Arduino schaltet automatisch
Begonnen von x347, 15 Mai 2016, 13:08:38
x347
ich habe einen Arduino uno mit Ethernet Shield und ein 4 Relay Modul.
Es scheint soweit alles zu funktionieren, ich kann sogar die Ausgänger über FHEM ansteuern. Allerdings schaltet der Arduino alle paar Sekunden automatisch alle 4 definierten Ausgänge und ich weiß nicht warum!
Kann einer Helfen?
* Firmata is a generic protocol for communicating with microcontrollers
* from software on a host computer. It is intended to work with
* any host computer software package.
* To download a host software package, please click on the following link
* to open the download page in your default browser.
* http://firmata.org/wiki/Download
  Copyright (C) 2006-2008 Hans-Christoph Steiner.  All rights reserved.
  Copyright (C) 2010-2011 Paul Stoffregen.  All rights reserved.
  Copyright (C) 2009 Shigeru Kobayashi.  All rights reserved.
  Copyright (C) 2009-2013 Jeff Hoefs.  All rights reserved.
  Copyright (C) 2013 Norbert Truchsess. All rights reserved.
  Copyright (C) 2014 Nicolas Panel. All rights reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  See file LICENSE.txt for further informations on licensing terms.
  formatted using the GNU C formatting and indenting
#include <Firmata.h>
* by default Firmata uses the Serial-port (over USB) of Arduino.
* ConfigurableFirmata may also comunicate over ethernet using tcp/ip.
* To configure this 'Network Firmata' to use the original WIZ5100-based
* ethernet-shield or Arduino Ethernet uncomment the includes of 'SPI.h' and 'Ethernet.h':
#include <SPI.h>
#include <Ethernet.h>
* To configure 'Network Firmata' to use an ENC28J60 based board include
* 'UIPEthernet.h' (no SPI.h required). The UIPEthernet-library can be downloaded
//#include <UIPEthernet.h>
* To execute Network Firmata on Yun uncomment Bridge.h and YunClient.h.
* Do not include Ethernet.h or SPI.h in this case.
* On Yun there's no need to configure local_ip and mac in the sketch
* as this is configured on the linux-side of Yun.
//#include <Bridge.h>
//#include <YunClient.h>
#if defined ethernet_h || defined UIPETHERNET_H || defined _YUN_CLIENT_H_
* Network configuration for Network Firmata
#define NETWORK_FIRMATA
//replace with ip of server you want to connect to, comment out if using 'remote_host'
#define remote_ip IPAddress(192,168,178,190)
//replace with hostname of server you want to connect to, comment out if using 'remote_ip'
//#define remote_host "server.local"
//replace with the port that your server is listening on
#define remote_port 3030
//replace with arduinos ip-address. Comment out if Ethernet-startup should use dhcp. Is ignored on Yun
#define local_ip IPAddress(192,168,178,241)
//replace with ethernet shield mac. It's mandatory every device is assigned a unique mac. Is ignored on Yun
const byte mac[] = {0x90, 0xA2, 0xDA, 0x0D, 0x07, 0x02};
#endif
// To configure, save this file to your working directory so you can edit it
// then comment out the include and declaration for any features that you do
// not need below.
// Also note that the current compile size for an Arduino Uno with all of the
// following features enabled is about 22.4k. If you are using an older Arduino
// or other microcontroller with less memory you will not be able to include
// all of the following feature classes.
//#include <utility/DigitalInputFirmata.h>
//DigitalInputFirmata digitalInput;
#include <utility/DigitalOutputFirmata.h>
DigitalOutputFirmata digitalOutput;
//#include <utility/AnalogInputFirmata.h>
//AnalogInputFirmata analogInput;
//#include <utility/AnalogOutputFirmata.h>
//AnalogOutputFirmata analogOutput;
//#include <Servo.h> //wouldn't load from ServoFirmata.h in Arduino1.0.3
//#include <utility/ServoFirmata.h>
//ServoFirmata servo;
//#include <Wire.h> //wouldn't load from I2CFirmata.h in Arduino1.0.3
//#include <utility/I2CFirmata.h>
//I2CFirmata i2c;
//#include <utility/OneWireFirmata.h>
//OneWireFirmata oneWire;
//#include <utility/StepperFirmata.h>
//StepperFirmata stepper;
//#include <utility/FirmataExt.h>
//FirmataExt firmataExt;
//#include <utility/FirmataScheduler.h>
//FirmataScheduler scheduler;
//#include <utility/EncoderFirmata.h>
//EncoderFirmata encoder;
// dependencies. Do not comment out the following lines
#if defined AnalogOutputFirmata_h || defined ServoFirmata_h
#include <utility/AnalogWrite.h>
#endif
#if defined AnalogInputFirmata_h || defined I2CFirmata_h || defined EncoderFirmata_h
#include <utility/FirmataReporting.h>
FirmataReporting reporting;
#endif
// dependencies for Network Firmata. Do not comment out.
#ifdef NETWORK_FIRMATA
#if defined remote_ip && defined remote_host
#error "cannot define both remote_ip and remote_host at the same time!"
#endif
#include <utility/EthernetClientStream.h>
#ifdef _YUN_CLIENT_H_
YunClient client;
#else
EthernetClient client;
#endif
#if defined remote_ip && !defined remote_host
#ifdef local_ip
EthernetClientStream stream(client, local_ip, remote_ip, NULL, remote_port);
#else
EthernetClientStream stream(client, IPAddress(0, 0, 0, 0), remote_ip, NULL, remote_port);
#endif
#endif
#if !defined remote_ip && defined remote_host
#ifdef local_ip
EthernetClientStream stream(client, local_ip, IPAddress(0, 0, 0, 0), remote_host, remote_port);
#else
EthernetClientStream stream(client, IPAddress(0, 0, 0, 0), IPAddress(0, 0, 0, 0), remote_host, remote_port);
#endif
#endif
#endif
* FUNCTIONS
void systemResetCallback()
  // initialize a defalt state
  // pins with analog capability default to analog input
  // otherwise, pins default to digital output
  for (byte i = 0; i < TOTAL_PINS; i++) {
    if (IS_PIN_ANALOG(i)) {
#ifdef AnalogInputFirmata_h
      // turns off pullup, configures everything
      Firmata.setPinMode(i, ANALOG);
#endif
    } else if (IS_PIN_DIGITAL(i)) {
#ifdef DigitalOutputFirmata_h
      // sets the output to 0, configures portConfigInputs
      Firmata.setPinMode(i, OUTPUT);
#endif
#ifdef FirmataExt_h
  firmataExt.reset();
#endif
* SETUP()
void setup()
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
  Bridge.begin();
#else
#ifdef local_ip
  Ethernet.begin((uint8_t *)mac, local_ip); //start ethernet
#else
  Ethernet.begin((uint8_t *)mac); //start ethernet using dhcp
#endif
#endif
  delay(1000);
#endif
  Firmata.setFirmwareVersion(FIRMATA_MAJOR_VERSION, FIRMATA_MINOR_VERSION);
  /* analogWriteCallback is declared in AnalogWrite.h */
  Firmata.attach(ANALOG_MESSAGE, analogWriteCallback);
#endif
#ifdef FirmataExt_h
#ifdef DigitalInputFirmata_h
  firmataExt.addFeature(digitalInput);
#endif
  firmataExt.addFeature(digitalOutput);
#endif
  firmataExt.addFeature(analogInput);
#endif
#ifdef AnalogOutputFirmata_h
  firmataExt.addFeature(analogOutput);
#endif
#ifdef ServoFirmata_h
  firmataExt.addFeature(servo);
#endif
#ifdef I2CFirmata_h
  firmataExt.addFeature(i2c);
#endif
#ifdef OneWireFirmata_h
  firmataExt.addFeature(oneWire);
#endif
#ifdef StepperFirmata_h
  firmataExt.addFeature(stepper);
#endif
#ifdef FirmataReporting_h
  firmataExt.addFeature(reporting);
#endif
#ifdef FirmataScheduler_h
  firmataExt.addFeature(scheduler);
#endif
#ifdef EncoderFirmata_h
  firmataExt.addFeature(encoder);
#endif
#endif
  /* systemResetCallback is declared here (in ConfigurableFirmata.ino) */
  Firmata.attach(SYSTEM_RESET, systemResetCallback);
  // Network Firmata communicates with Ethernet-shields over SPI. Therefor all
  // SPI-pins must be set to IGNORE. Otherwise Firmata would break SPI-communication.
  // add Pin 10 and configure pin 53 as output if using a MEGA with Ethernetshield.
  // No need to ignore pin 10 on MEGA with ENC28J60, as here pin 53 should be connected to SS:
  // ignore SPI and pin 4 that is SS for SD-Card on Ethernet-shield
    if (IS_PIN_SPI(i)
        || 4 == i
        // || 10==i //explicitly ignore pin 10 on MEGA as 53 is hardware-SS but Ethernet-shield uses pin 10 for SS
      Firmata.setPinMode(i, IGNORE);
  pinMode(PIN_TO_DIGITAL(6), OUTPUT);
  pinMode(PIN_TO_DIGITAL(7), OUTPUT);
  pinMode(PIN_TO_DIGITAL(8), OUTPUT);
  pinMode(PIN_TO_DIGITAL(9), OUTPUT);
  digitalWrite(PIN_TO_DIGITAL(6), LOW);
  digitalWrite(PIN_TO_DIGITAL(7), LOW);
  digitalWrite(PIN_TO_DIGITAL(8), LOW);
  digitalWrite(PIN_TO_DIGITAL(9), LOW);
  //  pinMode(PIN_TO_DIGITAL(53), OUTPUT); configure hardware-SS as output on MEGA
  pinMode(PIN_TO_DIGITAL(4), OUTPUT); // switch off SD-card bypassing Firmata
  digitalWrite(PIN_TO_DIGITAL(4), HIGH); // SS is active low;
  // start up Network Firmata:
  Firmata.begin(stream);
#else
  // start up the default Firmata using Serial interface:
  Firmata.begin(57600);
#endif
  systemResetCallback();  // reset to default config
* LOOP()
void loop()
  /* DIGITALREAD - as fast as possible, check for changes and output them to the
   * stream buffer using Firmata.write()  */
  digitalInput.report();
#endif
  /* STREAMREAD - processing incoming messagse as soon as possible, while still
   * checking digital inputs.  */
  while (Firmata.available()) {
    Firmata.processInput();
    if (!Firmata.isParsingMessage()) {
      goto runtasks;
runtasks: scheduler.runTasks();
#endif
  /* SEND STREAM WRITE BUFFER - TO DO: make sure that the stream buffer doesn't go over
   * 60 bytes. use a timer to sending an event character every 4 ms to
   * trigger the buffer to dump. */
  if (reporting.elapsed()) {
    /* ANALOGREAD - do all analogReads() at the configured sampling interval */
    analogInput.report();
#endif
#ifdef I2CFirmata_h
    // report i2c data for all device with read continuous mode enabled
    i2c.report();
#endif
    // report encoders positions if reporting enabled.
    encoder.report();
#endif
#endif
  stepper.update();
#endif
#if defined NETWORK_FIRMATA && !defined local_ip &&!defined _YUN_CLIENT_H_
  if (Ethernet.maintain())
    stream.maintain(Ethernet.localIP());
#endif
in FHEM, habe ich folgendes definiert:
define FIRMATA FRM 3030 global
attr FIRMATA sampling-interval 1000
#attr FIRMATA sampling-interval 3000
#attr FIRMATA loglevel 6
#Wert ist in ms und 14Bit breit, also nur bis 16384 setzbar (Beschränkung des Firmata-protokolls) - gilt für alle Pins
define Firmata_OUT_6 FRM_OUT 6 # definiert Arduino Pin 6 als digitalen Ausgang
attr Firmata_OUT_6 IODev FIRMATA
define Firmata_OUT_7 FRM_OUT 7 # definiert Arduino Pin 7 als digitalen Ausgang
attr Firmata_OUT_7 IODev FIRMATA
define Firmata_OUT_8 FRM_OUT 8 # definiert Arduino Pin 8 als digitalen Ausgang
attr Firmata_OUT_8 IODev FIRMATA
define Firmata_OUT_9 FRM_OUT 9 # definiert Arduino Pin 9 als digitalen Ausgang
attr Firmata_OUT_9 IODev FIRMATA
Vielen Dank für eure Unterstützung
Alex
