
1
2015-03-27 16:18:14
/heatingCircuits/hc2/heatingCurveSetting/percentage
29.812498
2015-03-27 16:18:16
/heatingCircuits/hc2/holidayMode/activated
OFF
2015-03-27 16:18:16
/heatingCircuits/hc2/holidayMode/startStop
2015-02-00/2015-02-18
2015-03-27 16:18:17
/heatingCircuits/hc2/operationMode
automatic
2015-03-27 16:18:18
/heatingCircuits/hc2/status
ACTIVE
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Evening/1-Mo
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Evening/2-Tu
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Evening/3-We
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Evening/4-Th
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Evening/5-Fr
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Evening/6-Sa
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Evening/7-Su
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Family/1-Mo
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Family/2-Tu
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Family/3-We
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Family/4-Th
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Family/5-Fr
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Family/6-Sa
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Family/7-Su
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Morning/1-Mo
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Morning/2-Tu
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Morning/3-We
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Morning/4-Th
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Morning/5-Fr
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Morning/6-Sa
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Morning/7-Su
2015-03-27 16:18:18
/heatingCircuits/hc2/switchPrograms/Program1/1-Mo
0000 normal 2400 exception
2015-03-27 16:18:20
/heatingCircuits/hc2/switchPrograms/Program1/2-Tu
2015-03-27 16:18:20
/heatingCircuits/hc2/switchPrograms/Program1/3-We
2015-03-27 16:18:20
/heatingCircuits/hc2/switchPrograms/Program1/4-Th
2015-03-27 16:18:20
/heatingCircuits/hc2/switchPrograms/Program1/5-Fr
2015-03-27 16:18:20
/heatingCircuits/hc2/switchPrograms/Program1/6-Sa
2015-03-27 16:18:20
/heatingCircuits/hc2/switchPrograms/Program1/7-Su
2015-03-27 16:18:20
/heatingCircuits/hc2/switchPrograms/Program2/1-Mo
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Program2/2-Tu
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Program2/3-We
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Program2/4-Th
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Program2/5-Fr
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Program2/6-Sa
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Program2/7-Su
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Seniors/1-Mo
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Seniors/2-Tu
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Seniors/3-We
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Seniors/4-Th
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Seniors/5-Fr
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Seniors/6-Sa
2015-03-27 16:18:21
/heatingCircuits/hc2/switchPrograms/Seniors/7-Su
2015-03-27 16:18:21
/heatingCircuits/hc2/temperatureLevels/exception
17
2015-03-27 16:18:21
/heatingCircuits/hc2/temperatureLevels/normal
22.299999
2015-03-27 16:18:22
/system/appliance/type
Heatpump
2015-03-27 16:18:22
/system/brand
Buderus
2015-03-27 15:46:05
/system/bus
CAN
2015-03-27 15:46:05
/system/sensors/outdoorTemperatures/t1
8.5
2015-03-27 16:18:22
/system/systemType
CanIcomGw
2015-03-27 15:18:05
fullResponse
OK
;D
Noch eine Frage zur Heizkurve, z.B. HK2:
Diese müsste sich in den folgenden 3 Readings "verstecken"
1
1
29.812498
Was bedeutet das nun mit den "Prozent" - bei mir ist diese Kurve
auf 22/44 eingestellt. .... ???
Grüsse.
Stefan M.
Hi zusammen
hab jetzt das Update auf 045.
Man sind das viele Readings.
@sailor
könntest Du vielleicht die Inactiven hc's gleich ignorieren ?
INACTIVE
lg
Stefan
FHEM auf 3 x RaspberryPi, 1 x Fritzbox,1 x Win. FS20 über CUL, HomeMatic über HMLan, 6 x  HM_CC_RT_DN,2 x HM_LC_BL1_FM,3 x HM_SEC_KEY,2 x HM_RC_Key4_2,7 x HM_SEC_SC,1 x HM_SEC_WDS,1 x HM_Sen_RD_O, 1x HM_Sen_Wa_Od,2 x HM_RC_Key4_2, 5 x HM-ES-PMSw1-Pl,1 x HM_LC_SW4_WM,1 x HM_SCI_3_FM
Starkstrombastler
#722
Hallo DLindner,
Zitat von: DLindner am 26 März 2015, 22:26:04
dies Dokument kennst Du ?
http://de.documents.buderus.com/download/pdf/file/63016219.pdf
vielen Dank für den Link, ich hatte das Dokument bislang nur in Papierform!
Die neuerliche ausführliche Lektüre zeigt: Für die RC30 ist die Weichentemperatur in einer "Doppelbelegung" versteckt, und zwar unter
>Monitordaten >Kessel > Anlage ist es der Wert rechts oben.
Das hat sich durch Herausziehen und Abkühlen bestätigt. Die GB142 nimmt diesen Wert auch als Regelgröße. Richtig schön zuzusehen, wie sie so langsam hoch und runter moduliert....
@Sailor:   nach dem Update auf 0045 habe ich zunächst viele neue Readings gesehen,  im Standby hatte ich aber schließlich genau die gleichen Readings wie unter 0044. Habe ich da irgendetwas übersehen?
Habe alte Daten angeschaut  ;)
IPC\Ubuntu + Fhem, 1wire, Shellies, Siemens Logo!, Z-Wave, PhilipsTV, Vu+duo2, KM200
Starkstrombastler
@sailor
durch das Update auf 0045 wurden die Readinga .../switchPrograms/A und ../B erweitert und es kam das volle Programm für /heatingCircuits/hc3 und hc4 hinzu.
Ansonsten habe ich aber keine neuen Readings. Muss ich noch etwas warten oder irgendwie aktiv werden?
@RaspII
Du hast auch eine RC30, wie sieht das bei Dir aus?
brembs
Zunächst mal Danke für ein tolles Modul! Bin ganz nue bei fhem, habe mir gerade einen Raspberry Pi besorgt, alles installiert und auf Anhieb hat alles geklappt, bin begeistert!
So wie grossi33's Readings sehen meine auch as, zielich identisch sogar, muss ich sagen.
Da finde ich aber keine Vorlauftemperaturen? Wenn die da nicht zu finden sind, dann kann ich die auch nicht auslesen?
Was ich eigentlich machen möchte ist meinen PV Strom und PV-Batteriestand auszulesen (beides über das WebInterface meiner PV Anlage) und wenn ich massig Strom habe und die Batterie voll ist, dann möchte ich das Warmwasser auf 65° heizen, bevor ich einspeise. Dazu müsste ich eigentlich nur ein kleines Skript schreiben, das mir die Vriablen aus dem PV-Interface liest und beim entsprechenden Zustand extra-Warmwasser bis 65° macht. Hat jemand etwas in der Richtung gemacht und hat einen Link zu einer entsprechenden Anleitung?
Tausend Dank!
Björn
HarryHase
#725
Wie kann in der Version 45 am besten die Werte ausblenden die man nicht braucht/will/ oder gar hat?
die ganzen ../switchPrograms/.. interessieren  mich erst mal nicht, verwirren mich ehr ..
dachte dass es so geht
attr myKm200 DoNotPoll  /heatingCircuits/hc1/switchPrograms /dhwCircuits/dhw1/switchPrograms /heatingCircuits/hc2 /heatingCircuits/hc3 /heatingCircuits/hc4
irgend wie geht das aber nicht
Grüße hh
DLindner
Geht doch. Sie sind zwar noch in der Polling-Liste zu sehen, werden aber nicht mehr abgefragt (bleiben weiß).
HarryHase
jetzt hat mein km200 ein update gemacht und hat die Firmware hochgezogen und wieder ist alles durcheinander.
01.09.04
Grüße hh
Sailor
Hallo Grossi
Zitat von: grossi33 am 27 März 2015, 15:01:27
noch eine Frage:
Durchsuchst Du schon mit der 0045 alle möglichen Services,
sodass jetzt alle möglchen Readings angezeigt werden?
Oder geht da nochwas?
Nein, mit 0045 werden alle moeglichen Services abgeklopft.
Mehr ist nicht drin, es sei denn Jemand findet noch ein Root-Service.
    Sailor
Man wird immer besser...
Sailor
Hallo Grossi
Magst du zukuenftig die Readings im Post unter CODE tags legen.
Dadurch wird die Seite nicht so lang.
    Sailor
HarryHase
Ist das normal das ich keine Rücklauftemperatur habe, oder ist da was kaputt an der Heizung?
/system/sensors/temperatures/return   -3276.8
Grüße hh
HarryHase
Bei mir geht das nicht; steht alles im Log in voller Schönheit drin ...
Ich habe alles probiert, mit führendem / ohne und mit schließendem / und ohne ... Kein Ahnung was ich falsch mache.
Grüße hh
Sailor
Hallo Harry
Das ist normal. Steht bei mir auch so drin.
Der Hintergrund ist, dass die Messung der Ruecklauftemperatur nur bei Systemen mit mehreren Waermequellen Sinn macht.
Ich vermute, dass dier Wert -3276.8 einem offenen Anschluss bzw. sehr hochohmigen Anschluss entspricht.
    Sailor
Newbee
Hallo HarryHase,
habe es wie folgt gelöst.
DoNotPoll
Readings sind gelistet und werden aktualisiert.
/heatingCircuits/hc1/temperatureLevels/day
20.5
2015-03-29 20:37:25
/heatingCircuits/hc1/temperatureLevels/night
17
2015-03-29 20:37:28
Readings sind gelistet aber werden nicht mehr aktualisiert.
/heatingCircuits/hc2/temperatureLevels/day
21
2015-03-28 09:33:22
/heatingCircuits/hc2/temperatureLevels/night
17
2015-03-28 09:33:24
Grüsse Newbee
Intel-NUC mit ubuntu server 20.04; FHEM 6.0
HM, Dect, Netatmo, Hue
Sailor
Hallo Harry
Loesch mal dein Stat file und starte fhem neu.
Dann duerften die Readings nicht mehr auftauchen.
    Sailor
