HM-CC-RT-DN pending commands
Begonnen von mabula, 25 Mai 2023, 13:28:31
mabula
HM-CC-RT-DN und HM-TC-IT-WM-W-EU sind über Fhem gekoppelt. Wird der HM-TC-IT-WM-W-EU mit "set HzThermoWZ_Climate controlMode manual" umgestellt wird der HM-CC-RT-DN nicht umgestellt und es beleiben pending commands. Anbei ein Mitschnitt der Ereignisse:
2023-05-25 12:55:23.435 CUL_HM HzReglerWZ_l_Climate controlMode: set_manual
2023-05-25 12:55:23.440 CUL_HM HzReglerWZ_l commState: CMDs_pending
2023-05-25 12:55:23.444 CUL_HM HzReglerWZ_l_Clima commState: CMDs_pending
2023-05-25 12:55:23.448 CUL_HM HzReglerWZ_l_ClimaTeam commState: CMDs_pending
2023-05-25 12:55:23.452 CUL_HM HzReglerWZ_l_Climate commState: CMDs_pending
2023-05-25 12:55:23.456 CUL_HM HzReglerWZ_l_Weather commState: CMDs_pending
2023-05-25 12:55:23.460 CUL_HM HzReglerWZ_l_WindowRec commState: CMDs_pending
2023-05-25 12:55:23.464 CUL_HM HzReglerWZ_l_remote commState: CMDs_pending
2023-05-25 12:55:23.468 CUL_HM HzReglerWZ_l CMDs_pending
2023-05-25 12:55:23.472 CUL_HM HzReglerWZ_r_Climate controlMode: set_manual
2023-05-25 12:55:23.477 CUL_HM HzReglerWZ_r commState: CMDs_pending
2023-05-25 12:55:23.481 CUL_HM HzReglerWZ_r_Clima commState: CMDs_pending
2023-05-25 12:55:23.485 CUL_HM HzReglerWZ_r_ClimaTeam commState: CMDs_pending
2023-05-25 12:55:23.489 CUL_HM HzReglerWZ_r_Climate commState: CMDs_pending
2023-05-25 12:55:23.493 CUL_HM HzReglerWZ_r_Weather commState: CMDs_pending
2023-05-25 12:55:23.497 CUL_HM HzReglerWZ_r_WindowRec commState: CMDs_pending
2023-05-25 12:55:23.501 CUL_HM HzReglerWZ_r_remote commState: CMDs_pending
2023-05-25 12:55:23.505 CUL_HM HzReglerWZ_r CMDs_pending
2023-05-25 12:55:23.511 CUL_HM HzThermoWZ_Climate controlMode: set_manual
2023-05-25 12:55:23.515 CUL_HM HzThermoWZ commState: CMDs_pending
2023-05-25 12:55:23.520 CUL_HM HzThermoWZ_Climate commState: CMDs_pending
2023-05-25 12:55:23.523 CUL_HM HzThermoWZ_SwitchTr commState: CMDs_pending
2023-05-25 12:55:23.527 CUL_HM HzThermoWZ_Weather commState: CMDs_pending
2023-05-25 12:55:23.531 CUL_HM HzThermoWZ_WindowRec commState: CMDs_pending
2023-05-25 12:55:23.535 CUL_HM HzThermoWZ_remote commState: CMDs_pending
2023-05-25 12:55:23.539 CUL_HM HzThermoWZ CMDs_pending
2023-05-25 12:55:23.548 CUL_HM HzThermoWZ commState: CMDs_processing...
2023-05-25 12:55:23.552 CUL_HM HzThermoWZ_Climate commState: CMDs_processing...
2023-05-25 12:55:23.556 CUL_HM HzThermoWZ_SwitchTr commState: CMDs_processing...
2023-05-25 12:55:23.560 CUL_HM HzThermoWZ_Weather commState: CMDs_processing...
2023-05-25 12:55:23.564 CUL_HM HzThermoWZ_WindowRec commState: CMDs_processing...
2023-05-25 12:55:23.568 CUL_HM HzThermoWZ_remote commState: CMDs_processing...
2023-05-25 12:55:24.152 CUL_HM HzThermoWZ_Climate commState: CMDs_processing...
2023-05-25 12:55:24.152 CUL_HM HzThermoWZ_Climate trigLast: fhem:81
2023-05-25 12:55:24.156 CUL_HM HzThermoWZ_SwitchTr commState: CMDs_processing...
2023-05-25 12:55:24.160 CUL_HM HzThermoWZ_Weather commState: CMDs_processing...
2023-05-25 12:55:24.164 CUL_HM HzThermoWZ_WindowRec commState: CMDs_processing...
2023-05-25 12:55:24.168 CUL_HM HzThermoWZ_remote commState: CMDs_processing...
2023-05-25 12:55:24.217 CUL_HM HzThermoWZ_Climate trigLast: fhem:81
2023-05-25 12:55:24.341 CUL_HM HzThermoWZ commState: CMDs_done
2023-05-25 12:55:24.341 CUL_HM HzThermoWZ CMDs_done
2023-05-25 12:55:24.352 CUL_HM HzThermoWZ_Climate boostTime: -
2023-05-25 12:55:24.352 CUL_HM HzThermoWZ_Climate commReporting: off
2023-05-25 12:55:24.352 CUL_HM HzThermoWZ_Climate commState: CMDs_done
2023-05-25 12:55:24.352 CUL_HM HzThermoWZ_Climate controlMode: manual
2023-05-25 12:55:24.352 CUL_HM HzThermoWZ_Climate desired-temp: 21.5
2023-05-25 12:55:24.352 CUL_HM HzThermoWZ_Climate T: 22.1 desired: 21.5
2023-05-25 12:55:24.352 CUL_HM HzThermoWZ_Climate winOpenReporting: off
2023-05-25 12:55:24.356 CUL_HM HzThermoWZ_SwitchTr commState: CMDs_done
2023-05-25 12:55:24.360 CUL_HM HzThermoWZ_Weather commState: CMDs_done
2023-05-25 12:55:24.363 CUL_HM HzThermoWZ_WindowRec commState: CMDs_done
2023-05-25 12:55:24.367 CUL_HM HzThermoWZ_remote commState: CMDs_done
Wird der HM-CC-RT-DN nicht über ..._Clima umgestellt?
Gruß Hans-Jörg
FHEM auf RPI mit FS20, Homematic, ELERO, Zigbee, Eigenbau z.B. Heizölsensor auf Basis Arduino, Anemometer; Sprachsteuerung offline über vosk/Python
MadMax-FHEM
#1
Wie wäre es mit list der beteiligten Devices gewesen?
Siehe auch: https://forum.fhem.de/index.php?topic=71806.0
Zitat von: mabula am 25 Mai 2023, 13:28:31Wird der HM-CC-RT-DN nicht über ..._Clima umgestellt?
-> ja
Ein HM-TC-IT-WM-W-EU wird per "set NAME_Climate controlMode xxx" gestellt.
Ein HM-CC-RT-DN per "set NAME_Clima controlMode xxx".
Wie aktuell ist fhem?
Sind HM-CC-RT-DN und HM-TC-IT-WM-W-EU jeweils gepeert?
Wenn ja: welche Kanäle untereinander?
Wie hier: https://wiki.fhem.de/wiki/HM-TC-IT-WM-W-EU_Funk-Wandthermostat_AP bzw. hier:https://wiki.fhem.de/wiki/HM-CC-RT-DN_Funk-Heizk%C3%B6rperthermostat beschrieben?
Welches Kommando hast du per fhem abgesetzt?
Das hier:
Zitat von: mabula am 25 Mai 2023, 13:28:31set HzThermoWZ_Climate controlMode manual
Der WDT (wenn korrekt gepeert) gibt das dann an den HKT weiter, wenn dieser mal wieder aufwacht.
So (auch) meine Theorie...
EDIT: wobei es keinen Unterschied machen dürfte was der HKT für eine Einstellung hat, da, wenn korrekt gepeert, er eh nicht nach internen Mechanismen arbeitet (also weder Wochenprogramm noch was manuell eingestellt wird/wurde), da der WDT die SOLL-Temp vorgibt (der HKT versucht diese lediglich zu erreichen/zu halten)...
EDIT: auch wenn eine abweichende Anzeige unschön ist/wäre...
EDIT: eben getestet: setzen des Modus beim WDT -> HKT wird nicht weitergegeben (ich habe mal lange [ca. 10-15min] gewartet da ist nichts passiert / allerdings nach "Knöpfchen drücken" -> "Übertragung aktivieren" wurde es dann übertragen -> dauert dann ohne "Knöpfchen drücken" nur sehr, sehr lange [wie lange: ? ] / Modus wird wohl nicht so oft übertragen bzw. empfangen/ausgewertet) . Steuerungstechnisch auch nicht relevant. Für die Anzeige nat. unschön. Hat aber (wohl) nichts mit fhem zu tun, weil diese Übertragung muss ja "Homematic-intern" zwischen WDT und HKT über Peering erfolgen... Anders: setzen des Modus beim HKT -> wird an WDT weitergegeben (logisch, diese Richtung ist auch wichtig, weil die Vorgabe der IST-Temp ja über den WDT erfolgt / Anmerkung: WDT reagiert [bei mir] auch "sofort" auf "Eingaben" von fhem [und HKT], ich vermute, dass dort "Burst" aktiv ist [evtl. bei mir wegen gepeertem Fenster-Kontakt?] oder der WDT generell "aktiver" ist)...
EDIT: (kurze Rede, langer Sinn siehe oben ;)  ) bei mir tut es, wenn auch mit langen Wartezeiten (Annahme) und/oder "Knöpfchen drücken" (daher sollte es nach [langer] Wartezeit auch autom. passieren)...
EDIT: commStInCh bei den "Haupt-Devices" auf "off"?
Gruß, Joachim
FHEM PI3 Buster (Test)
mabula
Anbei das list von 2 Devices:
   .AttrList  .devInfo .mId .stc IODev IOgrp actCycle actStatus aesCommReq:1,0 aesKey:5,4,3,2,1,0 autoReadReg:0_off,1_restart,2_pon-restart,3_onChange,4_reqStatus,5_readMissing,8_stateOnly burstAccess:0_off,1_auto commStInCh:on,off do_not_notify:1,0 dummy:1,0 event-aggregator event-min-interval event-on-change-reading event-on-update-reading expert:multiple,defReg,allReg,rawReg,templ,none firmware hmKey hmKey2 hmKey3 hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger ignore:1,0 model modelForce:ACTIONDETECTOR,ACTIONDETECTOR,ASH550,ASH550I,CCU-FHEM,CMM,DORMA_ATENT,DORMA_BRC-H,DORMA_RC-H,HM-CC-RT-DN,HM-CC-RT-DN-BOM,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-DIS-EP-WM55,HM-DIS-TD-T,HM-DIS-WM55,HM-DW-WM,HM-ES-PMSW1-DR,HM-ES-PMSW1-PL,HM-ES-PMSW1-PL-DN-R1,HM-ES-PMSW1-PL-DN-R2,HM-ES-PMSW1-PL-DN-R3,HM-ES-PMSW1-PL-DN-R4,HM-ES-PMSW1-PL-DN-R5,HM-ES-PMSW1-SM,HM-ES-TX-WM,HM-HM-LC-DW-WM,HM-LC-AO-SM,HM-LC-BL1-FM,HM-LC-BL1-FM-2,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-BL1-SM-2,HM-LC-BL1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-CV-2,HM-LC-DIM1L-CV-644,HM-LC-DIM1L-PL,HM-LC-DIM1L-PL-2,HM-LC-DIM1L-PL-3,HM-LC-DIM1L-PL-644,HM-LC-DIM1PWM-CV,HM-LC-DIM1PWM-CV-2,HM-LC-DIM1T-CV,HM-LC-DIM1T-CV-2,HM-LC-DIM1T-CV-644,HM-LC-DIM1T-DR,HM-LC-DIM1T-FM,HM-LC-DIM1T-FM-2,HM-LC-DIM1T-FM-644,HM-LC-DIM1T-FM-LF,HM-LC-DIM1T-PL,HM-LC-DIM1T-PL-2,HM-LC-DIM1T-PL-3,HM-LC-DIM1T-PL-644,HM-LC-DIM1TPBU-FM,HM-LC-DIM1TPBU-FM-2,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2L-SM-2,HM-LC-DIM2L-SM-644,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM-2,HM-LC-JA1PBU-FM,HM-LC-RGBW-WM,HM-LC-SW1-BA-PCB,HM-LC-SW1-DR,HM-LC-SW1-FM,HM-LC-SW1-FM-2,HM-LC-SW1-PB-FM,HM-LC-SW1-PCB,HM-LC-SW1-PL,HM-LC-SW1-PL-3,HM-LC-SW1-PL-CT-R1,HM-LC-SW1-PL-CT-R2,HM-LC-SW1-PL-CT-R3,HM-LC-SW1-PL-CT-R4,HM-LC-SW1-PL-CT-R5,HM-LC-SW1-PL-DN-R1,HM-LC-SW1-PL-DN-R2,HM-LC-SW1-PL-DN-R3,HM-LC-SW1-PL-DN-R4,HM-LC-SW1-PL-DN-R5,HM-LC-SW1-PL-OM54,HM-LC-SW1-PL2,HM-LC-SW1-SM,HM-LC-SW1-SM-2,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW1PBU-FM,HM-LC-SW2-DR,HM-LC-SW2-DR-2,HM-LC-SW2-FM,HM-LC-SW2-FM-2,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW2PBU-FM,HM-LC-SW4-BA-PCB,HM-LC-SW4-DR,HM-LC-SW4-DR-2,HM-LC-SW4-PCB,HM-LC-SW4-PCB-2,HM-LC-SW4-SM,HM-LC-SW4-SM-2,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-SW4-WM-2,HM-MOD-EM-8,HM-MOD-EM-8BIT,HM-MOD-RE-8,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-CFM-TW,HM-OU-CM-PCB,HM-OU-LED16,HM-PB-2-FM,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-2-WM55-2,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PB-4DIS-WM-2,HM-PB-6-WM55,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-2-PBU-FM,HM-RC-2-PBU-FM-2,HM-RC-4,HM-RC-4-2,HM-RC-4-3,HM-RC-4-3-D,HM-RC-4-B,HM-RC-8,HM-RC-DIS-H-X-EU,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-KEY4-2,HM-RC-KEY4-3,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-RC-SEC4-2,HM-RC-SEC4-3,HM-SCI-3-FM,HM-SEC-CEN,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-MDIR-2,HM-SEC-MDIR-3,HM-SEC-RHS,HM-SEC-RHS-2,HM-SEC-SC,HM-SEC-SC-2,HM-SEC-SCO,HM-SEC-SD,HM-SEC-SD-2,HM-SEC-SFA-SM,HM-SEC-SIR-WM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WDS-2,HM-SEC-WIN,HM-SEN-DB-PCB,HM-SEN-EP,HM-SEN-LI-O,HM-SEN-MDIR-O,HM-SEN-MDIR-O-2,HM-SEN-MDIR-O-3,HM-SEN-MDIR-SM,HM-SEN-MDIR-WM55,HM-SEN-RD-O,HM-SEN-WA-OD,HM-SWI-3-FM,HM-SYS-SRP-PL,HM-TC-IT-WM-W-EU,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS100-C6-O-2,HM-WDS20-TH-O,HM-WDS30-OT2-SM,HM-WDS30-OT2-SM-2,HM-WDS30-T-O,HM-WDS40-TH-I,HM-WDS40-TH-I-2,HM-WS550,HM-WS550LCB,HM-WS550LCW,HM-WS550TECH,IS-WDS-TH-OD-S-R3,KFM-DISPLAY,KFM-SENSOR,KS550,KS550LC,KS550TECH,KS888,OLIGO-SMART-IQ-HM,PS-SWITCH,PS-TH-SENS,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FFK,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FSS-UP3,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-FZS,ROTO_ZEL-STG-RM-FZS-2,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,S550IA,SCHUECO_263-130,SCHUECO_263-131,SCHUECO_263-132,SCHUECO_263-133,SCHUECO_263-134,SCHUECO_263-135,SCHUECO_263-144,SCHUECO_263-145,SCHUECO_263-146,SCHUECO_263-147,SCHUECO_263-155,SCHUECO_263-157,SCHUECO_263-158,SCHUECO_263-160,SCHUECO_263-162,SCHUECO_263-167,SCHUECO_263-XXX,SENSOTIMER-ST-6,VIRTUAL,WDF-SOLAR,WS888 msgRepeat oldreadings param readOnly:0,1 readingOnDead:multiple,noChange,state,periodValues,periodString,channels rssiLog:1,0 serialNr showtime:1,0 stateFormat:textField-long subType:AlarmControl,KFM100,THSensor,blindActuator,blindActuatorSol,dimmer,display,keyMatic,motionAndBtn,motionDetector,no,outputUnit,powerMeter,powerSensor,pushButton,remote,repeater,rgb,senBright,sensRain,sensor,singleButton,siren,smokeDetector,swi,switch,thermostat,threeStateSensor,timer,tipTronic,virtual,winMatic timestamp-on-change-reading
   .triggerUsed 1
   DEF        657B9C
   FUUID      5f52897f-f33f-e4db-9fab-9e7f6e14ba0c76b3
   HMLANGW_MSGCNT 564
   HMLANGW_RAWMSG 0500003E248470657B9C00000000D532
   HMLANGW_RSSI -62
   HMLANGW_TIME 2023-05-25 15:51:48
   IODev      HMLANGW
   LASTInputDev hmusb
   MSGCNT     1128
   NAME       HzThermoWZ
   NR         566
   NTFY_ORDER 48-HzThermoWZ
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 HzThermoWZ_Weather
   channel_02 HzThermoWZ_Climate
   channel_03 HzThermoWZ_WindowRec
   channel_06 HzThermoWZ_remote
   channel_07 HzThermoWZ_SwitchTr
   disableNotifyFn 1
   eventCount 115
   hmusb_MSGCNT 564
   hmusb_RAWMSG E657B9C,0000,CEEBCAF7,FF,FFAF,248470657B9C00000000D532
   hmusb_RSSI -81
   hmusb_TIME 2023-05-25 15:51:48
   lastMsg    No:24 - t:70 s:657B9C d:000000 00D532
   protCmdDel 23
   protCondBurst on
   protLastRcv 2023-05-25 15:51:48
   protRcv    566 last_at:2023-05-25 15:51:48
   protResnd  3 last_at:2023-05-25 09:01:55
   protResndFail 2 last_at:2023-05-25 09:02:00
   protSnd    110 last_at:2023-05-25 13:38:47
   protSndB   17 last_at:2023-05-25 13:38:45
   protState  CMDs_done
   rssi_HMLANGW cnt:14 min:-65 max:-57 avg:-62.14 lst:-60
   rssi_at_HMLANGW cnt:564 min:-75 max:-58 avg:-66.02 lst:-62
   rssi_at_hmusb cnt:564 min:-103 max:-76 avg:-85.43 lst:-81
   .attraggr:
   .attreocr:
   .attrminint:
     2022-05-04 18:22:00   .R-btnLock      off
     2022-05-04 18:22:00   .R-burstRx      on
     2022-05-04 18:22:00   .R-cyclicInfoMsg on
     2022-05-04 18:22:00   .R-cyclicInfoMsgDis 0
     2022-05-04 18:22:00   .R-globalBtnLock off
     2022-05-04 18:22:00   .R-localResDis  off
     2023-03-14 07:30:40   .R-lowBatLimitRT 2.1 V
     2022-05-04 18:22:00   .R-modusBtnLock off
     2022-05-04 18:22:00   .R-pairCentral  0x117BAC
     2023-05-25 07:26:53   .associatedWith HzThermoWZ,HzThermoWZ_Climate,HzThermoWZ_SwitchTr,HzThermoWZ_Weather,HzThermoWZ_WindowRec,HzThermoWZ_remote,HzThermoWZ
     2023-05-25 15:51:48   .protLastRcv    20230525155148
     2023-05-25 07:36:22   Activity        alive
     2023-05-25 13:38:46   CommandAccepted yes
     2022-05-04 09:10:54   D-firmware      1.4
     2022-05-04 09:10:54   D-serialNr      OEQ2276306
     2023-05-25 13:38:45   IODev           HMLANGW
     2023-05-25 09:02:07   PairedTo        0x117BAC
     2023-05-25 09:02:07   RegL_00.         00:00 01:01 02:01 09:01 0A:11 0B:7B 0C:AC 0F:00 11:00 12:15 16:00 18:00 19:00 1A:00
     2023-05-25 15:33:45   battery         ok
     2023-05-25 15:33:45   batteryLevel    2.7
     2023-05-25 09:03:22   cfgState        ok
     2023-05-25 13:38:47   commState       CMDs_done
     2023-05-25 15:33:45   desired-temp    10.0
     2023-05-25 15:33:45   measured-temp   21.3
     2022-11-24 20:34:09   powerOn         2022-11-24 20:34:09
     2022-11-24 20:34:09   recentStateType info
     2023-05-25 13:38:47   state           CMDs_done
     2022-11-24 20:34:11   time-request    -
     2023-05-25 09:01:27   trigLast        fhem:80
     RegL_07.:
       VAL
   helper:
     HM_CMDNR   36
     PONtest    1
     cSnd       11117BAC657B9C810214,11117BAC657B9C810214
     cfgStateUpdt 0
     lastMsgTm  1685022708.8552
     mId        00AD
     peerFriend -
     peerOpt    -:thermostat
     regLst     0
     rxType     6
     supp_Pair_Rep 0
     ack:
     cmds:
       TmplKey    :no:1684992413.16959
       TmplTs     1684992413.16959
       cmdKey     0:1:0::HzThermoWZ:00AD:00:
       cmdLst:
         assignHmKey noArg
         clear      [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
         deviceRename -newName-
         fwUpdate   -filename- [-bootTime-]
         getConfig  noArg
         getDevInfo noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         inhibit    [(on|{off})]
         raw        -data- [...]
         regBulk    -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         reset      noArg
         sysTime    noArg
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         condition  slider,0,1,255
         peer
         peerOpt
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        0
       det        0
       raw        1
       tpl        0
     io:
       flgs       0
       newChn     +657B9C,00,01,00
       nextSend   1685022708.98109
       rxt        0
       vccu       VCCU
       p:
         657B9C
         00
         01
         00
       prefIO:
         HMLANGW
     mRssi:
       mNo        24
       io:
         HMLANGW:
           -58
           -58
         hmusb:
           -81
           -81
     peerIDsH:
     prt:
       awake      0
       bErr       0
       brstWu     0
       sProc      0
       tryMsg:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       dev        1
       prs        1
     rssi:
       HMLANGW:
         avg        -62.1428571428571
         cnt        14
         lst        -60
         max        -57
         min        -65
       at_HMLANGW:
         avg        -66.0283687943262
         cnt        564
         lst        -62
         max        -58
         min        -75
       at_hmusb:
         avg        -85.4361702127659
         cnt        564
         lst        -81
         max        -76
         min        -103
     shRegW:
       07         02
     shadowReg:
     tmpl:
   .mId       00AD
   IOgrp      VCCU:HMLANGW
   actCycle   000:30
   actStatus  alive
   aesCommReq 0
   autoReadReg 5_readMissing
   burstAccess 1_auto
   commStInCh off
   event-on-change-reading .*
   expert     rawReg
   firmware   1.4
   icon       sani_heating_temp@red
   model      HM-TC-IT-WM-W-EU
   msgRepeat  1
   room       CUL_HM,Heizung
   serialNr   OEQ2276306
   subType    thermostat
   .triggerUsed 1
   DEF        2E8BBA
   FUUID      5c449fad-f33f-e4db-4fc5-922e75db8b32bc2f
   HMLANGW_MSGCNT 453
   HMLANGW_RAWMSG 05000131A886102E8BBA0000000A50D50B0000
   HMLANGW_RSSI -49
   HMLANGW_TIME 2023-05-25 15:53:55
   IODev      HMLANGW
   LASTInputDev hmusb
   MSGCNT     927
   NAME       HzReglerWZ_l
   NR         547
   NTFY_ORDER 48-HzReglerWZ_l
   STATE      CMDs_pending
   TYPE       CUL_HM
   channel_01 HzReglerWZ_l_Weather
   channel_02 HzReglerWZ_l_Climate
   channel_03 HzReglerWZ_l_WindowRec
   channel_04 HzReglerWZ_l_Clima
   channel_05 HzReglerWZ_l_ClimaTeam
   channel_06 HzReglerWZ_l_remote
   disableNotifyFn 1
   eventCount 113
   hmusb_MSGCNT 474
   hmusb_RAWMSG E2E8BBA,0000,CEEDB872,FF,FFBD,A886102E8BBA0000000A50D50B0000
   hmusb_RSSI -67
   hmusb_TIME 2023-05-25 15:53:55
   lastMsg    No:A8 - t:10 s:2E8BBA d:000000 0A50D50B0000
   protCmdDel 14
   protCmdPend 2 CMDs_pending
   protCondBurst on
   protLastRcv 2023-05-25 15:53:55
   protRcv    464 last_at:2023-05-25 15:53:55
   protResnd  9 last_at:2023-05-25 13:01:08
   protResndFail 2 last_at:2023-05-25 13:01:14
   protSnd    271 last_at:2023-05-25 13:29:50
   protSndB   18 last_at:2023-05-25 13:29:41
   protState  CMDs_pending
   rssi_HMLANGW cnt:12 min:-57 max:-52 avg:-54.58 lst:-52
   rssi_at_HMLANGW cnt:453 min:-56 max:-48 avg:-51.22 lst:-49
   rssi_at_hmusb cnt:474 min:-75 max:-64 avg:-69.1 lst:-67
   .attraggr:
   .attreocr:
   .attrminint:
     2022-05-04 09:12:21   .R-backOnTime   10 s
     2022-05-04 09:12:21   .R-btnLock      off
     2022-05-04 09:12:21   .R-burstRx      on
     2022-05-04 09:12:21   .R-cyclicInfoMsg on
     2022-05-04 09:12:21   .R-cyclicInfoMsgDis 0
     2022-05-04 09:12:21   .R-globalBtnLock off
     2022-05-04 09:12:21   .R-localResDis  off
     2022-05-04 09:12:21   .R-lowBatLimitRT 2.1 V
     2022-05-04 09:12:21   .R-modusBtnLock off
     2022-05-04 09:12:21   .R-pairCentral  0x117BAC
     2023-05-25 07:26:53   .associatedWith HzReglerWZ_l,HzReglerWZ_l_Clima,HzReglerWZ_l_ClimaTeam,HzReglerWZ_l_Climate,HzReglerWZ_l_Weather,HzReglerWZ_l_WindowRec,HzReglerWZ_l_remote,HzReglerWZ_l
     2023-05-25 15:53:55   .protLastRcv    20230525155355
     2023-05-25 13:29:42   CommandAccepted yes
     2022-05-04 09:10:54   D-firmware      1.5
     2022-05-04 09:10:54   D-serialNr      LEQ0852117
     2023-05-25 13:29:41   IODev           HMLANGW
     2023-05-25 13:29:43   PairedTo        0x117BAC
     2023-05-25 13:29:43   RegL_00.         00:00 01:01 02:01 09:01 0A:11 0B:7B 0C:AC 0E:0A 0F:00 11:00 12:15 16:00 18:00 19:00 1A:00
     2023-05-25 15:53:55   actuator        0
     2023-05-25 15:53:55   battery         ok
     2023-05-25 15:53:55   batteryLevel    2.6
     2023-05-25 13:30:51   cfgState        ok
     2023-05-25 13:38:45   commState       CMDs_pending
     2023-05-25 15:53:55   desired-temp    10.0
     2023-05-25 15:53:55   measured-temp   21.3
     2023-05-25 15:53:55   motorErr        ok
     2023-05-25 13:38:45   state           CMDs_pending
     2023-05-25 02:17:11   time-request    -
     RegL_07.:
       VAL
   cmdStack:
     ++A011117BAC2E8BBA810214
   helper:
     HM_CMDNR   168
     PONtest    1
     cSnd       01117BAC2E8BBA030435C26B0103,01117BAC2E8BBA030435C26B0107
     cfgStateUpdt 0
     lastMsgTm  1685022835.18451
     mId        0095
     peerFriend -
     regLst     0
     rxType     140
     supp_Pair_Rep 0
     ack:
     cmds:
       TmplKey    :no:1684992413.0538
       TmplTs     1684992413.0538
       cmdKey     0:1:0::HzReglerWZ_l:0095:00:
       cmdLst:
         assignHmKey noArg
         burstXmit  noArg
         getConfig  noArg
         getDevInfo noArg
         raw        -data- [...]
         reset      noArg
         sysTime    noArg
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         peer
         peerOpt
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     expert:
       def        0
       det        0
       raw        1
       tpl        0
     io:
       flgs       0
       newChn     +2E8BBA,00,01,00
       nextSend   1685022835.31867
       rxt        2
       vccu       VCCU
       p:
         2E8BBA
         00
         01
         00
       prefIO:
     mRssi:
       mNo        A8
       io:
         HMLANGW:
           -41
           -41
         hmusb:
           -67
           -67
     peerIDsH:
     prt:
       awake      0
       bErr       0
       brstWu     1
       sProc      2
       tryMsg:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       dev        1
       prs        1
     rssi:
       HMLANGW:
         avg        -54.5833333333333
         cnt        12
         lst        -52
         max        -52
         min        -57
       at_HMLANGW:
         avg        -51.2295805739514
         cnt        453
         lst        -49
         max        -48
         min        -56
       at_hmusb:
         avg        -69.1097046413502
         cnt        474
         lst        -67
         max        -64
         min        -75
     shRegW:
       07         04
     shadowReg:
     tmpl:
   .mId       0095
   IOgrp      VCCU
   actCycle   000:30
   actStatus  alive
   aesCommReq 0
   burstAccess 1_auto
   expert     rawReg
   firmware   1.5
   icon       sani_heating@red
   model      HM-CC-RT-DN
   room       CUL_HM,Heizung
   serialNr   LEQ0852117
   subType    thermostat
   webCmd     getConfig:clear msgEvents:burstXmit
Zitat von: MadMax-FHEM am 25 Mai 2023, 13:58:59Wie aktuell ist fhem?
Fhem ist aktuell.
Zitat von: MadMax-FHEM am 25 Mai 2023, 13:58:59Sind HM-CC-RT-DN und HM-TC-IT-WM-W-EU jeweils gepeert?
Ja, gemäß Wiki.
Zitat von: MadMax-FHEM am 25 Mai 2023, 13:58:59EDIT: commStInCh bei den "Haupt-Devices" auf "off"?
Sind hier sowohl Thermostat und Regler gemeint?
Bei mir hat sich binnen 2 Stunden nichts getan, nur ein händisches getConfig der Regler bringt das Ergebniss. Dies war früher nicht so. Seit wann kann ich nicht sagen, da das Wetter bisher bescheiden war und ich nicht umgeschaltet habe.
Gruß Hans-Jörg
MadMax-FHEM
Zitat von: mabula am 25 Mai 2023, 16:12:11
Alle Haupt-Devices vom TYP CUL_HM.
Musst du mal im Forum suchen, da gibt es auch einen "Einzeiler" für FhemWeb, der das dann für alle Devices macht.
Naja: list ok es fehlen halt die Kanäle ;) Zumindest die auf die es ankäme ;)
Zitat von: mabula am 25 Mai 2023, 16:12:11Bei mir hat sich binnen 2 Stunden nichts getan, nur ein händisches getConfig der Regler bringt das Ergebniss. Dies war früher nicht so. Seit wann kann ich nicht sagen, da das Wetter bisher bescheiden war und ich nicht umgeschaltet habe.
Hmm, evtl. werfe ich das noch mal an.
Wobei wie geschrieben: reine optische Geschichte. Wichtiger ist, dass eine Änderung am HKT an das WDT geht...
Allerdings kann ich grad nicht und ab morgen bin ich erst mal weg... :-\
Aber vielleicht schaut ja noch jemand vorbei und hat noch eine Idee...
Gruß, Joachim
mabula
Danke für die Unterstützung. In der Peer list für ..._Weather hat sich eine falsche ID eingeschlichen.
Gruß Hans-Jörg
MadMax-FHEM
Zitat von: mabula am 25 Mai 2023, 16:46:16Danke für die Unterstützung. In der Peer list für ..._Weather hat sich eine falsche ID eingeschlichen.
Gruß Hans-Jörg
Aber nur die Peerlist anpassen ändert nichts!
Das sind "nur" die Werte, die fhem aus dem Gerät gelesen hat.
Wenn da was nicht stimmt, dann muss das Peering der Geräte angepasst/geändert/erneuert werden.
Ich werd's die Tage trotzdem bei mir noch mal ausprobieren... ;)
Gruß, Joachim
mabula
#6
Habe den WDT und HKT auf Werkseinstellungen zurückgesetzt und neu eingerichtet. Das Peering zeigt keine fakes mehr.
receive
       HzReglerKu_Climate    =>  HzThermoKu_Climate
       HzReglerKu_Weather    =>  HzThermoKu_Weather
       HzReglerWZ_l_Clima    =>  HzReglerWZ_r_ClimaTeam
       HzReglerWZ_l_ClimaTeam  =>  HzReglerWZ_r_Clima
       HzReglerWZ_l_Climate  =>  HzThermoWZ_Climate
       HzReglerWZ_l_Weather  =>  HzThermoWZ_Weather
       HzReglerWZ_r_Clima    =>  HzReglerWZ_l_ClimaTeam
       HzReglerWZ_r_ClimaTeam  =>  HzReglerWZ_l_Clima
       HzReglerWZ_r_Climate  =>  HzThermoWZ_Climate
       HzReglerWZ_r_Weather  =>  HzThermoWZ_Weather
       HzThermoKu_Climate    =>  HzReglerKu_Climate
       HzThermoKu_Weather    =>  HzReglerKu_Weather
       HzThermoWZ_Climate    =>  HzReglerWZ_l_Climate HzReglerWZ_r_Climate
       HzThermoWZ_Weather    =>  HzReglerWZ_l_Weather HzReglerWZ_r_Weather
Das Thema mit den pending commands am HKT nach ändern des controlMode (manual/auto) am WDT bleibt, die über mehrere Stunden hängen können. Die Soll-Temperatur wird vom WDT, wie du schon geschrieben hast, zügig übermittelt und zum Regel verwendet. Somit ist es mehr ein kosmetisches Problem und hat keine Eile.
Genieße den Urlaub!!!
Gruß Hans-Jörg
frank
FHEM: 6.0(SVN) => Pi3(buster)
oelidoc
Zitat von: frank am 29 Mai 2023, 19:25:55https://forum.fhem.de/index.php?topic=132954.0
Leider gibt es zu dem (kosmetischen) Problem noch keine Lösung - obwohl in meinem Thread schon verschiedene Dinge angedacht worden sind.
Vielleicht findet sich ja doch noch jemand, der sich des Problems mittels Update annimmt.
oelidoc
frank
noansi stellt eigene culhm versionen in seinem tscul thread zur verfügung.
vermutlich ist der fix dort eingebaut.
ohne rt/tc habe ich keine möglichkeit den vorschlagp zu testen.
