Fehler bei ESPeasy
Begonnen von eisman, 30 März 2022, 10:45:05
eisman
Log:
2022.03.30 10:34:12 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/34_ESPEasy.pm line 2528.
2022.03.30 10:34:12 1: stacktrace:
2022.03.30 10:34:12 1:     main::__ANON__                      called by ./FHEM/34_ESPEasy.pm (2528)
2022.03.30 10:34:12 1:     main::ESPEasy_isCmdAvailable        called by ./FHEM/34_ESPEasy.pm (760)
2022.03.30 10:34:12 1:     main::ESPEasy_Set                   called by fhem.pl (3934)
2022.03.30 10:34:12 1:     main::CallFn                        called by fhem.pl (1948)
2022.03.30 10:34:12 1:     main::DoSet                         called by fhem.pl (1990)
2022.03.30 10:34:12 1:     main::CommandSet                    called by fhem.pl (2869)
2022.03.30 10:34:12 1:     main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3296)
2022.03.30 10:34:12 1:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (3189)
2022.03.30 10:34:12 1:     main::FW_Notify                     called by fhem.pl (3934)
2022.03.30 10:34:12 1:     main::CallFn                        called by fhem.pl (3846)
2022.03.30 10:34:12 1:     main::DoTrigger                     called by fhem.pl (4231)
2022.03.30 10:34:12 1:     main::Dispatch                      called by ./FHEM/34_ESPEasy.pm (1642)
2022.03.30 10:34:12 1:     main::ESPEasy_dispatch              called by ./FHEM/34_ESPEasy.pm (1109)
2022.03.30 10:34:12 1:     main::ESPEasy_Read                  called by fhem.pl (3934)
2022.03.30 10:34:12 1:     main::CallFn                        called by fhem.pl (781)
Device:
   CONNECTS   242
   DEF        bridge 8383
   FD         55
   FUUID      5f680b7d-f33f-793a-98f8-dce6bd3fd638228a
   HOST       bridge
   IPV        4
   MAX_HTTP_SESSIONS 3
   MAX_QUEUE_SIZE 250
   NAME       espBridge
   NOTIFYDEV  global
   NR         27
   NTFY_ORDER 50-espBridge
   PORT       8383
   STATE      Initialized
   SUBTYPE    bridge
   TYPE       ESPEasy
   VERSION    2.18
     2022-03-30 10:34:25   state           Initialized
   helper:
     maxCmdDuration:
       192.168.xxx.xxx 1
       192.168.xxx.xxx 1
     pm:
       Encode     1
       JSON       1
     sessions:
       192.168.xxx.xxx 0
       192.168.xxx.xxx 0
   alias      Bridge
   allowedIPs .*
   authentication 0
   combineDevices 1
   devStateStyle style="text-align:right;"
   group      Bridge
   room       device-ESP
   verbose    0
mfg
1x FHEM Debian, Homematic,ZigBee,FS20 / 1X Raspberry, ConBee / 5x ESP
1x FHEM Debian, Homematic,ZigBee         / 1X Raspberry, ConBee / 5x ESP
1x FHEM Debian,MQTT                               / 1X Raspberry, i2c,onewire,gpio
1x auf Windows 2012 Hyper-V-S
Skusi
ich habe genau dasselbe Problem und finde einfach nicht den Fehler.
Kann hier jemand einen Tipp geben ?
Gruß Holger
HP ThinClient 630, SIGNALduino, NanoCul868 (a-culfw), JeeLink Clone (LaCrosse), Firmata  für FB Heizung,Wasser+Gas+Klingel+Lux, Somfy Rolladen, Pollin Steckd.,TX29DTH,Tasmota+IR Lesekopf an Stromz., MAX Fensterkontakte, IButton, Fingerprint, SonOff Tasmota, ESP LED Controler, WLed,zigbee2mqtt...
