I have a 12V LIFEPO4 4KW battery with a JK BMS. I have installed the RS485 adapter, which seems to be isolated, which is a good thing. I will connect this to a WROVER32 running tasmota, and use two pins as a modbus RS485 bridge. I am running FHEM on a RASPI, which communicates with a lot of of other tasmota sensors using MQTT. Does a module exist for decoding and categorizing the BMS stream which I will hopefully be able to receive on the PI? Have I missed something ? Will this work like I imagine it could ? I would like to get the information so that I can control the charging routine for the battery pack, which presently gets any energy which is above +5W according to the main power meter reading using an optical magnetic adapter on the face of the meter (also tasmota). I get a reading every second from the Stromzahler. The software and hardware performs quite well presently, but extra info from the BMS could be an advantage. The charger is a server PSU (maximum 70A @ 13.7V) controlled from the PWM on tasmota. Any input or comment would be appreciated. Thanks.
Hi domo,
please check this link: https://github.com/syssi/esphome-jk-bms (https://github.com/syssi/esphome-jk-bms)
In a couple of weeks, I'm gonegoing to a have JK-BMS and I will either use this code or something similiar from GitHub.
Cheers
Gisbert
hi Gisbert, cool, i'll wait for your feedback..
so this is what the JK BMS is sending, I think it is ok, it needs to be parsed into different values:
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
best regs
Hello Gisbert, I decoded locally on the esp32 using berry script, and MQTT.PUBLISH commands.it works great. I think it is the best way to go. Regards domo
Hi domo,
I have to wait for another ESP32 which hopefully will arrive in about 2 weeks. The battery and the JK-BMS are now working since a couple of days.
My plan is to use syssis code: https://github.com/syssi/esphome-jk-bms (https://github.com/syssi/esphome-jk-bms). The connection seems to be easy as no further components besides the ESP32 board are necessary. 3 of the 4 pins (JST 1.25mm pitch) of the port called GPS are necessary. The 4th pin is the voltage of the battery (about 50~56 V) - this must not be used.
I will send the data via MQTT to Fhem. Syssis code is based on ESPHome / Python which needs to be installed on your computer. I followed the instructions of this page for another project (my DEYE hybrid inverter), it worked right from the start: https://smarthomeyourself.de/wiki/esphome/esphome-mit-python-ueber-die-kommandozeile-flashen/ (https://smarthomeyourself.de/wiki/esphome/esphome-mit-python-ueber-die-kommandozeile-flashen/).
Regards
Gisbert
Hi Gisbert, yes I looked at that project a lot, I used the file jk_bms.cpp to template my berry script, which is working quite nicely, it sends the mqtt already decoded to my rasberry pi, where FHEM gets it. so i guess you will look at decoding the data on your host. yes that pin4 is a no no, it has battery voltage on it, best leave it alone. so i have a small non FHEM related question, regarding berry script, why can't i use *=-1 to invert an integer ? this is very frustrating, it simply will not accept it, neither will a=-a , i am at my limit trying to get the mqtt.publish current reading negative when it should be... I have built a bespoke controller for my battery pack, with two charger and discharger PWMs which control a modified server power supply and a solar inverter to charge and discharge the battery. My pack is only 4KW so not too big. I guess i will need a few more panels on the roof now to charge that in one day. hope to hear how you get on too. best regards Domo.
Hi domo,
from a former project, I geht used to ESPHome which seems to be much user friendly than Arduino code. Therefore I will use the ESPHome code.
When I want to transform a reading in something else, I use most likely the attribut userReadings, e.g. in your case
attr userReadings Device newreading {0-ReadingsNum($name,'oldreading,'')}
Regards
Gisbert
