Neuigkeiten:
Am Sonntag den 8.12.2024 kann es ab ca. 8:00 Uhr zu kurzzeitigen Einschränkungen / Ausfällen bei den Diensten des FHEM Vereines kommen.
Die Server müssen mal gewartet und dabei neu gestartet werden ;)
test: modul zu integration von mercedes benz byocar daten
Begonnen von justme1968, 13 August 2020, 12:48:49
Heuberg
Ja, bei mir funktionieren die Tankanzeige (Reichweite und Füllmenge) problemlos
HM, MAX, MySensors, Fronius, Conbee II, ZigBee, VCONTROL, Modbus, RPi, AVM
Docter
Klasse Sache. Danke für das coole Modul.
... läuft bei mir nun auch.
sieht man unter Umständen auch mehr Readings, wenn man mehr Services hat?
ist GPS Position wäre ganz spannend für mich.
Persuasiv
Zukünftig gibt es wohl auch wieder eine Umstellung der API.
ZitatNeed for action: we are modernizing our technical platform
Dear Customers, Dear Developers and Digital Enthusiasts,
An important rearrangement is coming up to you: we are about to renew our API management platform. With the new platform, we are positioning ourselves for the future and will be able to offer our services in an even more stable and secure manner.
What does this mean to you and your product subscriptions?
You will soon need to make changes to your applications/projects that use our API key and OAuth-protected products. This will require, for example, adjustments to the API and OAuth endpoints of your applications.
https://eeerex.stripocdn.email/content/guids/CABINET_339c28c85b86dda6ff98592d66045502/images/05_uvq.png
Our request: at the beginning of July 2022 we will send you precise instructions to ensure that your affected applications continue to work. Prepare to use the upcoming instructions, because after the migration phase, your today's credentials will no longer be valid. That means you would loose access to these API products. So on your part, please plan some effort between the beginning of August and the beginning of November 2022.
Stay tuned for the upcoming instructions. We'll get in touch.
riogrande75
Zitat von: Persuasiv am 24 April 2022, 14:13:38
Bei mir geht seit dem 14.04. die Tankanzeige (Reichweite und Füllmenge) nicht mehr. Mein Me-Abo ist aber auch schon seit 1+ Jahr abgelaufen. Geht die Anzeige bei euch noch? Die Kilometeranzahl bzw. die Türen und Fenster gehen noch.
Bei mir ist auch seit 05.06. Schluss. "rangeelectric" wird noch upgedatet, "soc" nicht mehr.
Chris8888
Bei mir werden beide Fahrzeuge sauber angezeigt.
FHEM 6.0 auf einem PI4 mit div. Homematic-Komponenten, Alexa, Tablet-UI und Homebridge...und läuft einfach. Erweitert mit CCU3 und Homematic-IP...und läuft immer noch.
Persuasiv
Meine Anzeige funktioniert wieder. Ich habe keine Änderungen vorgenommen.
Docter
bei mir blieb zuerst der ODO stehen, jetzt kommen gar keine Daten mehr...
refresh token: 400 invalid_grant:unknown, invalid, or expired refresh token
Schade...
Docter
jetzt muss ich nochmal dumm fragen...
Funzt bei euch die Schnittstelle?
Hab alles neu eingerichtet, aber bekomme immer wieder den 500er Fehler.
Persuasiv
Docter
Asche auf mein Haupt...
Nachdem er sich wirklich nicht mehr upgedatet hatte, habe ich alles neu aufgesetzung und dabei wohl einen Zahlerdreher in der VIN gehabt.
Läuft wieder, Danke!
Chris8888
gab es ein Update? ich habe einige neue Readings...
Persuasiv
Ggf. erscheinen die nur, wenn man es auch bedient. Bei mir tauchen die Readings nicht auf ...
aikawa24
wie oft wird denn mit dem polls Attribut das Ausgewählte aktualisiert?
Persuasiv
Ich bekomme seit dem 1.10. alle zwei Minuten folgende Fehlermeldung:
Zitatunknown HttpAnswer: 500 {"errorMessage": "Internal Server Error", "statusCode": "500"}
Tritt das Problem nur bei mir auf? Ich habe zwischenzeitlich keine Veränderungen durchgeführt.
riogrande75
Ich leider auch  :(
Obowohl Token passt und lt. Byocar Website alle Services da sind.
Aber dass das Zeug instabil wie Sau ist, ist ja mittlerweile bekannt.
