As my EM1010PC tends to stuck and return exactly the same value for
hours, I'd like to be able to reset it automatically. The reset until
now was not of much use: you had to confirm the time/date manually on
the EM1010PC directly after the reset command was sent by fhem (or by
the Windows software).
After sending each possible one-byte command to the EM1010PC I found
one command which will skip the manual interaction, going to the sync
mode after reset, I added this command to the reset sequence, and
made the change available in CVS.
My EM1010PC has firmware version 1.5 (upgraded from 1.2), I would be
grateful if some of you would confirm that it is working.
Greetings,
Rudi
You received this message because you are subscribed to the Google Groups "FHZ1000 users on Linux" group.
To post to this group, send email to FHZ1000-users-on-unix@googlegroups.com
To unsubscribe from this group, send email to FHZ1000-users-on-unix-unsubscribe@googlegroups.com
For more options, visit this group at http://groups.google.com/group/FHZ1000-users-on-unix?hl=en
