WOL stoped working since last update (
Begonnen von Lectere, 17 Februar 2014, 14:43:00
Lectere
#15
Still don't work. In the log it says that i need to run etherwake as root.
I've tried this
http://forum.fhem.de/index.php?topic=17112.0
Copy to /usr/local/bin, set rights. Change the WOL command to /usr/local/bin/etherwake, rereadcfg.
Still the same; etherwake: this program must be run as root
SMSPassword redundant two-factor authentication for Netscaler, Vmware View, Cisco, Juniper, etc via SMS
http://www.smspassword.com
siggi85
I think this does not mean, that you need the root permission to excute the command. The command need the root permission to work properly. Do you tried this?
Zitat von: siggi85 am 18 Februar 2014, 08:11:18
If it is a permission problem you could try
chmod u+s /usr/sbin/etherwake
After that etherwake is always running as root regardless with user start the command etherwake.
