warnings seit heute in den plots ...
Begonnen von the ratman, 05 November 2016, 14:08:21
the ratman
jaja, ich weiß: nicht schlimm usw. - trotzdem:
2016.11.05 12:17:39 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at (eval 835) line 1.
2016.11.05 12:17:39 1: eval: { "$data{currval1} °C ($data{currval4} °C)/ $data{currval2} mBar" }
2016.11.05 12:17:39 1: stacktrace:
2016.11.05 12:17:39 1:     main::__ANON__                      called by (eval 835) (1)
2016.11.05 12:17:39 1:     (eval)                              called by fhem.pl (1007)
2016.11.05 12:17:39 1:     main::AnalyzePerlCommand            called by fhem.pl (1026)
2016.11.05 12:17:39 1:     main::AnalyzeCommand                called by ./FHEM/98_SVG.pm (828)
2016.11.05 12:17:39 1:     main::SVG_substcfg                  called by ./FHEM/98_SVG.pm (1133)
2016.11.05 12:17:39 1:     main::SVG_doShowLog                 called by ./FHEM/98_SVG.pm (1020)
2016.11.05 12:17:39 1:     main::SVG_showLog                   called by ./FHEM/01_FHEMWEB.pm (755)
2016.11.05 12:17:39 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (456)
2016.11.05 12:17:39 1:     main::FW_Read                       called by fhem.pl (3261)
2016.11.05 12:17:39 1:     main::CallFn                        called by fhem.pl (672)
2016.11.05 12:17:40 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at (eval 837) line 1.
2016.11.05 12:17:40 1: eval: { "Temp. $data{currval1} °C (min $data{min1} °C | max $data{max1} °C) / Taup. $data{currval4} °C / Feuchte $data{currval2} %" }
2016.11.05 12:17:40 1: stacktrace:
2016.11.05 12:17:40 1:     main::__ANON__                      called by (eval 837) (1)
2016.11.05 12:17:40 1:     (eval)                              called by fhem.pl (1007)
2016.11.05 12:17:40 1:     main::AnalyzePerlCommand            called by fhem.pl (1026)
2016.11.05 12:17:40 1:     main::AnalyzeCommand                called by ./FHEM/98_SVG.pm (828)
2016.11.05 12:17:40 1:     main::SVG_substcfg                  called by ./FHEM/98_SVG.pm (1133)
2016.11.05 12:17:40 1:     main::SVG_doShowLog                 called by ./FHEM/98_SVG.pm (1020)
2016.11.05 12:17:40 1:     main::SVG_showLog                   called by ./FHEM/01_FHEMWEB.pm (755)
2016.11.05 12:17:40 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (456)
2016.11.05 12:17:40 1:     main::FW_Read                       called by fhem.pl (3261)
2016.11.05 12:17:40 1:     main::CallFn                        called by fhem.pl (672)
info: der onkel hat die dinger ohne warnings teils seit monaten am laufen.
→do↑p!dnʇs↓shit←
Kannst du dazu bitte die Daten anzeigen?
Kommen sie aus DbLog oder FileLog?
the ratman
gern - hier die lists der beiden betroffenen:
   DEF        logdb:SVG_Sensor_Schlafzimmer_log_1:CURRENT
   GPLOTFILE  SVG_Sensor_Schlafzimmer_log_1
   LOGDEVICE  logdb
   LOGFILE    CURRENT
   NAME       SVG_Sensor_Schlafzimmer_1
   NOTIFYDEV  global
   NR         406
   STATE      initialized
   TYPE       SVG
   captionLeft 1
   dblogexclude .*
   endPlotNow 1
   fp_Schlafzimmer 1205,-5,0, ,SVG_Sensor_Schlafzimmer_1
   group      InfoPlot
   label      "$data{currval1} °C ($data{currval4} °C)/ $data{currval2} mBar"
   plotsize   1200,300
   room       Netatmo
   DEF        logdb:SVG_Sensor_Treibhaus2_6Stunden:HISTORY
   GPLOTFILE  SVG_Sensor_Treibhaus2_6Stunden
   LOGDEVICE  logdb
   LOGFILE    HISTORY
   NAME       SVG_Sensor_Treibhaus2_6Stunden
   NOTIFYDEV  global
   NR         419
   STATE      initialized
   TYPE       SVG
   DbLogExclude .*
   captionLeft 1
   endPlotNow 1
   fp_Treibhaus 1550,-5,0,SVG_Sensor_Treibhaus2_6Stunden,
   group      InfoPlot
   label      "Temp. $data{currval1} °C (min $data{min1} °C | max $data{max1} °C) / Taup. $data{currval4} °C / Feuchte $data{currval2} %"
   plotsize   1200,300
   room       Netatmo
ist alles db-log
mir fallt grad auf, dass beides netatmo is, von hm und zwave kommen keine warnings ...
und noch lustiger: in anderen plots, wo auch netatmo vorkommt, gibts auch keine warnings (leicht verwirrt bin)
→do↑p!dnʇs↓shit←
Mit Daten meinte ich die Zeitstempel/Zahl-Liste, die SVG darstellen soll, und die man z.Bsp. im PlotEditor per "Show preprocessed input" kriegt.
Wenn die Quelle DbLog ist, dann bin ich fein raus, da $data{currval1} etc vom Lieferanten (in diesem Fall DbLog) gesetzt wird.
-> DbLog Maintainer fragen.
the ratman
das wäre vom 1. plot (reichts?)get logdb CURRENT INT 2016-11-04_16:30:00 2016-11-05_16:30:01 Sensor_Schlafzimmer:temperature Sensor_Schlafzimmer:pressure Sensor_Schlafzimmer:humidity
2016-11-04_16:31:13 13
2016-11-04_16:36:14 13
2016-11-04_16:41:15 13
2016-11-04_16:51:18 13
2016-11-04_16:56:19 13
2016-11-04_17:01:21 13
2016-11-04_17:06:22 13
2016-11-04_17:11:23 13
2016-11-04_17:21:27 13.1
2016-11-04_17:26:28 13.1
2016-11-04_17:31:29 13.2
2016-11-04_17:36:30 13.3
2016-11-04_17:41:32 13.3
2016-11-04_17:51:35 13.3
2016-11-04_17:56:36 13.3
2016-11-04_18:01:38 13.3
2016-11-04_18:06:38 13.3
2016-11-04_18:11:39 13.3
2016-11-04_18:21:41 13.3
2016-11-04_18:26:44 13.4
2016-11-04_18:31:46 13.4
2016-11-04_18:36:46 13.4
2016-11-04_18:41:47 13.4
2016-11-04_18:51:50 13.4
2016-11-04_19:06:52 13.4
2016-11-04_19:11:54 13.4
2016-11-04_19:21:56 13.4
2016-11-04_19:32:00 13.4
2016-11-04_19:36:59 13.4
2016-11-04_19:42:00 13.4
2016-11-04_19:47:02 13.4
2016-11-04_19:52:04 13.4
2016-11-04_20:02:07 13.4
2016-11-04_20:07:09 13.5
2016-11-04_20:12:11 13.5
2016-11-04_20:17:11 13.5
2016-11-04_20:22:13 13.5
2016-11-04_20:32:16 13.5
2016-11-04_20:37:18 13.6
2016-11-04_20:42:19 13.5
2016-11-04_20:47:21 13.5
2016-11-04_20:52:22 13.5
2016-11-04_21:02:25 13.5
2016-11-04_21:07:27 13.6
2016-11-04_21:12:29 13.5
2016-11-04_21:17:31 13.6
2016-11-04_21:22:33 13.5
2016-11-04_21:32:35 13.6
2016-11-04_21:37:37 13.6
2016-11-04_21:42:39 13.6
2016-11-04_21:47:41 13.6
2016-11-04_21:52:43 13.6
2016-11-04_22:02:47 13.6
2016-11-04_22:07:48 13.6
2016-11-04_22:12:50 13.5
2016-11-04_22:17:51 13.5
2016-11-04_22:22:53 13.4
2016-11-04_22:32:56 13.4
2016-11-04_22:37:58 13.4
2016-11-04_22:43:00 13.4
2016-11-04_22:48:02 13.4
2016-11-04_22:53:04 13.5
2016-11-04_23:03:07 13.5
2016-11-04_23:08:04 13.5
2016-11-04_23:18:05 13.6
2016-11-04_23:23:08 13.6
2016-11-04_23:28:10 13.7
2016-11-04_23:33:11 13.7
2016-11-04_23:38:12 13.7
2016-11-04_23:48:17 13.7
2016-11-04_23:53:17 13.7
2016-11-04_23:58:19 13.7
2016-11-05_00:03:20 13.7
2016-11-05_00:08:22 13.6
2016-11-05_00:18:25 13.6
2016-11-05_00:23:26 13.7
2016-11-05_00:28:28 13.7
2016-11-05_00:33:30 13.7
2016-11-05_00:38:32 13.7
2016-11-05_00:48:34 13.6
2016-11-05_00:53:36 13.6
2016-11-05_00:58:38 13.6
2016-11-05_01:03:38 13.6
2016-11-05_01:08:40 13.6
2016-11-05_01:18:43 13.6
2016-11-05_01:23:46 13.6
2016-11-05_01:28:48 13.6
2016-11-05_01:33:48 13.7
2016-11-05_01:38:50 13.6
2016-11-05_01:48:53 13.6
2016-11-05_01:53:54 13.6
2016-11-05_01:58:56 13.6
2016-11-05_02:03:57 13.6
2016-11-05_02:08:59 13.6
2016-11-05_02:19:02 13.6
2016-11-05_02:23:16 13.6
2016-11-05_02:33:20 13.6
2016-11-05_02:38:21 13.7
2016-11-05_02:43:23 13.7
2016-11-05_02:48:24 13.7
2016-11-05_02:53:26 13.7
2016-11-05_03:03:28 13.7
2016-11-05_03:08:30 13.7
2016-11-05_03:13:32 13.7
2016-11-05_03:18:33 13.7
2016-11-05_03:23:35 13.7
2016-11-05_03:33:39 13.8
2016-11-05_03:38:41 13.8
2016-11-05_03:43:43 13.9
2016-11-05_03:48:44 13.9
2016-11-05_03:53:46 13.9
2016-11-05_04:03:50 13.9
2016-11-05_04:08:51 13.9
2016-11-05_04:13:53 13.9
2016-11-05_04:18:54 13.9
2016-11-05_04:23:55 13.9
2016-11-05_04:28:57 13.9
2016-11-05_04:33:59 13.9
2016-11-05_04:39:01 13.9
2016-11-05_04:44:02 13.9
2016-11-05_04:49:04 13.9
2016-11-05_04:54:06 13.9
2016-11-05_05:04:09 13.9
2016-11-05_05:05:35 13.9
2016-11-05_05:10:37 13.9
2016-11-05_05:15:39 13.9
2016-11-05_05:20:40 13.9
2016-11-05_05:25:42 13.9
2016-11-05_05:35:45 13.9
2016-11-05_05:40:46 13.9
2016-11-05_05:45:48 13.9
2016-11-05_05:50:49 13.9
2016-11-05_05:55:52 13.9
2016-11-05_06:05:55 13.9
2016-11-05_06:10:58 13.9
2016-11-05_06:15:59 13.9
2016-11-05_06:21:00 13.9
2016-11-05_06:26:02 13.9
2016-11-05_06:36:08 13.9
2016-11-05_06:41:09 13.9
2016-11-05_06:46:10 13.9
2016-11-05_06:51:12 13.9
2016-11-05_06:56:14 13.9
2016-11-05_07:06:17 13.9
2016-11-05_07:11:17 13.9
2016-11-05_07:16:19 14
2016-11-05_07:21:22 14
2016-11-05_07:26:23 14
2016-11-05_07:36:26 14
2016-11-05_07:41:28 14.1
2016-11-05_07:46:30 14.1
2016-11-05_07:51:30 14.1
2016-11-05_07:56:33 14.1
2016-11-05_08:06:36 14.2
2016-11-05_08:11:37 14.2
2016-11-05_08:16:39 14.2
2016-11-05_08:21:41 14.2
2016-11-05_08:26:42 14.2
2016-11-05_08:36:45 14.2
2016-11-05_08:51:51 14.2
2016-11-05_08:56:53 14.2
2016-11-05_09:06:57 14.3
2016-11-05_09:17:01 14.3
2016-11-05_09:22:02 14.3
2016-11-05_09:27:04 14.3
2016-11-05_09:32:07 14.3
2016-11-05_09:37:09 14.3
2016-11-05_09:47:11 14.3
2016-11-05_09:52:13 14.3
2016-11-05_09:57:15 14.4
2016-11-05_10:02:16 14.4
2016-11-05_10:07:18 14.4
2016-11-05_10:17:22 14.3
2016-11-05_10:22:23 14.3
2016-11-05_10:27:25 14.2
2016-11-05_10:32:26 14.2
2016-11-05_10:37:28 14.2
2016-11-05_10:47:32 14.1
2016-11-05_10:52:32 14.1
2016-11-05_10:57:34 14.1
2016-11-05_11:02:35 14.1
2016-11-05_11:07:37 14.4
2016-11-05_11:17:40 15.2
2016-11-05_11:22:42 15.6
2016-11-05_11:27:43 15.5
2016-11-05_11:32:46 15.4
2016-11-05_11:37:48 15.2
2016-11-05_11:47:50 14.9
2016-11-05_11:52:51 14.8
2016-11-05_11:57:53 14.7
2016-11-05_12:02:54 14.7
2016-11-05_12:07:56 14.6
2016-11-05_12:18:00 14.5
2016-11-05_12:23:00 14.4
2016-11-05_12:28:01 14.3
2016-11-05_12:33:04 14.3
2016-11-05_12:38:05 14.2
2016-11-05_12:48:09 14.1
2016-11-05_12:53:11 14.1
2016-11-05_12:58:12 14.1
2016-11-05_13:03:14 14.1
2016-11-05_13:08:16 14
2016-11-05_13:18:18 14
2016-11-05_13:23:20 14
2016-11-05_13:28:22 13.9
2016-11-05_13:33:23 13.9
2016-11-05_13:38:25 13.9
2016-11-05_13:48:28 13.9
2016-11-05_13:53:29 13.8
2016-11-05_13:58:30 13.8
2016-11-05_14:03:32 13.8
2016-11-05_14:08:33 13.8
2016-11-05_14:18:37 13.8
2016-11-05_14:23:38 13.8
2016-11-05_14:28:40 13.7
2016-11-05_14:33:41 13.7
2016-11-05_14:38:43 13.7
2016-11-05_14:48:47 13.7
2016-11-05_14:53:48 13.7
2016-11-05_14:58:49 13.7
2016-11-05_15:03:51 13.7
2016-11-05_15:08:53 13.7
2016-11-05_15:18:56 13.7
2016-11-05_15:23:58 13.7
2016-11-05_15:29:00 13.6
2016-11-05_15:34:02 13.6
2016-11-05_15:39:03 13.6
2016-11-05_15:49:05 13.6
2016-11-05_16:04:10 13.6
2016-11-05_16:09:12 13.5
#Sensor_Schlafzimmer:temperature:::
2016-11-04_16:31:13 1011.9
2016-11-04_16:36:14 1011.8
2016-11-04_16:41:15 1011.6
2016-11-04_16:51:18 1011.8
2016-11-04_16:56:19 1011.6
2016-11-04_17:01:21 1011.7
2016-11-04_17:06:22 1011.8
2016-11-04_17:11:23 1011.6
2016-11-04_17:21:27 1011.7
2016-11-04_17:26:28 1011.8
2016-11-04_17:31:29 1011.7
2016-11-04_17:36:30 1011.7
2016-11-04_17:41:32 1011.7
2016-11-04_17:51:35 1011.5
2016-11-04_17:56:36 1011.6
2016-11-04_18:01:38 1011.5
2016-11-04_18:06:38 1011.6
2016-11-04_18:11:39 1011.5
2016-11-04_18:21:41 1011.4
2016-11-04_18:26:44 1011.4
2016-11-04_18:31:46 1011.4
2016-11-04_18:36:46 1011.2
2016-11-04_18:41:47 1011.2
2016-11-04_18:51:50 1011.2
2016-11-04_19:06:52 1011.3
2016-11-04_19:11:54 1011.2
2016-11-04_19:21:56 1011
2016-11-04_19:32:00 1010.7
2016-11-04_19:36:59 1010.6
2016-11-04_19:42:00 1010.6
2016-11-04_19:47:02 1010.4
2016-11-04_19:52:04 1010.2
2016-11-04_20:02:07 1010.2
2016-11-04_20:07:09 1010.2
2016-11-04_20:12:11 1010.1
2016-11-04_20:17:11 1010
2016-11-04_20:22:13 1010
2016-11-04_20:32:16 1009.9
2016-11-04_20:37:18 1010
2016-11-04_20:42:19 1010
2016-11-04_20:47:21 1009.8
2016-11-04_20:52:22 1009.8
2016-11-04_21:02:25 1009.5
2016-11-04_21:07:27 1009.5
2016-11-04_21:12:29 1009.5
2016-11-04_21:17:31 1009.5
2016-11-04_21:22:33 1009.6
2016-11-04_21:32:35 1009.4
2016-11-04_21:37:37 1009.4
2016-11-04_21:42:39 1009.3
2016-11-04_21:47:41 1009.2
2016-11-04_21:52:43 1009.3
2016-11-04_22:02:47 1009.1
2016-11-04_22:07:48 1009.1
2016-11-04_22:12:50 1009.1
2016-11-04_22:17:51 1009.1
2016-11-04_22:22:53 1009
2016-11-04_22:32:56 1009.2
2016-11-04_22:37:58 1009.2
2016-11-04_22:43:00 1009.1
2016-11-04_22:48:02 1009.2
2016-11-04_22:53:04 1009.1
2016-11-04_23:03:07 1009.1
2016-11-04_23:08:04 1008.9
2016-11-04_23:18:05 1008.9
2016-11-04_23:23:08 1009
2016-11-04_23:28:10 1008.9
2016-11-04_23:33:11 1009.1
2016-11-04_23:38:12 1009.1
2016-11-04_23:48:17 1009.1
2016-11-04_23:53:17 1009.1
2016-11-04_23:58:19 1009
2016-11-05_00:03:20 1008.9
2016-11-05_00:08:22 1008.7
2016-11-05_00:18:25 1008.7
2016-11-05_00:23:26 1008.6
2016-11-05_00:28:28 1008.5
2016-11-05_00:33:30 1008.5
2016-11-05_00:38:32 1008.5
2016-11-05_00:48:34 1008.3
2016-11-05_00:53:36 1008.3
2016-11-05_00:58:38 1008.1
2016-11-05_01:03:38 1007.9
2016-11-05_01:08:40 1007.9
2016-11-05_01:18:43 1007.8
2016-11-05_01:23:46 1007.7
2016-11-05_01:28:48 1007.6
2016-11-05_01:33:48 1007.6
2016-11-05_01:38:50 1007.6
2016-11-05_01:48:53 1007.5
2016-11-05_01:53:54 1007.4
2016-11-05_01:58:56 1007.3
2016-11-05_02:03:57 1007.3
2016-11-05_02:08:59 1007.4
2016-11-05_02:19:02 1007.1
2016-11-05_02:23:16 1007.3
2016-11-05_02:33:20 1006.9
2016-11-05_02:38:21 1007.1
2016-11-05_02:43:23 1006.9
2016-11-05_02:48:24 1006.5
2016-11-05_02:53:26 1006.8
2016-11-05_03:03:28 1006.6
2016-11-05_03:08:30 1006.4
2016-11-05_03:13:32 1006.5
2016-11-05_03:18:33 1006.3
2016-11-05_03:23:35 1006.5
2016-11-05_03:33:39 1006.3
2016-11-05_03:38:41 1006.3
2016-11-05_03:43:43 1006.2
2016-11-05_03:48:44 1006.2
2016-11-05_03:53:46 1006.2
2016-11-05_04:03:50 1005.9
2016-11-05_04:08:51 1005.7
2016-11-05_04:13:53 1005.8
2016-11-05_04:18:54 1005.7
2016-11-05_04:23:55 1005.5
2016-11-05_04:28:57 1005.4
2016-11-05_04:33:59 1005.4
2016-11-05_04:39:01 1005.3
2016-11-05_04:44:02 1005.2
2016-11-05_04:49:04 1005.1
2016-11-05_04:54:06 1005.2
2016-11-05_05:04:09 1004.9
2016-11-05_05:05:35 1004.9
2016-11-05_05:10:37 1004.9
2016-11-05_05:15:39 1004.7
2016-11-05_05:20:40 1004.6
2016-11-05_05:25:42 1004.7
2016-11-05_05:35:45 1004.5
2016-11-05_05:40:46 1004.5
2016-11-05_05:45:48 1004.4
2016-11-05_05:50:49 1004.4
2016-11-05_05:55:52 1004.3
2016-11-05_06:05:55 1004.1
2016-11-05_06:10:58 1004
2016-11-05_06:15:59 1003.8
2016-11-05_06:21:00 1003.8
2016-11-05_06:26:02 1003.7
2016-11-05_06:36:08 1003.4
2016-11-05_06:41:09 1003.2
2016-11-05_06:46:10 1003.2
2016-11-05_06:51:12 1003.1
2016-11-05_06:56:14 1003.1
2016-11-05_07:06:17 1002.8
2016-11-05_07:11:17 1002.8
2016-11-05_07:16:19 1002.8
2016-11-05_07:21:22 1002.8
2016-11-05_07:26:23 1002.6
2016-11-05_07:36:26 1002.4
2016-11-05_07:41:28 1002.4
2016-11-05_07:46:30 1002.5
2016-11-05_07:51:30 1002.3
2016-11-05_07:56:33 1002.3
2016-11-05_08:06:36 1002.1
2016-11-05_08:11:37 1002
2016-11-05_08:16:39 1002
2016-11-05_08:21:41 1001.7
2016-11-05_08:26:42 1001.6
2016-11-05_08:36:45 1001.3
2016-11-05_08:51:51 1001.2
2016-11-05_08:56:53 1001.2
2016-11-05_09:06:57 1000.9
2016-11-05_09:17:01 1000.8
2016-11-05_09:22:02 1000.6
2016-11-05_09:27:04 1000.6
2016-11-05_09:32:07 1000.5
2016-11-05_09:37:09 1000.5
2016-11-05_09:47:11 1000.4
2016-11-05_09:52:13 1000.1
2016-11-05_09:57:15 1000.1
2016-11-05_10:02:16 1000.1
2016-11-05_10:07:18 1000
2016-11-05_10:17:22 999.8
2016-11-05_10:22:23 1000
2016-11-05_10:27:25 1000.1
2016-11-05_10:32:26 1000
2016-11-05_10:37:28 1000.1
2016-11-05_10:47:32 999.9
2016-11-05_10:52:32 1000
2016-11-05_10:57:34 1000.3
2016-11-05_11:02:35 1000.2
2016-11-05_11:07:37 999.8
2016-11-05_11:17:40 999.9
2016-11-05_11:22:42 999.8
2016-11-05_11:27:43 999.9
2016-11-05_11:32:46 999.8
2016-11-05_11:37:48 999.7
2016-11-05_11:47:50 1000.1
2016-11-05_11:52:51 1000.3
2016-11-05_11:57:53 1000.6
2016-11-05_12:02:54 1000.4
2016-11-05_12:07:56 1000.6
2016-11-05_12:18:00 1000.3
2016-11-05_12:23:00 1000.2
2016-11-05_12:28:01 1000.3
2016-11-05_12:33:04 1000.1
2016-11-05_12:38:05 1000
2016-11-05_12:48:09 1000.2
2016-11-05_12:53:11 1000.4
2016-11-05_12:58:12 1000.3
2016-11-05_13:03:14 1000.3
2016-11-05_13:08:16 1000.6
2016-11-05_13:18:18 1000.7
2016-11-05_13:23:20 1000.6
2016-11-05_13:28:22 1000.6
2016-11-05_13:33:23 1000.8
2016-11-05_13:38:25 1000.8
2016-11-05_13:48:28 1000.5
2016-11-05_13:53:29 1000.4
2016-11-05_13:58:30 1000.3
2016-11-05_14:03:32 1000.1
2016-11-05_14:08:33 1000.2
2016-11-05_14:18:37 1000.2
2016-11-05_14:23:38 1000
2016-11-05_14:28:40 1000
2016-11-05_14:33:41 1000.1
2016-11-05_14:38:43 1000.3
2016-11-05_14:48:47 1000.5
2016-11-05_14:53:48 1000.3
2016-11-05_14:58:49 1000.4
2016-11-05_15:03:51 1000.5
2016-11-05_15:08:53 1000.5
2016-11-05_15:18:56 1000.5
2016-11-05_15:23:58 1000.5
2016-11-05_15:29:00 1000.9
2016-11-05_15:34:02 1000.8
2016-11-05_15:39:03 1000.8
2016-11-05_15:49:05 1000.9
2016-11-05_16:04:10 1001.1
2016-11-05_16:09:12 1001.1
#Sensor_Schlafzimmer:pressure:::
2016-11-04_16:31:13 60
2016-11-04_16:36:14 60
2016-11-04_16:41:15 60
2016-11-04_16:51:18 61
2016-11-04_16:56:19 61
2016-11-04_17:01:21 61
2016-11-04_17:06:22 61
2016-11-04_17:11:23 61
2016-11-04_17:21:27 61
2016-11-04_17:26:28 61
2016-11-04_17:31:29 61
2016-11-04_17:36:30 60
2016-11-04_17:41:32 60
2016-11-04_17:51:35 60
2016-11-04_17:56:36 60
2016-11-04_18:01:38 60
2016-11-04_18:06:38 60
2016-11-04_18:11:39 60
2016-11-04_18:21:41 60
2016-11-04_18:26:44 60
2016-11-04_18:31:46 60
2016-11-04_18:36:46 60
2016-11-04_18:41:47 60
2016-11-04_18:51:50 60
2016-11-04_19:06:52 60
2016-11-04_19:11:54 60
2016-11-04_19:21:56 60
2016-11-04_19:32:00 60
2016-11-04_19:36:59 60
2016-11-04_19:42:00 60
2016-11-04_19:47:02 60
2016-11-04_19:52:04 60
2016-11-04_20:02:07 60
2016-11-04_20:07:09 60
2016-11-04_20:12:11 60
2016-11-04_20:17:11 60
2016-11-04_20:22:13 60
2016-11-04_20:32:16 60
2016-11-04_20:37:18 60
2016-11-04_20:42:19 60
2016-11-04_20:47:21 60
2016-11-04_20:52:22 60
2016-11-04_21:02:25 60
2016-11-04_21:07:27 60
2016-11-04_21:12:29 60
2016-11-04_21:17:31 60
2016-11-04_21:22:33 60
2016-11-04_21:32:35 60
2016-11-04_21:37:37 60
2016-11-04_21:42:39 60
2016-11-04_21:47:41 60
2016-11-04_21:52:43 60
2016-11-04_22:02:47 60
2016-11-04_22:07:48 61
2016-11-04_22:12:50 61
2016-11-04_22:17:51 61
2016-11-04_22:22:53 61
2016-11-04_22:32:56 61
2016-11-04_22:37:58 61
2016-11-04_22:43:00 61
2016-11-04_22:48:02 61
2016-11-04_22:53:04 62
2016-11-04_23:03:07 62
2016-11-04_23:08:04 63
2016-11-04_23:18:05 63
2016-11-04_23:23:08 63
2016-11-04_23:28:10 63
2016-11-04_23:33:11 63
2016-11-04_23:38:12 64
2016-11-04_23:48:17 64
2016-11-04_23:53:17 64
2016-11-04_23:58:19 64
2016-11-05_00:03:20 64
2016-11-05_00:08:22 65
2016-11-05_00:18:25 65
2016-11-05_00:23:26 65
2016-11-05_00:28:28 65
2016-11-05_00:33:30 65
2016-11-05_00:38:32 65
2016-11-05_00:48:34 66
2016-11-05_00:53:36 66
2016-11-05_00:58:38 66
2016-11-05_01:03:38 66
2016-11-05_01:08:40 66
2016-11-05_01:18:43 66
2016-11-05_01:23:46 66
2016-11-05_01:28:48 67
2016-11-05_01:33:48 67
2016-11-05_01:38:50 67
2016-11-05_01:48:53 67
2016-11-05_01:53:54 67
2016-11-05_01:58:56 67
2016-11-05_02:03:57 67
2016-11-05_02:08:59 68
2016-11-05_02:19:02 68
2016-11-05_02:23:16 68
2016-11-05_02:33:20 68
2016-11-05_02:38:21 68
2016-11-05_02:43:23 68
2016-11-05_02:48:24 69
2016-11-05_02:53:26 69
2016-11-05_03:03:28 69
2016-11-05_03:08:30 69
2016-11-05_03:13:32 69
2016-11-05_03:18:33 69
2016-11-05_03:23:35 69
2016-11-05_03:33:39 69
2016-11-05_03:38:41 69
2016-11-05_03:43:43 69
2016-11-05_03:48:44 69
2016-11-05_03:53:46 69
2016-11-05_04:03:50 69
2016-11-05_04:08:51 69
2016-11-05_04:13:53 69
2016-11-05_04:18:54 69
2016-11-05_04:23:55 69
2016-11-05_04:28:57 69
2016-11-05_04:33:59 69
2016-11-05_04:39:01 69
2016-11-05_04:44:02 70
2016-11-05_04:49:04 70
2016-11-05_04:54:06 70
2016-11-05_05:04:09 70
2016-11-05_05:05:35 70
2016-11-05_05:10:37 70
2016-11-05_05:15:39 70
2016-11-05_05:20:40 70
2016-11-05_05:25:42 70
2016-11-05_05:35:45 70
2016-11-05_05:40:46 70
2016-11-05_05:45:48 70
2016-11-05_05:50:49 70
2016-11-05_05:55:52 71
2016-11-05_06:05:55 71
2016-11-05_06:10:58 71
2016-11-05_06:15:59 71
2016-11-05_06:21:00 71
2016-11-05_06:26:02 71
2016-11-05_06:36:08 71
2016-11-05_06:41:09 71
2016-11-05_06:46:10 71
2016-11-05_06:51:12 71
2016-11-05_06:56:14 71
2016-11-05_07:06:17 72
2016-11-05_07:11:17 72
2016-11-05_07:16:19 72
2016-11-05_07:21:22 72
2016-11-05_07:26:23 72
2016-11-05_07:36:26 73
2016-11-05_07:41:28 73
2016-11-05_07:46:30 73
2016-11-05_07:51:30 73
2016-11-05_07:56:33 73
2016-11-05_08:06:36 73
2016-11-05_08:11:37 73
2016-11-05_08:16:39 73
2016-11-05_08:21:41 73
2016-11-05_08:26:42 73
2016-11-05_08:36:45 73
2016-11-05_08:51:51 73
2016-11-05_08:56:53 73
2016-11-05_09:06:57 73
2016-11-05_09:17:01 73
2016-11-05_09:22:02 73
2016-11-05_09:27:04 73
2016-11-05_09:32:07 73
2016-11-05_09:37:09 73
2016-11-05_09:47:11 73
2016-11-05_09:52:13 74
2016-11-05_09:57:15 74
2016-11-05_10:02:16 73
2016-11-05_10:07:18 73
2016-11-05_10:17:22 74
2016-11-05_10:22:23 74
2016-11-05_10:27:25 74
2016-11-05_10:32:26 74
2016-11-05_10:37:28 74
2016-11-05_10:47:32 75
2016-11-05_10:52:32 75
2016-11-05_10:57:34 75
2016-11-05_11:02:35 75
2016-11-05_11:07:37 75
2016-11-05_11:17:40 75
2016-11-05_11:22:42 73
2016-11-05_11:27:43 73
2016-11-05_11:32:46 73
2016-11-05_11:37:48 73
2016-11-05_11:47:50 74
2016-11-05_11:52:51 74
2016-11-05_11:57:53 73
2016-11-05_12:02:54 73
2016-11-05_12:07:56 73
2016-11-05_12:18:00 73
2016-11-05_12:23:00 73
2016-11-05_12:28:01 73
2016-11-05_12:33:04 73
2016-11-05_12:38:05 73
2016-11-05_12:48:09 74
2016-11-05_12:53:11 74
2016-11-05_12:58:12 74
2016-11-05_13:03:14 74
2016-11-05_13:08:16 74
2016-11-05_13:18:18 74
2016-11-05_13:23:20 74
2016-11-05_13:28:22 74
2016-11-05_13:33:23 74
2016-11-05_13:38:25 74
2016-11-05_13:48:28 73
2016-11-05_13:53:29 73
2016-11-05_13:58:30 73
2016-11-05_14:03:32 73
2016-11-05_14:08:33 73
2016-11-05_14:18:37 73
2016-11-05_14:23:38 73
2016-11-05_14:28:40 73
2016-11-05_14:33:41 73
2016-11-05_14:38:43 74
2016-11-05_14:48:47 74
2016-11-05_14:53:48 74
2016-11-05_14:58:49 74
2016-11-05_15:03:51 74
2016-11-05_15:08:53 74
2016-11-05_15:18:56 73
2016-11-05_15:23:58 73
2016-11-05_15:29:00 73
2016-11-05_15:34:02 73
2016-11-05_15:39:03 73
2016-11-05_15:49:05 73
2016-11-05_16:04:10 73
2016-11-05_16:09:12 73
#Sensor_Schlafzimmer:humidity:::
btw - ich hab eben fhem geupdated. jetzt kommt kein fehler mehr. scheint dann wohl eher was gesponnen zu haben. an den heutigen updates kanns wohl weniger liegen, denk ich mal.
→do↑p!dnʇs↓shit←
