CUL wird nicht geöffnet
Begonnen von Joey2511, 15 Dezember 2013, 00:16:29
Joey2511
Hallo zusammen.
Ich bin Anfänger und brauche Hilfe. Was läuft falsch bei meinem FHEM und CUL?
2013.12.14 23:26:34 1: localhost:2002 reappeared (fbaha)
2013.12.14 23:26:34 1: FBAHA_DoInit called
2013.12.14 23:28:59 1: localhost:2002 disconnected, waiting to reappear
2013.12.14 23:29:05 1: /dev/ttyACM0 disconnected, waiting to reappear
2013.12.14 23:31:23 1: Including /etc/fhem.cfg
2013.12.14 23:31:25 3: telnetPort: port 7072 opened
2013.12.14 23:31:26 3: WEB: port 8083 opened
2013.12.14 23:31:26 3: WEBphone: port 8084 opened
2013.12.14 23:31:26 3: WEBtablet: port 8085 opened
2013.12.14 23:31:27 3: Opening fbaha device localhost:2002
2013.12.14 23:31:27 3: fbaha device opened
2013.12.14 23:31:27 1: FBAHA_DoInit called
2013.12.14 23:31:27 3: Opening CUL_0 device /dev/ttyACM0
2013.12.14 23:31:28 1: Including /etc/fhem.cfg
2013.12.14 23:31:29 3: Setting CUL_0 baudrate to 9600
2013.12.14 23:31:29 3: CUL_0 device opened
2013.12.14 23:31:29 3: CUL_0: Possible commands: BCFiAZEGMRTVWXefmltux
2013.12.14 23:31:29 1: Including /var/log/fhem/fhem.save
2013.12.14 23:31:29 1: usb create starting
2013.12.14 23:31:29 3: Opening CUL device /dev/ttyACM1
2013.12.14 23:31:29 3: Can't open /dev/ttyACM1: Invalid argument
2013.12.14 23:31:29 3: Opening TCM310 device /dev/ttyUSB0
2013.12.14 23:31:29 3: Can't open /dev/ttyUSB0: No such device or address
2013.12.14 23:31:29 3: Opening TCM310 device /dev/ttyUSB1
2013.12.14 23:31:29 3: Can't open /dev/ttyUSB1: No such device or address
2013.12.14 23:31:29 1: usb create end
2013.12.14 23:31:29 0: Server started with 10 defined entities (version Fhem 5.4 (DEVELOPMENT), $Id: fhem.pl 3008 2013-04-01 11:19:27Z rudolfkoenig $, AVM Build: 84.05.55-25188, pid 879)
2013.12.14 23:31:30 1: telnetPort: Can't open server port at 7072: Address already in use. Exiting.
Joachim
Leg Dir bitte mal ne Signatur zu, damit man weiß, was für Hardware Du hast.
Meinen Job als Hellseher habe ich verloren, weil ich meist daneben lag.
Ansonsten sollte Dir folgendes zu denken geben:
wer ist was?
Gruß Joachim
PS.: Diese Beiträge sind echt lesenswert:
http://forum.fhem.de/index.php/topic,16311.0.html
http://forum.fhem.de/index.php/topic,13092.0.html
http://forum.fhem.de/index.php/topic,9637.0.html
gibt gute Gründe, weshalb sie bei Anfängerfragen als erste Beiträge gepinnt sind.
FHEM auf Raspberry
Ich versuchts mit Hellsehen:
Die FHEM Version, was man von der AVM Seite herunterlaedt, wird exklusiv von der AVM-Hotline betreut.
Wenn FHEM schon einmal laeuft, dann sollte kein Zweiter gestartet werden.
