FS20+Homematic devices on CUL
Begonnen von spuzvica, 18 Dezember 2013, 08:18:55
spuzvica
as I understand, FS20 use the SlowRF rfmode and Homematic use the Homematic one, right? Does that mean that it is not possible to control a mix of FS20/FHT + Homematic devices in a single system (I use Raspberry + busware COC module)?
Thanks
Rok
hexenmeister
ZitatFS20 use the SlowRF rfmode and Homematic use the Homematic one, right?
yes
Zitatit is not possible to control a mix of FS20/FHT + Homematic devices in a single system
yes. this does not work. you need two transmitters.
Best regards
Alexander
Maintainer: MQTT_GENERIC_BRIDGE, SYSMON, SMARTMON, systemd_watchdog, MQTT, MQTT_DEVICE, MQTT_BRIDGE
Contrib: dev_proxy
spuzvica
