alexa-fhem test version mit proaktiven events
Begonnen von justme1968, 15 Februar 2020, 18:44:06
Tueftler1983
habe auch mal das Beispiel Dummy aus dem Wiki angelegt.
Da das selbe ich bekomme den Dummy in der Alexa App angezeigt und der Status wird auch aktuallisiert aber ich kann in in den Routinen nicht als Trigger auswählen.
hier nioch ein auszug aus dem Log beim Triggern des Dummys
[2020-6-22 12:49:09] [FHEM]     caching: ContactSensorState: CONTACT_NOT_DETECTED (as string; from 'open')
[2020-6-22 12:49:09] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ContactSensor","name":"detectionState","value":"DETECTED","timeOfSample":"2020-06-22T10:49:09.241Z","uncertaintyInMilliseconds":500},{"namespace":"Alexa.EndpointHealth","name":"connectivity","value":{"value":"OK"},"timeOfSample":"2020-06-22T10:49:09.241Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"StateReport","payloadVersion":"3","messageId":"fb8e32f1-8b44-485d-a7a7-0ea4c712f5c8","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AB150F3D-35A14807631DC08E"},"endpointId":"5ef08aa8-f33f-16cd-98d7-3d9f6161134b86a0"},"payload":{}}}
[2020-6-22 12:49:12] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa","name":"ReportState","payloadVersion":"3","messageId":"36eb988c-41ef-447b-bc9c-69d3ca19e059","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AB150F3D-35A14807631DC08E"},"endpointId":"5ef08aa8-f33f-16cd-98d7-3d9f6161134b86a0","cookie":{"fuuid":"5ef08aa8-f33f-16cd-98d7-3d9f6161134b86a0","device":"voicetrigger1"}},"payload":{}}}
[2020-6-22 12:49:12] [FHEM]     caching: ContactSensorState: CONTACT_NOT_DETECTED (as string; from 'open')
[2020-6-22 12:49:12] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ContactSensor","name":"detectionState","value":"DETECTED","timeOfSample":"2020-06-22T10:49:12.318Z","uncertaintyInMilliseconds":500},{"namespace":"Alexa.EndpointHealth","name":"connectivity","value":{"value":"OK"},"timeOfSample":"2020-06-22T10:49:12.318Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"StateReport","payloadVersion":"3","messageId":"b5f6babf-3bce-4db8-b78d-03850c0fc9fa","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AB150F3D-35A14807631DC08E"},"endpointId":"5ef08aa8-f33f-16cd-98d7-3d9f6161134b86a0"},"payload":{}}}
[2020-6-22 12:49:15] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa","name":"ReportState","payloadVersion":"3","messageId":"a76ad4bc-88d3-4f9d-b1d5-2a87c3961e19","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AB150F3D-35A14807631DC08E"},"endpointId":"5ef08aa8-f33f-16cd-98d7-3d9f6161134b86a0","cookie":{"fuuid":"5ef08aa8-f33f-16cd-98d7-3d9f6161134b86a0","device":"voicetrigger1"}},"payload":{}}}
[2020-6-22 12:49:15] [FHEM]     caching: ContactSensorState: CONTACT_NOT_DETECTED (as string; from 'open')
MadMax-FHEM
Hab eben auch mal meinen "alten" "alleFenster-Dummy" auf proactiveEvents umgestellt, ebenso das Alexa-Device (muss/sollte man das!?)...
Kann "alleFenster" bei Routine auswählen...
...bekomme aber dann: wird leider noch nicht unterstützt...
Bilde mir aber ein es ging schon mal...
...gleich zu Beginn mit proactive Events...
Hmmm, glaube noch mit den ersten "Prototyp-Versionen"!?
(is mir nicht wichtig, mache eh alle Automatisierung in fhem und wenn ich dann eine Routine loslaufen lassen wollte: echodevice-Modul / wollte "nur" mit-testen ;)  )
Gruß, Joachim
FHEM PI3 Buster (Test)
Tueftler1983
So hatte noch alexa- Fhem Version 0.4.28 oder so. Grade Update gemacht nun läuft es
MadMax-FHEM
So, hab auch noch mal ein wenig "rumgespielt" und jetzt geht es auch (wieder)... :)
Nicht, dass ich's bräuchte...
...aber man will ja dass man könnte ;)
Gruß, Joachim
Tueftler1983
Schön, Alexa sagt mir jetzt wenn mein Regenwasser Tank voll oder leer ist.
Ist auch irgendwann was geplant das Licht (LUX) Sensoren integriert werden oder das ich Alexa fragen kann:" Alexa, wie voll ist der Wassertank"? Und die antwortet " Im Wassertank sind derzeit 1650 Liter.
So in die Richtung
MadMax-FHEM
Das ginge auch ohne Sensoren in Alexa und proactive Events: echodevice-Modul
Und ebenso echodevice-Modul in Kombination mit alexa-fhem Connector und Routine geht die Abfrage jetzt schon...
Gruß, Joachim
Tueftler1983
Meinst du so?
Eine Routine in der Alexa App erstellen die mir den DUMMY d_abfrage_tank auf on setzt und in FHEM ein DOIF mit:
([d_abfrage_tank] eq "on")(set ECHO_G000MW04xxxxxxxxx speak Im Wassertank sind derzeit [ESP_8_Tank_US:Liter] Liter)(set d_abfrage_tank off)
Hast Recht funktioniert auf Anhieb...
MadMax-FHEM
Ja, so in etwa...
Es gibt auch die Möglichkeit ohne dummy mit direkt DOIF/notify auf das voice-Reading des echodevice-Moduls...
Im echodevice-Modul Thread gibt es auch weitere Beispiele...
Und ist ein DOIF nicht etwas "groß"/"übertrieben" für diese "simple" Reaktion!? ;)
Da hätte ein notify auch gereicht... ;)
Gruß, Joachim
Tueftler1983
Mag sein ich komme mir der Syntax vom FOIF gut zurecht. Bei notify haperte bei mir immer verstehe den Aufbau nicht so Recht.
Aber ich gucke gerne wie ich es noch besser machen kann, vielleicht sogar offener und flexibler.
Tueftler1983
#99
So geht's auch....
([ECHO_G000MWxxxxxxxxxc:voice] eq "wie voll ist der wassertank")(set ECHO_G000MWxxccccc speak Im Wassertank sind derzeit [ESP_8_Tank_US:Liter] Liter)
Weiß nicht wie ich das dynamisch halte so daß es egal ist zu welchem Echo ich spreche mir dieser dann auch antwortet
Denke ist irgendwie mit ["^ECHO_:voice"] ...
Leider funktioniert das nicht:
(["^ECHO_:voice"] eq "wie voll ist der wassertank")(set $DEVICE speak Im Wassertank sind derzeit [ESP_8_Tank_US:Liter] Liter)
amenomade
Das hat langsam nichts mehr mit dem Thread zu tun. Kannst Du vielleicht ein neues Thread kreieren? Ich glaube, Andre hätte lieber hier nur Rückmeldungen zu "alexa-fhem mit proaktiven events".
MadMax-FHEM
Da kann ich nur zustimmen!
Und (hatte ich ja schon [mehrfach] geschrieben): im echodevice-Thread gibt es gute Beispiele (ist ein längerer Thread, muss man etwas suchen)...
Man kann die "Sprachauswertung" auch an z.B. TEERKO oder Talk2Fhem oder babble etc. "auslagern"...
Gruß, Joachim
Invers
Problem:
Ich spiele per Alexa etwas ab, Radio oder Album von Prime z.B.
Ich stoppe mit dem Befehl set alexa stop per DOIF und mit set alexa play per DOIF spielt der Zwerg weiter.
Nach längerer Zeit im Stopmodus geht aber nichts mehr. Egal, was ich eingebe, eie Wiedergabe wird nicht fortgesetzt. In den Readings sind aber die Infos noch vorhanden.
Sage ich zum Lautsprecher "Alexa play" geht es als Fortsetzung des Titels/Senders weiter.
Was kann ich tun, damit die Wiedergabe zuverlässig fortgesetzt wird? Gibt es einen Trick?
Hintergrund ist die automatische Wiedergabe von Musik im Bad, wenn das Licht an geht.
justme1968
ich glaube du bist im falschen thread und beim falschen modul...
unabhängig davon: zumindest bei sprach kommandos "merkt" alexa sich nur etwa 10 minuten das aktuelle ausgabe gerät. danach muss man den geräte namen wieder mit verwenden.  kelle ich that das ja auch etwas mit deinem problem zu tun.
MadMax-FHEM
Da schließe ich mich an: vermutlich meinst du das echodevice-Modul...
Das Verhalten ist bei mir auch so...
Ist wohl etwas vergesslich die gute Dame ;)
Entweder immer mal wieder kurz anspielen und stoppen ;)
Oder die play-ID (oder wie das genau heißt) mitgeben.
Ich hab mir mal ein paar kopiert.
Also so wie im eigentlichen Thread beschrieben entsprechende Playlisten-IDs finden (siehe Michael Winkler Webseite)...
Damit hat das bei mir funktioniert...
Nutze ich aber so nicht mehr.
Ich kann damit leben, dass wenn es nicht mehr autom. weiter geht, ich es halt einfach per Sprache noch mal anwerfe... ;)
Gruß, Joachim
