Revision 19354: mqtt2.template: tasmota-rgb-led - add Dimmer set option
Source: Revision 19354: mqtt2.template: tasmota-rgb-led - add Dimmer set option (http://svn.fhem.de/trac/changeset/19354/trunk)
